PDA
View Full Version : 4.6 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 [53] 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175
  1. I need more Power
  2. 01 GT auto tranny in a 97 GT?
  3. What Size MAF?
  4. QUICK! Give me a rundown!
  5. what do i have?
  6. 10.5 bullit wheels matching the 02 bullit wheels?
  7. Replacing gas tank filler neck gromet..
  8. fuel system cleaner on supercharged GT(rough idle)
  9. Some questions for you pros!
  10. Squeaky Clutch
  11. Ring&pinion install
  12. I keep getting the CEL
  13. California Emissions Question - Can I use parts with different EO numbers?
  14. Eibach drag springs
  15. Which LCA's?
  16. 96 GT ecu tuner question
  17. rub on 2 inch?
  18. h-pipe question
  19. MAF!!!
  20. Wheel lip sticking out from tires?
  21. Diablo Predator problem...maybe
  22. do they make a KC clutch for 99 cobra?
  23. Who else has had the gears polished
  24. Mass Air cleaning????
  25. [clutch issue] YAY!!! :D- Fun Stuff
  26. help me please!
  27. NEW MOTOR
  28. 03 Cobra engine in a 97 GT?
  29. noisy engine
  30. I noticed something about using different fuels, do you notice the same?
  31. slp racing pipes
  32. All the parts are almost here... Valve Spring install help?
  33. Wheels and tire question
  34. Question on clutch/flywheel
  35. 99 cobra wont start up!!
  36. (99 cobra Questions can anyone help me out!!)
  37. recommendations for clutch...
  38. 302?
  39. mach 1 block vs cobra block
  40. Question for Convertible Owners with Bilsteins or anyone else who can Help
  41. Rear Cobra/Bullit Brake Conversion Kit Question
  42. Injectors and WHP
  43. Trick One Suspension
  44. Tire Survey fot the 15" wheel owners
  45. How to assemble Mach1 Struts
  46. auto to manual swap
  47. Fuel Pump Filter Replacement?????
  48. dangerous wobble solutions for IRS?
  49. Stanless Steel Valve Stems
  50. Best Bumpsteer Kit???
  51. First Mustang mods....
  52. why do mustangs sometimes have scratchy startups???
  53. lift clutch pedal to adjust??
  54. Vacuum
  55. Tires
  56. More power/exhaust
  57. Supercharger install...what am i missing?
  58. stiff king cobra clutch?
  59. Help.....I need a transmission decoded!
  60. Bumper/ Headlight Assembly got messsed the **** up, need help!!
  61. Lift Bars?
  62. 97 4.6l dohc cam timing
  63. how many qts of oil fill your v8??
  64. Yellow coolant okay?
  65. Wheel bearings a hummin' ...sealed, or not?
  66. Novi 2000 kit
  67. Intercooler Options
  68. Steps To my next mods...
  69. My cars takin a dump on me, i need help
  70. I need brake help!!
  71. Best bang for your buck besides gears? Exhaust questions too..
  72. Header bolts backing out
  73. Battery/Charging Question....
  74. Standard or Full Length SubFrame Connectors?
  75. Need some help with P1SC...
  76. Have to clean my Accufab 75mm TB every few months
  77. Zex Question?
  78. Flowmasters louder?
  79. fenderwell emissions pump
  80. Injectors/ and oil capacity questions
  81. Help, Car completely dead
  82. Fuel pump, Kind of worried about the wires
  83. Ordering a SLP Loud Mouth ll, X-Pipe or Cats?
  84. P1131 & P1151
  85. Q about slp x-pipe
  86. Centerforce and SPEC clutches
  87. Axle housing width.
  88. Inertia Switch??
  89. heaven h pipe?
  90. Ford fixed my tranny
  91. 87-93 vs 94-04 shock/strut height difference
  92. PI swap HP
  93. Need Help With Nitrous
  94. If one were to do a cobra swap
  95. flaaping..... fluttering wtf is it?
  96. Fuel Filter
  97. Fuel Filter
  98. White crap under my oil cap?
  99. iac solenoid
  100. Mystery MAF..
  101. Can DIABLO read existing tune?
  102. 5.4 swap- parts needed?
  103. Can anyone help me out with the "J-Mod"?
  104. Finally took the GT to the track
  105. How to tell....?!?
  106. these brakes worth it?
  107. Sumitomo HTR Z
  108. Ford GT Fuel Pump
  109. 02 GT Idle speed?
  110. MAC o/r prochamber vs prochamber w/ cats
  111. tranny drop
  112. Speedo problem.....
  113. 4.6 build questions
  114. KB 1.7
  115. Nitto vs BFG vs Mickey ET Streets Drag Radials????!!!????
  116. Catted H pipe for 96-98 cobras??
  117. Accufab 75mm TB/Plenum Install Write-up (Biggest DUW Ever)
  118. 15" wheels?
  119. Not so much a mod as preventive maintenance
  120. Speedo problems
  121. I need a Bulb Number.
  122. New Shocks?
  123. check engine light question
  124. springs, shocks, and maybe MM plates oh my!
  125. How do u test a mass air meter?
  126. Powermaster Altenators vs. PA Performance - Difference In Quality?
  127. need help identifying wheel locks
  128. Smells like COOLANT spirits
  129. upgrading to cobra brakes
  130. Equal length Shorty Headers Worth the Trouble?
  131. shims?
  132. Mach 460 Question
  133. Cobra Brake Kit Upgrade
  134. A chip- I want
  135. Dome light wont turn off
  136. Transmission Cooler Needed?
  137. Coolant
  138. struts&shocks 99 cobra w. IRS
  139. help, new bad problem
  140. long term outdoor car storage tips needed...
  141. Need some help with axle removal.
  142. Bad paxton tune+ dyno
  143. wiring question
  144. Question about SCT parameters.
  145. When/where to get a dyno tune in D/FW
  146. IRS swap w/ solid axle
  147. What kind of IRS bushings should I buy?
  148. Mac Catback/Offroad X Opinions?
  149. My car is not very Nice
  150. HP gain?????
  151. Pinion shaft lock bolt SNAPPED!
  152. Which PCV valve do I need?
  153. After putting in smoked headlights + silverstars
  154. long tube headers
  155. Best Procharger tune out there?
  156. Mod (to do) List
  157. 4.6 liter surges/rumbles
  158. 315s ?
  159. Widest tire up front?
  160. cobra hood and gt bumper fitment?
  161. Necessities for h/c/i swap
  162. Wobble in the rear @ 80+ mph
  163. hand held tune or dyno tune??
  164. I got bit today
  165. Weird sound occurs after I turn off car.
  166. swapping motor.......electrical question??
  167. Washer Fluid won't spray
  168. AC Removal on a 4.6
  169. Need help?
  170. Diff. Pressure Sensor
  171. 91 octane with predator....problems!
  172. JLT True Ram Air Intake......
  173. 4.10s == New Rear End?
  174. When getting L/T headers installed?
  175. Fuel tank leaking after removal
  176. Blown head gasket question?
  177. What else comes with Accufab/plenum combo?
  178. New X pipe2
  179. Catless X- Pipe
  180. Shopping for a new Longblock
  181. question about VT stage 2 cams
  182. Installing a Kenne Bell 1.7 W/O an intercooler
  183. Livernois heads or Patriot Stage II heads
  184. Kenne Bell S/C Whine
  185. (Xcal2) Which one of these is my engine Code? What does my Code look like?
  186. Tranny Question
  187. Turbo/super charger
  188. P-51 intake manifold on PI headswapped 98 GT??
  189. Rebuild
  190. Tire/ Wheel question
  191. Dumb Question time. X-pipe
  192. Going to MPH which supercharger do i get?
  193. aftermarket axles
  194. Foglights and Reverse lights - not working?
  195. Suspension Upgrade Question
  196. MRT H
  197. Need Help With Tires??
  198. throttle body spacer...
  199. procharger + 10 PSI stock bottom end=?
  200. x pipe swap issues driving me up wall... please help!
  201. Doing Gears... is this what i need to get rid of the Howling Rear End?
  202. 4.10's and their effects
  203. Shortie or LT's
  204. Should I get the motive 3.90 or the frpp 4.10 gear?
  205. Question about superchargers
  206. headers
  207. If you're upgrading your front GT brakes to Cobra brakes...
  208. recommended?
  209. Front tire sizes
  210. aode or 4r70w
  211. GOT MY CAR WEIGHED!
  212. Question on heads
  213. Stock fuel injector color and rating.
  214. so i started my car today?
  215. crank & cam sensor install
  216. Location of convertible wiring in hardtop?
  217. 3v 5.4 question for BillFisher
  218. Engine Rebuild
  219. Exhaust
  220. Gastank cleaning method question
  221. Need Help Immediately.........
  222. gauge question?
  223. weird vibration
  224. Aluminum drive shaft & 4:10's
  225. BLOWER
  226. Out of Round Specs
  227. turbo or supercharger
  228. Black bullits, 17 x 10.5, what is the largest tire i can fit on them?
  229. Saleen Blower???
  230. Zex white wire? Throttle position sensor?
  231. What size slicks
  232. 3.73 installation cost
  233. CEL help I need an inspection!!
  234. SCT XCalibrator 2 or JMS super chip
  235. Fuel Injectors?
  236. gears gears gears
  237. T45 Diagram?
  238. Is it necessary to prime the oil filter after oil change?
  239. Clutch chatter & input shaft question???
  240. Mod order / SCT Tune
  241. Borla Cat-back
  242. Rear brake caliper tool
  243. Gutted Cats
  244. Will the 4.6 hold up to a Supercharger??
  245. Comp cams
  246. T-45 Synchro rebuild Kit (worth the $$)?
  247. Did anybody use the shift stops with their MGW?
  248. Weld ProStar Owners....ENTER
  249. BBK progressive springs, now what shocks/struts?
  250. Rear brakes dragging?
