View Full Version : 5.0 Tech
- dyno results
- 4 lug drag wheels..
- Harmonic Balancer Problems
- Quite S-trim?
- 90 gt wont start
- Low Oil Pressure?
- black or chrome bullits on 86 gt
- trac-lock rebuilt= vibration?
- burned my clutch up :(
- o-ring w/MLS gaskets?
- 351W swap into 96-98
- Transmission Change vs. Rebuilt
- Twisted wedge heads.
- supercharger questions
- 351 or 302. part numbers are making no scence??
- wierd problem...need some input
- probably a stupid question
- Smell under some hard acceleration...clutch? Surely not...
- gt40 vs gt40p
- New site...
- 351w swap oil pan dipstick
- Quick question for you 5.0 guys...Centerforce pressure plates
- Cheap Performance?
- 90 5.0 bouncing idle and stalling.Please help!
- What do you guys really think about K&N air filters
- Do my ears deceive me?
- Stock ratio of ring and pinion gears?
- Progress Thread: 3G install / parts / pictures
- Any help with my Stroker problem?
- What is the proper way to set timing on a 90 lx.5.0
- 351 Modified W/tranny Q's
- someone tell me how the heck to use this indexed timing chain kit
- TrickFlow Track Heat H/C/I Engine Kit
- idle and code help please
- What the heck IS this?
- brand new 306
- Intake Spacer
- bright light issue
- need help!!!!
- Everything you ever wanted to know about oil....great resource!
- spark plugs?
- where to find a cross-member for a 3550 tremec in a 95
- What all is needed for a H/C/I Install?
- switching from efi to carb
- Keep blowing coolant hose's...... *pic*
- would my car benifit from this stuff
- exhaust question
- Water port on FRPP Intake Gasket
- good asking price for a good running 140-150k mile 5.0??
- ANYONE USE THE CYBERDYNE GAUGES?
- Is this a good one?
- Anyway to make the 2.3 dash work??
- What are the MAF wires voltages supposed to be?
- Thinking of a 93 are pistons really not as good?
- ? re: wobbling balancers???
- Transmission, U Joint, or just the way it is?
- Was playing with my shaft last night... is this normal?
- Help a fella spend $6,000!
- 255/50 MT ET Streets on pony's
- Retard/Advance TFS stage 1 cam ??'s
- Machine shop costs/ extreme broken bolt situation ->
- lower control arm bolts WTF?!?!
- OH NO!! trick flow hci install??!!
- ford valve cover height
- Aluminum vs steel driveshaft.
- wide tires/suspension ?
- Acetone (A mustang's best friend)
- Help with buzzing relay !!! Electrical gurus come in!!!
- where to find a 5 star american racing wheel?
- FPR question........
- will this cam work with my stock S/D setup
- Wheels, tires, and backspacing...
- Hello to all I'm new here
- I Need Help with head casting #'s
- supercharger boost problem
- car bogs after a hard shift
- HARDWARE QUESTION
- Fuel rail install question?
- Steering ratio
- where to buy step washers for 351 heads on a 331?
- Fox/Vortech problem
- quick help with 5 lug conversion...please
- Delete, Yes or No
- running in the mid 1.5's on stock suspension
- Front tire width?
- autometer tach and dash tach,which one is right?
- fox body long tubes in an sn95?
- can u roller rocker on stock clyinder heads..
- ahh traction lok help!
- 2100cfm electric fans on ebay
- WATER WETTER/ ROYAL PURPLE PURPLE ICE
- Tire.com says 235-45-17 on a 17x9 inch rim..
- Schematic: Short Belts.
- 83 T tops how to fix door windows
- Another Electric fan question. (I searched)
- installing roller rockers
- What cam/rockers to go w/AFR 165's? Also what timing chain?
- Does the speedo bolt go all the way through the tailshaft?
- Mass air conversion question
- trickflow main girdle with stock oil pan ???
- cooling problems
- What is Valve float
- Steering Wheel Shaft Diameter?
- Show me a pik of your Taurus elec. fan...
- Greasing bushings?
- Please Help!
- transmision no shift
- Solenoid post...........
- Doors And HAtch not closing
- Exhaust opinions and help!!!!!!
- need advice
- what pistons to use
- 3.8 TO A 5.0
- help changing ignition lock
- 3g alt parts help
- new 5.0 how many lbs on super charger
- How much Boost
- Signal Flasher Location
- Help with door panels! Pix!
- how will the B-cam act over stock?
- still surging idle, went through complete list please help
- Draglites on a DD
- Problems after AOD install!
- AFR Spring Pressure's???
- What top end?
- How does a turnbuckle tensioner work??
- timin chain had lots of deflection
- Engine ticking.....
- Building a 302
- Help! No Camshaft Endplay!
- Just finished 2.3->5.0 swap. EGR question???
- installing Lower Spring Problem!!!!
- upgrade old 302
- New Exhaust....Now Overheating...WHAT?!
- Trick Flow Upper Intake T/B Bolts (4)
- oil leak. possibly waterpump gasket
- Tips for removing rear end side upper control arm bushing/shell?
- Rear brake lines - removal questions
- Will X Pipe Pass Emissions?
- 11.5x26x15 on 8.5" rim?
- push button start
- Removing window trim?
- is 570cfm good enough.
- Selling Incon Turbo Kit
- Factory Touch Up Paint
- can a car run if the dist is 180 degrees off?
- Another Weld Wheel question
- Intermitant Electrical Problem
- TO bearing question
- tuning on a stock car
- Help with ET's!!
- What headers to go with prochamber?
- car running rich bump up timing??
- will a 10.5 inch slick fit on 10 holes and on an 89
- Need new distributor gear for 351w roller- what part number??
- Aod Converter
- Afr 165 pushrod issue. Need suggestions!!!
- sealing timing cover to oil pan.
- vibration coming from shifter area help
- Need help finding a bad ground...I think.
- B&M ripper shifter problems - have ?'s.....
- Convertable top care
- Hesitation/sputtering at WOT from 3-4k rpms
- Dry Sump Street Fox
- Painting Turbine Rims Gloss Black
- using helicoils on rocker arm bolt hole. will it pull out
- Should I advance ?
- what MAF is this?
- quick question
- How do I clean my MAF
- position of distributer
- Which one would you buy?
- 3550 Pops out of reverse?
- Lower Torque Box reinforcement qestion - to anyone who has them installed
- oil on spark plug / ticking under valve cover
- Master Cylinder Question!!
- Studs & Head Gaskets
- Electrical Help...car won't start.
- Wiring Guys: Enter Please
- which fuel pump
- where to buy tremec 3550 parts,
- Disributor position problem
- Batt keeps dying after it sits. would this work?
- Help With Headlight Installation
- Second gear pops out but only when down shifting?
- No start after mass air conversion.....
- HELP: Trying to remove AOD (PICS)
- Can I make AFR 185's fit with a stock cam?
- INJECTOR SIZE?
- Best way to break in a clutch?
- oil spill in the heater box...what to do
- Distributor/Injector/Ignition Problem
- HELP! '96 stock alarm system
- aerostar aluminum driveshaft
- I need help asap!!!
- PowerTrax users HELP!!
- anyone running indexed timing sprockets?
- How much power do yall think im making
- Tremec T-5 in 5.0?
- Horrible Exhaust Smell
- Center Console Heating up!
- Turbo guys
- supercharger on my new engine?
- Vert questions?
- f303 cam and what else?
- Anyone with S/D running a not different cam
- AOD TO T5 SWAP!! NEED SOME HELP!!!
- Stock oil pressure gage and fuel pressure issue
- Need help asap!!
- What do you think about Ford Motorsports Front Lower Arms?
- Holley systemax info
- High mileage blower install
- experiencing valve float?
- HELP FUEL PUMP NOT WORKING!!
- PA Performance....
- I need help!
- Going to Dyno the car tomorrow, any guesses on what she's pushin?
- issue with car starting
- question about swapping cars
- 67 Galaxie w/ 91 5.0 EFI Swap not Running Right
- pedal assembly
- H/C ?
- ?? installing electric fan...I think I am missing the thermostat control box? help
- Rebuild kit
- Electric Water Pump.
- Performance/Tune shop recommendations in Salt Lake City??
- H/C/I qusetions
- brake caliper bolt, washers!
- ordering T56 from D&D
- Cranks but No start Question
- proform electric fan??
- Help...Post Fuel Pump Replacement Issues
- Coilover Install, no directions
- Electric fan ????
- Trickflow Upper intake manifold whisteling
- Deep Dish Bullits on fox
- Lots of Pics. calling all 5.0 experts. Engine rebuild. Need HELP
- gt-40 heads with 1.7 crane gold rr???
- Rear Upper control arms?
- Swap headers not working
- Surging idle checklist?
- Cam Install???????
- Rear lower control arms What goes with mac?
- JUST INSTALLED THE WET KIT
- flasher relay?
- oil pressure woes
- CC plate slotting.
- Head gasket help!
- T-5
