View Full Version : 4.6 Tech
- Mach 1 Long tube headers ?
- Built 3650
- overheating
- Hey i have a question...Im so lost
- possibly intoxicated ford tech told me..
- Eibach Springs
- Putting a supercharger together
- Using Predator to check TPS.
- My first blower
- How well do 96-98 4.6s react to nitrous?
- Mach 460 problems help!!
- Clutch Writeup
- Fox Lake Stage II or Ported Stock Heads
- Anyone know if I have gears by speed vs. RPM?
- Did I get taken on some shocks?
- Need help pleaseeeee
- Vibration problem
- front suspension problem
- upgrades while waiting for supercharger
- 1998 GT 4.6L
- What steering wheel puller?
- Direct Port Nitrous Question
- cam bug
- Car doesn't feel good at times
- Way to reset gauges???
- suspension noise
- Strange Noise @ 50 mph
- bad idle - MAF sensor?
- I have 2 nuts backing off!!!
- steering creak (inside the car)
- Severe Stumble Midway through the rpm range?
- Transmission advice needed
- shortened exhaust ques. ??
- Valve chatter
- Headers Question
- pink injectors?
- Question about t-lok!!!!
- Lug nut torque?
- help car wont stay on theft light
- Well got bore and drive like you stole it
- removing a rounded or stripped nut
- odometer in and out?
- K&N filters are bad apparently???
- motor mout ?'s
- LOST BOOST!?
- What backspacing with 15x4" rim?
- Help I need a Catted X/H for my Mac Long Tubes!
- 03 Cobra Pumps and Tank Question
- jlt rai or cai?
- Any DM SpeedCal Experts? Center Console Stolen, Speedo Not Working
- Very strange...SES light not coming on but bulb is good
- Ok a new problem...kinda.
- intake and exhaust ?
- aFe Pro Dry Synthetic Air Intake Systems
- upgrade injectors???
- 99 gt wont start...HELP!
- Please I Need help with timing chains
- Head Questions part 2
- New sound started coming from the motor tonight, has me worried...
- '00 GT left half of gauge pod doesnt work
- suspension question
- rear vibration after uca and lca's
- Stock 2V Pistons - Will they hold up?
- spark plugs after pi intake swap
- Fiber Glassing? Car Broken Into, Only Center Console Taken
- Gorilla Lug Locks - Removal?
- 2000 GT, 'Clunk' sound during initial acceleration & braking
- Mach tune vs GT tune
- What is needed to block off EGR?
- Installation question for guys with Windstop
- replacing carpet in 97 with 04
- my opinions on mac offroad h pipe
- 4.6L SOHC Motorcraft Plugs..What's number?
- noob open to sugestions
- Need some Advice on My new Steeda Cable
- Cheapest Forged Shortblock???
- ticking coming form....
- MRT Hi-Flow H-Pipe
- 500 bones
- hp gains from mods
- pump assembly tubing
- Bassani Mid Length Headers Question
- Head Questions.
- 255/35/18 vs. 275/40/17 ..Which covers more gap?
- Bad wheel bearing???
- swap 04 PI crate engine into 97 GT
- noise coming from rear end
- 4.6 dohc heads???
- P1151 - Bank 2 Lean
- Update To My Tranny Issues...
- v6 swap
- 99GT Heads on a 98GT???
- Ball socket/drivers side exhaust leak
- thanks again. u guys saved me a buttload
- 4.6/5/4 pistons
- programmer help
- New Suspension?!?!
- Delayed odometer at start up
- patriot heads
- Lights don't work help.....
- TR3650
- 315's and effect on suspension characteristics
- Broken Shift Boot Clip?
- 3650 Question NOT TSB RELATED
- Strange Noise, Suggestions
- Time to replace shocks and struts
- harness location or 4.6/ wapping out the 3.8
- I have to be the record holder for this...
- Window problem
- Brake Help
- FUEL LINE REPLACEMENT
- Help.....car does the strangest thing when going over bumps...
- 255/40/17 vs. 245/45/17 need a quick answer
- Plugs
- Strange smoking problem
- Cam gear oil problem
- Code p0340, sensor replaced, check engine light gone, but car backfiring...help!!!
- How to wire fog light switch to 248a 96gt?
- how to..
- 100 Octane Unleaded fuel
- Throttle Body Decision
- The bottom bolt on the vortech bracket help
- Lifter/Rocker Question
- Brake pad change help
- I Got a Big tranny Problem
- Is my ECU/electronics gonna be fried??
- quick tranny swap question
- Motor ideas
- 04 Mach 1 column for my fox... no keys!
- JLT Cold Air (Searched)
- Getting a strange Clunking noise
- Rear Window Weatherstrip Replacement Help
- Pulling the OL' 4.6L
- 2001 mustang gt do i need a new rear sway bar ?
- In desperate need of help!! Alternator dead!!
- changing rod bearings with motor in car.
- Getting hard to shift...
- lightning maf????
- Cams - Valve/Piston spacing
- ABS light
- Do I need a MAF and injectors?
- cc plates?
- Randy - parts question
- Do I need a Friction Modifier in my differential
- Can this be done
- coil spring vs. coil spring
- Anyone using the DashDaq?
- steering wheel wont come off
- Removing stock exhaust question.
- Changing the mach 460 head unit...quick question
- Engine Rebuild
- So just got off the phone with vortech
- 2001 gt PI intake??????
- Help!!! ECU dead
- MIL Tech Question
- 04 Mach 1 --> 88 fox: ign and multi-func wiring HELP!
- Somethings Wrong Please Help
- IAT Sensor Relocation?
- After 2 years, I'm Back in the Game! - Engine rebuild need help!
- Car won't start when cold....
- Torque Boxes
- Head Swap - Anything else I need to know?
- Clutch Clunk???
- Mark 8 swap
- Please help, I cant get my belt back on!
- Lightning Mass Air Meter
- Good Repair book for new edge Mustangs?
- possible clutch problem
- Vortech Supercharged guys here.... Having Oil problems still...
- lowered with longtubes?
- polyurethane bumper repair
- shorty header?
- Header Bolts & Nuts
- Want to Know how to install a Vortech SQ S-Trim??
- gear break-in question
- anybody have the mrt cated h on a 02 gt?
- block for tt
- 2000GT, Need new clutch. Please advise.
- Supercharger setup help
- Are MSD Coil Overs worth the money?
- struts or shocks 01 GT
- How much boost can the stock ignition handle?
- o2 sensor
- Caliper sticking?
- Oil pan gasket
- Are subframe connectors stock on 99-04 verts???
- How To for Oil Seperator
- Terminator suspension kits?
- CEL's
- 275 MT drag radials
- The widest of them all!!!
- what brake pads do you run??
- How Much RWHP?
- Tokico 3026 Torque
- Do I need to upgrade to 8-rib pulleys?
- LONG TUBE RATTLING ON MY 2000 GT
- stock sway bar size on a 2001 mustang gt ?
- 2000GT, Sluggish / hard shifting
- 2002 V6 to V8 swap
- Eibach Pro-Kit or Ford Racing M-5300
- New trans, same problems
- 96 GT missing under load??
- Crappy ford tune
- Negative toe on the right rear
- Question about switching side exhaust to rear
- Infamous Chirping Sound - Heater Blower
- HELP! installing cams HELP!
- 500rwhp how-to write-up w/ sq-trim
- installing cams?
- cobra rear brakes and 15" rims
- Which tuners or chips will remove pats
- 4R70W Smart People in here!
- 98 GT steady acc = bucking
- Help me remember where this part goes.
- Will a 95 gt rack fit a 2000 gt?
- cobra bumper
- More Problems Help
- I think my idler pulley is getting ready to die *Video*
- Kenne Bell Supercharger
- Aftermarket Parts & Clutch Kit Help
- another 2 problems for the stang....
- My interior roof is caving in near my windshield!!!
- 2000 gt engine noise
- High revs upon start-up
- cruise control
- REBUILDING BLOWN MOTOR
- 1998 GT getting a Cobra front bumper...questions..
- stalling when cold?
- Automatic Almost Stalling?!?!
- easy wheel offset question...
- Need help with 97 GT stalling problem
- Oil cooler filter adaptor?
- t45 removal
- Courtesy lights/97 GT conv.
- gt vs svt block?..help!!...
- Water Pump Troubles
- gotta a few leaks, thinking about pulling the engine. any advice
- Need a valve spring compressor to remove springs off NPI/PI heads?
- Blowin some smoke
- HELP!!! My Mustang has Problems
- how to make 97 gt fast(er)
- Did I hook up my trans cooler wrong?
- Relatively new clutch making noise! help!
- Car Hesitates...
- Tranny Issues...Please Help.
- Explorer Motor Drop in.
- 97 Gt (auto) Question about order of Pi Swap
- injectors?????????
- No coolant circulation 99 cobra
- exhaust manifold stud and bolt
