PDA
View Full Version : Classic Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91
  1. brake problem
  2. BRAKE HELP
  3. t5 swap - mid project questions
  4. Whats a used C4 worth?
  5. upgrade suspension on a budget????
  6. 69 Clutch Pedal on EBAY
  7. Need more grumble...
  8. Alternator - Voltage regulator problem
  9. converting from 2 piece to 1 piece rear main. Gotta a ?
  10. Cant line up rear leaf spring!!!
  11. '68 Power steering problems
  12. Is CompCams camshaft a good selection for my 393 Stroker?
  13. Identify my Rearend and Two Mystery Parts
  14. Help With rear end ID
  15. Best A/C system for a 66 fastback
  16. Will 70-71 Torino disc spindles swap to a 70 Mustang?
  17. Brake Pedal
  18. help w/ rust around rear window on 66
  19. 2500 STALL WITH 3.25 GEARS?
  20. Sputtering and Stumbling under accel
  21. Wilwood Forged Spindles
  22. of corse another problem haha
  23. Re installing axels- Problem
  24. Car dynoed and off to the races.
  25. 1970 351 C Sanden Compressor Belt Routing
  26. the continuing saga of Steve Austin, the 6 million $ car
  27. wat rim/tires are these?
  28. rear main-leak
  29. I'm Clueless / Muffler Install
  30. "dead spot" at certain RPM
  31. No forward gears
  32. 265 50 15 1967 fastback
  33. MC help
  34. Vapor Lock??
  35. Shelby 302/289 Intake Manifold?
  36. 1966 straight six need help
  37. Where to get?
  38. versailles rear..which shock plates?
  39. 65 Engine/tranny/suspension swap
  40. Help!!Need 428PI/428CJ Guru!!
  41. POWER STEERING PUMP
  42. Finding 8" pinion yoke local in CT?
  43. Those of you with Rod and Custom suspension
  44. Emergency Flasher
  45. J-Car rack and pinion question
  46. Shelby Quarter Window
  47. manual steering adapter, 67-70
  48. Gt-40 Crate Motor carb jetting
  49. Headlight Extension Repair
  50. Bronco 9" swap
  51. What connecting rods are these?
  52. 72 Fastback restoration
  53. 72 Mustang Windshield Wiper Problem
  54. Subframe connectors?
  55. maximum compression ratio, 91 octane
  56. Ez Wiring Kit Help...
  57. At a loss!
  58. New Harness Question
  59. Timing cover gasket
  60. Faulty Window Regulator?
  61. WHEELS
  62. Idler Arm Bushing
  63. Sail Window Gasket Install
  64. What color is this Eleanor Fastback.
  65. Power steering bracket???
  66. Need help on a measurement-65/66
  67. Anyone try this setup?
  68. Short or Tall style motor mount for 66?
  69. Removing Steering Shaft???
  70. anyone use this
  71. Rear End Narrowing
  72. Header & 351w are not even close
  73. What rear end gears do I have?
  74. Need help finding/fixing exhaust hanger
  75. Removing camshaft
  76. Shorty header V ported cast manifold
  77. Odd fix for backfiring through the carb
  78. Where do you mount thermostatic switch?
  79. Pilot bushing for t5 swap?
  80. cam 3400-6800 rpm
  81. 351 stroker kit.
  82. Hi-Po
  83. 3rd in norwalk funford true street
  84. Is it a GT ?
  85. Car dies at high rpms
  86. exhaust sound: before and after Car Chemistry inserts
  87. One of the few, the proud, a running turbomustang
  88. new to stangnet 1970 mustang coupe
  89. filling up sux
  90. grinding starter?
  91. wrong tranny
  92. throttle spring help
  93. Wiring help for 1 wire alt and Accell distributor
  94. I need to ship a bumper
  95. Carb tuning help
  96. Need Help with 1966 289 that won't crank just click
  97. My headers wont fit
  98. Windsor questions???
  99. WHICH TIMING SET TO USE
  100. Flexplate torque specs
  101. dynacorn question, not debate :)
  102. narrowing a chrome wheel
  103. 68 MUSTANG ENGINE SWAP
  104. cowl
  105. 1967 Shock Towers - SOHC Engine
  106. 70 must. Which lokar throttle cable??
  107. 12volt switched power?
  108. 69 block worth anything??
  109. Turn signal wiring question
  110. bosch platinum plug ?
  111. Would not turn off
  112. Where does the air blowing my feet come from?
  113. engine
  114. Ignition wiring
  115. 65 Mustang gas cap
  116. Timing problem
  117. trouble with horns
  118. "Damage Control" w/pics (Cowl Vents)
  119. eleanor wheels
  120. C4 to AOD in a 66 Mustang
  121. Hydroboost questions
  122. temp guage
  123. Best way to mask interior for dash paint?
  124. T-5 conversion driveshaft yokes...
  125. ARE THERE GROMMENTS THERE
  126. How much exhaust is too much?
  127. Maier '67 racing front apron w/ spoiler - pics?
  128. MSD Street Fire
  129. setting up pinion on 8" rear end
  130. a few quick questions
  131. Painless electric fan relay kit, how do you wire manual override switch?
  132. My friend's project car maybe screwed
  133. side exit exhaust
  134. clutch pedal assembly for 71-73.
  135. This is kinda funny.
  136. Pipe thread and fittings questions
  137. Best Holley carb for 347 stroker combo?
  138. Currie Aluminum 9" Housing - for go or just show?
  139. Caster adjustment issues
  140. I hope I don’t get squished
  141. Ford Sqeek! Upper control arm
  142. Do Roller Idler Arms work?
  143. some new headers
  144. looking to spens some money
  145. Custom throttle linkage completed
  146. Driveline? Or engine?
  147. q code 72 fb
  148. 12 months after paints job... bubbles!
  149. wheel housing
  150. 65 mustang exhaust question
  151. Rear sway bar install
  152. '65 Tail Light Nut Tapered Spacers
  153. distributor wires
  154. Versailles Disc brake options
  155. gold nugget special
  156. Holy **** that was a BIG black widdow
  157. RE: engine stand
  158. pertronix ignition problem
  159. Whats the trick to remove the cowl?
  160. Export Brace Bar
  161. firing problem
  162. Question for 69-70 351w mustang guys
  163. Fuel Force Carbs
  164. Interior paint question
  165. Ever Heard Of: Metal Bonding Adhesive
  166. looking for engine code
  167. 65 Backfire
  168. ordering brake lines tonight
  169. Melted Fan Relay - pics
  170. removing balancer
  171. Pic of My Car
  172. I have no Idea what it could be...
  173. valve spring question
  174. Should I buy this Falcon?
  175. last tire question
  176. anyone heard anything about PRW?
  177. Wheel Hop..grr.
  178. 289 intake question ("new F4B or RPM Air Gap)
  179. Cowl vent paint question - 66 Stang
  180. 21" oval vs 14" round air cleaners
  181. edelbrock or crane cam?
  182. third steering column u-joint
  183. AOD shift
  184. Last thread.. I promise... tachometer options in a 66
  185. Aftermarket T5 shifters in classics
  186. Buying a clutch pedal tomorrow, need to know what to get...
  187. Gold Package??
  188. Speed Bleeders with Baer Brakes
  189. Compressor/rad hose
  190. No Fuel Pressure
  191. ALMOST DONE!!!!!!!!!!!!!!
  192. stripe sizes
  193. Bellhousing
  194. '66 Mustang 4 spd to T5, now want tremec
  195. Vent Window Weatherstripping
  196. Rhetorical question
  197. Aftermarket wheels on a lowered '69
  198. H/C/I Assistance
  199. Official Drag Tire Thread
  200. clutch/flywheel... before i buy, want to check to make sure its right...
  201. Carb Help!!
  202. JBA exhaust systems
  203. Brass Dist. gear wear with H/V oil pump
  204. PS pump removal..Belt Tensioner?
  205. 68 mustang power steeting with headers
  206. Bought from TruDesign Wheel or heard of them before? OR where to buy Mag 500 wheels?
  207. T&L or TandL engines experience? - crate engines w/warranty?
  208. How to mount an Edelbrock Cable Plate Kit?
  209. We've decided to do our own thing here in S.D.
  210. We've opened a shop in S.D.
  211. Which Paint Scheme?
  212. side cowl replacement
  213. C4 experts, need some help
  214. Transmission identification...
  215. Nickel, chrome, or ceramic Tri-Y's
  216. M/T Drag Radial tire pressure?
  217. Need pics of a 351c in a 65-66...
  218. Racing Stripes Part 2
  219. HELP!!!
  220. Ground Effects
  221. rear end measurement
  222. front steering for 67
  223. Late Model Seat questions...
  224. opinion on engine mods
  225. Driveshaft diameters
  226. what color is this?
  227. Quality of NPD's power top cylinders?
  228. radiator support
  229. Sound Insulation installation
  230. SHOULD I BUY A SFI RATED FLEXPLATE
  231. little shop help
  232. What pressure radiator cap?
  233. please dont kill me but what do you think.
  234. Aaaaaaaaaaaaaagh...yet another issue with 408
  235. heads, cam, carb, nitrous
  236. 66 COUPE - taillight short? need help?
  237. 134 a capacity w/ Sanden Conversion
  238. What would yall do here?
  239. HELP!!!
  240. Washed, Waxed, New Wheels - Pictures
  241. Backspacing on torque thrust D's
  242. Coupe-Convertible Conversion?
  243. In dash dvd in a '73
  244. Antenna delete
  245. New Radiator, could still be hot?
  246. Versailles Rear End Assembly
  247. a/c and p/s delete
  248. Wont start after it is warm/hot
  249. 05GT wheels on 67
  250. 71-73 Seat risers & floors
