PDA
View Full Version : Classic Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91
  1. '67-'68 GT Rear Valance Quality
  2. Trying to make head selection
  3. 66 with 17" Vintage 45's
  4. Anyone have a Steering Box Laying around???
  5. 351w headers and comments
  6. Rust Question
  7. body bolts, buy new or restore old?
  8. Easiest way to tell if I have granada/early mustang/other disc brakes?
  9. 1967 Tranny Question
  10. need dimension of side (rocker stripes) for my 66
  11. World Heads on a 302 need input
  12. 9" Axles and Bearings Question
  13. People with powermaster alternators, did you have belt squeal?
  14. 5.0 Engine Question
  15. Hole in Valve Cover!
  16. Racing Air Ride Suspention
  17. Brake Pedal Assembly Clip 1966 Mustang
  18. 5.0 brackets on my 68?
  19. HP to the ground?
  20. C4 leaks... inevitable?
  21. Learning from a mistake (cam install)...
  22. Engine build specs
  23. water pump , new engine old style car
  24. What cam with Edelbrock heads?
  25. which fuel pump eccentric on a 88 roller
  26. how to contain rust
  27. Who can ID these seats?
  28. 302 Engine build....
  29. Wheel hotochop request...
  30. Over heating
  31. White lithium vs synthetic grease on window parts?
  32. Does no one install R&P without a kit?
  33. 351W in 65 mustang help
  34. Brake problem
  35. Upper control arm movement
  36. C4 to T5 Swap U-Joint ?
  37. Roller Bearing Idler (no difference)
  38. salvage yards with rust free sheet metal
  39. Retrofited Sebring Convertible Seats
  40. Clutch/Pressure Plate Not Releasing ???
  41. CONV. WINDOW ADJUSTMENT
  42. Anyone with SN95 font suspension? 68?
  43. fat 14 inch tires
  44. Cable clutch adjustment?
  45. 17 inch wheels on a 69' Mustang Fastback - Correct Fit
  46. 66 BOSS 408 project
  47. 65 Fastback - Help Me Build It
  48. toploader ID
  49. How to do a Proper Wax/buffing Job.
  50. Some more security
  51. Workmanship rant
  52. Help radiator neck
  53. Today's work: ignition and elec-windows switches
  54. trunk carpet: installed
  55. late model into a 68 ?
  56. cant remove export brace spinning boltz
  57. ignition help
  58. LOW OIL PRESSURE
  59. Aluminum
  60. 351W, is this a good deal?
  61. New Problems with 347 build
  62. needle and seat problem (Holley)
  63. Drive shaft length
  64. rear end swap and others...
  65. plug leaking in gas tank
  66. A/C?
  67. Attention Fathers.... Trying to be a smart dad...
  68. 351c in a '65
  69. 65 A Code Engine Questions (restore to orig)
  70. Coil Spring Insulators
  71. Amazing what a little paint can do!
  72. Can you pull the steering colume out of the steering box?
  73. Hood louvers on a 1969 Mach 1
  74. NEED HELP ASAP
  75. Side Scoops
  76. heads and bore
  77. LONG TUBE VS SHORTY HEADERS
  78. Adjustable brake proportioning valve - where did you mount yours?
  79. Help Buying 69 Notchback
  80. NEED SOME SUGGESTIONS ON REAR SWAY BAR FOR 69 MACH 1 390
  81. Beginning roller 347 assembly... have Q's (lots of pics)
  82. Yet another wheel/tire fit thread...not a common rim though
  83. Are these wheels valuable??
  84. Wheel and Tire Suggestions? -- 65 Mustang -- PICS!
  85. Brake lights not working
  86. Car weight with aluminum block.
  87. Hard Fuel Line install-Impossible?
  88. Dies when put into gear
  89. Got my Tri-y's
  90. Need advise on car purchase
  91. dodge viper 6 speed trans is 69 mustang ?
  92. frame/body specs & measurements
  93. Another Ticking Noise ?
  94. 65 parking brake problem
  95. Lets talk Chassis stiffening and body flex
  96. six with a v 8 sound?
  97. stock looking bolstered seats
  98. 295 15 tire w/ 10' rim is it possible on a 70??
  99. HELP ASAP need to get to work and car is well messed up
  100. Eliminating Power Steering
  101. Tire Question
  102. Coil spring compressor
  103. my friends 88gt beat me :mad: + exaust Q.
  104. Alignment shims
  105. Holley 4160 vs dp fast idle ??
  106. What other Clutch Pedals Fit??
  107. Shorty headers, with RPM kit installed on a 289
  108. Tranny Gear
  109. SURPRISE! piece of piston in my oil pan
  110. Mustang pictures.
  111. Floor Pans for a Falcon convertible (63)
  112. KICK PANEL SPEAKER SOLUTIONS?????
  113. eleanor gas cap on a 67 coupe
  114. NO FUSE FOR HEADLIGHTS in 65
  115. THINKING PAINT!!
  116. idle problem
  117. Most likely a dumb question?
  118. Which timing chain to use?
  119. can i use std base circle with this
  120. Roller cam conversion a different way, is this possible ?
  121. sport seat foam and upholstery
  122. Big 67 power steering problem
  123. 68 Shelby hood vents
  124. Rocker arm totaly loose...
  125. Clutch has the shakes (the kind that break things)
  126. why do i go through so many starter silnoids?
  127. Stangnet, I've got it!!
  128. gasoline fumes in garage with car not running
  129. Headlight switch/fuse panel
  130. It's not vapor-lock / part 2
  131. Holley Street Avenger?
  132. 1/4 time for 347
  133. Starting problem
  134. Subframe connectors
  135. cheap cam+Lifters?
  136. Putting Together Fuel system
  137. Can a T5 be rebuilt to handle more power?
  138. Safety: Harnesses and Cage Q's
  139. dash repair question
  140. Brake questions
  141. wheel studs
  142. Template is 0.020" off - is that a big deal?
  143. Insurance wants me to find a body shop in sandiego for the 67' poor baby :(
  144. gauge cluster lighting problem
  145. '66 tire?
  146. Shock mount location?
  147. Vin# question problem
  148. Lowering blocks/U bolts
  149. Aamco C4 rebuild or TCI sizzler from Summit?
  150. Radiator question
  151. EFI Troubles, Help!!!!
  152. Header gasket type?
  153. ?? about Paxton kit
  154. Wish List!
  155. at what rpm do you have your c4's shift at?
  156. vapor-lock???
  157. Has anyone used TCPs Bump Steer Kit?
  158. Will 275's fit a 17x8?
  159. Steering Question/Problems
  160. roller rocker arms
  161. kick down bar
  162. Water Pump Question
  163. Prob a stupid question...
  164. Custom Headliner Ideas?
  165. Steering Question
  166. Anyone swapped in a '94-'95 5.0 EFI ?
  167. went to the track with the new turbo kit...
  168. Spark Plug Gap... head or block?
  169. Easiest way to determine year of C4?
  170. Tire?
  171. refurbishing stuff
  172. I think it's the timing
  173. Kids enjoying the car experience seating
  174. One headlight dim
  175. 73 Mustang Motor Mounts?
  176. IM GONNA BUY AND SELL!
  177. Why did this clutch cable break? Pics..
  178. How much did you pay for AFR 165's?
  179. 1965 GT Front and Rear Spring Rates
  180. 3 point seatbelts
  181. 90 efi wiring diagrams
  182. Electric cooling fan
  183. Identification # decoder?
  184. 69 Mach1 Project Progress
  185. TO CHAMFER OR NOT TO CHAMFER CRANKSHAFT
  186. Need source for cowl parts
  187. engine compartment measurements
  188. Expanding Foam
  189. Best way to clean and strip underside?
  190. 302 roller with a mech. FP
  191. Body Shop - Lower Hydson Valley, NY
  192. Drag wheels and tires
  193. 9 inch woes!
  194. 64-66 turbo mustang headers
  195. How much power can an 8" really take ?
  196. Idler Arm bracket for '65/'66
  197. Would these fit??
  198. Granada track width
  199. Quick master cylinder rod length question
  200. Shelby front end drop
  201. converting to dual master cylinder
  202. Going To The Track, Need Better Belts, and or Roll Cage?
  203. what c-4 transmission bolts to a 302 in a 65 mustang?
  204. 9" Buildup Questions
  205. Guessing Game: What Broke!?
  206. question about wheels
  207. Riverside Show N Go
  208. Spindle Damage
  209. Which distributor gear?
  210. 6 cyl or 8 cyl steering components.
  211. Adjusting Master Cylinder rod
  212. Need help finding water pump pulley
  213. Rear Suspension
  214. Cams not liking 2.79's?
  215. Finally got some paint on the car!!!
  216. Rollbar
  217. Hello from the new guy!
  218. Possibly a differnt T5 swap problem?
  219. "Carlisle" getting closer, are you going?
  220. Fuel Cell or Stock Tank
  221. Outer Wheel House replacement-71-71?
  222. Roller spring perches...
  223. Wheels/tires
  224. Cutting coil springs while installed?
  225. Interior Paint Fiberglass/Plastic/Metal
  226. so wow im stupid but i need help
  227. G-Machine 66 Stang, "THE CAR"
  228. Probably a Dumb Question
  229. Auto Sound USA-66 Radio
  230. Need Front Coil/Susp Advice
  231. 65-66 vs 67 KH caliper brackets
  232. Uni-body twist versus HP
  233. Need help with wiring alternator from scratch on my 66
  234. Suspension upgrade in progress
  235. sbf heads
  236. 66 Mustang wiring conversion
  237. Starting Off First Restoration
  238. What's the best way to get an alloy Rad in a 66
  239. New Project- still a Ford
  240. Help with Interior & Floor Restoration Tips
  241. Why does it die?
  242. WTF!!
  243. Finally have pics of my car for yall.
  244. Ford focus fans
  245. Northern Radiator & Taurus Fan install
  246. My T5 swap - Project wrap-up and pics
  247. Power or Manual Steering?
  248. shift light ?
  249. Harsh gear change on a FMX box
  250. 5-speed transmission that fits an early mustang perfectly?
