View Full Version : 4.6 Tech
- Auto Tranny Filter change!
- 4.10s and driveline vibes
- Help..Exhaust Question
- Bullitt/Mach shifter trim ring
- Powerheads, a good cheaper alternative?
- Jump started another car..now @#*$!!!
- Springs without isolators
- Automatic Transmission/Driveline "clunk"
- 96-98 info
- Quick ABS question, HELP!!
- Spark plugs
- BBk shorties ???
- Turbo 5.4 Liter
- No Heat
- Wide Band O2
- Catted X-pipe question
- OUT of STOCK!!!! mac o/r H
- 281 to a 302 stroker
- prochamber
- Fire!!!
- How do I get more traction
- cobra R hood
- MIL illiminator(s) gone bad? "Service engine soon" light is ON again
- gas smell With A/C
- electric fuel pressure gauge
- battery hold down
- who has nitrous...
- Weight Reduction
- cams and supercharger?
- How Much Power And Torque To The Wheels
- Zex Dry or Wet nitrous kit?
- Car rpms dropping quick
- predator wont recalibrate my speed-o
- Tranny Fluid from Up Above...
- Heater core problems in 99-04 gts
- How do you measure inches of torque?
- oil separator install....question..
- Mods Wish List
- O2's
- speed-cal install question
- Cut outs?
- 3.73 or 4.10 or ??
- Rear End Problems
- Need a 4V for swap, any hookups?
- Do you need a roll cage/bar to install 3 point harness like the 4,5,6 do?
- idle problem
- Rear diff, axles, gears etc
- ?`s about cams for npi
- Mustang tuning PI intake
- VT Stage 1 cams on a stock Bullitt
- Nead Home Head Porting Info/Pictures For PI's
- updated vid from blown vt engine
- Eibach Sportline Help......
- Mustang Performace: Too cheap?
- Dragging SFC's??
- questions on changing springs on 04 GT
- 24mm or 50mm? Pics please?
- Defect or not?
- LF Your Opinions on Ultra-High Perf Summer Tires
- new guy....few questions?
- Just Bought A 5.4 SOHC!
- Need detailed instructions for Maximum Motorsports subframe connectors installation
- Timing issues/help
- Xcal2 87 Tune
- eibach........................................
- need some info, starting to think about a built block.
- Need Help With Engine Install: PICS
- Need Engine Swap Information
- ? about shocks with steeda springs
- Speed-Cal (96-98 autos)
- 15" wheels/what tires?
- hey KB owners, need some info
- Fluidyne 5 speed radiator on an auto
- who has long tubes and aftermarket H-pipe w/cats on a '98?
- Nitrous and Preditor
- New head idea... what do you think?
- New Bumper??? which one To Get
- real quick alarm question ('96)
- Track run of 03 Kenne Bell GT
- how often do coil packs go out?
- X-cal or Predator
- Interest in a simpler KarKraft functional hood scoop?
- Replacing Front Seal for Rear End housing
- How loud 40 series Flows and O/R H pipe
- Help Me Deciede!
- Cutting stock REAR springs?
- Patriot Heads??
- Plastic manifold Help
- fuel pump ?
- Those who have 3:73 gears, get in here
- Louder- LOUDER!!
- Fuel Injectors Ticking Loud..Normal..?
- Ride Height.....
- what size tires to get?
- Exhaust power output question
- Need pics...Red SN95 w/ black bullits??
- Put my c springs in yesterday!!
- cobra fogs light help
- keep NPI and do Cams or not?
- Lighting question
- Throttle position sensor voltage on 02 GT
- Car started to run like crap then fixed it's self
- Ok to unhook computer???
- NPI Upgrade Opinions
- Where to get hood
- chin spoiler instalition tips...
- SOHC to DOHC
- gear install parts list
- Pro-dumps or tailpipes
- HELP! sohc to DOHC swap
- I want a CB radio, any ideas on mounting/installation?
- ABS light coming on
- Any thoughts on Weld-in or bolt-on X-pipe with stock cats?
- Question about Steeda Underdrive pullies
- How do you guys work under the hood on older cars?
- Going from CAI back to stock, one extra connection?
- MGW (for the 100th time)
- correct me if im wrong but.....
- Engine pulling time
- What are your thoughts on Alum Driveshaft
- $2,000 for a Vortech S-Trim!? Ahh! Help Quick!
- this sux
- MAC o/r H pipe instal.pointers
- New hood
- C&L Plenum + Accufab or BBK 75mm
- where is the k & n part number?
- Anyone with Idle hang up and high idle issue get in here!!
- Which Alternator?
- Boltin' up STB?
- Finally fixed.
- 4R70W..Torque Converter..?
- K&N Cleaning kit lifespan
- Advanced Idle issue questions(and its long)
- Detonation with K&N and XCal 2...
- what do you think car value??
- back from the track...
- 18x10 with SS drop
- Which Tranny???????
- Royal Purple
- Pinging, surging, stalling
- exhaust and cold start question
- same as the 4.6L in the mustang?
- Pics of stock midpipe
- Fuel Injectors for F-150 4.6 Best Price? Where???
- Do it yourself clutch install
- with 87 octane , how much timing?
- how do you know if you clutch is going out?
- ? about SLP Loudmouth Catback
- Creaking when brakes are applied?
- Uh oh, broke something in my suspension..
- Results from the strip, opinions needed
- Difference between Black-Coated Mac H pipe and regular Aluminzed?
- If you had 2-3k for upgrades to a 98 mustang gt what would you do?
- 2000 GT blowing coolant out of tail pipes
- ? regarding X pipe
- How can i advance timing????
- Synthetic advantages.
- 4.6 Mustang GT Questions
- 00 gt Water diagram?
- 96 gt mods? could use some help
- anyone use predator to tune with a s/c?
- ~PICS~ Parts ready to be installed...
- need a little help from my friends
- Replacing valve stem seals on SOHC, Advice?
- How to remove rubber particles from paint
- Anyone have lowering springs with stock shocks?
- 4V heads
- installed MRT black chrome tips.
- Is my coolant THAT low?! *pic*
- rear end pinion bearinf replacement
- Help codes p0171 and p0172 Fuel Trim Malfunction
- S/C'd plug and gap.
- Long tube header install write up???
- Good place to buy catback
- Solid Axles vs IRS
- longtube headers
- Help With Automatic Door Locks
- What else would this Vert need for 500rwhp?
- quick xcal2 question
- 99-04 Stock Cat-Back. Stainless Steel or Aluminum
- Clutch / Clutch Pedal Problems
- Best way to check for a vacuum leak
- Springs Q'ss
- autometer guages?
- Can anyone give real dyno numbers on predator install?
- Tranny install help.
- Steeda pulley install.
- Need help on codes
- Should boot snap On the Plug./4.6 bucking.?
- Dangerous?
- Steam
- Gears
- Mach 1 Chin arrived....how to straighten?
- White spots on my delete
- P.I. head and cam swap.
- squeaking noise from right front
- PI or Supercharger
- 98 Convert Window Problem
- parts for intake swap!
- long tubes and x pipe 99 gt
- O/R H pipe, MIL elimantors and Check Engine Light
- whats a good chip to get predator or sct?
- Need help with axle thump
- Cobra wiring harness
- vibration problem help
- removing oxidation
- T/O bearing issues:Please read and respond!
- Newbie Intake Manifold Question
- thinking of switching to mgw short shifter...
- Mustang leaking water from exhaust
- 00 gt blew water out of tail pipes?
- Help me with my buddies 04 Mach 1
- shudder??
- Strange sound?
- Power steering fluid leak!
- Drag Suspension
- Jacking point
- Tire?
- Did anyone else have IAC failure shortly after doing the copper cap mod
- Header fitment chart ?
- Dyno's after Vortech install - 03 4.6 2v
- help with code!!!!!!
- Break in Period w/4.10s
- Suspension Project For Winter
- 315/30/19 BFG DR on an 18x10 ??
- teflon tape?
- Under what conditions do i NEED CC plates?
- this mechanic is retarded
- BBK LT Headers, Dr. Gas X, Bassani Cat Back?
- Has this happened to anyone else?
- Factory "Panic" as a No Cost Alarm System?
- Quadrant Adjustment
- Bought supercharger, still some questions!
- Is this shop toying with me??
- off-road with cams....
- tunning question?
- tunning question?
- installing cobra rear brakes
- Missing the way it used to sound (down with the police!)
- Tires and Wheels
- Blizzaks
- what size spare do i need for 13" brakes?
- Ticking
- Touch up Paint?
- Mach 1 chin spoiler scraping
- What's The Problem?
- Automatic to 5 Speed?
- Location of abs control module????
- Help with a Code
