View Full Version : Classic Tech
- PS question
- Power steering question
- New Bushings & Front Strut torque question....
- Door Ident Plate Clean Up
- How do I remove whats left of the harmonic balancer?
- Timing Cover
- Where can I get a rear axle?
- please help with hard shifting tranny
- price suggestion
- security for your daily driver
- Drove for the first time in 16 yrs
- AFR 185's on a 306?
- 68 gauge problem
- 67 GTA clone information
- How to Choke?
- 65 mustang 6cyl brake conversion..4to5lug
- eastwoods fender lip roller(have you used one)
- Hand Brake
- What fuel pressure.....and why?
- Anybody Know a good PowderCoater in TX?
- tranny leak
- Electronic choke
- Removing Ignition switch and truck lock
- 65 parking light removal
- Does Anyone Make New Steering GearBoxes for The 71-73 Mustangs?
- Anyone have or heard of B-Quiet insulation?
- What 4-speed is this?
- help needed...tire rub in a bad place
- 5.0 Engine Trouble!!!
- Parking Brake
- best exhaust for the $
- restoration shop lawsuit
- Electrical interlock?
- Quick Question
- First time at the track not as good as I had hoped
- 351 crank vrs 302
- New shortblock / wrong block
- carb question?...
- T-5 to TKO 600
- Identify this motor by the heads?
- where to get wiring quick disconnects?
- Brake problems
- Shelby Drop Question
- Plain black grill for 66
- Some weight loss Info
- top
- Engine Casting Numbers?
- '68 Dash VIN missing
- 302 long block total weight
- yay....it all fit!
- Picture request
- what year did they use hardened seates/302 heads
- Anyone ever paint their master cylinder
- where should?...
- how do you know when to rebuild??
- wheel spacers
- 4 wheel disc manual vs. disc/drum power brakes
- Crown vic rear disc fit a '66??
- to head or not to head
- Window regulator: attaching channel guide bracket
- Holley Carb problem!!!
- broken exhaust manifold stud
- How BAD is this?
- Hot to tell if 9" axle is small or large bearing?
- 1966 headlight switch
- universal parts inc. radiators
- 460 std bore size?
- Wanting to swap four speed for c-4 help!!!!
- 1968 Convertible top trim removal
- Rear questions.
- HELP A.S.A.P---->tach installation...
- front wheel scrub, can i have them machined?
- 9" Rear disc conversion for only $375?
- '66 Rocker molding clips
- Installing Head Gasket Question
- High Volume Oil Pump on Stroker 393?
- Vaccuum lines in boosted applications?
- what gauges are most important?...
- Quickrelease Steering Wheel?
- EFI speed sensor swap?
- Liquid masking tape
- New shoes for my 71 Boss 351
- aod conversion
- front end damage on 67, what do I do about the vin's
- Wiring harnesses/connectors
- Help with 67 console trim finish
- Learning to Street Rod
- Difference in engine bay 69 vs. 70
- Heater switch connector and resistor
- need 347 info for eagle kit
- Harness Clips
- Cam Decision
- Best oil for TrueTrac?
- Welded diff
- Pictures of 65 Fastback project
- universal harness help!!!
- 66 Fastback front coil over shocks
- Tremec tips
- Anyone use vinyl interior paint?
- Why Painless? Why EZ? Why not replace with stock style wiring?
- What new wheels and tires should I get?
- got a RPM question
- 289 to 331 Problems?
- edelbrock perf. 1406 help
- Fender flares on 65 fb need info
- T56 Transmission
- 2000 seats in a 1970, will they fit?
- Power steering hose configuration, 64 1/2 w/ Eaton pump
- 1969 Mustang Cowl Panel
- single to dual master cylinder
- Installing a 4R70W
- 66 rear lift
- Exh leak thru vlv cover bolt holes??
- Does it matter the gph on my fuel pump?
- which drag radials???
- maverick disc brakes...help please
- 8.8" in my '68
- front frame rail replacement help
- 70 Mach I Power steering problem
- 69 fstbck exhaust
- Why should I replace my freeze plugs?
- Voltage Regulater Wiring
- help brakes....65 fastback
- New sector shaft and wormgear
- Shifter linkage for a AOD on a 65
- Tilt Steering Column in a 65
- Suspension Upgrade
- Magnum 500's
- Edelbrock Air Gap ?:Water jackets?
- How much HP to an 8 inch rearend
- ? on # of CC's my heads have
- Serpentine Pulley for 74' 351W?
- help on pistons and piston rings for 351W?
- I NEED HELP BUYING A TACH...
- pinion angle
- Carpeted trunk and sub box ... pics!
- How do I identify authentic Shelby wheels?
- 4 speed stuck in 3rd gear
- brake swap
- Need help troubleshooting engine vibration
- Test pic
- exhaust manifold paint
- granada disc question
- Underhood detailing
- Speedometer Gear Question
- Mustang II suspension on a 71-73 Mustang
- Subframe Connectors
- I completed my rewire. EZ Wiring Harness review
- Edelbrock Perfomer Intake vs Edelbrock RPM Intake
- Firewall repair question.
- HID Lights
- headlight switch removal
- One thing always leads to another. (Pulley Help)
- Alternator spacer length?
- Rear seat delete fiberglass
- Finally primer going on.
- Can Fiberglass be heated?
- Bench front seat w/ split uppers?
- Calling EDBERT - Gauge upgrade!!
- Bad ground?
- Gas Tank Restoration
- interior and exterior lights pulsing.
- Granada Swap ?'s
- distributor
- 6 cyl springs on a V-8 66
- Shops in Orlando?
- LED turn signal bulbs?
- 289 Rebuild Suggestions
- Need pics of 67 or 68 coupe
- Try it again
- 65 coupe rear backlite glass
- First Time Post/66 Mustang Help
- Ford-o to t-5 swap on 63 Ranchero
- no lights, no stereo, no power?
- my 66 progress
- Better traction for drag racing
- Proper oil pressure
- aod vs top loader
- Gauge Cluster & Glovebox Bezels
- MII suspension guys please give me some insight
- c4 tranny questions
- b&m megashifter
- SPARK PLUGS?..
- quesion for XXBULLETSXX
- Emergency Winshield Molding HELP!
- Brake pedal adjustment
- New kid on the block
- Interior lights voltage ? (71-73)
- help identify my wheels please!
- 70 Front end alignment specs
- Shelby Drop & tire clearance......
- granada swap tie rods
- heres some pics of the 68
- Where to buy performance steering box for 71 Mustangs
- Specs on an old CAM for a 390FE
- Will baer brakes fit on 65 fastback from.....
- 67-68 owners who swapped auto-manual
- 351c header fitting issue
- front suspension and brakes
- Eaton Power steering Pump, placement of brackets
- I need help identifiing engine
- Need help with harmonic balancer for 351W
- Where do I start for a total rebuild of 68 coupe
- How to diagnose steering box?
- 69 front discs on a 66 - what would it take?
- cowl vent repair?
- Custom Coil Over Setups
- Power Steering Question
- won't start
- Axle measurement help...Moser screwed up
- New or Rebuild Trans (C4)
- Simple crank pulley help
- Remove windshield wipers????
- head gasket sealant?
- picked up a 68 coupe the other day...
- #1 piston on the right or left 351W
- Cam for stock 351w?
- Aftermarket tach in factory dash of a 72 Mach1
- 65 tire / wheel help
- How to fix these poor fitting Side Scoops?
- transgo or transpack??...
- i know i know im repedative
- Paint Issues
- Help me choose wheels..
- clarke welder
- To cheat or not to cheat?
- ???351w or 347????
- help i have ignition problems
- A/C System line pressure?
- quarter panel vents/scoops?
- My new fuel injection ECM bracket (Big photos beware)
- 351c Turbo Intake Manifolds
- ignition
- Hopefully my last wiring question (turn signal switch)
- advice for 351w
- Machine Shop Recommendation - Houston
- Need more help....
- FR M8509R Aluminum pullys?
- Machining or Grinding Cam Journals???
- C4 Trans advise
- dual quad questions
- 67 Rocker moldings
- Coil location?
- When has an ignition coil gone bad?
- no spark @ plugs
- Harmonic Balancer, Crank, and Flexpalte matching help!
- Cam Change, but Noticed Problems with Bearings
- emblem and trim removal?
