View Full Version : 4.6 Tech
- Next Mod?
- Drivers Window won't go up/down
- Superchips Max MicroTuner
- MAF screen?
- 3 things, Where do you buy mach 1 lip?Anyone with wheel spacers?speed w/ 410's
- Low 12s...99 GT 5speed Sprayed. How?
- PI swap done! but a little tick now...
- turbonators
- Shifter
- Mustang Parts for sale..
- OK guys..here it is.
- Where is the fuel pressure regulator on a '98?
- Can you guys please help me on this One
- gas leak
- tuning chip..??
- stock CAM Specs
- am I losing POWER with this????
- Bullit
- 98 cobra with an '03 6 speed????
- Eibach Pro System Kit?
- Cobra vs. Bullitt....rocker panels, that is
- New Subframe Connectors Installed!
- MRT Catted H-pipe w Bassani Cat-Back w/o Baffles SOUND CLIP
- Quick question...MAC or BBK off road H
- Estimated time of removal/install
- Where can I find a Intake manifold with an aluminum water runner?
- A few exhaust opinions/questions
- Which exhaust with Stock H?
- Rear Main Seal Leak
- Stock gears in 2000 compared to 3:73
- is a catted X or a catted H better?
- Need Help...
- Long tube problems
- 2003 auto GT - Shifts seem too rough, could use some of your thoughts.
- Rear end differential Gasket
- So the car I JUST bought is already ****ing up on me...need serious help
- ECU code ?
- o2 sensor problem
- how many mph's will i be off after my 4.30 gear install??
- What color bumper cutouts for an Azure Blue Mach 1?
- Big Problem, Need Advice
- Buying a used Steeda Tri-Ax?
- How much PSI?
- how to clean maf
- Pro 5.0 Ripped my shifter boot
- Sound Clip Needed: O/R ProChamber + Borla Stingers
- michelin sport cup tires
- 4.10's highway mileage
- clutch is gone
- rearend problems
- catback
- A Ferfect Idea
- Venom Nitrous Kit for SALE!!!
- Tire sizes..
- I'm sick of my TR-3650.
- Engine Noise
- Differential Oil Type?
- Need Major Help, Please...
- 96 Cobra chip or programmer
- Underdrive Pulleys?
- $4500 for mods
- New Mods
- B&M auto shifter
- Really stupid coolant question...
- Engine
- Need desperate help with BAP/wiring upgrade...
- brake question?
- POWER shifting
- Adjusting exhaust pipes...maybe bending
- March ram air
- Easiest way to raise compression
- ANY LOSS oh power
- I wanna know about Edelbrock IAS Shocks
- Gears?
- pro 5.0 install... 04'
- HELP!!!! GEARS 3.73 or 4.11's or.....
- Trade my GT rear end w/03 Cobra?
- Pullies Good or Pullies Bad?
- daily driver clutch
- hood scoop
- help on throttle body install
- Can you put 4v heads on a 2v?
- Rattling driving me CRAZY
- Topline Whitebox Shifter 3650??!?!
- anybody know anything about DSS engines?
- i found out what that ticking noise was!!!
- trying to pintpoint a problem after s/c installation
- IF i needed caster/camber plates for new springs, would these suffice?
- 2v twin turbo running again
- Mach 460 Stereo
- Aftermarket gauges installed, now have ??
- Procharger hoses? Pic inside.
- Torque specs for clutch?
- Stereo Installation Question
- Underhood Insulation
- Spinning only one wheel with slicks?! :(
- need a crusher for gear swap?
- Engine miss/hesitation
- How much power can a stock 4.6 bottom end handle?
- totalled car; no way to put stock tune back from predator?
- How too get this Crap off?!?!?!
- Need seperator plate hole diagram
- Need help with my 96 cobra
- DO i need a tune for THIS??
- which mod should i do next?
- INSTALLED ACCUFAB,75mm,CAI,& Predator???
- '03 motor in my 96?
- Track Times 1/8th
- what would be your next mod
- Storage Compartment (Under Radio)
- Front End Question: '00 GT 'Vert
- changing console/stereo stuff
- Mgw = Wow!
- Quarter mile time question
- I changed drive belt, and then...
- How low?
- how many times have you changed your exhaust
- Removing Emblems
- Compression Raito?
- O2 sensors + Diablo Predator tune + dyno = ?
- Cleaned my engine bay!
- Car seems quieter after tune??? Am I crazy?
- Brakes are doing weird crap
- New wheels
- Flaming River Power Rack for 94-04
- SCT just stopped working
- NX kit - 100 shot
- Chance to put a Cobra T-56 in my GT - Should I buy this?
- Strange no start problem
- am i safe with this set up and is it true that
- Anyone tried rebuilding a wheel hub?
- Need some advice on suspension plans
- Diablosport Predator Performance programmer
- New 4.6L Owner, have some n00b questions...
- What is the Best NITROUS Kit for The $$$
- What is the Best Throttle Body and Plenum
- heavy / stiff Clutch
- is this a crock or does it work?
- VA emissions question
- '03 Mach 1 w/ Rebuilt Title
- turning off o2 with predator
- Anyone got a 96-98 GT Vert Auto... Drag times ?
- new best at track last night
- high compression
- Looking for Best Price on Bilstein
- intake recall dates?
- Auxilary power in center consule
- Can't do a burnout
- BBK Tuned Length vs Mac Long tubes
- Polyurethane End Link Kit ??
- A two part ? Super Unleaded Gas & A Shift Light
- Vibrating Clutch Pedal
- Warranty Questions??
- bbk 4.6 shortie headers reviews
- A/C blew up today. 01 bullitt
- accufab TB Plenum
- EGR or Smog tube connected to header...what size Nut ??
- Why do some claim a tune is needed after a CAI??
- ignition capacitor. what/where is it?
- what psi do you guys run on pump gas?
- Technical brake upgrade help needed!
- What gears come in 04 gt?
- What's The Rev Limiter Set At From The Factory
- mac prochamber with flowmaster one chambers
- Throttle Position Sensor Calibaration????
- Which Flowmater muffler......?
- Dallas Mustang Speedo Recalibrator
- how much h/p
- Predator tuning with a wideband sensor?
- realistic 1/4 time
- vibration over 110 mph with 4:10 normal ??????
- Another PI swap question...Imagine that.
- Idle Air Control 'Motor' ?? IAC Valve...
- Which O2 sensor is this?
- 4.6 head swap kit
- if you needed to replace your motor(in ca)
- Do rear end gears add to your HP #'s on a Dyno?
- Grinding while turning
- What is the difference between a '96, '97 or '98 Cobra Oil Pan?
- Leaks Anti-freeze??
- Fuel pump
- What gear ratio for auto. 2003 GT's
- TRI ax shifter
- X pipe noise
- Dr. Gas Hangs
- Ss Vs Bullitt
- What are all the parts needed for a rear gear swap
- H Pipe to Header bolts...can't get them off help
- tire sizes on a 99 GT with mach1 rims
- cats removed....
- T-Handles Comfortable?
- P0172 ? Need Help
- Help scraping coming from somewhere!!!
- Flow tech LT header?
- Need Advice (04 Engine into 97)
- Anyone with the Maximum motorsports Sport Box
- quick blower questions!
- rear brake popping when put in reverse
- Will 03 Cobra gaskets fit my 99 2V?
- where to find 9" rear?
- Bassanni x- pipe problem
- drop in or cai?
- turbo
- isolators w/Steeda Springs, IN or OUT ?
- Cams?
- What Cam for future blower combo?
- quick clutch question
- Power shifting?
- need x-pipe help!!!
- Will an Autometer Lunar instrument cluster,fit a 2004??
- Help!!! Starting problem.
- Replacing AC cmprssr clutch assm...purge system?
- tire advice
- Question: Tie rod ends need replacing at 45k according to the dealer..??????
- full length header clearence??
- question about shifters
- Startup Problem???
- Tensioner
- PCV Valve ?
- Sub Frame Connectors on Verts
- Anybody use the 1" wheel spacers from 50resto.com?
- Need info on free flowing, straight through design mufflers
- Suspension
- Tri Ax shifter's question
- '99-up rear end dimensions
- What will control arms exactly do for me?
- ANy idea how to cover up/get rid of the license plate wholes in the front?
- Hmm Which Shifter??
- Fuel Pressure
- Synthetic oil a "waste" of money?
- FRPP Aluminum Driveshaft question again
- I need blower advice !!!
- Finally Dropped It (PICS)
- Need Track Help!
- Auto Trans Rebuild Videos Online!
- Lincoln 4.6 DOHC
- Need Advice For 98 Cobra
- Steeda Tri-Axe or Pro 5.0 Shifter?
- Exhaust! :shrug:
- '05 front end on an '02 GT
- where to buy a saleen s281 wing for 02 GT
- Installed KB, Low #'s?
- Subframe connector brand difference
- 18x10 Wheels
- any body have an H pipe with flows?
- building an engine
- will a 2000 mac pro chamber fit my 98 gt
- Suspension wizards... Adj upper control arms good for what?
- Question about a K&N Air Charger kit on my Mach 1
- Mass Air Meter
