PDA
View Full Version : 5.0 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 [97] 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252
  1. Headers and Short cat'd hpipe
  2. Waterpump help
  3. Body work issue
  4. Lowering Springs
  5. New Clutch
  6. car wont start
  7. Help with K-member on 91
  8. a/c removal help
  9. Best (or the top few) NON-Adjustable struts/shocks
  10. 347 Eagle stroker & GT-40x heads-Good idea?
  11. My steering wheel is crooked?
  12. front end noise
  13. lifters/pushrods questions/early 302 gurus please.
  14. Need Clutch Adj. Help I'm Going Crazy!
  15. where did you guys mount your elec. fan switches?
  16. lookin for a few opinions
  17. just noticed a small problem
  18. Trick Flow Cam
  19. best way to improve ride quality?
  20. What fuse controls the cigarette lighter?
  21. softer ride
  22. need help pretty quick
  23. anyone running the crane hi6 ignition? pros / cons ?
  24. fittings/parts needed to install fuel rails?
  25. motorsport z cam
  26. Dear Stangnet, Please Recommend me a Cam plus various other deeds
  27. tps voltage is acting strange
  28. upr coil over
  29. Momo steering wheel install problem... please help!
  30. need help bad!! STILL no spark to coil!!!
  31. Removing Anodized finish?
  32. help with tires
  33. Another tranny qwuestion
  34. 89 5.0 backfire?
  35. Did I purchase a bad hurst shifter?
  36. Clutch Quadrant
  37. I need Help with my 347 stroker
  38. do the TPS and EGR share a wire??
  39. do stock 5.0's have forged pistons or not?
  40. QUICK! How are Volkswagen's ?
  41. difference between tokicos premium and hp shocks?
  42. 3.90 gears : anyone run these?
  43. Duration question: custom cam vs TFS2000
  44. looking for items for my 88 GT 5.0
  45. Repairing cracked and rusty shock towers
  46. converting to 1994 spindles do i need ??
  47. Guys using Scorpion rockers and Twisted Wedge heads come in.
  48. Yet another stupid question
  49. Terrible Squealing Noise
  50. question about 351's
  51. help me decide
  52. Best fitting long tubes?
  53. broken roller rocker
  54. Stock intakes and stuff (help)
  55. What's worse than installing a heater core?
  56. Shaving heads?
  57. Buying used porcharger ??
  58. i need some panels
  59. 1 3/4" shorty headers for fox bodies
  60. bad vibration above 65mph
  61. Am I crazy?
  62. Oil pressure question?
  63. Help! Surge on Cruise Control Only??
  64. 24# injector question
  65. question on powerdyne BD11
  66. A9L question...
  67. OH GOD HELP ME
  68. Is a cougar motor any good??
  69. what throttle body
  70. trick flow oil fill kit?
  71. GT sideskirts...
  72. Caliper Question
  73. 5.0 Bronco question (sort of long)
  74. need more low end torqe
  75. Driveshaft Help
  76. shaking problem
  77. "clevor" valve clearance question.
  78. Stud/Pedestal Mount?
  79. Should I Go With A Bigger MAF? & Different Air Intake?
  80. Quick valve lock question
  81. Electric Flexlite Fan Now not running as cool
  82. Twofold Question - Striker and Belt
  83. trickflow high port heads
  84. How effective is a power flush? (Cooling system)
  85. TFS stage 1 part number
  86. more top end?
  87. Intake Swap Frustration
  88. rear disc brake line questions
  89. "In the hole" question
  90. 289 crank
  91. Engine Bay Dress up Question...
  92. 02 sensors bad every 6 months or so..
  93. Axle Question
  94. rack and pinion
  95. Need more power
  96. Low Battery Voltage
  97. someone help coolant leak
  98. Fuel Injectors on Ebay
  99. Will firmer Shocks fix this problem...
  100. Who's the member here who sellsx torque box reinforcements that weld in???
  101. 97 Grand Am Auto Locks
  102. HELP!!! No vacuum after head and intake swap.....
  103. please help
  104. Who's making 400+ rwhp with a blower? Fuel system questions
  105. fast idle / computer problems
  106. Any differences between '88 Crown Vic and Mustang GT 5.0 Blocks?
  107. Victor Jr. setup
  108. how hard is it to install injectors?
  109. Torque settings
  110. just installed mgw shifter
  111. Piston question
  112. RPM calculator, HELP!!
  113. NEED HELP FROM THE T-5 GURUS
  114. Few Questions
  115. will this work, what else do i need
  116. bad whining sound when accelerating
  117. supercharger??
  118. fuel tank problem?
  119. in need of help
  120. What are the colored vacuum lines for at the back of the engine compartment?
  121. Brake Question
  122. HELP...Brake Problems and more???????
  123. HELP...Brake Problems and more???????
  124. HELP...Brake Problems and more???????
  125. DCControllers Question... Yount
  126. upgrades
  127. I need more power, S-Trim Qs
  128. efi fuel pump
  129. 92 lx hatch seats
  130. arm rest delete questions
  131. distributor question
  132. 5.0 to 4.6 fox swap
  133. Fuel tank size??? How many gallons
  134. what would it take
  135. How strong is the rear end?
  136. Crown Vic Police Cars
  137. installed new headers, stearing arm is against tube
  138. 140 MPH Speedometer
  139. first impressions after electric fan install
  140. audio help
  141. tilt steering
  142. What is my aprox. C/R?
  143. ? about the design of the factory neutral safety switch
  144. Yellow substance in oil? what is it?
  145. Vacuum tree......
  146. Injectors staying open>?
  147. LC1 wideband questions
  148. AOD to T-5 parts list?
  149. EGR....i think.
  150. will the stock 5 lug rotor work??
  151. I DO NOT FU@#ING BELIEVE THIS!! ARGHH!!
  152. How much HP from stock fuel lines?
  153. Not ford but I NEED help
  154. T-5 question
  155. Intake for carb'd 347??
  156. Would this combo work?
  157. a/c black thing and line called?
  158. t5 gurus needed
  159. Looking for how to on installing springs on my heads
  160. Brake Help
  161. converting gt to lx
  162. GOD %$#@! ignition still doesn't work - please advise.
  163. Steering wheel vibration
  164. Buying used cars suck......
  165. question on 5 lug rotors??
  166. Making my car run smooth at all times...
  167. Quick question about the Edelbrock performer
  168. eibach drag launch springs
  169. Has any one tried one of theese
  170. 3G harness
  171. Anyone using UPR Triple Pick-Up or Speed Release Quadrant with Double Lock Adjuster
  172. clutch question
  173. Tach Not Working
  174. problem with romac balancer!
  175. Blower battle....
  176. how to tear down and rebuild a trac loc!
  177. Coolant Leak from interior of car? please help
  178. Explorer TB TPS HELP!
  179. changing to gt40 manifold
  180. clutch real stiff...
  181. What size tranny coolers are you running?
  182. Engine = 182k...engine re-build kit?
  183. Gas cap on F150 throwing a code and dorkin up engine??
  184. Someone have tried a Zoom clutch?
  185. Doing A/c delete now Stuck!
  186. Brake Proportioning Valve
  187. Need brake hose help...
  188. What octane
  189. selling nitrous kit
  190. 3rd and 4th gear gone.
  191. want to hit low to mid 12s
  192. fuel tank sender line size
  193. replaced ignition switch... still getting nothing.
  194. What do you guys think????
  195. 351W oil pan question
  196. Altenator Upgrade
  197. School of Automotive Machinists
  198. Dart jr iron heads?
  199. Fuel pressure
  200. Vaccum Tree Delete?
  201. Venom 400 control module... does it work?
  202. Eibach sportline questions for those who run them
  203. Downs Ford Upper Box Intake
  204. Coil overs for 91 Lx
  205. What gears to use with a 4cyl T5?
  206. I have $1000 to spend, help.
  207. Valve job on heads?
  208. wiring problems maybe.
  209. 351 swap
  210. Best DR for 4.30 gears?
  211. Salt and Pepper Shaker (10 pin) connectors
  212. Advancing the cam?
  213. Question about Tremec shifter
  214. 03 cobra wheels on 92lx
  215. Headers and Flanges
  216. New Manifold Install ??? Cruise control too
  217. T-5 Swap Complete. Rattling in Bellhousing??
  218. Maximum or Steeda
  219. AOD to T-5 Swap
  220. Removing paint from trim
  221. Spec or Centerforce dual friction???
  222. 85 gt to 87-93 master cylinder swap
  223. DAMNED DOOR LOCKS!!!!!!
  224. eec shuts off above 7k rpm?!?!
  225. Washed car.. then wouldnt start until i...
  226. wanting to put E7 heads on a 1984 302. Valve clearence issues???
  227. no gauges
  228. tremec 3550
  229. New to fox
  230. fiberglass trunk lids
  231. Painting my car
  232. Fenderwell Cold Air or March Ram Air
  233. Looking for free/cheap weight reduction idea's
  234. Hedman Headers
  235. Too many electrical accessories to fit on starter relay?!@?$%
  236. AOD to T5 - new speedo cable needed?
  237. still need help with ignition
  238. MERKUR X4Ti
  239. car stumbles
  240. 4 bolt main or girdle??
  241. need help in a big way - ignition problems big time.
  242. 94/95 MAF install completed!
  243. Auto trans Shifter ...
  244. need help! electric fan install gone wrong - car won't start
  245. G-force T-5 Dog Rings
  246. Tranny Removal help
  247. Quick Question on the TwEECer System
  248. Restoring bare aluminum finish on wheels?
  249. rear adj. lcas? help
  250. Absolute cheapest set of alum. heads?
