View Full Version : 4.6 Tech
- Getting Pulleys, does the car need a retune
- Easy question CEL (x pipe)
- Brake Cable
- Converting '99 GT from auto to T-56: PCM Question
- Air Conditioner and Idle
- Snow Performance Boost Cooler 2 Meth Injection
- 3.73s=increase in MPG?
- Help...Fuel Pump Relay wire
- Going N/A No stones. Need adv
- Transmission problems (again - not clutch)
- JLT CAI rubbing on oil fill cap... resulting in oil leak?
- Help a classic guy with '04 GT bolt-ons...
- Come In: Gasket Prep and Bolt Prep for PI headswap needed!
- Any reason to get 180* t-stat over a stock t-stat for PI headswap?
- Any flow difference between PI exhaust manifold and non-PI exhaust manifold?
- NAPA 600-1819 Exhaust Manifold Stud Kit installation
- Car Dies in [R]
- main bearing bolts, cam bolts ??
- Battery Relocation Install Help
- Ticking During turning... help me!
- IAC??
- Someone has to know???
- Will 99 GT brakes fit 96GT??
- Heads and Cams help...
- best longtubes and x pipe combination?
- UPR K Member kit, any good?
- Coolant sensor issues.
- Need suspension advice...
- Port matched PI intake
- belt size with new s/c pulley
- Shorty Headers!
- it's go time
- Injectors on a 4v
- Aluminum DS question (PIC)
- alternator bracket?
- Timing chain being replaced..while its open...
- SRS air bag ??
- Just installed my cams...
- new heads..
- Plenum torque spec
- 4.6 vs 5.0 engine weights
- Fog lights on '03
- titanium retainers?
- Anyone swaped out the solid rear for IRS??
- I Know You Guys can figure it out
- Ceramic brakes squeak when warm?
- Please HELP! Which cam do you reccomend?
- Question about PI cams
- Anti-Theft problem?????
- Engine Lifting Brackets...
- NEED HELP ASAP
- Alignment Issues, Need Suggestions
- Spark plugs for PI'd '96
- help please....!?
- gear oil weight ?
- 2V to 4V
- Differential Size???
- I'm baaaaaacckkkkkk... Blew my head gasket
- plug choice
- Trick Flow track heat manifold...
- Car problems just got worse (ignition issues)
- burning clutch smell and noise from clutch help
- 400hp ideas?
- Need new shocks /w Eibach pro kit?
- Back fire
- trouble code p0320
- Lightning MAF- I searched...
- Need help removing CCRM
- Spark Plug pics
- kill switch for anti-theft?
- UPR Hood brace intall ??
- Is my clutch going out?
- Springs install day 2
- Throtle Body and Plenneum options
- shuts off
- COP Resistance
- Ford racing supercharger
- supercharger problem
- Pin connections for cig lighter?
- Caold air kit fitment.
- Worth my time?!
- MAC Ceramic Longtubes Installed!!
- Swapping 99 & up parts on a 98 GT Question
- Spring install problem
- Ring gap questions for stock bottom end with nitrous
- Help Crankshaft Sensor Circuit problem=wasting gas
- Quick answer needed!!! Swappable Parts?
- WTF possible pats problem?
- nitrous
- Cruise control problem
- Shocks, Struts and Spring install
- Help
- Saleen S.C. and Drive Train
- KC Clutch question, who screwed me?...provider or installer
- 04 bullitt tranny, what years will fit?
- Engine Block Decoding and Help
- Strange Rattling/Noise from X pipe
- supercharger fit questions...
- HELP! Not sure what to do! PLZ
- blower ?'s
- code 0720?
- Why is it important for a gauges ground lead to be near the sending unit?
- Transmission noise after changing shifter and fluid
- aftermarket headlight dispersion
- idles rough
- went to the dyno today...
- Sick and tired of KYB Shocks , struts
- Full tune up
- Ordering my new drivetrain stuff (Am I missing anything?)
- Noise after exhuast install HELP!
- to many cranks to start
- Aftermarket rockers & lifters a big deal, I guess?
- BLEED OR NOT?
- Vogtland Spring ??
- Cam Selection, please advise.....
- C&C Plates and still negative camber
- What oil weight?
- Driver's side window won't roll up
- I need help please dohc swap
- Planning an engine build. Advice?
- What happens when..
- Strut tower brace? need it or not?
- King Cobra
- Sputtering at Startup
- Help! My car will not start
- Rear end noise after MM LCA's install
- Help! What is she doing?
- Any difference in stock clutch between 96-98 & 99-00?
- My car started missing when its cold...ideas?
- coolant leat?
- Suspension install/Chassis bracing pics..
- Can a Ford Dealer Recalibrate Speedo?
- Damn Car issues
- Question about tuneup and gas mileage
- Rear Brake Help
- No throttle, the pedal is down.
- drilling out screw
- My differential cover is broke.
- PI Engine Swap
- silly shift knob question
- Tire Size
- Parking Brake Tension
- Those with HIDs (96-98) where did you mount the balasts
- replacing steering rack bushings...
- NGK Plugs- whats the deal here??
- Are my rotors ok?
- clicking sound after brake install?
- Please help..…Car won’t start!
- Dynotune for me?
- How to install a Vac-Boost Gauge by a complete N00b
- 96 markviii dohc to 97 gt sohc swap
- New Clutch?
- Is my IAC going?
- Supercharger pulley!!
- Where is PCV valve??
- Stainless Problems
- 8-bolt to 6-bolt flywheel swap
- Coolant in #4 Plug Hole
- Tuner guru's come on in...
- SPEEDO CALIBRATION
- dropped....
- Oil on spark plug
- P0190 code on Vortech '01 GT but running pig rich?
- Radiator fan almost caught fire!!!!
- Will these fit?
- Do you torque your spark plugs ??
- Car starts then dies?
- Theft Light! Can ONLY DRIVE @ WOT!
- I am so stupid - fuel line & fuel filter
- Brakes dont feel right!
- Nee to replace my clutch, what do you think about this clutch? - Discuss
- Cylinder's 4 and 8 not firing
- Accuracy of Auometer dash cluster
- 2k rattle, windshield wiper arm?
- ok so im an idiot
- Urethane Bushings
- what to do next???
- Super Charger Question!
- Best Spark Plugs for me??
- bad engine vibrations???
- valve spring suggestions
- Tensioner bolt torque spec?
- stock alternator rating
- Check out my new and improved Novi 2000 idler pulley brackets!
- Nitto Question
- UPR firewall adjuster,Triple Hook Quadrant
- Stage8 Header Bolts
- Anyone NOT running a "crossover" mid pipe?
- 01 GT Hood Scoop Broken
- muffler and spray 2000 gt
- Clutch getting replaced, and got some questions about clutch parts and replacement.
- Quick SCT XCAL2 question.
- Wheel Spacers
- spark plugs
- Fixed 2-3k rpm rattle
- throwing codes - O2?
- Mobil 1
- Flywheel Help
- Question about suspension...
- how bad did I screw up?
- Burning smell at WOT?
- T-45 spring return on TOB?
- Installing springs this weekend.
- Spark Plug Blew Out - Need Advice
- Flowmasters
- Ball Joint/ Tie-Rod End Write-Up?
- slp catted w/lt??
- How much of a PITA are LCA's to install?
- Help plz vortech guys car boging bad below 3k
- MGW Shifter Installed
- OE PCM Capabilities
- Center Exhaust
- Fuel Issues?? - Need Help
- flatspots under load with vortech
- i need help, have codes
- People with T3650's in their 96-98 Please Help
- Stupid Headlight
- will these tires fit.
- Will this wheel/tire combo fit?
- SCT Tuning\Logging guide
- Twin Turbo or Kenne Bell 2.6L
- Loud squeaking when clutch pushed in and warm
- Reputable remote street tuners?
- ignition??
- Installing MSD 8963 shift light in 00GT
- bassani midlengths
- Fuel pump or cam sensor?
- STD Horsepower??? 510 hp 454 ft/lbs
- Anyone have a Bullit Suspension Kit on a Convertible??
- Swapping a 2001 motor in a 96 mustang gt?
- 97 cobra motor to a 98 gt ?
- 2000 gt rear in a v-6 ?
- Mac CAI and Air temp sensor.
- Mobil 1 5w-20 Extended Performance
- To all the people who has the Old Prochamber
- Transmission leak need help
- purchased c/b and x pipe, what needed for install
- Swapping 8.8 with 3.73s frmo my 87 to my '04?
- High Idle/rev issue...
- How to get 60' time down?
- iac
- Creaking Noise..
- Ticking in rear end
- Motor Mounts?
- WHAT SIZE HEADERS
- Any tips/tricks for blower and longtube install
- i need some help from people who know how to make a fast cheap mustang
- Vortech V2 & Washers??!!
- Which mufflers to replace stock ones???
- tps
