View Full Version : 4.6 Tech
- grille delete radiator cover
- What drag radials for a 17x8 wheel?
- Optima battery size?
- blower choice - kb or vortech?
- Zex tps wire?
- Wheel spacers, size and brand?
- BBK or MAC LT Headers w/Midpipe ??? 04 GT
- squeeking clutch?
- cats or no cats???
- Procharger shaft play?
- Rebuild Help!
- comp 262 with nitrous?
- stage 1 cams
- Need help with tires, PLZ.
- Intake Manifold question
- Gear installer near Charlotte NC?
- Gauges
- why wont it start??? *help*
- California Emissions for 99 GT...HELP!!!!
- What injectors with procharger?
- Question about Flowmaster dumps
- Need Help w/ weird sound
- Question on NGK Irridium IX TR55IX plugs
- Wheel Question
- Opitima battery & tray
- Magnaflow High Flow Cats: it's smog legal according to the box,but does it pass smog
- Big Brake questions
- 4.10 gears
- 1500 rpm buck - EGR related?
- 02 Sensors, Question - Front/Rear SAME??
- wilwood 14'' brakes
- Metal stuck in intake valve....how to remove?
- oil leak
- Stock Gears
- Timing Adjusters
- 96 GT possible problem areas?
- Need help with procharged 02 gt
- mach1 springs
- Just got 3.73's w/ SCT II programmer
- cai's and water
- msd wires and coil packs
- Blower or Internals First?
- KING COBRA CLUTCH
- headrest question....
- 98stock trans
- 98 Auto Transmission Question
- Wideband question.
- Engine Code - Cylinder 4 Missfire
- Vt cams help
- Seat Question?
- 2003 cobra weight
- p0153
- shaking shifter
- Question - Where to install wideband O2 sensor on stock exhaust
- Springs, and Tire Sizing
- Polished Aluminum Pullies for the 4.6 GT SOHC?
- Wheel hub - Thank you
- Tire Question
- zex install, Fuel line question
- what clutch to go with?
- JLT CAI
- Aluminum Driveshaft, worth it?
- Spark Plug Problem
- Installing 2000 GT motor in my 96 GT??
- clutch noise
- Autometer Boost gauge Accuracy?
- Not running on all 8 after intake cracked
- Which plug fits the 03 GT
- Can you buy a "built" rearend
- Best way to recalibrate speedo
- 98 gt stock rims
- Sun Visors the same for convertible & coupe?
- CAI
- Which radiator fits my 4.6L?
- How to diagnose cc plate clunk/pop?
- 18x11 wheels...can i do it?
- 98gt fog lights
- shorty/mid length headers that make power...?
- Undecided on blowers...
- What Tools Are Needed For Cam Swap
- SVT Focus pump:which is the correct part #?
- Sway Bar Install!
- N/A vs Blown
- Bump steer kit or X2 Ball Joints or??
- do I need the plastic deflectors under my bumper?
- GT Was Hard to Start This Morning
- Boost and intercooler gauge help ASAP!!!!!!!!!
- Are Cost High Performace stroker kits one of the best?
- How do you aim the Damn Headlights?
- Transmission Type
- c-clip/axle/gear questions help?!?
- Rattle from the rear..what could it be?
- Stock Crank Pulley Variations?
- will eibach drag launch kit work with steeda front swaybar?
- ahh man my clutch
- cobra supercharger swap??
- Knock Knock, whos there?
- Exhaust Tip Loose.
- 70mm TB or 75???
- New exhaust
- J-mod and Xcal 2
- Had engine cleaned, now battery light coming on, suggestions?
- Air Conditioning in the Winter
- Supercharger or Heads, Cams and Intake... Can't Decide
- AFTERMARKET PEDALS (install help needed)
- Ford Racing rotors?
- Throttle Body / Plenum Recommendations
- another question about steeda lower control arms
- Engine Break In Question
- Custom Turbo Kit
- Need your opinion on a decision about SC vs Bolt ons
- Steeda Aluminum Lower Control Arms
- 1996 MUSTANG GT IGNITION HELP
- Help figuring rim size
- catalytic converter broken... high flows?
- Harness issues with different lamps
- VT stage 2 cams
- I NEED HELP!!!
- tranny fluid capacity
- We are being way too nice about the SEARCH BUTTON
- Suspension
- Hood Latch Issue
- How do you adjust the door so that it lines up with the body
- Fuel Injector Question
- Mach 1 Grill Delete Part #
- Procharger question?
- Bad Luck!!!
- Multiple Questions (what to do this year)
- Plumbing Nitrous???
- S/C or NA
- Suspension questions
- got my gt tuned today!
- KYB or Tokico?
- Best hooking tire for a stock 17x8 wheel
- springs...help!!
- '97 Vert top problems... again. Any suggestions
- tires rubbing on frame
- Which Cylinder??
- Will a 01 Cobra Gauge cluster work in a 01 GT?
- need SC help!!!
- H&R springs plus Deep Dish
- Question on suspension upgrade
- Patriot Heads/Cams
- Radiator and Coolant Leak
- Whats gears with blower?
- Anyone have Squeaks with their Mach 1 Steeda STB?
- Best Street Tire
- cobra r brakes VS. cobra 10th anniv.
- Bullitt Air Silencer
- isolator vote
- ba falcon boss 260(5.4 3v)auto dyno sheet
- Will my tire size be ok?
- difference in cai's??
- Magnaflow x-pipe install
- Issues with comp 262 cams
- Irritating Noise
- Have you guys ever heard of a spark plug being blown out of a head?
- SAGGING EIBACHS??? GET IN HERE!
- Life span of shocks/struts/front end components
- Two simple questions...
- Can Exhaust Get INTO Tranny/Differential..?
- Engine block coolant sensor plug
- Some cobra questions
- question about a 4.6
- heads & cams
- Suspension!!!
- MSD Coil Pack Upgrade
- 99 KB GT or a 03/04 Cobra?
- Log Block suggestions for 02 GT
- eibach sportline lowering kit...
- 98 gt pi swap
- CEL with slp catted x and longtubes
- Which catted midpipe to make bassani c/b rumble?
- Ebay cold air kit opinions
- What kind of shifter handle do you have?
- how much spray can the plastic intake take?
- OBD-II Trouble Codes
- power steering fluid purge help?
- Battery going dead
- Magnaflow to magnapacks
- Suspension Help
- gears and tune question...
- trouble codes for my '02 GT
- First Trip to The Track Since the Hurricane
- Taking the air silencer off my kenne bell stang
- Quick question about Cats -Mind The Noob Please
- H&R SS, X2 BALL JOINT, AND BUMP STEER KIT COMBO
- gears, and pricing.
- Sell me a part to your Factory air intake
- Random Tire Question
- lowering Question
- Door Tag + VIN Code Chart
- T56 questions
- Steering wheel shake
- P0401 EGR FLow and Intake Change Help?
- stock H pipe Question
- opinions on new combo needed.. stroker and heads etc.
- Springs for lowering exactly 1 inch
- sagging eibachs! new springs
- new car!!! (which mods can swap?)
- front end needs more lowering!!!
- the H or X debate
- Nitrous on PI swapped 98 Gt motor, safe?
- exhaust question
- Which brand X pipe with my Borla Cat back?
- Squeaky belt
- ordered nitrous am i missing anything.
- 99 Cobra Guage cluster
- Who here actually NEEDS bigger brakes
- do i need a new tune?
- Gauge Sweep.
- Cleaning engine bay, who does it?
- What big brake kit should I get?
- Vacuum Sensor?
- What is the widest street tire i can fit on my 2000
- dirty brown fog's
- MPH Mongoose Vortech Kit vs. RPMoutlet's Procharger Kit.
- Rear seatbelt removal
- Suspension mods
- Trying to add a one-touch window down module, need help!
- Will a short prochamber match with BBK LT's
- Just bought a '96 Mystic Cobra - question about shifter.
- EGR vacuum line
- Dyno Number Comparing Comp Cams & VT Cams
- Flowmasters + MustangTuning X pipe.
- K&N Typhoon
- Do you waste alot of Gas Idling in P..?
- Valve job questions
- UPR X-Pipe is on!!!
- possible valve chatter?
- HELP!new cams in but running really slow
- Corrosion in Tag Light
- Help I am not getting enough oxegen
- What midpipe with Bassani C/B???
- Help with UPR catted X pipe
- What is the flow calibration on a stock MAF?
- Differences in LCA's b/t Steeda, MAC, Hotchkis, etc... LCA's?
- Exhaust Install?
- 99 GT Free Intake Change Recall
- moser axles
- longtubes best fit
- 02 GT won't start!
- difference in size in stock maf
- Help! Reinstalling factory air cleaner
- BILSTEIN BTS KIT
- Squeaky belts
- Which clutch to use?
- Problems with Magnapack Catback
- DS loop and Prochamber
