PDA
View Full Version : Classic Tech
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91
  1. 289 or 302?
  2. EFI starting issue
  3. update on 66 minitub
  4. Need some schooling on 8 inch rears.
  5. How do you change the fluid in a 8" rear diff?
  6. '69 Mach 1 Shifter
  7. Early 80's 302 Oil
  8. Brake light switch
  9. Leaf Spring Question
  10. Anybody used stock Ford parts for a Hydraulic Clutch?
  11. Needed: Headlight Switch Retainer for 1970 'Stang
  12. Fiberglass Fenders
  13. Transmission Kickdown
  14. cost of engine rebuild???
  15. Engine Tag decode: engine code no.
  16. 68 Mustang Seatbelts
  17. Engine starts (woot), starter making strange noise/having trouble turning it over
  18. Fires but doesn't start
  19. Question on Junkyard rearends
  20. Im ******* DONE with the 289! Short block suggestions?
  21. New Starter Squealing
  22. Electrical - A/C Problems
  23. In a 66, does a set of 65 motor mounts drop the engine at all?
  24. Any good frame/unibody repair shops in Detroit area?
  25. $500 barn find please look
  26. Engine quits without warning???
  27. found a 351w
  28. blower/supercharger on a 351w automatic??
  29. Where to find camshaft dowel pin?
  30. Another Rack and Pinion question
  31. struggles to shut off?
  32. Aod Swap - Speedometer Cable
  33. need engine build advice.......
  34. Tremec TKO-500 in a '71 Mach 1?
  35. Key issue
  36. Floor Pan pricing
  37. power steering growl
  38. EFI wires needed?
  39. See if anyone can make heads or tales of this?
  40. Almost got is started... kind of a whoohoo??
  41. Air cleaner recommendations?
  42. Started changing head gaskets tonight and header gasket question.
  43. Ms River Rouge meet Mr Cleveland
  44. Shop Manual. Paper or electronic?
  45. May have to sue my engine builder
  46. 1972 powersteering question
  47. 71-73 aftermarket oil pan for 460 question
  48. Ordered quarter panels
  49. Need suggestion on Hole in block... is it okay?
  50. 9" rear needs new clutches - where to get?
  51. Interior Products
  52. 70 spindle will it fit?
  53. Sub Frame Connectors
  54. bronze guide liners
  55. Dumb Ignition Question
  56. Fuel gauge and sender
  57. Had a problem at the track last night, need advice
  58. big block in fox
  59. C4 transmission has 2-3 flare up
  60. how much tower can i trim
  61. new to site 70 restomod ??
  62. IT'S ALIVE!!!
  63. Curious about the negative battery cable
  64. paint gun recommendation.
  65. holley carb
  66. How much will a stock driveshaft handle?
  67. Which High Volume Water Pump
  68. Weiand Colt 500 Intake
  69. Estimate on cost of changing to 5 speed
  70. 3.80's for a 8"
  71. wing removal
  72. 8 inch rear with 31 spline axles
  73. Good Price on 8" Rebuild?
  74. 750dp to big for a 351w?
  75. what type of distributor for blow thru turbo setup
  76. Seating MSD distributor -- sat flush before, now won't...
  77. Antifreeze leak from somewhere at the back of the block?
  78. Wanting to add Shelby decklid + endcaps to my '68 Coupe - questions
  79. Which oil pan to use?
  80. Fitment of headers
  81. What disc brake kit should I choose? SWAP.1 or SWAP.3 kit from discbrakeswap.com?
  82. 69 fenders
  83. door help
  84. 2005+ mustang steve brakes on a 69 stang
  85. front end rises but doesn't come back down
  86. One piece rear main conversion
  87. C4 external band adjustment?
  88. How to Title a Hot Rod
  89. 1973 Mach 1
  90. changing rear axle bearings on a 9"
  91. Sound deadener for 65 Mustang
  92. Need help with C4 not wanting to shift into 3rd?
  93. Obnoxiously loud squealing noise
  94. Carb Questions...
  95. Horn Button Troubles
  96. Headers with X-Pipe or H-Pipe?
  97. Camber problems
  98. quick question...mounting pad width on rear axle?
  99. Engine Temperature
  100. Fox Body X Pipe in a 67?
  101. DIY o2 sensor LED display
  102. 67 mustang 289 wont start not getting fuel??
  103. Front End Alignment
  104. suspension swap question
  105. best place to find 289 timing chain cover
  106. Suspension Kit
  107. Bushing installation order?
  108. 3spd auto not cooperating in a 65
  109. How much is the new combo gonna make?
  110. 65-66 Quarter panels
  111. Heater hose barb/fitting for Edelbrock Air Gap
  112. What can you tell me about these pistons?
  113. fire or fuel
  114. Question re wiring for 65 fastback
  115. Oil Pressure - Schematic of oil route on a 302 block
  116. sealer?
  117. what year will fit
  118. Looking at new distributors, recommendations?
  119. New distributor gear when installing new cam?
  120. Aluminum Trim
  121. Feller for a product, Traction Device
  122. another timing issue/ backfire
  123. Will 05 Stang wheels fit a granada front brake conversion?
  124. My heating issues may be over.
  125. Rear Frame Rail / Trunk Floor
  126. I'm lost identifying this block
  127. tilt steering for my 6T5
  128. ok i cant find it
  129. Fuel issue
  130. Rims and tire question
  131. Mid-teardown questions...
  132. Does painless really not hurt?
  133. 2 peice shrouds?
  134. Carter AVS on a Ford motor?
  135. 67 mustang question
  136. Decisions, Decisions....
  137. FMX Auto Transmission - Help!
  138. ignition miss
  139. ignition miss
  140. After 3 1/2 years IT'S ALIVE! (pics)
  141. enriching mix with an autolight carb
  142. Power Steering Pump Toast!
  143. Dynacorn 65/66 Fasback bodys?
  144. Trick Flow O-ring heads... where do you get new O-rings?
  145. Cracked C4 casing... solution?
  146. Whats a 67 Coupe 428 w 4 speed worth?
  147. Rear Drum Brakes
  148. Not Enough Holes
  149. 1965 mustang 427 side oiler swap
  150. clearance piston to wall
  151. rod bearing clearance
  152. valve guide question
  153. headers
  154. Gloss body - flat stripe paint question
  155. What custom license plate?
  156. How long does a new engine run a little warmer?
  157. 351W transplant help needed
  158. flexplate & transmission questions
  159. Mustangsteve - anyone placed an order recently? Ballbearing kit MIA
  160. 65-66 ignition cylinder
  161. powdercoat your headers
  162. 428 SCJ Oil Cooler Lines
  163. "T" code duraspark
  164. Headers for 351W in 70 mustang
  165. Power locks
  166. Any Ideas??
  167. Side Scoop
  168. Temp Gauge reading?
  169. Finding a Clutch Pedal
  170. Correct driveshaft Length
  171. Drop Spindle Thread?
  172. Just starting out.
  173. 351w with a Stealth in a 66... what air cleaner to get?
  174. Installing head, cam, intake, carb - general guidance for assembly and tuning?
  175. Pushrod length question - how exact must they be?
  176. 69 windsor heads
  177. 68-69 302W head question
  178. 1969 Grille Paint
  179. 3 speed question
  180. boss stripes
  181. Brake line info...
  182. Custom Autosound- USA-66 AM/FM Radio. BRAND NEW!!! FOR SALE!!!
  183. Noisy shifter
  184. 351 Boss hood and mach 1 hood
  185. E-Brake handle solution
  186. Okay I'm excited now - dropped the 428 in last night
  187. 1970 Mustang seats vs 1970 Cyclone
  188. 66 Traction bar HELP
  189. Adjusting Rocker Arms on 351C-4V
  190. Difference between 289 and 351 oil pickup
  191. New dyno w Edelbrock heads
  192. Bonehead
  193. Took her for a spin for the first time in 4 years! What a BEAST!
  194. Wheel hunt
  195. HP estimate
  196. Slotted Mag fitment questions - Come on in Dodgestang
  197. What a 66 rolling shell worth?
  198. perplexing engine problem, need help
  199. E3 spark plugs
  200. Independent Rear Suspension?
  201. G-Bar rear exhaust photo
  202. Frame Rail Replacement
  203. Where is the vacuum tube on Autolite 4100
  204. how well do the factory trac loc's work
  205. I need header help
  206. How would you set up a old car??
  207. C4 questions servo upgrade/shift kit
  208. Alternator tests fine, only makes 12.4v on car???
  209. Coil Springs Info
  210. Floor pan question
  211. powermaster 140a alt
  212. Ron Morris front suspension alignment Specs?
  213. Rear end question?
  214. Need help with Explorer disc brake conversion
  215. 68 mustang rear seat
  216. Anyone used this product?
  217. Third Member Swap
  218. mod motor retrofit kits??
  219. help: window trim
  220. usable parts on 88 Lincoln Mark VII?
  221. Car won't stop turning over
  222. Battery/Alternator Charging problems
  223. Caliper and 14" Rim Clearance?
  224. '69 Mirror Questions
  225. heat and sound insulation
  226. Hit 6's in the 1/8 mile ....
  227. Spare tire mounting bracket
  228. Rear seat delete panel installation?
  229. 65 went for a spin w/ a stripper have pic's
  230. MagnaFlow Wide Open Exhaust
  231. Need help with Tach on HEI Distributor install
  232. wheel and tire question
  233. Engine is getting close to going in
  234. Rear sway bar installation problems
  235. '70 Mach 1 Hood Turn Signals
  236. Got a new Third-Member, did I F up the pinion yoke?
  237. New Heads , New Noise
  238. motor mounts
  239. 69 Mach 1 repop ABS quarter panel trim panels are crap!
  240. 67 fb factory wire harness question
  241. 1965 front brakes question
  242. broke something
  243. FMX Transmission problem??
  244. 351M Ideas
  245. classic axle bearings
  246. Tail pipes would hit valence...Am I forced to use turn downs?
  247. body work summary
  248. power steering pump too hot
  249. PR length
  250. Did some welding today...
