View Full Version : 4.6 Tech
- O2 sensor problem...
- exhaust
- installed lmaf and 42lb injectors and flashed my ecu
- slp lt power curve
- Need Help ASAP
- Creaking Seat, anyone have the same problem?
- Lost torque maybe??
- Car lurches after 4.10 install
- Transmission fluid temp concern with 4.10s in a 4 speed auto
- What's needed for a 5.4 swap
- 235/45ZR17 and 245/45ZR17: any noticeable difference?
- Fuel Rails
- Driveshaft Vibration update.
- Went to the dyno today... odd results..
- timing
- What octane gas do you use?
- what color paint do i need for the cluster?
- Best Place to Buy NX wet kit
- Help Please. (Couldn't find it via searching)
- Two things...
- about control arms.
- what brand rebuild rear kit did you get?
- Quick Electrical Question! Help!
- Weak point of 2 valve 4.6 motor.. RPM?
- Where to find new motor?
- Post up pics of exhaust brackets
- Replacing the Drivers side manifold studs..
- Whining from an idler pulley?
- Ford Racing M-5400-A
- What a pleasant suprise...
- 275/50/15 the same as 26 x 10.5 x 15????
- possible reason for loosing coolant?
- Wierd whine coming from rear. HELP!!
- 4.6 Motor Oil ?
- plz help w/ gauges (boost/oil p)
- 245 & 315 instead of 275 & 315 ??
- What intake for my 5.4?
- bullit or pi or somthing else
- Water in headlight!
- LIGHTEN MY VERT...with a conversion???
- What exactly is in a stock 281" ??
- PI Stage II heads or Super Charger?
- Intermittent Driveline Screech Noise
- K-member torque specs?
- Opinions on a nitrous set-up
- Center mirror removal
- subs under back seat??? anybody?
- Tire thread again
- What is a a good plug ???
- P.i. Question
- wheel polishing price
- how long does it to replace a clutch in a 98 GT????
- tires for a cobra... which ones
- H&R Race Springs
- diablo predator
- Superchargers
- Steering Q
- Anyone ever been here?
- Problem with driver's seat shifting slightly
- best place to buy vortech s/c
- Clutch Pedal Adjustable?
- Wheel size saleen??
- High Milege 97 GT
- Anyone with SLP Loudmouth I's?
- quick ? B 4 I take car into shop
- how long till they break
- borla exhaust ?
- Need Help! Autometer Lunar Gauge Cluster
- got new tires, how are they?
- Weight on a stock 94-98 hood?
- Ducktail spoilers for 99+ Stangs?
- Falken Tires
- 02 GT idles high, and returns to normal slow
- Tires or Pulleys
- guys, will getting p&p heads change my exhaust or
- spring rates, and other related questions
- 96 GT stock.. need rumble
- difficulty of cam install on a 4.6 2v?
- MIL's
- Making those great racing videos
- Anyone ever mount a NEON underbody kit, please help.
- H-pipe
- flaming horse
- Time for another bolt-on. WHAT?
- Fellow Vert Owners...Help....
- pending codes??? huh?? for OBD-2
- Tech links-Lowered
- Girly Question
- Pi intake swap
- Help identifing Rims.
- Touch Up Paint
- Ford racing strut tower brace
- anyone have a pic of the mac straight shot
- Is this an exhaust leak?
- OBD II emissions testing
- Changing Plugs Tomorrow - Need Quick Assistance
- MGW shifter
- PST Carbonfiber Driveshaft group purchase
- 2000 cobra R wheel
- factory gear?
- Performance vs weather?
- What would you do.
- throttlebody
- Why the major price difference?
- Cam ?
- ODBII testime.......advice please....
- Clutch still good?
- Throttle cable ?
- Steeda Control Arms
- pressure plate
- new hood/shaker system & bumper pics!
- Choices?? What to buy?
- tire rating question
- 05 wheels
- front axle nut size help!
- exhaust advice
- fouled plugs
- Meatal to Rubber Squeak ?
- Bearing kits for Gear Installation.
- SES light- No codes, but weird idle problem.
- smoking egr? help..
- Tire Sizing for '00 R
- 4.6L engine issue
- 895 Foglight Bulbs - Anyone Running These?
- just give me the resonators from the SLP
- ABS Light won't leave
- Hpipe leaks at header
- Gt Badging issues
- Lock gas cap?
- help me lose weight....i'm fat
- HELP!! Broke down on I-95 last night!!
- How much of a gain from porting PI heads?
- Exhuast leak from hell and the DR GAS X pipe
- i dont want to embarrass my self....
- i meant cleveland,oh
- New mod for 97 cobra?
- anyone in clevanland get gears swapped?
- Strut bolts
- Car starting to ping :(
- Anyone have Spintech pro streets & O/R X?
- Intake Combo
- Pros and Cons of 4.10's
- stereo install ques.. not stock mach
- Motive 3.90
- Ouch!!! Need some body work..
- Is MAC garbage?
- superchager parts Q
- Fuel Injectors?
- 4v engine swap
- Sludge in Engine...Gotta Replace?
- Engine strain
- SCT Panel Installed
- BBK Plenum?
- which side is which
- BFG Tires
- Which Catted H-pipe to buy?
- Exhaust Question
- Tires?? need help
- I know this question has been asked 1000 times
- Shopping for parts
- Anyone in NY have a tuner?
- Eibach vert springs on a coupe?
- x-pipe or not
- first dyno tune on sat
- Water in Spark Plug Hole
- Aluminum Driveshaft for 4R70W?
- PI heads and cams and MIL eliminators
- Derale Transcooler
- installing an H-pipe
- Eibach Springs .. "not low enough"
- 04 injector size
- Mach 460 replacement - wire harnesses
- heads + cams better then all else?
- Poor fuel pressure!
- Inexpensive tiers for Saleen Replicas
- What do you all think? Question about racing stripes
- Cylinder 6 misfire.
- Fuel Pump Install - Info needed.
- 04 Cobra or Repair 00GT
- Question about lowering
- 1998 Cobra fog light help needed!
- Tune/clunk question
- High Volume Oil Pump
- Mach 1000 acting ugly
- 97 Cobra t45 Rebuild
- Supercharger Vs Heads
- Why did Ford go returnless?
- King Cobra
- Mobil 1
- Got Some Cash How much RWHP can I make??
- Now that im blown... what cars are a match for me besides other highly modded ones?
- does any of your cars feel good some days,
- pulled some codes today
- HELP!!!! Warranty help!!!!
- White smoke at startup
- the rear anti sway bar...
- 3.73s
- what and where is the silencer?
- What launch RPM
- Not a blown head gasket afterall..
- Bullitt exhaust tip size?
- Quarter Mile Time
- HELP! Car wont start
- Window tint poll
- Steeda Tri-Ax Shifter
- At what rpm does a Cobra become a Cobra
- Carburating a 4.6??????
- cam install gone WRONG!!!
- SRT-4
- mgw shifter
- why do I only see 10 posts at a time??????
- Engine Noise At Startup?
- FedEx came...Longtubes & X pipe!!
- FR500's, Anyone have These?????
- Hp Twin Turbo 2v Dyno #s
- Tires Opinions
- Coolant leak at the front of motor
- Cam Duration
- ecsta supra 712 compared to nt555
- Parting out car
- What Tranny?
- Just got 4:10 installed but...
- 94-98 Guys with Saleen Body Kits... Step Inside
- 4.10 Gear Swap - What all will I need?
- Chrome Bullitt Wheels...
- 1999 11-sec all motor Cobra for sale, 13k in mods.
- Crusted coolant on plugs in bank 2
- 4.10 Gear At Home Install Time
- At Home Tuning - What to watch for?
- Broken off tip on dipstick
- Will a 6 speed fit a 96 GT ??
- NXL Direct Port Nitrous
- good 5K or not???
- Venom nitrous?
- 2 Question.. which trangso kit.. and how to lauch an auto..
- 98 cobra HP estimates plz
- I need a v6 trunk w\out a spoiler
- How To Get Rid Of Rattling Noise
- Car shakes very rough after starting
- more performance???
- thinking about nitrous...?
- pics of my MM Motorsports 4 bolt caster/camber plates
- cobra clutch for GT?
- 4.10 T-45 test in a 1998 GT....
- last chance for input!!!!!!!
- sct for 04 gt. need some input
- tranny question...????
- Question about exhaust
- SES light having a hiccup?
- Sheared off fake scoop, drivers side. Help!
