PDA
View Full Version : 5.0 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 [96] 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252
  1. What Is This Box?
  2. what would cause me to keep blowing voltage regulators?
  3. What is the purpose of this passage in the head?
  4. Forged or not? Need some help.
  5. Dash bulbs don't work? Don't change them quite yet.
  6. Do i need a chip?
  7. Running real shaky
  8. What do you guys think?
  9. Should I rebuild bottom end??
  10. What did I do wrong in adjusting my rockers?
  11. Help me tune my 12.XX stang.
  12. soleniod troubles
  13. HERE COMES A HEADACHE
  14. 4 to 5 lug...the easy way?
  15. Transmission Problem
  16. Who has a Hurst Billet-plus shifter?
  17. my new toy
  18. AEM and 4R70W
  19. Stock Engine??
  20. leather interior
  21. Electric fan vs. underdrive pulleys power/benefits
  22. Dash problems need help FAST
  23. Is the harmonic balancer supposed to be this difficult to remove?
  24. what type of manifold???
  25. AFR 165 heads
  26. Cam installation difficulties
  27. UPR K member setup
  28. 50oz or 28oz??
  29. surging idle check list
  30. GT40 heads question
  31. Oil in EGR spacer???
  32. taurus fans on ebay
  33. CHP motor ordered up.
  34. Axle Question 5 lug
  35. Anyone use this to remove pressed wrist pins?
  36. Questions about battery/alternator voltage
  37. ball joints and tie rods
  38. The Best Way to cut the inner lip of the back well??
  39. which brake lines??
  40. Anderson N-91 cam with a Blower
  41. need help
  42. Another Windage Tray Question
  43. Got the Block Torn Down, But I Think it has had it.
  44. TFS head question...
  45. Powerful Stereo and Alternator/Battery question...
  46. t5 assembly
  47. ok i reakky need help with axles!!!
  48. Torque box damage assesment-pics inside
  49. O/R H-Pipe Install
  50. Control Arm Question.....
  51. Compression test results
  52. do i need longer pushrods, why
  53. somebody please help
  54. Under the hood now - Help: A/C System Removal
  55. new tb cant get to idle right
  56. Vibration SOLVED
  57. What size engine stand?
  58. sensor questions
  59. Speedo Driven Gear Questions
  60. Upper torque box reinforcements
  61. i'm having the worst luck lately
  62. Need help with idle problem please
  63. I need the truth about Explorer intakes......
  64. forced induction effects due to stroke
  65. PART THROTTLE HELP...INTAKE POP!!
  66. Tuning with a Potentiometer,AFPR and a LM-1
  67. Alarm removal, wont start now
  68. Stroke vs. Bore
  69. best stroker kit for a windsor
  70. piston to valve clearance
  71. Will i need 94'95 spindles to run 5 lug saleens 18x9
  72. help asap
  73. Door Actuators?
  74. Help!!!!!!!!! Ford Alarm/keyless entry
  75. speedo gear?
  76. Electric Fan, how many CFM for my combo
  77. Wire question
  78. What do I have?
  79. Fuel Pump Question: P1SC setup
  80. BOLT PROBLEMS!!!
  81. Changing timing cover gasket
  82. gt-40 intake
  83. Could detonation throw a EGR code?
  84. Windage tray HP diffrences
  85. Tranny question...Pivot ball?
  86. Hows this setup gonna do at the track??
  87. Clutch Cable Problems
  88. Ground question
  89. WTF?
  90. Distributor Shims?
  91. what mod next?
  92. can a Turbo from a 7.3L diesel be put on a 5.0
  93. oil leaked out when i pulled the harmonic balancer bolt
  94. 90 GT T-5 donor car.
  95. one wire replacement alternator - have ?'s
  96. Pist! muffler guy!
  97. IGNITION/FUEL PROBLEMS
  98. Middle of winter A/C question????
  99. easy way to bump compression
  100. UPR Smog Delete work with Supercharger?
  101. Split 5-spoke 96-98 wheels on 5lug Fox?
  102. roller rockers
  103. Fuek Pressure guage question
  104. Pics: Tubular K-Member
  105. Trans Popping out of Gear
  106. Which custom cam / blower cam for my car?
  107. I think I'm gonna buy a new short block. Need recommendations
  108. Can you use the 1998 mustang spindle's on a fox
  109. TORQUE BOXES!!
  110. egr question, lend me your ear.
  111. tensioner pulley...
  112. Weight vs. traction??
  113. Noisy Clutch/Throwout????
  114. Computer
  115. power steering pump that doesnt whine
  116. TFS High Ports Vrs. Edelbrock RPM heads
  117. Need a quick tranny overview
  118. torqing specifics
  119. New motor
  120. fuel pump question
  121. Full Bolt-on, what mod is next?
  122. engine fault codes
  123. help installing and adjusting shaft mount roller rockers!
  124. launching on street tires??
  125. difference in headers
  126. Rack and Pinion GURU's help school me!!
  127. Guess what? Still on my intake
  128. built aod or 5speed
  129. replaced entire brake system now having strange issues
  130. Help improve my combo!
  131. Exhaust
  132. Need new AOD tranny suggestions.
  133. pulleys
  134. question about thumper heads, wrong info maybe
  135. Busted Differential
  136. Cobra Insert...Can someone please tell me how this works?
  137. Question about new exhaust vibration
  138. unibody
  139. How much will a vic. jr. help me?
  140. efi to carb
  141. which cam
  142. TRANNY GUYS t5synchro/3550 synchro
  143. OK, dumb question... how to load grease gun?
  144. Some MAF Theory and question...
  145. A9L, A9P questions
  146. Roll Bar Q'S
  147. little advice
  148. How do I measure push rod length
  149. H/C/I swap. got some ??
  150. Worked Performer RPM heads and intake overkill for stock cam/block?
  151. Heater hoses go to which solid hose?
  152. coolant overflow problem
  153. Which rear control arms?
  154. Mark VII Rear Disc Hardware
  155. is my Fuel pump bad?
  156. computer guys
  157. leaking at the timing cover gasket
  158. odd compression results...and fuel question.
  159. Door Fittings
  160. EGR question
  161. What do you think this combo is capable of
  162. LM-1 wideband question.
  163. S-trim Fuel Pump
  164. Standard Rotation Waterpump heater hoses
  165. Recommend a clutch for my 86 GT
  166. overkill??
  167. Alternator in 94
  168. Lower TB Welding Importance
  169. anyone know who initials on the end of this cam are from JH7114
  170. Car acting funny
  171. All AOD's equal?
  172. computer and maff???
  173. How Do I Remove These Moldings???
  174. Boost Timing Retard
  175. Runon with rich mixture??
  176. Is my car going to be a dog?
  177. Any guess on how fast?
  178. Eibach drag launch or Stock springs?
  179. TFS stage 2 : too much cam?
  180. trick flow or edelbrock
  181. What bushings do I need?
  182. 87 5.0 flywheel end crank holes blind?
  183. running a 4 ga ground strap
  184. Can Someone Help?
  185. new heads and intake
  186. Ballast Resistor trouble
  187. suspension upgrades for 2.3 to 5.0 swap
  188. Serious Engine Problem!! Suggestions!
  189. Stock Tranny
  190. Idle drops when oil cap is off..raises when put on?
  191. a few questions about a V-8 swap
  192. Please Explain Bigger Fuel Pump Logic!!
  193. will bald BFG DRs hook??
  194. pro 5.0 shifter, will it fit?
  195. WTB for 87-93 5.0
  196. MSD Ignition
  197. Are Cometic MLS head gaskets really worth the extra money??
  198. rod and piston question
  199. Who's installed spherical axle bushings???
  200. looking for a new hood NEED HELP!!
  201. Do I need a new Master Cylinder???
  202. having a b**** of a time
  203. more brake problems...help!!
  204. 4 lug thrust II?
  205. 94/95 maf swap
  206. NITROUS SAFETY ACCERSORIES
  207. problems with motor
  208. combo opinions and power estimates
  209. MAC boom tube catback exhaust
  210. Why is my new 3G alt not charging my batt?
  211. C&L V.S PRO M meters?
  212. Anyone know the quality of these headlights?
  213. installing lowering spirngs - how difficult?
  214. junk yard T-5
  215. stock 89 GT 5pd hatchback gears
  216. which heads.
  217. fuel pressure
  218. '87 GT alternator question
  219. Looks like I need a new motor, need some real advice
  220. idling at 650-750 rpm?
  221. looking for used part sources
  222. Buying upper and lowers...
  223. Where to go next
  224. NITROUS KIT help
  225. Do batteries short out? I think mine just did
  226. Front bumper cover install
  227. Which wire for gauges?
  228. safe RPM's
  229. 2.3 to 5.0 wiring
  230. Did some part polishing this weekend
  231. Headers and Short cat'd hpipe
  232. Waterpump help
  233. Body work issue
  234. Lowering Springs
  235. New Clutch
  236. car wont start
  237. Help with K-member on 91
  238. a/c removal help
  239. Best (or the top few) NON-Adjustable struts/shocks
  240. 347 Eagle stroker & GT-40x heads-Good idea?
  241. My steering wheel is crooked?
  242. front end noise
  243. lifters/pushrods questions/early 302 gurus please.
  244. Need Clutch Adj. Help I'm Going Crazy!
  245. where did you guys mount your elec. fan switches?
  246. lookin for a few opinions
  247. just noticed a small problem
  248. Trick Flow Cam
  249. best way to improve ride quality?
  250. What fuse controls the cigarette lighter?
