View Full Version : 4.6 Tech
- 2004 GT - is the PCV valve ELECTRIC HEATED???
- Long tube question
- reset Computer
- Ok to spray before supercharger??
- Need Help with Gauges
- header / motor mount question
- Tick/Ping Sound
- Extremely odd knock/sound
- Question about lug nuts...
- Auto to MANUAL swap. Parts list and step by step instructions.
- Creaking Steering
- Tuner?
- Mystery Coolant leak
- Idle problem
- Changing to synthetic, weight reccomendations?
- Tensioner Pulley?
- AUTO to MANUAL HELP
- SN95 horse removal
- Blew out plug
- Dog Gonnit not again....
- help! faulty throw-out bearing
- Urethane steering bushings
- 99-04 4.6 Fuel Pump
- What diff fluid to use?
- Vortech Mini Race used as a BOV?
- what kinda Tranny fluid for T-56??
- !PROBLEM! Mustang won't idle
- New Engine Soon... Questions!
- Whats wrong with car tranny or clutch??
- Rough Shifting Feeling with the 5 Speed
- Rod knocking.? Cam tensioner.? HELP, I have a lot of questions...
- 03ghoststang help please
- Axleshaft length
- Rear axle tag
- What could cause this problem to happen with my Mach 1?
- Electrical problems
- JMS Velocity kit VS MPH Mongoose kit?
- Differential lube... what weight?
- wheel fitment
- exhaust leak
- stock tach accuracy
- More Suspension?
- BBK TB question.
- What is Wrong With My Transmission? (*VIDEO*)
- New here, have a couple questions
- Nitrous Timing
- will it fit?? s/c
- Headman LT Headers Feedback
- Gears
- Are all chip programmers the same?
- 97 4.6 overheated - misfires?
- 31 spline axles
- K member problems
- Anybody know what this means....
- HELP!!!
- Removal of stock H-pipe...yikes!!!
- convert to manual parts list
- Idle issue after plenum/tb install
- not sure if its my clutch or tranny
- odometer question
- IAC question
- Need help withs Mods. Head Porting/Bullit Intake
- Anyones BBK Plenum NOT fit right??
- max boost
- PCV?
- Adding a s/c
- Does this bar make this K-Member stronger or weaker?
- Alternator?
- wideband set up?
- suspesion question
- Exhaust need your expertice!
- Tranny swap?
- Help! auto tranny problem late 1-2 shift
- rear end howl
- RPM Questions
- Help Broken Steeda Shifter Pivot Shaft
- What are the symptoms of a bad tps?
- wanna remove my rear wing and emblems need some info
- Electrical Problem
- release fork spring noise? TOO MUCH TENSION ON CLUTCH CABLE? DANGER? SQUEAK!!?
- Engine Bone Dry - No Oil, Coolant
- Spring install using a spring compressor.
- T56 questions
- Got My Car Dyno'd
- did anyone ever do this before
- Predator Programing ?
- Forgot Bumper Foam
- B&M Hammer Shifter
- PI to NPI adaptor plates
- tranny problem or too light of a shift, shift kit maybe.
- Clutch feels odd
- novi 2000 eating belts?
- dry cell battery+cold weather
- What is this sensor? Trans leak.
- Too Much End Play?
- 15x8 drag wheel back spacing
- Turning a 4.6 into a 5.4
- Upper and lower control arms
- removing head studs
- Do I need Cam Gear Kit.
- Clutch is gone...need a new one, suggestions?
- Lincoln Mark VIII
- A Strange Noise thread
- How hard is it to install LCA's and a Panhard bar?
- Car wont stay running from a Cold STart???
- Tranny Brake.....
- Difference btw Small and Big Block??
- rev limiter
- Somethings gotta be wrong
- Newbee question on Autometer gauges
- 97 Cobra Engine Question
- 97 Cobra Engine question
- how to install gears.
- What harm could gear whine do?
- .030 over, too much?
- wierd swaying while turning
- What to Do??
- Starter heat shields for longtubes?
- CHECK ENGINE light started blinking
- 02 GT Brake upgrade recommendations
- Recommend Clutch Please?
- Clutch difference b/w 02 and 04
- MISSING ANYTHING IN S/C MOTOR BUILD?
- Brake conversion
- Whats the difference in plenums?
- High Rev
- Pulleys what is the difference
- Need to change Mid-Pipe with Basssani Headers?????
- Stalling problem?
- service engine light ?
- i think i have a cat conv problem
- Rear end shake
- 2002 Mustang GT Cobra Engine Swap
- Temp gauge
- Passenger Airbag Cover?
- 98 gt head/trans questions
- Problems fitting a novi 2000 to 96 gt.... please help :)
- use diodes for factory keyless enrty? when adding aftermarket alarm?
- 97 mustang no spark
- How are Patriot Heads?
- clutch adjustment problems
- Magnapack Exhaust for Mach 1
- quick electrical question
- GT vs. Mach 1 fuel pump?
- My key is stuck, HELP ASAP
- Mysterious PROBLEM for 98 Gt
- Redline Tuning Hood-Struts
- oil filter relocation kit?? for my 98 Gt?
- help, engine...
- exhaust leak
- sticky front brakes
- STALLS AT PART THROTTLE
- Thinking bout the switch Petro to Syn oil
- prolly a dumb question
- Changed my T-fluid and Greased the TO (PICS)
- got 2001 auto mustang gt need help wit performance
- Tech Article for Early SN95 Spring install
- Return tranny line
- bushing help.
- Bellhousing Bolts
- Best oil and filter.
- Programmer Help.
- Remote Start....on a 5 speed
- UPR coilovers
- Gas PUMP ISSUE NEED HELP
- Spring Difference: Convertible vs Coupe
- Hesitation to start?
- Compression to high?
- what should i do......
- How hard would it be to put a manual in my 4r70w?
- 3650 Fluid Type, amount ...additive
- Cobra Brake install
- VT Engine Break In
- Traction Control
- Anyone ever use ATF fluid in place of PS fluid?
- Trouble replacing steering rack bushing
- Off-set bushings steering rack
- EGR gasket
- Window Switch
- my bullit intake exploded on the dyno today...
- LUCAS OIL, TRANS and ENGINE
- Blower ?'s
- supercharger with high compression????
- replacing battery
- Rebuild Time
- Where to buy mustang turbo? and how much different is the install?
- Looking for Beefy engine part specs..
- Battery not charging?
- Header power gains
- Stock cable too short for Steeda D-hook quadrant
- LCA questions???
- Opinions on Centerforce Duel Friction?
- Back Fire on Start?
- broke the HB bolt
- Christmas day gauge install disaster! :mad:
- I need some intake help ASAP!!
- Can I really trust a Zex N2O management unit
- I think my 96 GT has a bad trans.. Whats in it?
- How To: Change Your Cluster to Blue L.E.D.s/Incandescent bulbs for $8
- sepentine belt problems..any input appreciated
- Coolant in Cylinder Heads and No Compression
- Car will not stay running..
- Difference in tremec 3550, 3650,
- New Pro Street/Strip 4STB-E --w/EOD & L/U Transmission
- tuning svo head combo
- What's a good suspension setup?
- Dr. Gas X pipe
- Question on Pulley Size
- What Would I Get Out Of This?
- Best Tire in Cool Weather for Dry Launching Traction
- 98 Mustang GT - Starting/Running Problem???
- Can I Paint my Zex Control Box?
- Wet or Dry???
- School us on engines...
- will useing a fuel pump at its max duty cycle
- HELP with catback install
- spring isolators
- P1405 Code, Need assistance please
- best mass air
- Nitrous Questions??
- t45 - hard to shift into gears
- shifter vibration
- Just wanted to let everyone know that the +1 clutch mod on the trac loc kicks A$$!
- t56 question
- transmission help
- VPWR??
- Adjust TPS to fix throttle hang?
- pop/click noise from serpentine belt 02 GT Auto
- Adjusting the E-Brake
- 5spd trans problem
- What is the usual backspacing 17 x 10.5 rims
- Blew my steering rack!
- Oil Cooler, use tranny cooler?
- Carbon buildup or bad tune?
- Long tube vs. short tube headers
- sticky door lock
- 8 rib conversion
- Ford OBD Trouble Codes
- Need help asap
- Lean Cylinder and Long Tubes *Pictures*
- Headers and Exhaust?
- Automatic Trans, slap off the line
- Just bought a shortblock. . .where to go from here
- engine rebuilding ideas and suggestions
- Messed up my alarm/remote entry.
- Possible lean Condition
- 03 Cobra Eaton on a 2V
- Professional products throttlebody
- VT Shortblock and Cam Question
- Breaking in new SPEC clutch - having issues.
