View Full Version : 4.6 Tech
- question about a 4.6
- heads & cams
- Suspension!!!
- MSD Coil Pack Upgrade
- 99 KB GT or a 03/04 Cobra?
- Log Block suggestions for 02 GT
- eibach sportline lowering kit...
- 98 gt pi swap
- CEL with slp catted x and longtubes
- Which catted midpipe to make bassani c/b rumble?
- Ebay cold air kit opinions
- What kind of shifter handle do you have?
- how much spray can the plastic intake take?
- OBD-II Trouble Codes
- power steering fluid purge help?
- Battery going dead
- Magnaflow to magnapacks
- Suspension Help
- gears and tune question...
- trouble codes for my '02 GT
- First Trip to The Track Since the Hurricane
- Taking the air silencer off my kenne bell stang
- Quick question about Cats -Mind The Noob Please
- H&R SS, X2 BALL JOINT, AND BUMP STEER KIT COMBO
- gears, and pricing.
- Sell me a part to your Factory air intake
- Random Tire Question
- lowering Question
- Door Tag + VIN Code Chart
- T56 questions
- Steering wheel shake
- P0401 EGR FLow and Intake Change Help?
- stock H pipe Question
- opinions on new combo needed.. stroker and heads etc.
- Springs for lowering exactly 1 inch
- sagging eibachs! new springs
- new car!!! (which mods can swap?)
- front end needs more lowering!!!
- the H or X debate
- Nitrous on PI swapped 98 Gt motor, safe?
- exhaust question
- Which brand X pipe with my Borla Cat back?
- Squeaky belt
- ordered nitrous am i missing anything.
- 99 Cobra Guage cluster
- Who here actually NEEDS bigger brakes
- do i need a new tune?
- Gauge Sweep.
- Cleaning engine bay, who does it?
- What big brake kit should I get?
- Vacuum Sensor?
- What is the widest street tire i can fit on my 2000
- dirty brown fog's
- MPH Mongoose Vortech Kit vs. RPMoutlet's Procharger Kit.
- Rear seatbelt removal
- Suspension mods
- Trying to add a one-touch window down module, need help!
- Will a short prochamber match with BBK LT's
- Just bought a '96 Mystic Cobra - question about shifter.
- EGR vacuum line
- Dyno Number Comparing Comp Cams & VT Cams
- Flowmasters + MustangTuning X pipe.
- K&N Typhoon
- Do you waste alot of Gas Idling in P..?
- Valve job questions
- UPR X-Pipe is on!!!
- possible valve chatter?
- HELP!new cams in but running really slow
- Corrosion in Tag Light
- Help I am not getting enough oxegen
- What midpipe with Bassani C/B???
- Help with UPR catted X pipe
- What is the flow calibration on a stock MAF?
- Differences in LCA's b/t Steeda, MAC, Hotchkis, etc... LCA's?
- Exhaust Install?
- 99 GT Free Intake Change Recall
- moser axles
- longtubes best fit
- 02 GT won't start!
- difference in size in stock maf
- Help! Reinstalling factory air cleaner
- BILSTEIN BTS KIT
- Squeaky belts
- Which clutch to use?
- Problems with Magnapack Catback
- DS loop and Prochamber
- Which Bits for Dremel?
- 34/78 Optima Red Top doesn't drop in for 01 GT
- Midpipe Question...
- Heater bad
- tired of Magnaflow; should i get Borla or Bassani?
- I got a P0103 code! What does that mean?
- Question - Anyone have the catch code to hex code list?
- those of you with LTs
- pi motor
- will these slicks fit??
- please dont yell at me.. need a quick response
- Name That Xpipe Noise
- Where is the air silencer?
- How to improve handling significantly?
- 5.4 swap
- steeda UDP
- Little Bit of Hesitation??
- cooling problem?
- Cams question (other mods as well)
- cams and longtube question
- H&R SuperSports, how many of you still use stock shocks/struts?
- How do i remove the bulbs from the new crealcorner headlight housings?
- SCT Xcalibrator 2 Questions...
- Any differences in reliability between supercharger A and supercharger B?
- Muffler help...
- Handheld tuner vs. Mail tune vs. Dyno tune
- anyone have projectors on their 99-04?
- Clutch pedal issue: Clutch or quadrant/cable?
- Toasted starter?
- exhaust loudness ?
- Prochamber final questions
- CDC Shaker and Kennebell S/C clearance question
- ATF through the intake
- Headliner wet, need help.
- Motor Swap Question?
- NX kit or supercharger?
- N.C. New Emissions test
- Clutch for 4.6
- mark viii block in a 98 GT?
- Not your regular Gear Question
- My 2000 GT project..(blower/tune/mods)
- Best Mail Order Tunes
- Bad battery causing a misfire? Help
- IAC Restrictor Woes
- sluggish after x-pipe
- Bassani Catback finally installed!
- NON-PI head porting
- Installed HIDs.. but the light is EVERYWHERE
- saleen side scoop removal HELP FAST!!
- WHat does it take to put an 03-04 Cobra bumper on a 99+ GT??
- Help!!!!!! (air/fuel ratio)
- speedo calibratrion (4.10 gears)?
- how easy is it to install shocks,struts,springs
- Pop-pop-poppin' sounds when turning right
- California Emissions - another question
- Bullitt Intake Port and Polish
- Professional Products 4.6L 99-04 Manifold.
- 4.6 thunderbird. easly upgraded? need help.
- Aftermarket Shifter Noise
- ABS module replacement how-to??
- battery and alarm
- Bullit pedal install problem
- pinging at WOT, 87 octane
- mod motor gurus look here
- Quick question: SOHC to DOHC?
- Odd Steering Wheel Electrical Problem
- CC Plates w/ Eibach Pro-kit?
- California Emissions Test - Questions
- What Degree Thermostat in 4.6???
- how to reset alarm system?
- AT w/OD off...heats up gears faster...? (please tell me this is wrong)
- Car is going on the DYNO tommorow! (1/3/06)
- spark plug with nitrous ?
- 4.6 transplant into 68 fastback
- whats wrong? - car won't start
- Im a little confused about something (H pipe)
- Heads/Cams Emissions Question
- Eaton M112 Compatible Engines
- removing headrest.......
- dash/gauges wiring diagram needed for a 98
- X engine code?
- What Pulleys Do Not Fit The Steeda Timing Adjuster?
- HELP! (Diablo chip)
- Stock Rims - max tire sizes
- Idle!!!
- Headlights and Foglights dont work?
- What Gears?
- Need help, changed plugs, now revving high
- Car throwing code, how long after it's cleared before emissions
- How to properly store my car.
- Brake Noise
- Changed plugs..now it revs high....
- 04 vert issues..looking for little help.
- Transmission fluid on 5 speed and MGW shifter????
- What should be replaced?
- ECM
- Intrax Springs, anyone?
- Bad miss after h-pipe install
- HIGH HORSEPOWER
- Putting Convertible Up/Down without E-BRAKE?
- 70mm throttle body, is it really worth it?
- 99 GT valve cover removal and heater core install need help?
- TKO Transmission Guru's! I need help!
- Who makes the best blower manifold? (Saleen, Kenne Bell, Roush, Allen)
- Figured out 99% of my interior rattles
- 2002 GT Stock Alarm Problem
- 98 GT Overheating After Long Idle
- which tuner to get?
- comp valve spings
- brake pads (dust)
- installing PI intake
- PI cam installation worth it??
- 4v heads on a 2v engine
- Aftermarket Fuel Rails?
- QUICK NEED HELP!!!!
- I NEED HELP !!!!!!
- How required are C/C plates?
- How To Remove Center Console
- Battery goes dead in 5 days! Any ideas???
- stangsuspension.com lowering springs
- oil galley plugs?? leave the front ones in or what?
- cc plate installation
- New Factory Block, Windsor or Romeo??
- DIY prochamber install
- Help! Car runs like crap after intake swap and fuel pump replace
- LOWEST PI mustang dyno numbers
- Check engine light: P0411 code, huh?
- What muffler provides substantial interior resonance?
- Bassani Catback just arrived!!!
- Are Steeda Sport springs and FRPP "C" springs the same?
- removed spoiler...now what to plug holes/how to clean
- Can U Swap Intrument Clusters w/no issues????
- cam seized
- trouble installing white faced guages
- Just installed my Bassani X pipe
- TPS sensor problem
- need help finding weird tool
- How Good Are The Ford Racing Suspension Parts?
- throttlebody
- NEED WIPER MOTOR FOR 00 GT
- What kind of thermostat?
- Weird engine sound when cold or reving at idle
- Engine knocking.. Help please !!!!!!
- Which tranny to get???
- Hammer or Hurst auto Shifter for 2003 GT auto?
- 4.10 but no tranny cooler
- Idle in neutral and drive - why are they different? Auto trans
- Check Engine Light
- Speedo Off?
- Can you weld a coated mac o/r pipe?
- Head porting tips?
- Magnaflow catted x-pipe
- Rear Springs
- control arms
- Idle problems
- What Nitrous Kit To Buy?
- Ignition Systems!!
- Leaky coolant sensor plug
- torque converter gurus...help me out, quickly!!!
- Couldnt get the old shifter off to install the MGW!!!! :(
- Wheel Spacers
- sorry about the spark plug ?
- Trans makes wierd noises in 1-2 shift (96 Cobra)
- transmission noise
