View Full Version : 4.6 Tech
- tune , and pinging !!?? why
- would this combo work for 600rwhp?
- rear caliper question
- Throttle body spacer??
- Question about stripped header bolt?
- P053- what is it?/Torque specs for intake plenum
- Shock Question
- What causes lean and rich out of the same bank
- Timing chain tensioner issue/oil pump?
- gears on automatic with no programmer?
- mil's
- Wheel weight choices
- Quietest Midpipe / Headers?
- Diablo or get 4:10 installed
- Aluminum Steering Rack Bushing Question
- Do I need a new intake?
- Should I buy hypertech programmer for $200?
- Please help fellow stanger.
- headers.......need help
- Exhaust Install Questions
- part numbers
- Possible PCV problem and a misfire
- Eibach springs?!?!?!
- Trak Loc Rebuild
- Do Cats Go Bad If Not Used?
- LTs vs. Mid-Length
- Back right tire likes to squek!
- Blew a fuse but I don't know where it is!
- Ethanol blended fuel effects?
- intake manifold warranty ?
- Valve Chatter
- Afternoon clanking noise
- more ejecting spark plug drama....
- VT Stage 2 Cams (emissions)
- Smoking problem?
- Stupid Compressor
- Weird noise/squeek from engine bay
- p&p pi heads or patriot stage 2's?
- 03/04 cobra mid pipes work on our 99-04 gt???
- Installed my Accufab 75mm Throttle body and Plenum Today!
- Did I blow it?
- Convertible owners
- SES light
- is this carrier any good??
- tires and rims
- Caster/camber ?
- trying to install factory hood scoop on 99 gt
- Exhaust Question/HP Estimate
- Fuel Tank Equivalency Between 1996-1998?
- Exhaust Install
- Paint question, help ASAP is appreciated!
- Whats the biggest drop you can get out of springs
- Intake problems?
- Question about turn signal relay
- Ok...Whats the Deal?
- GT Sparkplugs
- help with my project 2001 saleen s281
- plez help very bad vibration
- Question about a transmission swap
- Which clutch with 400rwhp?
- What size O/R X?
- Gas Gauge Assistance?
- Stage 1 cams, VT or Comp Cams
- What should I get...LCA's, MM FL SFC's, or X-pipe?
- O2 extensions w/ LT's??
- x pipe draggin!!
- Underdrive Question
- Gained 25rwhp and 3rwtq at peak from cam swap
- Does this mean I have a "chip?" Found this while looking under the hood.
- Long Tube Header Question?
- Right price
- Need some advice on compression
- bout time to do some maintenence, need some help
- Why not buy 87-95 Alum. DS and swap yoke?
- gears being swapped next friday...what should I do while I'm in there?
- Need serious opinions/help with PI intake gasget/swap stuff. please read!
- What fluid for the rear end of an 01 GT?
- Did I put my O2 sensors back in correctly? Blue/Left Purple/Right
- Ram Air
- How to tell if I did the MIL Elim right.
- Very close to buying a 6psi non-ic KB
- SLP Header inspection/ What to look for?
- Pintle cap question
- tps help
- stupid ? about o/r x-pipe
- Engine tick
- Vacuum Gauge Question
- Plenum spacer and EGR tube
- a/f ratio question.
- header ?
- AMSOil remote dual
- Wheel Slippage?
- 98 dohc heads on 03 sohc engine?
- Diablo Delta Chips for $100...Worth it?
- transmission fluild
- Throttle body....intake plenum
- Anyone compare difference b/w Cobra R vs Cobra brakes
- 96-96/99-04 4.6 Plug Wire Interchange
- Gains from TB on Cobra?
- stupid bulb
- Transmission ?
- LCA install more than I expected
- Turn signals, hazards, and brake lights not working..
- Gear Install Kits
- 99 GT Front Bumper Replacement
- CAMS??
- gatorback belt??
- mods
- 4v heads on GT block?
- Whelp, she made 349.9 / 348.9 at the wheels
- a weird noise after installing a mac o/r h pipe
- Shortie install tips
- Xcal 2..One Word:WOW..bu tneed help.
- Those with Saleen Front bumper, please read
- Start/idle issues
- Those with 99-01 Cobra Bumper on GT, HELP!
- Ordered Panhard Bar!
- Alum Flywheel
- Whos got a stroker/motor swap?
- Time to replace PCV?
- Tire size/brand choice, opinions needed.
- Engine Running Poorly
- fuse blows in reverse
- Torque Converter ? T-bird not stang Please help
- supercharger oil weight?
- BRAKE CALIPERS?
- Clearance Issues with 99-04 Bassani Cat-Back
- Engine Knock, need advice
- Autometer Air/fuel guage O2 sensor input wire??
- Couple of tire questions
- New Dyno #s!
- 373 gears, PI parts, dailey driver and petrol prices!
- T-56 to replace T-45 in 98 GT ???
- Cam Keeper Question
- squeak from rear
- manual to auto swap help
- C & L with strut tower brace...
- Interior Question
- Vortech is installed!
- Fixing heater core hose pipe on Intake manifold
- 99-04 Maximum Motorsports Control Arms
- Brake Light
- When do you know your cats are bad
- Reichard Racing intake manifold
- will these wheels work?
- P&P Head Question
- Bassani Cat-back with UPR X or Dr. Gas?
- Tokico Blues are installed
- need opinions on block rebuild
- LT's, which ones? Why?
- Buzz sound when car idles...
- tranny question
- Gauge Pods?
- Vortech with P51 VS KB
- This is important, You have less than 3 weeks
- how much can a stock mach 1 take????
- 2nd to 3rd shift transmisson whining?
- safc 2
- kenne bell boost a pump
- That much boost for not much $$$???
- bassani mid lenths or hooker l/t?
- Clutch Question for the Experts
- 03-04 Cobra Hood fitment?
- Nitto DR tire psi ?'s
- Saleen wheels causing squeaking brakes, didn't someone else have this?
- Stock flow numbers?
- Serious Cam questions
- Upgrading to Cobra Calibers and rotors
- 4.10 not worth it!!!
- what series autolite??
- Strut Install Question/Help.
- (ABS) light?
- Rear Shock Question
- Custom gauge install on 2000 GT - where CD player goes
- Header recommendation... W/ VT Stg 1 N/A Cams
- Any sn95's running 275/40-17 on 10.5 cobra r's on the Rear
- Engine problems please help!!
- Nitto 555R vs. BFG DR's
- lowering the car
- BBK X-pipe
- Got my SLP line lock installed!
- Magnaflow or Magnapack?
- how do i remove the fuel line at the fuel rail?
- squeaking coming from front end
- Kenne Bell 2.2L Question
- recommended maint.
- Flowtech on auto GT?????????
- Stage 1 Head Swap
- Mass Air/Tune Question
- 2001 GT Alarm Problems
- Quick X pipe question
- Aftermarket Clutch/Quadrant Users, come on in...
- Electrical Problem: Lost horn and key/headlight on warning chimes
- 03-04 Cobra parts
- plug question part 2
- Ok to cut flex hose?
- Automatics- Is a 2nd gear boost possible?
- Change dashpot settings to drop rpm's faster
- boost question
- K-MEMBER ISSUE!!
- TSB for TieRod Ends...Anyone have a copy?
- BRAKE PROBLEM--HELP PLEASE!!
- Auto Transmission Problems
- Crower Cams for 2v, 3v, & 4v....
- PI swap compression question
- knocking noise from motor
- 4 valve heads
- Downshift points
- Threw a code, P0190
- obdII quest?
- Anyone running a meziere electric h2o pump?
- Caster/Camber - Alignment?
- Help me decide on suspension/rear end...
- Rear Seat Delete Kit
- p1443 code ???
- Installed Throttle Body/Plenum!!!!
- Tighten up the bottem end?
- overrevving
- Catback Opinions
- TUNER-which one should I get
- Does Mobil 1 oil go bad?
- Convertible top replacing PROBLEM!
- TCI Torque Converter
- Methanol Injection?
- Problem with factory pulley rubbing on ATI P1SC housing
- Best way to go on brakes?
- 03 Cobra blower on 99
- Oil temp gauge
- Steeda alternator pulley rubs
- What tires should i get?
- TRI-AX PROBLEM!
- Maximum Motorsport Konig Maxxim Wonder Wheel
- Drag Wheels/Tires Info
- 2001 GT to 2003 Cobra Front Bumper -> Foglight Harness?
- which oil do you use. I am debating
- Surging in first gear
- Howling sound form the motor
- P1445 Code Help please
- shocks and struts
- Threw a plug!!!!!
- wheel stud / lug nut question
- House Ported P.I. Heads
- Fuel pump ?
- Making Brembo EVO Calipers Fit a Stang
- Tune Needed For Long Tubes?
- 99-04 Cat-back on a 98
- Water Temp
- Too Tune or not to Tune, that is the question..
- LCA's any good?
- What size/brand wheels and tires should I get?
