PDA
View Full Version : Classic Tech
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91
  1. Alternative Alternators?
  2. reverse light
  3. Rust encapsulator: Should I use?
  4. Trying to set my timing
  5. Getting the Rustang roadworthy again
  6. Good Mechanic
  7. Should I go for this Holley DP on Ebay?
  8. Oil pan gasket question
  9. Car Security- Inline Check Valve
  10. Cam too tight in rebuilt engine?
  11. 69' Mustang power steering swap??
  12. Installing a dual master cylinder on my 1964 1/2. How should I hook up the lines?
  13. Cheap wheels for the track
  14. 2nd post
  15. Larry's Performance
  16. Any '69 coupe guys w/ a 3-3.5" cowl hood?
  17. 302 timing question for my 68
  18. Mach 1 Console
  19. Vin# Info "S"-"A"
  20. 1969 mustang Neutral safety switch problem
  21. quick paint question
  22. turbocharger on ebay what do you think?
  23. Carb issues
  24. Cowl Repair.....ohhhhhhhhh
  25. carb question :shrug:
  26. Help mounting 1970 mustang disc brakes on a 1969 ford mustang
  27. Engine Compartment Light
  28. Granada Discs, T5 question, Pan Rust Question
  29. Torsional rigidity test: 67 coupe
  30. Options with Pertronix II
  31. Front bumper fit on 67
  32. 1/4 Window inner beltline
  33. More Powersteering questions.
  34. Should I take my car to mexico to get it painted?
  35. Help, I'm out of parts to replace! -- Electrical
  36. chasing fuel vapor
  37. Testing Oil Pressure
  38. 1965 V-8 Fan
  39. getting my car painted!
  40. 1970 Mach 1 Steering Wheel Size
  41. my Stang going for a full respray (lots of pics, dial-up warning)
  42. coolant leak under glove box....
  43. Does anyone make a fuel sending unit with a bigger pickup?
  44. 1968 DOHC 4.6 Coupe Project
  45. HP guess
  46. 600cfm Edelbrock Performer Series Carb Problem
  47. Just had the suspension and steering redone. WOW!!!!
  48. I need help!! Is my 68 worth saving?
  49. Anybody using Jegs SBF aluminum heads?
  50. Stock manifolds choking engine?
  51. Steering and Suspensin questions
  52. Power steering woes.
  53. MIG Welder
  54. Manual Transmission Conversion
  55. Progress Pics
  56. Fiberglass hood work/prep
  57. How to: 12v Relay
  58. Frame Rail Repair
  59. 67 Coupe Headliner Installation
  60. what would be my redline?
  61. turning radius
  62. How to use a voltmeter?
  63. '65 Door Internals Assembly
  64. Alternator Wiring How-To
  65. What would cause engine break-up at 5200 RPM?
  66. What are these?
  67. What are these?
  68. Sealing Differential
  69. rebuilding my 72 mach1
  70. Best battery cable lugs/terminal ends
  71. Hard Starting: Looking for possile leads...
  72. '70 Mach 1 Sport Lamp Switch
  73. wiring mini starter without stock solenoid...
  74. Mustangs Unlimited Headers Update
  75. 351W Identification help
  76. Drip Rail Moulding Weatherstrip/Sealer
  77. MII rack and pinion
  78. is a 3" exahust too big?
  79. Type F, Type FA, Mercon, what fluid?
  80. Part search - conv top boot cover retainer strip
  81. floorpan paint question
  82. Re: The crashed mustang in S Carolina
  83. Ignition Coil problem
  84. Falcons with quadrant/cable setup?
  85. driveshaft length question
  86. Brake pedal falls to the floor after rear brake line replacement
  87. Pony kickpanel assembly
  88. Hydraulic Clutch adjustment
  89. FP Eccentric rubbing timing cover?
  90. Car wants to crank when hooking up battery
  91. Voltage regulator
  92. Hesitation and sputter problem aroung 2500 - 3000rpm
  93. Sad day for NHRA
  94. ignition timing
  95. Your Engine Compartment!!!
  96. 68 Drivers seat, repair question for rebuilders
  97. 1967 Mustang
  98. Nightmare Mustangs Unlimited Headers
  99. Another 9" question
  100. 17x8 wheels up front??
  101. Centerforce clutch question
  102. Project Outsourcing Tips and Lessons Learned
  103. Hydraulic clutch conversion
  104. '66FBGT 289 Engine Rebuild Estimate
  105. Header / exhaust recomendations
  106. 12 volt connections. What are my options?
  107. unisteer rack and pinion problems
  108. Rear end Id help..
  109. Outer wheel housing removal?????
  110. clutch / brake pedal??
  111. Tranny trouble, need advice
  112. Timing pointer
  113. Random dying and backfire in 66 289
  114. Please describe the behavior of a locking differential
  115. Valve stem seals part number Cleveland?
  116. Rear brake line bracket relocation
  117. Got a decent mph at the track last night
  118. help w/ 289 head/intake/carb/cam decision
  119. Stupid Emissions Question...
  120. Strange Starting Delay
  121. Stock 6-cylinder cam timing?
  122. Wet spark plugs....
  123. Ignition switch or solanoid
  124. On-line instructions?
  125. Alternator question
  126. 72 mustang 4 speed header issues
  127. Brake line problems???
  128. Fuel Sending unit
  129. 18's really to big on a 65-66? pics inside!
  130. Anyone know where to find a door? or anyone have experience with the aftermarket
  131. 65-67 KH type disc brake parts
  132. Engine swap - Intake Height Problems
  133. AOD swap questions-wiring and flexplate
  134. Fuel pressure vs idle quality
  135. White smoke from exhaust.
  136. 33 dodge coupe, 68 tbird 429 balancer questions
  137. need help
  138. Help Diagnos Compression Check & Leak Down
  139. What octane fuel do you use
  140. new dyno #'s for the turbo 67 mustang
  141. 289 or 302???
  142. In Line 4 barrel carb
  143. How much HP.... 302
  144. heavily worn thrust bearing on #3 main
  145. Transmission Kickdown Cable
  146. Where to find a deep groove V-belt pulley for 3G swap
  147. Stuck again
  148. Slternator on a 73-which wires where?
  149. Anything missing from this combo?
  150. The Game Plan
  151. Anyone ever seen an L88 hood scoop on a classic Stang?
  152. Mustangs fancy sister?
  153. rear disc brakes cure lockup
  154. Oil Pan for 351w
  155. Your thoughts: Panhard bar & Ron Morris coil overs?
  156. Falcon/Ranchero welcome?
  157. Rebuilding a 9” Third Member?
  158. Where to get 67 falcon Rear Leafs?
  159. First start up....
  160. Deck hight 351W ??
  161. flowmaster exhaust
  162. Holley 4160 tuning help
  163. Front End Alignment
  164. Overheating but only when keeping engine above 2k rpm
  165. Timing and total advance ?
  166. How much good are Tri-Ys with my set up?
  167. Please any advice
  168. What am I forgetting?
  169. Anyone have a watts link ?
  170. 157 tooth or 164,
  171. HEIDT's Rear 4-Link& sub-frame connectors
  172. Radiator Hose
  173. Engine removal
  174. Disk brake kits
  175. T-5 Spacer
  176. Need cam opinions please
  177. Roll bar question
  178. Wheel/Tire Fitment
  179. What size Radiator will I Need?
  180. Tail/Brake Lights Don't Work
  181. Removing vinyl top
  182. Valve Stems Selas or Worse?
  183. accelerator pedal pivot rod
  184. Rear End Swap - Can I Use Old Plates
  185. If you had...
  186. Accessory mounting plates
  187. C4 Not locking into first gear????
  188. The "Mustang II" IFS Real Info & Debate Thread
  189. Six Gauge Instrument Cluster
  190. NPD's Power Brake Conv. Kit
  191. rear defrost wiring 71 fastback mach 1
  192. what ET for mph?
  193. 1968 I6, carb float the cause?
  194. 17 inch rims on a 66
  195. SPEC I clutch gone after 40K moderate miles
  196. T5 and Mercon V?
  197. aluminum radiators
  198. Help with a 351M problem
  199. Weird Noise
  200. Top 30 Winner
  201. Saga of the Crown Vic Rear Discs
  202. bezels removal
  203. 460 in a 67
  204. Car Alarm on classics
  205. Almost gametime...
  206. 1970 Mach 1 Spoiler
  207. pertronix spacer
  208. Marti Report - need transmission info
  209. 4.6 fit in a 1965 mustang
  210. 87-93 brake booster in a 66?
  211. Sloppy Steering
  212. NEXT THING ON THE TO DO LIST..
  213. Tremec TKO Installation in a 69/70 Mustang?
  214. 289/302 Questions
  215. Valve clatter could it be timing?
  216. What gears do you have?
  217. I got the new front suspension on but?
  218. 65 Fastback rear seat belts?
  219. Fuel Pump Selection
  220. 71 fastback questions
  221. Tranny Rebuild Help -
  222. I have a couple stupid questions
  223. protect your wheels
  224. carb help!!!
  225. 351C heads question.
  226. Cams Cams Cams
  227. Fuel injection
  228. problem with tach with msd in 71 mustang
  229. Shelby Valence Opinions Needed
  230. Headers
  231. Quck tire question
  232. 351W question for my '68
  233. We dropped motor in yesterday.
  234. Can I use the green-red wire from the voltage regulator as 12 volt source?
  235. 67 fb gas fill neck/tank install question
  236. quick help
  237. 67 351w/ will 85 F150 AOD work?
  238. Brake line clips
  239. Thoughts on the new CPP front suspension?
  240. can you kID a hydr. roller cam by eyeballing one?
  241. chugging away
  242. can I?
  243. ? for you engine builder's
  244. Battery tray & apron delete idea (pics)
  245. Popping through Carb, WILL NOT start?
  246. Do I need staggered rear shocks on my '73?
  247. 351c wiring
  248. Vintage drag racing footage
  249. Feelin' the Heat!
  250. Synthetic vs type F tranny fluid
