PDA
View Full Version : SVT Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21
  1. Tried searching... can you help?
  2. Need a fuel pump!
  3. CHip or hyper tech
  4. Best Blower pulley???
  5. planning for supercharger need help
  6. Safe launch RPM for blown 98 Cobra
  7. Studder/bucking
  8. 94/95 rear disks
  9. A Little 99 Help
  10. Computer Flash instead of chip
  11. 97 Cobra rear end seal
  12. '03 Vert Headlight and Rear Seat
  13. ABS Light
  14. 03/04 Wheel Hop Fixes
  15. Does 03/04 really need shifter?
  16. Traction Control????
  17. Best mod under $500
  18. Want to remove sunroof...How??????
  19. 7.5 year old Cobra just got its first "mods"
  20. Camera mount.....
  21. Belt squeak drives me crazy
  22. Cobra eater
  23. which mi-pipe for cobra?
  24. 98 Cobra Intake Manifold
  25. cobra r replica
  26. timing adjusters suck
  27. Radar/Laser detector install question
  28. I need cobra advice
  29. Differences between 1999 and 2001 cobra....
  30. wheel fitment problems....
  31. car dieing when clutch is put in
  32. How much RWHP can the stock 03 Cobra handle?
  33. PoyZNus??
  34. fog light socket
  35. what pullies
  36. Blower Pulley Change? Air/Fuel problems?
  37. Best Headers for 04 Cobra
  38. mustangtuning.com
  39. catback for 99 cobra???
  40. OIL: 6 or 7 quarts ?????
  41. Headers/Cats hitting ground with springs installed?
  42. Best price on Bassani BX Catback?
  43. 42lb injectors are in...FMU needs to come out
  44. Vids of my MagnaFlow exhaust
  45. import wants to race
  46. Power gains with new Exhaust & Pulleys
  47. Part # for inner CV boot for '03+?
  48. Silencer?
  49. What is the law in missouri for tinted windows
  50. what has the most performance w/ great sound(exhaust)
  51. 03 cobra hood on ebay again...
  52. Help With Picking Exhaust
  53. Should I upgrade my exhaust?-Which one if I do?
  54. kook headers install
  55. timming adjusters
  56. 2.8" pulley with questions
  57. shifter grind in first. what the hell is going on?
  58. installed plasma booster
  59. Shock/Struts
  60. Spark Plugs
  61. 18" BBS RK wheel for sale-- for cobras
  62. 97'Cobra weak points
  63. '99+ GT axle dimensions???
  64. 03/04 Cobra Heat Exchanger (who has one?)
  65. Need help finding EEC
  66. Bored with my catback
  67. dyno results after magnaflo catback install
  68. '03 Radiator Swap
  69. car cover questions
  70. 18x9 wheels for 96cobra. what tire size? without rubbing
  71. IRS TO SOLID Swap Questions
  72. Need Tire Size Help!!
  73. Who makes 17x10 wheels?
  74. need cat-back advice
  75. Wheel Problems???
  76. Will this make the 13's
  77. 99 cobra where to start
  78. help finding front wheel bearing assembly
  79. O/R H and no-muffler catback
  80. Cobra Production Number?
  81. Critical
  82. Need Install Shop for Rear-End Gears in Southern, IN
  83. does anyone here have the side pipes on there cobra and ............
  84. 03 Mach 1 chin spoiler on Cobra
  85. 03 Cobra kook long tubes leaking
  86. 03 Cobra kook long tubes leaking
  87. Lowering springs?
  88. Bent/Broken gas pedal fix???
  89. What is the trick to pop out the plastic inserts in the side scoops?
  90. Side window louvers??
  91. HELP Engine code!!!
  92. Seat Covers.....
  93. Eibachs and spacers on...pics
  94. Here's what 650RWHP looks like
  95. Anybody with a 99+ cobra and magnapacks?
  96. fuel injectors
  97. Pulley modulation....3 to 2 pulleys...
  98. Rear axle question
  99. i just bought a 03 convertable cobra.......(more)
  100. 99 cobra cooling system hole?
  101. Need opinon- Carbon Fiber Or Aluminum Driveshaft?
  102. Noob Cobra Owner.....
  103. My Dr. Gas X pipe and cutout
  104. Odometer problem/Rev limiter
  105. Just ordered an 04 Competition Orange Cobra
  106. 99 Cobra chasing 2 Porsche Carerra GT on Autobahn Video
  107. 01 Cobra 300RWHP...Whats a good way to get there??
  108. Cobra R wing
  109. what kid of car is this? cobra motor and interior.. not a panzo
  110. Subframe Connectors that aren't weld-in, good or bad?
  111. Cheapest place for 4:10's
  112. Best bolts for LT headers?
  113. mil light eliminators
  114. noise behind cluster 99 cobra
  115. Control arms on 98 Cobra!
  116. how do you get an Oasis report?
  117. 2003 Left over help
  118. need more h.p
  119. Is this normal behavior for a Spec Stage I clutch?
  120. Eaton vs. Ford 31-spline posi unit???
  121. I need pics of Cobra IRS
  122. Tremec built 5 spd in '98 Cobra?
  123. king cobra clutch
  124. ? At what point do you need to...
  125. How good are stock subframe connectors on the 03 vert?
  126. Can anyone tell me what more mods I can do
  127. Some Dyno numbers for the Slobra!
  128. 95 GT to Cobra Clone, Need Information
  129. sorry guys i was wrong never ran my car!
  130. NOS....99 cobra
  131. tuning q's
  132. Cobra disk brake measurements?
  133. this is my first time posting here and im looking to get a cobra (more).........
  134. Single Blade Throttle Body?
  135. 1/4 mile times on my new 98 Cobra
  136. Kenny Brown ALuminum IRS Bushings?
  137. 1997 cobra front wheel bearing
  138. Anybody got pics of hood pins on 96-98 Cobra?
  139. Intake Runner Cotrol Unit ???
  140. How much will break it?
  141. Will a center console from a 03 Cobra fit my 96?
  142. Who mkaes the wider rims for the 03 Cobra
  143. 95 Lightning Horsepower & tq?
  144. Cobra alarm
  145. Thinking about gettin an 01-02 or 03 cobra, got some questions...
  146. After market intake for 01 cobra
  147. what more mods can I do
  148. Spoiler on 03 Cobra front bumper
  149. 2003 Cobra making ticking noise
  150. Someone told me that catted Midpipes make more power then O/R midpipes..fact or myth?
  151. I got my Magnaflow X installed today!!
  152. 03 Rears Blownup?
  153. Catted Mac h-pipe out, offroad H in...
  154. Online Store?
  155. anyone find a good Aluminum DS for 99 cobras?
  156. Trouble with '99 4V heads?
  157. Installing Gears
  158. My Pro 5.0 is giving me problems. what did I do wrong?
  159. abs dash light
  160. 2001 cobra
  161. 4v Motor In My GT?
  162. IRS vs Solid Axle Any Input
  163. Transponder key problem?
  164. $1200 after Iraq-help me
  165. 98 Cobra Vert. 10.99sec or less ????
  166. what company make's the best Strut tower brace and sub frame connectors for 99+ Cobra
  167. Is 120K miles too high for a 99 cobra?
  168. 96-98 Cobra Performance Numbers
  169. Please, need info on MAF
  170. leakdown results for mac l/t/ headers
  171. T-56 swap
  172. new saleen wheels????
  173. Your 03 Cobra Rims/Tires
  174. How many miles before dyno?
  175. Looking for good racing seats
  176. 01 suspension upgrade BBk or Eibach?
  177. Best gear Ratio 3.73s or 4.10s
  178. Port and polish on 4V heads?
  179. What RWH/RWT to expect for my 03 Cobra?
  180. What do stock Lightnings run in 1/4?
  181. 93 Cobra cam?
  182. 99 cobra i want a prochager?
  183. What is the difference b/t the Focus 2.0 and the Zetec 2.0??
  184. Tire question
  185. SHO question . . .
  186. Timing for Maximum Power
  187. air intake setup
  188. DenseCharger Question!
  189. Need help with lowering
  190. 1999 Cobra Sway Bar Diameter
  191. 04 Cobra
  192. question two of them
  193. IRS to Solid Axle swap
  194. people who got screwed with mac longtubes
  195. 99 cobra rear bumper to 01 rear bumber
  196. Thinking about dropping the k mamber and trying a JBA install
  197. Thinking of buying a '99 Cobra convert. Any drawbacks?
  198. Magnaflow Catted-X. Has anyone tried two gaskets on passenger side?
  199. Anti-theft System problems
  200. Taking off spoiler, fill-ins for holes????
  201. 2003 Cobra IRS on 2001 Cobra
  202. Spark plug problems.
  203. Hour 4.6L V8 2001 Cobra engine in a $96,000 car?
  204. springfield mo
  205. exhaust question again
  206. How did you remove your stock H pipe? It impossible!
  207. paint code question
  208. Few goodies I picked up for the cobra
  209. Hello All
  210. Focus Fuel Pumps
  211. Is this a good exhaust set-up for a 2001 Cobra??
  212. 5.4 DOHC MP Intake
  213. Bought a full magnaflow exhaust today... got the wrong X pipe!
  214. Rear main oil seal question
  215. Installed Bassani catback on 96 cobra.. QUIET
  216. 1995 Corbra R to be auctioned
  217. What X pipe did you use and why? Which Catback?
  218. timing chain
  219. Speed-volume control for Mach 460?
  220. 03 cobra svt vs. turbo older mustang
  221. Steeda Timing Adjuster
  222. To Cobra owners in states that rquire front license plate
  223. Need OEM 98 Cobra rotors.
  224. Newbie, SVT Focus owner
  225. Did all 96-98 cobras come standard with the mach 460?
  226. Traction control
  227. decided to mod the 01 after all, advice please.
  228. 03/04 Cobra Pics
  229. Nx Wet On 99 Cobra
  230. Ford Brings Back Shelby Cobra !!!!!
  231. TSB listings
  232. New clutch feels much different
  233. Need Help desperately
  234. At my wits end; $60 MIL Elem.'s still do not work after trying everything to fix it
  235. Chip Gains
  236. Gutted Mass Air Meters?
  237. Which bower is better
  238. 03 Cobra with 2.8 pulley???
  239. Tampa, Fl mechanic
  240. 01 cobra
  241. 2001 cobra front & rear Eibach spring install
  242. Traction-lok compatability
  243. your input appreciated
  244. Help.....cobra exhaust woes
  245. plugs for GT40X heads ???
  246. Need Help: Burning Oil and Compression Test Results
  247. 03 cobra production numbers
  248. Nickel Plated Rotors
  249. 99 Cobra water pump vs. 98 Cobra water pump
  250. 03 Cobra Vert exhaust help needed
