View Full Version : 4.6 Tech
- What do these codes mean?
- Spilling fuel! Need some info!
- cross drilled? slotted?
- belt is slipping
- Interested in a Mach 1
- xcalibrator2 fan settings on 02 gt
- P-51 + hood fitment
- lowering and headlight question
- Ignition Questions...
- OPINIONS Please
- 3.55 or 3.73
- my tuner figured out why my car was running lean.
- wierd idle noise
- left rear sagging
- 4-bolt cc plates, coilovers?
- Tire size 97 mustang GT
- Thinking about getting some stage 2-2.5 heads and cams..
- accufab TB+plenum Instal....a tiny issue
- Which Tires??
- Is UPR still in business
- CDI box worth it?
- Need A Guide For Some Stuff Please
- valve body
- Car wont start Theft
- Tools needed for front brake job?
- problems with gauges, pulled needles off
- man ive had such bad luck lately
- Basic Stroker Kit Q's
- quick question tonight thanks(n20)
- How to get the most hp from exhaust
- Rearend Noise - 8.8, Please help
- Grille Delte
- nitrous plate Q?
- Bbk Shorties Anyone???
- Saleen Series IV vs KenneBell 1.7 ...
- PI engine in NPI car
- who makes them?
- 3.73???
- Simple tranny question..
- Sputtering-like sound at low RPMs
- Spec Stage 1 Clutch..Lowest Price
- Nitrous installed and used.
- King Cobra Clutch Kit??
- How to ?
- Small problem???
- HVAC vent problem
- 4.10's installed
- Which CC Plates?
- who's runnin' nos?? a few q's
- this combo any good? How much?
- Stripped lug nut bolt
- bullitt gas cap
- Got a blower....what gauges do I need?
- H&R Cups kit for 2003 GT
- Question about C&L fit 00'
- 5.4 swap questions
- a/f gauge
- Viper alarm with Auto Start??
- MAC Prochamber Worth It?
- Interior paint
- pro tuning worth while on stock 4.6?
- 4.6L Underdrive Belt Lenght
- Seat track
- WMS Power Pipe
- Knocking noise - SOLVED!
- kill switch
- Curb weight
- Anyone with a supercharger and nitrous
- please help i need a quick respond
- UPS just delivered Mach1 chin, any install tips?
- Xmas Supercharger
- What are symptoms of a bad o2 sensor?
- Caliper slide pins are frozen
- Steeda Cat Back/Exhaust Question
- None of my accessory 12Vs work...why?
- bad "tick" in door when cold
- Going to install Spark Plugs, have some Qs
- Alright, 4.6L newbie...answer a few questions.
- Bassani Mid-lengths
- Novi 1000 question
- 5.4 3v swap update
- GT Guys, What Timing are you running with your Programer
- Check engine light?
- Which suspension??
- Urethane Preparation?
- Chip
- GOT MY PI HEADS! need this verified....
- New Dyno #s Twin Turbo 2v
- Dip Stick Tube
- Muffler Ideas -- Would this work?
- How do you get your pin stripes off?
- Oil seeping
- Tech Info. On 2005 and 6 Mustang GT Needed Please - Looking at Buying>>>
- Things i need to do/know before installing TB+plenum
- Engine Tapping
- Check Engine Light with Tach Adapt Install?
- Help: I have to always be giving the car gas or it will die
- Long Tubes
- Stock Oil Gauge
- Any DIS 4 users? Install/troubleshooting...
- My car wouldnt start twice?
- DOHC swap in to GT
- Nos Or Chip
- My friends new PI trqe converter!
- Which driveshaft? (IRS)
- Valve cover?
- Rotating Assemblies - got a few Q's?
- best place to buy sct xcal2?
- Rev Limter???
- part number 710
- rear antisway bar question
- 5.4L Swap
- Installed brakes - problem now I think
- plastic cup for shift ball
- Problem after installing window switch (don't think related)
- Tranny ??'s
- Dumb question... what oil?
- Porting out MAF
- Mach 460 interior speakers don't work
- Best Launch RPM For A Stock Auto?
- o/r H and Check engine light.Very big important question
- Cleaning the IAC
- Careful with seafoam
- More "Cobra Brakes on GT" questions. Sorry
- Headers
- Optima Battery
- question
- Beset Price for SLP Loudmouth?
- Tranny problem
- Cams
- should this be missing?
- headlight upgrades
- MRT has a instrument cluster now like the autometer one
- Car on stands - caliper wont go back on HELP!
- 3.73 gear install for 98 gt vert auto
- pi swap
- question about steeda timing adjuster?
- Eibach Anti-Roll kit - Which setting for the rear?
- Any tunere here? getting dyno tuned but still getting a slight lean condition?
- should i assume i have gears?
- Anyone have Bilstein BTS Suspension Kit?
- Can anyone tell me the performance of my 96 gt ?
- How Many Hours to Swap Intake Manifold?
- Question about modifying wheels
- 3650 tranny problem
- How many hours to do a head swap?
- Exhaust NOTE Help! BBK, VIDEO Inside...
- pulleys
- What is this part on my fuel line (with pic)
- Painted Grill Delete
- What engine parts should you upgrade when putting in a SC?
- any aode people with aftermarket valve body?
- How to tell if quad shocks are busted
- motor problems need help
- Gauges
- Tuning Software
- Lightning MAF Sensor?
- Can of Compressed Air
- '99-'00 GT's - how common is highway pinging?
- Anyone use pacesetter headers?
- Turbo
- SLP l/t went in today!!!
- disconnecting alarm system
- driveshaft
- Need Help Selecting a Clutch
- Convertable Owners
- Cobra R Hood In Here
- Eibachs or Steeda Springs?
- what is wrong too much gear and tire????
- Anyway to keep oil splatter off valve cover from pcv area?
- Code reader
- Is there away to make the engine run leaner in open loop mode (engine cold)
- Machine Shop
- Fuel not reaching injectors??? Out of ideas!!??fuel pump replaced!@
- Need ideas for makin hood look nicer
- need some advice on present purchase to benefit future build
- FMS and Motorcraft Friction Modifier the same?
- Mass air flow sensor troubles and fixes
- Is it worth it?
- what the heck is this?
- Who has cheap bassani x pipes?
- Crashed into a ditch!!!
- 1996-98 guys with nitrous come in...
- Anyone else get this?
- New rotors
- overheating please help!
- Matching gauge and dash colors?
- Wondering where I should go from here..
- Question about engine coolent?
- throttle body
- Steering wheel shakes when brake is applied
- O/r x pipe swap
- Anyone see mpg increase with catback?
- Got a link to MPH?
- heater core haters unite!
- P/I heads and cams
- Question about UCAs & LCAs
- Loud noise in rear when going over bumps?
- So Ford messed up my car...AGAIN. AntiFreeze in Cylinder.
- Which Long tube headers... <POLL>
- going to order a vortech kit in the morning, have some questions...
- Girlfriend damaged one of her car's wheels. Is it safe? (Pics)
- oil pooling in valve cover?
- Which is louder: Magnaflows vs. 2 chamber Flows
- 99 gt sohc engine specs?
- Off Road X pipe Question
- super 40's are on...
- 00 gt dies after start.
- Gauges install. HELP
- Anoying Problem!!!!
- Spring question from a newbie??
- Tire Poll
- '97 GT Conv. - conv. top will not go up
- Engine Problems, please help!!
- Which clutch???
- Whats the difference between H beam rods and I beam?
- help with a choice??
- What mufflers/catbacks would sound good with an x pipe?
- experts with paint jobs
- Scattershield for t-45
- diff cover
- paxton supercharger
- headlights/brake lights dont work after heater core replacement
- Question on Installing HID's
- New Nittos
- Rear End Leakage
- E brake light, bent rim and clutch? please help
- can someone help me find this part?
- 4.56 Gears
- Race weight...
- I'm confused
- Electric Water Pump
- 04 GT Engine swap to 03-04 Cobra
- Borla: Stinger or Chambered
- Car overheating!!! (Yes another thread about this)
- vert top detailing question...any detail gurus come on in!!
- Bbk 75mm Tb
- intake of some intake
- how much gains can i see from TB
- MAF question
- glass packs
- Cylinder Head bolts
- 150 stop and go miles with the Spec Stage 3 and still chatter
- Procharger vs Vortech
- Need a Springlock release tool
- Need some input. Buying first 4.6
- Any reccomendations?
- What next?
- setting the speed without a tuner
- wont idle when cold
