PDA
View Full Version : Classic Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91
  1. My Quarter windows dont go up HELP!!!
  2. Head gasket suggestions
  3. recommend some good bone yards to me (need a new door shell)
  4. looking for pictures of shaved things..trunk caps,door locks,decals and lettering,etc
  5. Cobra r hood for a 67?
  6. primer/filler?
  7. Motor and tranny identification
  8. anyone ever shave the cowl intake vents?
  9. some info please...
  10. Plugs clean,strong CO odor
  11. Monte Carlo Bar
  12. 1969 Mach 1 project car help
  13. Intermittant wipers on classics?
  14. Has anyone put gauges in place of center A/C registers on a '69?
  15. Switching to EFI- computer question
  16. c4 shift points
  17. 67 console differences ?
  18. New Sun Visors loose
  19. Need help with engine question...
  20. Reccomendations for new rear leaf springs?
  21. headliner bows on fastback.
  22. Repro Fenders Fitment
  23. Question about Convertible tunnel plate
  24. '67 Cobra Automotive R-Model Nose Pics?
  25. 69-70 Painless wiring harness Jan 07!!!
  26. 2 1/16" or 2 5/8" gauges?
  27. Oil on my plugs, please help with diag
  28. Just Humor Me...
  29. WOW...That Sucks...A LOT
  30. Anybody running a toploader in a '69-70?
  31. BATTERY RELOCATION....
  32. shift kit?
  33. shift kit?
  34. New Project! 65 289 vert
  35. Who here has done thier upper ball joints?
  36. wacky electrics
  37. Help with AOD kickdown lever. Please
  38. Wheel Sizes for a 65 coupe....?????
  39. bench test power brake booster?
  40. What are the widest tires I can fit on a 71-73 Fastback?
  41. Fatman Fabrications decision (kill the Fox?)
  42. What brand / type of Shocks ???
  43. rear end pinion angle...
  44. advantages of a four link with coilovers out back
  45. Rust in trunk, what do I do, what do I do?
  46. intake manifold install
  47. Master cylinder
  48. Metallic Paint Problems, Please HELP!!!
  49. Roll cage time
  50. Bolt Kits for '65 Coupe
  51. Who has 218HR or 270 HR Comp Cams?
  52. Who makes good overdrive units
  53. Winter Project
  54. In-car oil pan swap
  55. What rear axle bearing size do I have?
  56. Need internal parts for 1964 Eaton power steering pump
  57. quick T5 swap question
  58. Stumbling Hard
  59. BLOWING OIL FROM BREATHER AFTER HEAD CHANGE
  60. Eaton power steering rebuild. Is it very difficult?
  61. 65 mustang with 351W
  62. 351W Fuel Injection Thoughts
  63. Not Classic, but still mustang tech
  64. GT/CS Fiberglass Install/Fitment Cost?
  65. INTERIOR
  66. 2004 Mustang seats into a '65 Fastback -pic-
  67. mysterious blue box haha
  68. First dyno today. Disappointed
  69. time for new shocks
  70. Transmission Choices: AOD or C4 reverse Manual
  71. 69 mustang up on blocks
  72. New Top Time - Need advise on price
  73. power to manual steering...just want to make sure
  74. POR-15 vs. Powdercoating
  75. 69/70 highback seats in a 64 1/2
  76. 69/70 highback seats in a 64 1/2
  77. 69/70 highback seats in a 64 1/2
  78. I CRASHED MY MY TONIGHT...=(
  79. start up problems
  80. 1965 mustang engine rebuild
  81. 66 Tiger
  82. rotisserie questions...
  83. manual trans problem..help needed
  84. found why my breaks stink
  85. Rebuilding PS Valve Assembly and Slave Cylinder
  86. I busted my car up tonight
  87. ignition/starter question
  88. Toploader Swap 1967 390
  89. replacement seats
  90. Head rests in 65 Mustang
  91. three point seat belts
  92. Car or 401K?
  93. Help with Rust Hole
  94. rear end width question
  95. Manual or auto better for drag racing?
  96. Brake problems
  97. car or college?
  98. wiring headlight switch
  99. rear axle: removal pictures
  100. Anyone that has installed a billet grille...
  101. Name this mystery part
  102. Clunking Sound After Gear Swap
  103. FMX specs.
  104. 65 Fastback front end rise
  105. Mustang show on history channel today
  106. need directions,steps,help, on how to drill trunk lock on fiberglass decklid?
  107. Can I still talk about Mustangs if I don't have one yet?
  108. unusual top-end knock
  109. Would 8.8 rear end gears be the right one?
  110. Header Help!!!!!!!!!!!!!!!
  111. mini tub/full tub
  112. Tire Size for 1967 Mustang
  113. Brake Help.
  114. Wipers run the wrong way
  115. Best heads for 351M on a budget
  116. Headers for 351W
  117. re-wiring. 3 wires I question
  118. Happy Birthday to our Mod !
  119. Just installed 17x8s on my 65, some Q.s
  120. Power windows 71-73
  121. Engine Building Books?
  122. denver co muffler shop
  123. Who runs AFR 165's?
  124. Orginal Exhaust Question.. 66 Coupe 289 V4
  125. Instructions for running fuel system for efi...
  126. Need either a quiet electric fuel pump or manual pump solution
  127. Which oil pan for DSS Main Support?
  128. hood locks
  129. Rack and Pinion Problems
  130. Rustoleum durability?
  131. Leaf Springs, Coils & Shocks
  132. Restomod instrument arrangement
  133. Water pump backing plate
  134. engine stalling
  135. Reusable Trans pan gasket for C-4?
  136. 67-69 uppercowl on 65-66
  137. axle bearings and seals
  138. Engine and tranny swap
  139. T-5 Conversion -Preorder HELP
  140. What size fuel line
  141. Engine replacement & tranny rebuild
  142. Power antenna...
  143. Demon Carb Trouble...help runs for
  144. Quick left signal wiring
  145. Wiper motor test question 71-73
  146. EFI Guys - TFI Coil Location and Bracket
  147. any pics of a 67 cpe with 15x10's out back?
  148. 1965 mustang dash wiring install... help!?!?!?
  149. Repo horn ring
  150. Speedometer question
  151. Anyone ever get tired of..
  152. Getting ready to build my rear end
  153. And this would be why my waterpump failed.
  154. T5 vs FMX - Picture and weight comparison inside
  155. 92 crown vic AOD doner?
  156. comments and suggestions solicited and welcome re: camshaft
  157. Kick Down Cable Problem
  158. Lower Ball Joints
  159. Pics of 17" Vintage 50s on a classic?
  160. FE into a 71-73 pony questions
  161. Flywheel - 160 - 289 2v
  162. 67 Power Steering Pump
  163. versailles rear end tire fit ????
  164. AUTOMATIC SHIFTERS...
  165. no start
  166. Ford or Mopar
  167. foose wheels
  168. pushrod length
  169. 67 convertible project ?
  170. What am I missing? (Wiring question)
  171. I need the wiring guy's link to his painless installation
  172. Got a deal, a build begins...
  173. Little deeper into the 11's!!!
  174. 1st project on my '70: brakes. Advice needed...
  175. need advise hard to start
  176. Here's my idea
  177. Paint question dealing with heater box
  178. Check Out This 71
  179. Need help shipping non-classic from PA to WA
  180. pic of 67 convertible project
  181. New Best Time w/ RAM AIR install.....
  182. Water pump question
  183. proper disc to flywheel clearance...help
  184. 67 trunk springs
  185. turbo set up and custom made headers
  186. Is this what I think it is???
  187. Tig Welder
  188. Air ride front (or rear) shocks (bags)
  189. M&F cover car - build pics
  190. ? about welders
  191. Blown/Intercooled 65
  192. Starting a new engine with diesel fuel
  193. Restomod engine rebuild
  194. shifter question
  195. Floorpan replacement cost
  196. stroked 351W (408) header help needed please
  197. Where is my flasher?
  198. '67 heater core replacement with a/c
  199. Ram Air install and Battey relocate finished..
  200. Replacing Parking Lights with Fog Lamps
  201. I got a new car :)
  202. 66 mustang 289 spacer plate c4
  203. start up problems still!?!
  204. Shifters
  205. Subframe connectors
  206. Suspension setup opinions
  207. 73 power drain
  208. G-Bar Suspension
  209. 1969 Mustang 4.6?
  210. Starting the RestoMod-- Please guide me!
  211. 67 standard steering wheel-horn contact help?
  212. floor pans
  213. Shelby mod on 65
  214. KAR Mustang in Ohio
  215. EFI intake hose interference
  216. Adjustable Hydrolic Tappets
  217. advice on towing a mustang
  218. Body ?'s.
  219. What can you do with a wrecked '03 Aussey Falcon...
  220. Options for brake upgrade
  221. Best way to raise a 67?
  222. Lost on I-45
  223. lumbar bladder in stock 65 seats
  224. Lowered my 66'
  225. Are Holley squirters interchangeable with Demon squirters?
  226. Bellhousing for a T5 on a 289
  227. Distributor ?'s.
  228. Need input on a 400hp 351W
  229. Shaker hood on 65-66?
  230. torino third member
  231. Wiring Question
  232. c4 to t5 in my 67?
  233. will this work?
  234. GM 3 wire hook up
  235. Which is worth the most???
  236. Brake light switch...oops
  237. Wiring Tachometers
  238. Battery relocation wiring question???help....
  239. Engine Placement help
  240. How much is this car worth??
  241. Open diff?
  242. 5 liter swap into my 68
  243. How to restore a shelby steering wheel
  244. '65 200 6cyl to 289 8cyl conversion
  245. Quick bumper Question
  246. AOD Source?
  247. lincoln versailles rear end
  248. need some rear end literature
  249. Cowl replacement on a 69-70 stang....
  250. My latest happenings
