View Full Version : 5.0 Tech
- does anyone have any data on stock springs?
- Help... simple wiring question hopefully.
- Hp guess time
- 1 chamber flows sound like 4.6 ? ( i know this has been posted 17,000 times - sorry)
- ADVICE PLEASE/ Girdle/Oil problem?????
- Which Oil Pan for my 347?? help
- rebuilt motor problems
- SQUEEZING MY FUEL SYSTEM, HELP!!
- Lakewood Scattershield Install?
- Convertible Top Differences 83-90 vs 91-93?
- XFI Cams
- Anyone have a "cool" car cover?
- ring gap questions
- Stud mount rocker arm question
- this fu--in sucks
- GT40p springs
- Do I need to find TDC when doing heads, but not cam?
- New rear springs, still high/not level!!
- Heater core hoses kinked
- Installing Electric Fan
- my gt
- Ignition timing advance
- SOMETHING BROKE IN REAR END!!!HELP
- Timing Chain Cover Bolt Sizes
- Looking for b303 cam audio or video
- KOER Codes 94 44 (searched)
- need powersteering bracket for 91' 5.0
- need wiring diagrams for fox body
- Setting Pinion Depth using MHD Method
- Need help ASAP....quick coolant question
- Front Brakes/Suspension rebuild
- Overheating Problem
- what should my next mod be
- Air back through the intake? Is it normal?
- Blinkers=no go
- weld rim backspacing help
- couple questions
- Paint Job in a Can???
- Car Overheating Help
- need some help
- 1991995 Front Control Arms on a 1993 Mustang?
- Slow crank/none start after car has warmed up
- T/W HEADS GT 40 INTAKE READY TO GO ON NEED ADVICE
- WHAT TIRES ON 17x8.5 '93 COBRA WHEELS????
- Need some Brake Help
- 93 Cobra Intake on 89 LX
- New Set up
- twisted wedges and timing N/A combo?
- 94+ brake swap experts
- Yet another SMOG/EGR question.
- Wrecked car HELP!!
- Charging issue, help please
- Why does my one of my GTs rev slower than the other one?
- Engine Kit Help
- kmember questions
- Need Help!!!!!!!!!!!!
- switching to a turbo 400
- Got in a lill argument with Da Silvia at Performance World
- What to use for head gasket sealer?
- EEC-IV gurus ?
- BADDD WHEEL HOP NEED HELP!!
- Has anyone ever ran the oil return into the TC cover
- Idoling problem...
- What do you guys think about this cam?
- waterpump leak?
- Distributor gear?Mallory unilite
- need help with bbk equal length install
- Maximum Motorsports clutch cable, finally!
- is there a difference?
- clutch problem
- rear drag springs?
- Assembling a rear.
- paint advice please!!
- HCI issues after completion
- right junkyard parts?
- Please Help..worse case/not happy
- Turn signals & ac/blower fan not working
- Help: KOEO/KOER codes 95 and 42
- front lower control arms(a-arms)
- Help with Black Magic Fan
- couple more T-5 swap ?'s
- aod swap
- Not 5.0 but My Mercedes keeps dieing!
- Clutch help please
- FMS Thermostat housing
- Foam in oil... ?
- control arms
- very strange headlight problem
- Driveshaft Safety Loop? R They a need?
- Auto Meter
- WHAT YOU GUYS THINK BOUT THIS CAM?
- Hood Lining?
- Electric Fan and pulleys q's
- Installed cobra intake...I think I am missing a sensor? help
- Fox body ignition wiring diagrams
- 3 G Alternator Wiring question-Did search-no luck. What's a fuseable link????????????
- AOD build-up
- Dumb simpley question. How do to remove the Pully from the Power steering pump?
- Dual Circuit Fluid Coolers
- Need some tuning help guys!!
- Proper way to adjust proportioning valve?
- Anyone looking for the Waterpump Accessory Studs - In Here
- carbed fuel filter question
- non-roller to roller help
- 5.0 flywheel balance weight
- yet another problem with my wonderful stang this time its the brakes
- 4cyl springs?
- Building a rear...
- vss sensor o-ring
- Milodon Oil Pan Question
- Cylinder Numbers... Easy question...
- Feder Replacement
- New motor slower than stock ... READ
- I want to post pictures of my car for "you all"
- Where can I buy this online? *PICS*
- struts!!!!!!!!!!!!!!!!! need help!!!
- Car dies after an hour!
- need some help
- What's that box behind the radio?
- Look at FR M-6007-XB3 Crate Engine Please help
- squeaking from bellhousing?? (breaking clutch cables)
- Clutch Setup or tranny problem?
- Bought new Mustang - How to get in 11's
- Well guys..........come on in here :-(
- 11" brake conversion
- Distributor cap question
- rotor removal 89 5.0l
- removal and installation of steering column
- WTF??????? water pump problems PLEASE HELP!!!!
- Engine Codes "again"
- OLD HEADS AND INTAKE WORTH ANYTHING?
- Which heat range spark plug for supercharged 306
- someone teach me how to tune my carb.
- Valve Cover Clearance with Roller Rockers
- 94' 95' spindles
- 5.4 to 351 swap
- RHS vs. Dart Pro 1 195 vs. Vic jr's vs. high ports
- Which oil, conventional, synthetic, or blended?
- Which Pistons suit my needs
- Installing H-pipe
- H nd X pipes vs Straight pipes
- Tranny Needs?
- Looking for a shop....
- BOGGED DOWN
- AC knob/control relocation
- new gears...will they affect speedometer?
- I am looking for Ported Lightning Lower Intake Flow Data
- shifter knob coming off....help
- 18 inch deep dish rims? (18x10)
- Procharger p600b...any good?
- 78' engine block
- How difficult to swap in a new shortblock?
- power
- Is Gasoline finally loosing to Diesel?
- all motor horsepower
- Q if you've done SN95 Brake Conversion
- Cobra intake install on speed density
- Rear Shocks Opinion?
- car idles now, but...
- POR 15 vs. Rust Encapsulator
- backfire through the intake??
- New set up, what do you think for power?
- $1500 Later, car is slower HELP!
- ABS sensor really cause a dash cricket??
- Alternator Problem
- CAN ANYONE HELP ME??? FOX BODY REAR DISC BRAKES
- Oxygen sensors, probably a dumb question
- what hardware do i need??
- whats up w/ these heads?
- What front drag struts for a lowered car?
- vortech or powerdyne
- car idles rough,
- Wouldnt start, then just kept cranking without key
- explorer 5.0 using mustang computer?
- 24# injectors on a 331?
- What alternator, how to make it work?
- Need help removing broken copper pipe
- converting from Y303 to twisted wedge
- Passenger side lock won't go down?
- number 5 fuse blows
- Synthetic oil kills trac-loc?
- Tire Rubbing!!
- ECU harness install..hard?
- probably a stupid question, but why not
- M-6003-A50 gasket kit
- Tune Up Questions
- What kind of tranny to get?
- FMS Hydraulic roller listers (are these the ones i need?)
- 351W buildup
- Pro Topline Cylinder heads
- Having gears install this spring, anything else i should get?
- 50Resto bumper covers..Any good??
- how did i mess up this install
- How much does a 5.0 weigh?
- o/r H leak
- Can someone post a picture of a "ripped" torque box?
- Anyone heard of or used CAM headers
- Need offroad H-pipe ASAP. Get BBK or Summit?
- Guide me Stangnet brethren
- Easiest&Cheapest way to remove rev limiter??
- Are upper&lower control arms a must have
- MAF SENSOR, DIFFERENCE HERE?
- Wont Run With Maf Plugged In
- am i going to need my pistons notched
- Any vehicles besides the lightnings that have a GT40 351w?
- Need good timing cover seal...suggestions...?
- better steering?
- A/C compressor bad?
- Anderson N-41 Cam
- finally rid of rearend noise
- 88 LX Running problem!!!
- Questions about tire/rim size and suspension
- Windage tray ?
- 140 alternator upgrade - wiring question
- Cutting stock springs?
- radiator support
- How do I make Carb valve covers wor w/EFI
- Valve Cover Leak
- Water Pump Recommendations?
- why the hell wont my belt stop squealing?
- where do I find these that will fit my 88 gt
- what cam with aod
- Anyone run these?
- Transmission question...
- Headers for AFR 185's
- 1969 short deck 351w stroker?
- Nitrous questions
- Stang backfiring after Cobra intake install...what's the problem?
- slick? 8.8?
- T LOK REBUILD NEED HELP
- Gears swap: n00b question
- Good battery but no start...
- Trivial Electrical question.
- the 'unservicable' balljoint
- axle seal install depth
- Pilot Bearing or Bushing?
- O2 Sensor Help!!!!
- MAF question
- Tech articles
- $2500 to throw around need some suggestions please?
- Oil In intake
- 3G Alt swap (w/ u-d pulleys)
- 5.0 Head Gaskets
- Vibration's??
- battery relocation and alternator??
- C&L 80mm mass air??
- auto tranny guys come in
- Oil fill extender
- TORQUE BOX REINFORCEMENT PLATES
