PDA
View Full Version : 94-95 5.0 Tuning
Pages : [1] 2 3
  1. Air Bag light code 12.
  2. question about OBDII
  3. Any magic chips for our cars ?
  4. IAC restrictor plate installed!
  5. P.M.S help
  6. WOT TPS value off for my Tweecer?
  7. Dyno'd tuned or other option?
  8. MAF Transfer and Injector Slopes
  9. New A9L set up for us AODE boys......
  10. kamrf's Q's
  11. Can I put on a MAF meter calibrated for 24# injectors without using a Tweecer?
  12. tweecer users please help
  13. Noise filtering capacitor for PLX/Tweecer
  14. Tweecer/Tuner guys, help with A/F at idle
  15. Anyone find a better deal than this? (wideband O2 w/ logger)
  16. Ugh...
  17. worth upgrading a base Tweecer to R/T????
  18. The Purpose of the tuning forum
  19. TwEECer Tuning Manual
  20. P.M.S.-How To's, User Guides, Tuning Tips, Articles.
  21. idle reset
  22. Just bringing up an oldy but goody tuning tweecer thread
  23. Sluggish at low RPM
  24. Not sure if this is the place to ask but why does my car bog?
  25. PMS Trouble Codes
  26. Tweecer-Dummy has a few questions.
  27. Effects of humidity on MAF transfer/function
  28. PMS or Tweecer RT (need advice quick please)
  29. SCT chip question
  30. PCM question
  31. wideband and fuel map tuning.
  32. To tune or not to tune?! That is the question
  33. Detonation on throttle tip-in and Manifold Volume scalar
  34. tweecer r/t help me?
  35. Ok...Load or Loadx
  36. 42lb/MAF Conversion for j4j1/cbza questions
  37. Megasquirt
  38. What other uses is there for a Tweecer than "beefing" up an aode.
  39. Alternative Tunes?
  40. Tweecer or not?
  41. running problems
  42. SCT Tune Timing Question
  43. spark plug heat range question
  44. PMS Series X?
  45. Reading twEECer R/T datalogs
  46. Superchip: Tuneable at home?
  47. I'm in market for WB 02s
  48. GT & Cobra Stock Maf Curve Comparo
  49. Python venom 400 pcm ?
  50. I thought PMS is what my wife got?
  51. Anybody using Tweecer to control 4r70w shifts?
  52. any1 in the south jersey area know how to...
  53. Limits of twEECer
  54. Tuning Help..Longshot here but WTF hehe
  55. Tweecer users- I have to ask.....
  56. Computer Program..Which one is this??
  57. PMS Users - How hard is it to program out the EGR?
  58. PMS Question - Is a VC breather better than a line back to the intake?
  59. I'm finally ready to tune this for performance! Need some advise!
  60. t4m0.ccf stock tweecer file needed
  61. You guys are gonna hate this, but. . .
  62. A pms and tweecer r/t price question
  63. A few questions about pms/twEEcer differences. I searched first :-)
  64. Tweecer datalogging - necessary?
  65. Tweecer Newbie in Desperate Need of Help!
  66. wheres the hp
  67. Supercharger
  68. Tweecer datalogging issue
  69. Getting ready to Tune! Damn Scared!
  70. MAF Flow Chart
  71. help!!! PMS 42lb injectors Pro M
  72. Yet another lame question from a Noobie
  73. Engine Displacement Question
  74. PMS users, i have a simple question
  75. P.M.S Help W/ tuning in S.Florida (VibrantRedGT maybe)
  76. I need help !!! Puting a flow sheet into Tweecer
  77. What should be my first tweecer mod?
  78. Tweecer: Why are my fan values negative?
  79. Vortech boost control needed with PMS?
  80. Tuning help
  81. Ford's total timing....
  82. 94 cobra 342ci s.c. trouble tuning cammander 950
  83. Made a 10 to 30pt MAF conversion spreadsheet
  84. AODE settings
  85. Tweecer RT but no wideband O2= bad?
  86. New EEC Forum
  87. PMS users w/ stock injectors
  88. Fan temperature activation.
  89. Cobra vs GT MAF Sensor and MAF Transfer Curve Question
  90. My car is only running 9* total timing at WOT while I am targeting 18, how to fix?
  91. Easiest way to reset PMS?
  92. Major Throttle Problems.
  93. PMS Experts, a few questions, lil help please
  94. Noobie, Can't get laptop to recognize the tweecer
  95. how to use calcon?
  96. Mass Air Meter to Throttle Body Question
  97. Why is my car pulling timing PART 2! Dyno graphs inside!
  98. Tweecer installed and working, J4J1 loaded up :)
  99. O2 sensor readings, left vs. right bank
  100. EEC Analyser MAF tab Question.
  101. Why use an Adjustable Fuel Regulator?
  102. Simple tweecer mod for increase MPG on Highway
  103. Will Lightning MAF with PMS?
  104. How accurate is the HP/TQ estimate in EA?
  105. buy tweecer or burn a chip
  106. can someone look at these log files?
  107. Need help . . . why is it backfiring??
  108. maf's and hp/flow
  109. Where is Min Inj PW set? AND What is DIA of Clear C&L Tube?
  110. HP?
  111. datalog at track
  112. Wide band o2's
  113. Kam's, fuel trim on and off throttle?
  114. Clearing KAM with Wrong Calibration File?
  115. Distance from MAF to throttle body
  116. Typhoon Intake
  117. Anyone using a DataQ???
  118. Timing sensor on clutch
  119. Dyno Tuned yesterday...... something isnt right..... 404hp 396tq??
  120. Where to get Tweecer Software?
  121. Anyone using CalEdit v1.30A10?
  122. Set Base Timing with CalCon?
  123. What is an Acceptable KAMRF?
  124. Request from Tweecer users
  125. HELP!!!
  126. Ticking....
  127. Wide Band Screen Shot
  128. Tweecer
  129. Valve Cover Question
  130. Long Tube Headers: Where to put WB O2 sensor?
  131. Grady's Tweecer fuel_table_startup_OL calc?
  132. How much timing is good on a NA car and what A/F?
  133. egr question
  134. i have a Question about saving files in CalEdit ???
  135. Interested in a PMS
  136. wideband of choice for tweecer?
  137. 94 gt sputtering after warms up
  138. Installed new MAF and now it runs slow
  139. Tweecer question
  140. 95 Mustang GT stalls/dies, already replaced TFI and Dizzy
  141. Jumping in and out of closed loop
  142. Adding spray on a little 95 GTS...
  143. Pro M harness
  144. Can anyone explain how load is calculated
  145. tweecer guys, have you tried this????
  146. Bad Gas Mileage, what to look for in datalog?
  147. what is up with the tweecer support forums??
  148. Can you scan for codes using the tweecer?
  149. What tuning strategy are we supposed to use?
  150. Tweecer setting cam peramiters
  151. tweecer site down?
  152. Tip Accel Problem
  153. Throttlebody/Pro-M 80mm
  154. CalEdit V1.30 Software Bug
  155. turning off egr with tweecer wich scalar is it ????
  156. No o2 sensors
  157. PW1, KAMRF1, HEGO1 are not equal to PW2, KAMRF2, HEGO2
  158. Dyno-ing--Worth It?
  159. Can I read my engine computer calibration with the u4po out of the car?
  160. thermactor air control
  161. Question about aftermarket MAF's
  162. start from scratch?
  163. Opinions/Insight needed
  164. Blksn955.0 talk to me
  165. specs
  166. My idle is rock solid except when.....
  167. ECU Question
  168. timing advancement
  169. Tweecer Noob, Help
  170. Having problems with CalCon
  171. AODE/Tweecer Guys, Question, trans_dnshft_slptrgt_hld_dur_3
  172. I'm such a noob!!!
  173. WHERE IS MY POWER?? NEW ENGINE INSTALL
  174. Question
  175. Noob Tweecer user in need of help!! Long kinda
  176. My first TwEECing experience!! Have some questions.
  177. New motor install, tuning issue - cars just dies
  178. High idle with timing change
  179. Can't go to WOT
  180. How To Setup Converter to Lock 2nd/3rd
  181. A9L swap question
  182. Tweecer not datalogging?
  183. new datalog
  184. Who has 50+ injectors???
  185. Building a 331 Computer and tuning questions
  186. New to tweecer
  187. 2004 pms vs tweecer r/t
  188. Running rich - go AFPR or Tweecer?
  189. Noob need tuning advice
  190. AC and Injector offsets vs Batt volts=KAMs rich,lean,rich,lean
  191. Something wrong??
  192. Setting Timing with Tweecer R/T?
  193. Tweecer + FMU question.
  194. Tweecer + FMU question
  195. Where to mount PMS
  196. Got It Running
  197. tweecer speed density tuning
  198. gt tuning tips
  199. 3.73s Installed!
  200. 95GT troubles:(
  201. TwEECer Tune
  202. Tune Backups to CDs..Need computer guru's help
  203. Need a Flow Sheet For Granatelli 75MM Mass Air
  204. Interested in PMS, Whos got the best pricing
  205. PMAS 80mm MAF Curve
  206. Installed PMS, etc, and now got t. codes
  207. diablo chip question
  208. J4J1 in an AUTO?
  209. Latest vs of Tweecer = 1.30A10
  210. kind of along shot eectuning forum help
  211. error messages when datalogging in calcon!!!
  212. LC-1 Wideband -> twEECer
  213. rock steady idle just by installing tweecer?
  214. Which tuner is king
  215. Tuner in denver/colorado springs
  216. tweecer + fpr?
  217. FYI, hot OL idle problem solved
  218. question about global spark adder.......
  219. My car is running WAY TO HOT! WHAT TO DO?
  220. LC-1- Where is your system ground?
  221. will my tweecer work in a new model mustang?
  222. boost to nitrous
  223. nitrous express
  224. how to datalog
  225. need help with lc-1 wideband
  226. pickup coil questions
  227. Bullseye Power
  228. Power Steering Prob
  229. Voltage Change-Dataq to Calcon
  230. Adding some parts, your two cents.
  231. Tweecer or My own Tune?
  232. Couple ? about TWEECER
  233. Idle Surge???
  234. Stroker size question
  235. Saved Tuned Settings.
  236. 95 convertible 5.0 questions?
  237. Can I download or use one of YOUR tunes?
  238. 347 is running now where to begin on the tune?
  239. True or false?
  240. Wideband, where to hook up....eec?
  241. PLX Devices vs Dynojet Wideband Commander
  242. Tuning to pass inspection
  243. tweecer and codes
  244. Hows my settings of Fuel Pressure? Timing? Running a little rich I think.
  245. popping sounds
  246. LC-1 on the way, any hints for install?
  247. Tweecer
  248. H/C/I smaller cc´s will i need to set it on tweecer?
  249. 94 gt bkfire issue
  250. AFR q's
