PDA
View Full Version : 5.0 Tech
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248
  1. Help build new FAQ on StangNet
  2. Which mufflers to use?
  3. When or should you chg fuel injectors??
  4. crank end play ?
  5. Easy way to flush radiator??
  6. so what cam are ppl using with THUMPER heads
  7. coil over spring question
  8. My mercury zephyr 5.0 project
  9. I need sound clips of speen density cams
  10. Compression Test done. Here are numbers.. HELP
  11. How to test a coil?
  12. Nitrous on 74 block
  13. Top Speed w/ AOD
  14. Still having cooling issues with 94Cobra
  15. E Cam and Twisted Wedge heads? Are stock pistons ok?
  16. Removing smog
  17. Opinions on new combo, thumper heads
  18. big block or small block
  19. I need all the info you got!
  20. Hood won't latch...
  21. HyFire VI or MSD Digital 6+
  22. Electric Fan Question?
  23. question about porting stock stuff
  24. 4.10 gearsw/ n-91 cam and tremec 3550
  25. Has anyone used a IST Air Adjuster? Help me please
  26. Spark Plug Question
  27. 20" or bigger cobra R's?
  28. Quarter Windows On A 90 Hatchback
  29. crazy vibrations in shifter
  30. Could my stock 5.0 beat a '81 chevy monte carlo with a 350?
  31. BRAKES keep locking up.
  32. Strut Tower Brace Install
  33. Stroker Kit.
  34. **Best and the Worst Shops**, Name 'um!!
  35. Anyone w/pics of Vortech on 96-98 Cobra?
  36. Car Finally Runs, But Runs Very, Very Crappy!
  37. Anybody know about the Cobra mass air kit?
  38. 351W Build Up. Engine Guys come one in
  39. 5 lug conversion a 4 cyl car
  40. do plat plugs = power loss
  41. what is the diffeence between a stallion bumper and a stalker?
  42. 5 speed swap question...
  43. Would a manual rack and pinion off a pinto work on a 5.0?
  44. 18x9 chrome Saleen Wheels on a Fox
  45. 2nd temp sender location
  46. Drag radials guys,at what rpm can you launch??
  47. should i be faster???
  48. Clutch Quadrant Question
  49. Is that a tfs part #?
  50. PDA software for our 5.0's??
  51. one honking Stang
  52. motorized hatchback door -- anyone seen 1?
  53. No Oil Pressure On Cold Start???? Knock Knock Knock Knock!! Help
  54. Steeda Rear Quarter Window covers
  55. front suspension woes
  56. A-arm bushing removal
  57. help installing the 93 conra grill insert?
  58. Clutch pedal vibration
  59. Flowmaster Question
  60. Best place to get a SINGLE Cobra roller rocker?
  61. newer disc mustang rearend into fox,will it fit???
  62. Anyone use the BBK fuel pump?
  63. Need speaker wiring diagrams, anyone???
  64. Larocca's doesn't know how to fix my 93. WTF????
  65. Weird sound coming from BBK O/R H Pipe ?!
  66. Choked exhaust = failed emissions???
  67. Some motorsport lowering spring concerns
  68. motorsports front lower control arms? (long)
  69. Auto Tranny Question? Change brown fluid?
  70. Anybody Have a Mini Starter??
  71. Front spring install, right and wrong LOL
  72. better bang for buck 347 vs. 351w
  73. Cobra Grille Insert
  74. Post your World Product Widsor SR Head combos
  75. My friends freshly painted yellow Mustang
  76. Belt Sqeeking Really Bad!! Why??
  77. HELP......whats the best cam to run with twisted wedge heads and track heat intake???
  78. FS: Fox-Body Leather Seat Upholstery.
  79. painting subframe connectors
  80. 351w in a fox?!?!?!
  81. SN95 Rear Seats?
  82. Why won't my fuel pump work?????????
  83. post pics of 86 tail lights or cobra tail lights
  84. t5 whining after a few launches on slicks???
  85. Aluminum Radiators
  86. How to adjust the clutch switch
  87. Factory temp gauge users come in!
  88. wiper cover and cowl hood
  89. 89 5.0 "easiest" brand of Long tubes to install? Knuckle Busters!
  90. Rear End Alignment?
  91. Moog Ball Joints
  92. Bullit rims on fox body pics
  93. What AFR Heads for My combo?
  94. I have a AOD w/ shiftkig and 3.73 gears, is it worth getting 4.10s?
  95. PICnsd:What's the best way to remove a strut tower brace? (I know, stupid quiestion)
  97. Are heads from 96 explorer GT40 heads??
  98. timing is jumping?
  99. Still no turn signals.....HELP!!!!!!!!
  100. Engine mounts? Solid, Poly, Stock? And Why?
  101. Car GODS enter here
  102. Should i put my supercharger on my brand new motor or break it in first?
  103. WANTED 88-93 GT vert with a 5 speed
  104. Eletric Fan?
  105. 4cyl Springs Front and Back OR just Front?
  106. Tilt steering column conversion!
  107. My stang is too loud... Exaust setup questions
  108. 427 (351W stroker) opinions
  109. Where to get turbos??
  110. Feul/ Timing Guru's, need help with detonation!
  111. New KAASE SBF heads - best heads available?
  112. Surging while driving
  113. Broke my Baby today
  114. Car is bucking at cruise, any ideas?????
  115. Body Kit
  116. Boost Cooler??? Anyone tested yet
  117. Will a 96-03 t5 tranny work in a 87-93 5.0???
  118. 5.0 heads flow charts
  119. I got a new Stang. What should I do with it?
  120. Need this obnoxious Squeak found!!!
  121. dyno tune
  122. Painless Wiring .... Quick Question.
  123. '03 GT seats into a '93 LX
  124. what spark plugs to run
  125. Tires for 17x9 Cobra rims
  126. Modular guy just went and bought a 5.0 questions
  127. open exhaust question
  128. Turbo modified into belt driven ????
  129. weak e-break
  130. 1983 4 speed tranny
  131. Need a new mod!!
  132. timing and running issues
  133. Stater Relay PICTURE NEEDED!
  134. typhoon intake /edelbrock
  135. oil dipstick
  136. AODE Shifting Problems
  137. SMoking from Exhaust
  138. Possibly water in my oil
  139. Nitrous express kit for sale or trade
  140. Custom Panhard bar
  141. Dumps??
  142. Steeda cams, tell me about them?
  143. Think twice before installing subframe connectors
  144. please help..what do i need for injectors and maf size?
  145. Was gonna do carb.. but... back to EFI
  146. Spyder Intakes?
  147. Not getting SPARK!
  148. Aluminum Engine Block
  149. why wont my car start?
  150. BXR Upper & Lower Intake
  151. Desktop Dyno - Please rate this motor...
  152. 20w-50
  153. Pics of my ported stock intake
  154. Gears Install Write-up?
  155. which intake for a 347
  156. Oil Pressure Guage
  157. engine miss under load
  158. Torque arm/panhard bar question
  159. X_pipe Or Pro Chamber?????????
  160. 15 inch wheels with 13 inch brakes?
  161. Has my heater core gone??? Funny smell when I turn the heater on!! Help!
  162. engine cutting out at 4,500rpm
  163. Who makes the best Rear Anti-Roll Bar?
  164. What can do I to shave weight????
  165. Flex- a- Lite Electric Fan
  166. Which is easier swap, 5 Speed to Auto or 4 cyl to V8?
  167. I NEED to run a 14.1 quarter mile, How?
  168. bad pilot bearing? vibrations in shifter
  169. stupid door locks- have a theory
  170. 91 Mark 7 to 93 GT engine swap
  171. bad rod or crank bearing???/
  172. GAS smell
  173. Help with pcv vavle issues
  174. Recal my mass air, or upgrade?
  175. best water pump set up for street/strip car
  176. Stang won't start... here are the symptoms
  177. Stock Rev limiter?
  178. Need some transmission advice
  179. Eibach Road Race kit in a fox?
  180. So who's gonna step up and represent us at the Hot Rod Magazine Pump Gas Drags?
  181. AOD VS. C4 / hassle versus performance
  182. HELP blower gurus
  183. Broke the oild dipstick tube, now I can't check oil!
  184. bullitt rims...4 lug
  185. transmission swap?
  186. Rear coil over before and after...
  187. What Size CC on Gt40 Lightning Heads
  188. building a monster
  189. A bunch of handling questions for the experts
  190. Header Clearance T-5 to C-4 Swap
  191. Balancer/Dampener Install... won't go on.
  192. Does your Throtle Body and Pullies Make noise?
  193. pedistol mount or stud mount rockers?
  194. H/C/I coming, help me!
  195. Can you mount a flywheel wrong?
  196. ECT sensor replacement/thermostat Q's
  197. car breaking up past 3500/4000
  198. valve cover baffle
  199. Building a simple short block.
  200. Which is the best electric radiator fan?
  201. exhaust question
  202. Good handling combo or waste of $$$?
  203. Turning a GT into LX?...87-93
  204. Bad Belt Tensioner?
  205. Carfax needed...
  206. Low Idle
  207. TurboCharger Question, Can I do this??? *pic* and help needed!
  208. How to check valve train geometry?
  209. injector size?
  210. Vibration
  211. Help with codes, please!
  212. Fuel tank dropping problem
  213. Creating black out switch
  214. Aftermarket Coil cause rough idle?
  215. 87-93 LX questions
  216. edelbrock 2.02 w/stock pistons???
  217. leafblower supercharger
  218. Poll....best Bolt-on For Under $500
  219. Clicking Noise Coming From Clutch?
  220. MM Strut Tower Brace & Plastic Coil Cover
  221. Anyone running 3.90s?
  222. Want to get an H, X, or Pro Chamber pipe but can't decide...Help me out!
  223. could axle cause a vibration?
  224. TFS Street intake, TW Heads, But which cam?
  225. Gear drive on a street/strip car?
  226. New Bbk Intake
  227. Ranger axles, ok to get from 4x4?
  228. clutch
  229. Do Police Intercepts have 24lbs injectors?
  230. I got a "Mark VII" rear rotor, but it's only 10.5" why!?
  231. Can i reuse my stock head bolts?
  232. AOD and nitrous what gears?
  233. Clutch question
  234. How To Install A Thermostat
  235. exhaust sound
  236. 275's on a fox?
  237. How to improve brakes on 86 LX 5.0
  238. Rattling noise... Alternator?
  239. Stock Foxbody 1/4th mile times
  240. T5 GURU's please help with any info
  241. HELP-- windshield wipers will not turn off....
  242. 351w
  243. 5.0 into a 4 eyed 4 clinder
  244. 31 spline carrier unit out of a truck?
  245. Sway Bar Diameter - Performed a Search - HELP
  246. mounting engine to stand
  247. need starter help
  248. What size T-fitting for oil presuure gauge?
  249. exhaust sys. w/ mellow low end & mean top end?
  250. What is the wieght distribution on a stock Foxody?
