- Good writeup on 4V heads
- 93 Cobra computer swap??
- 97 Cobra making a loud humming on Accel
- head problems with 03/04 cobra?
- 1999 cobra valve cover help
- 96-02 camshaft specs
- mods for the modular
- Tire Size
- Magnaflow
- 99 cobra problems
- did you guys feel power difference with x pipe?
- 94 cobra wing led not working
- Please help fix the tick!
- Still not running right
- Anyone here have a used xxxxxxxxxxxxxx in black?
- 4.6L 32vavle question
- Oil Cooler HELL!
- When is it time to replace O2 sensors?
- 1999 cobra headers
- Which head and cam combo for 95 cobra?
- Ford Reman '03 Cobra Marauder
- NEED HELP IM A 5.0 GUY
- IRS Ball Joint boots
- 96-98 svt tranny swap
- strange noise
- Speedometer high by 12.676% ?
- O3 Cobra Compression test
- '95 Cobra R Interior
- To polish intake or not to polish that is my question?
- Cooling Problems
- alignment ?
- how do you replace turn signal bulb?
- need some help...
- X2 Ball Joint with 17"
- chamber/caster strut mount
- where to buy svt badge for trunk?
- 96 Cobra Problems
- NEW OWNER OF A 96 Cobra
- x pipe question
- 93 Cobra clutch
- Stainless bumper inserts question
- Tires for 96 Cobra--how wide?
- How To Correctly Adjust the clutch
- Stock 04 Cobra springs..
- threw a code
- Speedster tonneau
- New to me 04 cobra coupe
- injector size
- 03/04 Cobra suspension
- Trouble code
- 99 cobra help
- 30lb Injectors
- 93 Cobra Wheel Fitment?
- 23 psi with Kenne Bell
- 98 Cobra m/c... which port goes where?
- 2001 Cobra Eaton SC question here!
- Caster/Camber Plates
- 1999 cobra convertible exhaust help
- 99 Cobra ECU Question
- long tube upgrade
- cooling system ?
- just ordered my first mod! few questions
- Cobra modifications
- New Dyno Numbers thread
- 3650 shifting hard.
- 04 cobra shifting ? and 1/4 mi time
- Looking at buying an 03 cobra, ?'s
- 2.5" vs 3" cat back exhaust 03 Cobra
- full tune up on 97 cobra
- 01 Cobra Crank
- Diablosport predator tuning
- What length stage 8 bolts?
- 2003 - Key Question
- Rebuild T-45 versus T-56 conversion costs? Help please!!!
- Heaton torque specs?
- 03 Cobra - Loud pop then odd noise from motor
- 99 cobra bad clunking sound
- 04 Cobra Warranty Question
- Gauges
- Boost bypass
- MGW T-56 short throw
- Shifting hard????
- 1999 cobra PLUG PROBLEM
- Safe 03 power.
- 96-98 cobra mods
- i got a tough but simple speedcal ?
- E-brake light is on
- IRS Differential Fluid Change
- 03 cobra k/bell noise?
- Warranty work in Raleigh area - where go?
- suspension questions
- 96 cobra not running real well
- Bullitt vs. Cobra suspension question
- '03 Cobra power progression through the years...
- Anyone have experience with Steeda mufflers?
- my new 97 cobra
- 04 COBRA (compression questions)
- Oil cooler leak
- 04 Cobra has developed a strange whine.
- SCT Tuning/Traction Control
- Max tire
- Leaking gas tank seal
- Stock swaybar size?
- Just curious
- IRS Trac-Loc rebuild
- 96 Cobra with new T56 6 spd ZOOM!
- 03/04 Cobra (catted) Shorty H-Pipes
- octane question!
- Just got the Tokico DSpecs on
- Fluids
- BBK fuel pumps ok?
- Injector size?
- 96 Cobra + KB 2.1 = 400 rwhp?
- 2002 mac o/r h pipe on 98 cobra
- Stock PBR Claw or Brembo 4 pison calipers
- 5.4 block swap
- inner tie rod end help
- Supercharger Pulley Upgrade on 03-04 Cobra
- A Dragon is Born
- used 03/04 cobra stock or modded?
- Error code P0171
- supercharging 98?
- wiring up a bap?
- Cobra IRS wheel hop
- 2001 rear wheel width question
- Need help with 4-valve
- 97 to 98 computer difference
- brake rattle?
- Mach 1 vs Cobra sway bar.
- Squeaky Pullies?
- Drain gas if car's been sitting?
- Which turbo for my cobra?
- How much power can a stock 99 cobra handle?
- Trac Lok on an 03 Cobra
- forgive my ignorance, 98 cobra in the UK
- Which side is bank 1?
- Too wide of tires
- new exhaust equals little smoke???
- MIL still on after eliminators
- 1996 Cobra vert rear sway bar
- Demolet CAI questions
- pointers on h-pipe install???
- '94-95 vs. '96-98
- Oil on #3 and #4 plugs
- Afco
- Metco Lower control arms w/ relocation bracket- 96 cobra
- engine lull
- Hellion recommendations
- 98 32V V8 Overheating??
- 1997 Cobra mustang
- Mil eliminators????
- Clutch mods?
- 1999 Cobra plugs
- what h-pipe to get
- 97 cobra nitrous help
- the infamous 03 tick
- 04 cobra battery light
- superchargers and lightened flywheels?
- 31 SPLINE AXLES ?
- Interested in a 97-98 Cobra...
- A/C on 93 Cobra
- 96-98 cobra
- 97 Cobra header back exhaust
- Got to "LOVE" this 4.6l
- Alignment Specs
- 20 psi with 2.6 k/bell look .possible?
- 97 Cobra S/C upgrades???
- 96 Cobra darting around
- Reviving my baby
- will lightning s/c fit 96 cobra ??
- New Clutch
- need link ?
- 98 cobra upgrades what to do next????
- thinkin about getting a cobra, some questions
- 89 fox body solid swapped into 03 cobra...
- T-56 Tranny... How Tough Are They
- HELP ANYONE LOOK ?
- Re:PO 411 code
- Boost gauge doesnt work......need help please
- Anyone have a step-by-step to change brakes on 01' cobra?
- xcal2 on an 01 cobra
- Will low voltage cause problems?
- Silly cam question
- TPS adjustment?
- 1998 cobra will not start
- cobra heads
- help,I lost my key!!
- brake pads?
- 96 Cobra Rattle at start up
- coolant sending unit help!!!
- HELP!
- JLT Cobra Cold Air Intake Question?
- 98 Cobra: What is different about the fuel pump assembly from 96-97
- Coolant crossover tube.
- chipping paint
- SLP Loudmouth 1 question?
- Stock Injector Size on 96 Cobra?
- Good Northern Cal shop for suspension mods?
- Throw Out Bearing? Pressure Plate? Help?!
- AC not so AC any more... recharge?
- Wild Idea
- Can stock 03 cobra flywheel be resurfaced and used with new clutch?
- 03 Cobra stalling during deceleration
- T -56
- 96 Cobra pulley squeek problem
- 2003 wire diagrams?
- Newbie Rear Brake Problems
- SICK of my T45
- Fix Rattling Window
- 03 cobra
- good converter for c4 behind dohc
- how much timing to run?
- Flashes vs Chips
- imrc?
- 2.6LS or 2.6LH? KENNE BELL
- 96 4V Cooling
- Vortec for 97 Cobra
- pistons in a 93 cobra
- Tightening Koni yellow shocks
- 315's on a 96 Cobra
- Which Clutch?
- KB 2.2L - Worth it & How Much - U.M.
- cobra R hood wont close on 03 front bumper?
- 03 Cobra Rear-end swap
- Is this oil grade OK.
- how much power before stock 99 cobra injector are maxed?
- 99 cobra recall
- P1516 code
- Q.. 99 Cobra w/ 430's and a Vortech
- WHO HERE AS A 2.6L kennebell?
- brake help
- Best pulley commbo w/ heat exchanger?
- New block for 98 Cobra S/C
- 1997 106,000 miles-Potential IMRC Failure/Ports and Heads
- 98 Cobra smog pump
- Problems with going into 2nd gear
- More Progress On The Whipple Install!
- WHOS RUNNIN MICKEY THOMPSON ET STREETS?
- Bye Bye Eaton!
- 2004 Cobra Timing position?
- which and where to find an 03/04 rear driveshaft flange
- headlight adjustment
- Anyone every restore their stock rims?
- HELP!!! Cant figure out what to do.
- Transmission Problems!!!!
- KENNE BELL 2.6L QUESTION
- Couple quick questions
- Quick help needed on brakes
- X Pipe or H Pipe
- Can sohc short block off 2003 GT work with dohc Mach 1 engine?
