View Full Version : 4.6 Tech
- Brake Swapping
- supercharger question and 4.10's w/6 speed
- Cobra top vs. GT top ?
- Questions about changing/charging my AC..
- Is the stock tachometer really inaccurate?
- cracked intake....
- charge or pi?
- 05-06 rear into a 96
- Fixed everything and still leaks
- Can you ice down a KB?
- Front brake pad recommendations???
- Hesitation on startup
- prob a stupid ques....but confused..
- messed up rear end
- Stock cable & aftermarket quadrant adjustment
- Mac question
- Installing Brothers Speed Cal
- will i need a new BPV?
- Diablosport
- 305/35/18 555R on a 9.5" Rim?
- shift light
- need a new clutch but im on a budget
- What is this?? Why Leaking??
- What gains to expect with pi intake
- A/C Condensation Problem
- High-flow cat X-pipe or O/R?
- Front end noise?
- PLEASE HELP ME
- What are the tell-tale symptons of a worn clutch?
- finally got an X pipe
- what tires to get
- Rebuilding Transmission t45
- Changing diff fluid
- brakes question
- port job on aluminmum intake manifold??
- 180 deg. thermostat direction...
- 2v minor mods ?
- winter tune supercharger
- A few Questions....
- Another Stalling Question...
- Question about X-pipe install?
- Intake took a crap...
- Engine ticking noise *vid*
- Educate me on 4.6L turbo systems
- Idling problems
- Big Air 90mm MAF Meter BA-2400
- getting slight power flucuation with votech
- Clunk sound.
- How to install Headilghts (bulbs)??
- Do you have a clutch freeplay correction kit?
- So why are my foglights blowing out??
- experience?
- 4.10s or 4.56s?
- bullit versus PI?!?!?
- What do you think this set up will make
- IT HAS BEGUN! My custom TT sutup thread.
- Electrical Problems?
- installing 5" tach...help
- Guages don't fit in Speed of Sound Pillar?! *pics*
- help me get this whats missing
- More Fuel, More Power?
- cams
- Quick question about MAF
- Lug Pattern
- Header Gasket Replacement???
- Driver's side door lock and the cruise control
- bullit heads...
- cold air intake
- Please help with 1700 rpm miss!
- DS vibration after installing MM LCA's...
- MM XD LCA's First impressions
- Explorer Rear on a Stang?
- Do ANY 17" wheels work with the 2000 R Brembo brake kit??
- Track-Lok versus other Brands
- Axle Question
- how hot is too hot?
- 02 stang w/ p1sc questions
- Power from the Saleen Series IV S/C
- Trans problem or clutch problem, need help ASAP
- cheapest place to buy stock replacement injectors?
- What else should I do
- Backfire on idle change
- Online tuners
- Compare the Granatelli c.o.p.'s with Accel's
- ABS light on/off
- E Brake??
- Transmission Problems after long tube install?
- alarm installed...FUEL PUMP NOT WORKING!
- Odd problem
- Trandmission noise......
- Cruise control
- Is it normal for the car to stink after adding H pipe and Cat back?
- Cruise control cable install
- Idle issue - Side exit exhaust
- CEL P0174 & P0171
- oil pressure problem
- Cold air intake
- magnaflow or mac?
- Adjusting air/fuel ratio?
- Sticks in reverse every now and then...what causes that?
- oil in my superchargers intake
- Ways of getting more power.
- Engine knock after oil change start-up...is this normal???
- how to gap spark plugs?
- Tuning and temp/humidity
- cutting front springs
- Does X pipe void warranty?
- Quick Transmission Fluid Change Questions
- ROD KNOCK.......NEED HELP
- Best Tuner for 4.6?
- clutch squeak
- Need Catted H pipe help doing install Now
- weird wheel hop (?) issue
- 1996 Mustang GT Trouble Codes 0171&0174
- Keep going thru cats
- can new o2 sensors hurt motor?
- Really need your help & advice.
- new idea..cams
- long tube headers and a tune
- TYPHOON
- elec water pump questions
- clutch pedal adjustment
- 1994 Mustang (V6) Roller Project
- spark plugs ? reg vs plat
- Threw some simple codes..Suggestions?
- Saleen supercharger and hood clearance
- underdrive pulley question?
- need headers like yesterday!!!!HELP!!
- stock Tach problems...
- Fuel pressure rising at idle?
- Will this break my axles or differential???
- o/r H vs. o/r PH...which is louder?
- Blueovalindustries clear light set
- Caster/Camber Plates?
- clanking noise at idle
- KYB's Fitment issues!
- lowered car making noise
- Power Loss from an exhaust leak?
- Advice on cams
- Header replacement question
- AC question
- diff and tranny fluid ?s
- fuel pressure reading ?????????
- NPI Head Milling
- Cleaning the IAC & MAF questions
- Idle way too high
- Quiet Catback Take 2.....
- New Jersey Emissions
- Need advice on rear end build
- Battery Gauge Jumps Around
- 96GT heads cam intake
- Well I thought they fixed the tranny...
- Would i need a re-tune?
- dyno results SUCKED....so pissed.....everyone with forced induction....please get in
- Best Mods for staying N/A
- FRPP springs
- What brand of air intake is the best?
- Bleeding the Brakes
- New Shifter Question
- Throttle sticking
- Kenne Bell 1.7L ?
- Diff and gears
- mechanical to electrical speedo switch
- Synthetic Oil choice for Rear end, T56 Tranny, and Engine
- 03 Cobra or SC the 02GT???
- Timing question
- newbie question, please help!
- Does anyone have a guide for H pipe install on a 99 GT?
- Where is the mileage stored?
- 03-04 Chrome SVT Cobra Wheel
- Very low level of tech thread
- 2006 4.6L GT in my 69 mustang
- looking for info on pi heads and blowers
- Extended balljoints question - calling all w/ Steeda X2s or equiv.
- Steeda T/A question??
- 75mm Accufab throttle body/plenum and fuel consumption MPG
- Q's for Tuners or Ford Techs
- cams
- Truth About CAI Systems
- Output speed sensor circuit malfunction
- What size wrench for oil pan plug???
- Calling all Predator owners with auto trans...
- V6 to Windsor swap? Kmember etc...
- Question about PI engine swap
- Mounting Mr. freeze...
- 03 Cobra PCM shut down!
- Brembo Brake upgrade
- trouble code
- stroker kit??
- Cam experts inside pls
- Who has FRPP C Springs?
- Considering 96 Cobra Vert
- Please help fast...
- Help with prepping GT for tune...
- Best Exaust
- MY IC CAME IN!!! PICS! And a little tech info :)
- Suspension Setup
- Anyone Identify this engine noise?
- Speed Sensor Outlet Malfunction
- My bad experience with PATRIOT heads
- T3650 Noises
- Supercharger and fuel system
- next big install
- tranny pin out.
- What size TB for my car?
- HOW CAN I IDENTIFY A PI INTAKE?
- QUICK! Which Royal Purple Fluid do i use in my tranny...?
- How much drop should I expect?
- Exhaust noise, normal?
- Clutch Pedal Play
- KDW's
- Supercharger
- 15" wheels on '01 GT?
- Supercharger and underdrive pulley's
- Problems at the track
- Door lock actuator install
- Ford C springs Advise, What Shocks Struts, TOM???
- Replace the door lock actuator on a 96 GT
- bullit mach 1 brake upgrade
- Transmission Heat
- help with rear control arms
- difference between 18x9 and 18x10?
- noticable gains?
- Universals
- Got some codes for you guys.
- Mechanical or Electrical Gauges???
- tap,tap,tap goes the tranny
- Car stalled twice under semi hard braking
- Grand Prix question
- Still Jerking
- How Much Gear Oil To Use?
- Changing Diff Fluid
- gear debate
- Pinging
- Air/fuel ratio datalog
- Preventive
- 03 cobra t56 in 98 GT
- pypes catback
- SLP X pipe HANGS WAY LOW??!! Why??!?>
- FRPP catback questions..
- I have gaps at the top window on both windows...common problem?
- Need some advice with my gear install...
- vacuum gauge installation
- mm fl SFC install question
- Do I need to replace bearings on gear install ?
- fluctuating RPM's with AC on
- Trans Question
- Blew my intake apart last night
