View Full Version : 4.6 Tech
- 98 gt...bx cat back install
- Steeda Sport Shifter..?
- Got your Horse Power.. Fuel Injector Formula
- automatic transmission controller
- Do I really need a tuner with these mods?
- spark plug q
- '04 pulley install q?
- Dyno numbers w/ cams :)
- So should I use ATF or something else in my GT?
- 4.6 2v (non pi) to 4.6 3v swap
- TKO 500 peolple come in please shifter advice
- Cold start noise
- just finish.......
- Power Window Switch Issue
- Power steering pressure hose removal
- I got a CEL need some help
- desperately need inputs on clearance
- Can I change my header gaskets without dropping the K-member?
- What causes a car to sit uneven???
- T45 Problems...
- Longtubes with Magnaflow o/r X
- noise
- need help from my fellow engine gods
- Diablosport Predator question
- exhaust MOST HP
- STINGERS owners please come in.......
- ROTOR HELP NEEDED
- Coolant drain
- WINDOW MOTOR ISSUES
- Alignment at home? (Gauges and such)
- mach1 motor in a ...
- Best intake plenum/TB combo?
- MPH Stage 3 Heads
- Electrical Issues.
- 2000 GT intake manifold question.
- Partshopper Easter Sale starts now!
- donut gasket between hpipe and pass mani.. which way does it face????
- Not the "run-of-the-mill" CAI question
- throttle cable.....?
- How to tell Windsor or Romeo?
- Vibration after gears replaced
- What Should I Do After The Heads?
- What else is needed???
- low gas light question
- Need help, clutch, tranny, flywheel....
- Cams/springs and heads. . .
- Mustang Smoking
- Stripped a "Coil On Plug" Bolt while changing spark plugs (Part # for the bolt??)
- How to change oil on Manual Transmission ?
- Aftercooler gains?
- What pistons, rods, and crank to use?
- Grill Delete Directions ?
- Replacing a 4.6, cost?
- Magnaflow O/R X hissing
- Oil leaking
- will a 95 gt hood latch work for 00 gt?
- question about shorty headers
- When Do I Go To 24lbs Injectors?
- need a good 99 cobra S/C combo.
- rear end noise
- Friction modifier with synthetic gear oil?
- Help - Rusted Rotors - Brembo's no less
- Removing heads - any precautions?
- swapping 5 spd man tranny with 4 spd auto
- Paint Matching For Tinted Clearcoats
- LT header choices
- head swap articles
- Yet Another Programmer question...Diablo Sport with my mods
- will 315/35/18s fit on 18x10 saleens on a 96 saleen ?
- Drag launch
- Where to buy rotors & Pads?
- My BOV is stuck open.. :(
- Dyno Differences Between 4.10, 3.73, and 3.27?
- Need Help!
- I have a '95 T-Bird Swapping in '99 newer 4.6
- Idle all over the place
- SLP line lock installed! *PICS*
- 02 GT: Front wheel bearings at 30,000 miles?
- Engine Light: EGR Excessive Flow
- Spark plug help!
- Need help ASAP!
- Replacement Tranny?
- Driveshaft vibration?
- 97GT still pings like a bastard
- Front tire wear.
- BBK or Accufab?
- brake flush question
- direct port nitrous injector sizes
- heater/ac motor removal?
- info on head swap
- Tranny Swaps for a 1996 GT
- magnapacks or borla stingers
- HP question for 2001 Cobra
- Supercharger gauges on an SN-95 vert.
- Just secured $6,000 for a new KB SC.... questions...
- 96-98 Cobra speedo in a 96 GT
- tokico d-specs or bilsteins?
- Idle Sticking ? ?
- Diablosport Predator Owners -help-
- Tremec warranty?
- belt problems
- 4.6 stroker boosted 20psi
- anyone have MAC Pro Dumps
- New exhaust system help
- Which 275/40/17 do you recommend (choices inside)
- Anyone running BBK ceramic coated Long tubes, please come in..
- Wanna go Wingless
- simple way to 300rwhp
- Deciding on fuel pumps
- a few pinion angle questions (kinda)
- keyless entry location
- no locks,radio,mirrors,cluster lights ect. help please?
- how does it react?
- New engine break in time
- Use IRCM's?
- Trouble passing emissions HELP NEEDED!!
- First time here.
- Best bang for the buck mod?
- BF Goodrich DR2 vs. Nitto 555R
- Exhaust system ques
- Free Mods...?
- How the hell do I get to the plugs
- windshield wiper turns on by itself
- Clutch question
- stock maf limit/tweecer users???
- interior clunk
- does anyone have the upr adj. shifter handle?
- Need Cam Advise
- stumbles and dies
- Road race tires
- what to expect?
- Intake spacer they do anything?
- Can I run my dry kit off my Lt1 TA on my 01 GT?
- Which transmission?
- Bleeding cooling system after flush ( very important)
- Rolling Fenders
- 01 Mustang Door Hinge
- Replacement inner boot?
- Go it done MMR 900 shortblock
- Rear Wheel/Tire size and spacers
- coolant flush help
- Replacing the rack and pinion:
- 450 RWHP sound right???
- SPEND MY MONEY!!! About $1000 to spend what should I get?
- Update on LT's and x pipe and P0174
- engine protectant
- Doing Mongoose Install...Need help
- Stripped Wheel Lock Lug Nuts
- wideband a/f question
- Tuner ?
- Seat problem
- A nitrous question for you guys...
- CC plate install (MM) question
- Tie rods and end links
- shift kit
- Aftermarket Headlights....PLS COME IN
- spray
- Maintenance to do while doing PI headswap
- SES light on - fuse 8 blown?
- Struts and no Shocks?
- Tranny Noise?
- Light question, and tranny fluid question.
- Brake light comes on... low fluid?
- Upgrading from AOD to 5 Speed on a Conv.
- Alignment specs- toe problems
- Mid pipe?
- Gear Break in Period
- Need help please with wiring!
- Powerdyne supercharger
- Tie rod end question
- Charging help?
- Cutting Cats off Stock H-pipe
- Warping dashboard?
- What cams should i get?
- 390rwhp = ? 1/4
- MMR shortblock.. or something else?
- trans swap help needed... aode to t45.
- [tranny choices] what do you think
- Royal Purple
- BULLIT Intake Manifold
- NOS QUESTION
- rear brake install problems
- Can i use slicks on a stock auto GT?
- aluminum flywheel?
- Wideband and A/F bung location on X-pipe
- Replacing rubber window trim at top of door
- How to shed 100lbs?
- Oil capacity... two different answers.
- stock trans any good?
- Check engine light on??? svttech chime in please
- Tokico Ilummina's or D-Spec's?
- tranny question...
- Centerforce clutch question
- 02 GT....dies when coming to a stop with a/c on
- Passenger airbag switch for 97 GT
- Clutch problem
- PI HEAD Q
- speedcal or SCT II???
- gears and snow bad mix??
- Quote-UnQuote BEST CAI?
- oddly quiet...
- Fuel pressure ?
- Engine code p0300, p0303,p0304
- Flywheel question
- Which clutch for my car ...!!!!!!!!!!
- nitrous fuel pressure
- tire mounting problem
- 2.5"
- JBA Catback for 2V GT
- Gear Reflash
- FINALLY got a Mustang, now need some maintenance tips.
- Describe the changes you felt after installing aftermarket lower control arms.
- Timing pics please give advice.
- 96-98 Stock GT Trannys
- Transmission Help!
- wheel spacer question
- shaker hood scoop???
- Kenny Bell blower, plz advice
- Clutch chattering and squeaking
- 98 GT Magnaflow Xpipe fitment on a 99Cobra
- Advice on KYB AGX adjustable shocks
- anyone done the MRT hood struts?
- Clutch Problems??
- How much are HCUs?
- 351W swap into 96-98
- Kicking It
- does your slotted/cross drilled/dimpled rotors soud like this?
- my 97 GT project...wiring question
- 99+ heads and intake on 97 4.6....
- Transmission Rebuilt vs. Change
- Any one have a KarKraft shaker AND mods?
- Spec stage 2 6k+RPM
- Traction control won't turn on.
- wheres the blower motor for HVAC on 99+ cars?
- NEED ELECTRICAL HELP
- Dry nitrous kit for a 96 Cobra
- trans?
- oil leaking from PCV
- MT ET Street Radials??????
- 00 GT will not change to 2nd gear
- Trac Lok is acting up
- Awesom! My lower intake is cracked! Yay
- weird sound when I give it gas...need advice
- Aluminum drive shaft is installed....
- Tranny swap: 5spd manual(TR3650) to automatic(4r70w) swap
- Thermostat Question
- Those With 99-01 Cobra Bumper, Question...
- Well it finally cracked
- How To REMOVE Ford Emblem, Trunk?
- Misfire question
