View Full Version : 4.6 Tech
- 1/8 NPT port ??
- Weird noise
- Tokico Illuminas vs Drag only Illuminas
- vortech v2-sq very loud?
- Catted H-Pipe
- Driver's side light going bad
- oil on plugs??
- Tech somewhere told me 87-93 shocks dont work on our cars
- 13" Brembo rotors - Min thickness
- Service Engine light on..
- Leaking headlights
- 03' GT..Need some help with wheels!!!!!
- Ford 70 mm Throttle Body
- Bad BAP or FRSP?
- Will a 2800 stall TC from a 03 GT work in a 98 GT
- slp lm1's need help.
- Newbie brake questions
- Belt Tensioner Bad?
- I paid over $1,000 to gain 23hp...Sound right to you?
- spring install/isolators?
- is this true?
- help with cutting for afm w/p1sc
- Will this fit???
- Racing Seats/Harnesses
- autometer fuel pressure gauge removal
- Need some help, car starts but dies immediately
- is this possible?
- Got TKO installed, new clutch, put squeaking noise - is it throw out bearing?
- 180* Tstat + Superchip
- Cruise cable adjustment
- Are Tokico's In My Future?
- Coil Pack Bolts, where to find them?
- Wiring help!!!
- PCM Fuse Keeps Blowing!
- MAF Sensor Cleaning?
- Tire Size with 18X9 Rims
- AIR CONDITION TROUBLESHOOT??
- Bumper Repair
- Clutch Pedal Vibration
- Adjustable Cam Gears...Which one's should I get?
- began the rebuild
- Eibach and vibrations
- 11" Clutch in a 00GT T45???
- Brake upgrade question
- DSS Main Support - worth the dough or Waste of money?
- Exhaust for a Mach1
- Installing 3.73 gears
- 8.8 rear end strength?
- Quick, need h-pipe to manifold exhaust nuts? What size/thread are they? 2002.
- Need some advice
- Horn problem
- fuel pump........
- Spec Stage 2 and Peddle Pressure
- Clicking sound when turning... what is it?
- I got some Q's regarding X-pipes.
- losse coolant
- cams are finally in, but wont idle!
- 96 Cobra overheat issue again
- Humming_Groaning Noise
- Re-use main studs on engine rebuild or get ARP???
- Weird misfire problem.
- Spark Plugs/gap
- What the heck is wrong with my new clutch?
- cluster glass scratches
- Fuse question!!
- Building an engine on a budget..
- upr upper control arms broke.
- Running only l/t headers..no exhaust?
- Throwing P0133 and P0153 after O/R prochamber install
- Oily short throw?
- Plenum question!!
- What to do for mods????
- question about a synchro
- tach stopped working, spun around
- 10.5 Wheel Question
- Will 2006-7 rims fit on my 2004?
- Can Someone Help!!!
- Need Ford Tech Help! ECU Question.
- New to the 4.6 Need some help!
- is my tranny slipping?
- Clutch Slipping?
- 97 GT stock speedo gear???
- What CAI?
- Got a used GT, Whats in it ?
- Need some advice on tuner
- Clutch problems
- Bad Tensioner?
- what are PI heads.
- Need help with plugs for supercharged 03 gt
- Possible wheel bearing??
- 2 connections behind driver side floor heat exit
- stock inlet tube+75mm TB
- Swapping from 2v to 4v....Need some input
- Help me diagnose my drag results.
- How do I get the headlight knob off (2002)
- PTI with COMP XE270 myth? Those considering this cam LOOK
- RPM Problem...
- Definative guide (2004 GT) trans temp and cooler install 4R70W
- Thud
- Tranny swap on a 01 GT
- X-Pipe hp gain question?
- TR-3650 to TKO 500/600 swap.
- JY source for PI heads?
- MGW shifter
- Help-Bassani X-pipe installed. Leak on Drivers side header flange.
- 1999-2004 4.6L SOHC engine pics please
- Whistling
- car shuts off randomly
- PYPES Exhaust
- How bad did I F*** this up?
- It sputters
- What sounds like an exhaust leak but isn't?
- car won't start when warmed up and hot outside
- fuel smell
- Car Wont Go Into Park Or 1st Gear
- PCV problem?
- 2002 alternator output help please!!!
- Cracked Intake Manifold
- Project revival
- stock rod
- Fuel injectors
- IRS Swap
- Engine Builders -> How to spot junk/quality internals?
- installing OEM front springs help please...
- 4R70W Buildup
- Fuse box diagram
- PI Intake Gasket
- Will BBK catted H pipe peice into the existing mac h?
- Lug Bolt Strippage
- Car Will NOT shut off!
- Buying Mustang GT with 98K Miles Maintenance ??'s
- Non Mustang Ford COP Engine Issue?
- should the vibration Damper be this hard to get off?
- Who makes the mach 1/bullit struts&shocks
- Headers.....
- Rim Size!!
- Xenon Head lights
- Mark 8?
- 4.6 Dohc Starting Point
- 4R70W Transmission Problem
- New Guy Here: Bolt on 4.6 Project. Please Help
- Urethane or Fiberglass Wing
- Installed New Intake, Now Ticking
- ac compressor whine
- can you throw a code with canned SCT tune?
- Should I upgrade my brakes, or just get fluid flushed and new pads?
- Comp Cams XE 270
- help with belt slip
- When do gears lose their advantage?
- trying to narrow down
- tuning software
- What could this be?
- If you lowered a 99 or 01 Cobra with H&R springs, Read This (pic)
- rear diff oil
- Oil puddling on valve cover near PCV?
- Spark plug change, little problem
- brake problem
- 1/2 second buzz under passenger side.
- can anyone help a stangirl
- Why won't the starter come off?!
- clutch or clutch cable???
- Transmission/x pipe Removal ?
- Need Help - Need a good Mustang Shop near Milwaukee Wisconsin
- Got a New Tune
- Header Install Question
- LCA Install...issue with parking brake cable and spring
- NEED HELP--updates on saleen supercharger install
- A/C vent selection broken
- Headers & Oil Use
- dual focus pumps question
- Gas smell
- Ordering Stroker Kit, Couple a questions.
- Transmission Not Shifting!!
- sputter at 3 grand??
- shocks and struts
- Does anyone have an Arizen seat bracket?
- 96-98 Mustang's, is there a "a/c delay relay?"
- GT long tubes/mid pipe combo fitment
- 4.10's in!!!
- Installing JLT...Need Assistance
- Are these codes related to this problem??
- Removing the PPRV
- Rounded top starter bolt!!
- Mustang passenger airbag?
- sct maf 2400
- Interior lights stopped working after WOT, no blown fuse..
- check engine light on but no codes
- 2000 Cobra R Wheel Center Caps
- MSD coils
- high pitched noise when gas pedal is depressed
- Wheel Center Cap Size?
- Squeak
- Help me out with what mods to purchase.. Patriot Heads + what?
- Center Wheel Caps?
- Car Has Weak Startup.
- Correct Transmission Fluid
- Cutting Stock Springs - Questions...
- Aluminum driveshaft???
- Should I buy a 96 GT with blown up motor???
- High idle with A/C on?
- Engine Tunning Anyone....?
- valve rattle
- my cobras compression.
- Cobra wheel center caps
- Bullitt swap T3650 to T56
- Cheap T3650?
- best subframe conectors?
- follower clearance?
- NEED DIRECTIONS ASAP
- Fuel Injectors
- race bypass valve
- valve rattle
- Intake Leaking water....
- Hows are these cams?
- No fuel Pressure.....
- Suspension Tips Anybody....??
- Electrolysis Leaking Radiator
- anyone know anything about windows?
- Has anyone had this problem with windnoise?
- changed iac...broke off bottom bolt
- Tick tick tick tick...
- Driveshaft Question
- Control Arm Torque Specs
- blend door
- Vibration problem
- Timing?
- starting problem on 2000 4.6
- alternative to roush side exhaust
- Car runs crappy when warm
- Window hits conv top
- Battery light comes on when revving high
- strange noise
- 97 5.4l 3v swap ONLY
- car wont start
- Used D1SC Question
- Rack and Pinion purchase
- Car dies on me at a complete stop?
- Help needed on check engine light codes
- 4.6 Replacement
- 4th gear issue
- Need Some Lowering Help
- Accufab
- Replacements Fuel Injectors
- Rack and Pinion
- opinion in which exhaust with mac l/t
- How Long do Upscale Shocks/Struts last?
- 98 GT questions...
- throtle sticking HELP
- GT500 brakes for us!!! How to get 14" brakes for less than a grand $$ ->
- Steeda shifter tight... HELP!!!
