View Full Version : Classic Tech
- Mustangs Plus Super Starter Grab a Track Kit Missing Anything?
- Starter motor?
- 67/68 Fastback for parts
- Need help on Rim Backspacing.
- 289 Help
- Heidts or TCP?
- which camshaft, can't decide.
- Help, need a quick measurement
- Radiator question
- pics of my ride
- pics of my ride
- 3G alternator problem?
- Yet another electrical problem
- shop says my ignition is the cause to my overheating problems?
- Starter motor relay expansion
- Confused about bearing retainer.
- 351 heads on a 302
- painting new suspension parts?
- check bearings in a 66 c4 valvebody
- 68 Needs Repair Any Advise?
- cheap headlights
- Rust on hood
- Who has 275/50/15's on 67-68?
- Master cylinder pushrod questions..
- Heat and sound deadening material
- Summit Sport seat comfort?
- rear end difference
- power windows?
- edelbrock rpm heads and alternator
- rear end.......
- How to determine plug heat range ???
- Master cylinder-what this hole?
- Fuel Line.............
- Tire help
- What brakes?
- 2 vacuum advance hose connections on a 289?
- Unisteer Rack & Pinion
- Drag race suspension?
- My 65 project car
- Websites for paint and body
- Pics and tips from owners with fiberglass deckilid w/spolier
- OBD II Code Reader: Recommendations?
- '67 with Edelbrock carb
- Bearing retainer bolts for T-5
- recommended driving distance
- Possible T-5 hydraulic clutch option... Nissan sourced
- Decode This! Now Decodes All Fords from 1960 through 1969
- pressing axle bearings
- My 8.8 project finished
- Disc brake swap problem
- Fuel line size
- My plan for a fun streetable 300 HP daily driver
- oil pressure question
- T5 Conversion Report
- Fords/Mustangs in St Louis
- Pics of 17X10 on 65 fastback
- Front Disc Brake Kit Winter Special
- anyone have a picture of the TCP rack and pinion steering setup?
- Granada Disc Conversion
- Engine woes
- What seats to go with
- BRIGHTER/ WHITER
- what are the differences and benefits between mechanical and hydraulic cams?
- New Starter Question
- Pic of Aerostar aluminum driveshaft vs. 5.0L driveshaft
- 351W Turbo project
- Ac compressor swap
- T-10 web site anybody?
- 289 vacuum advance/timing question
- Starter Problem!!!!
- 1966 200 6cyl - Carburetor Trouble
- How to Install 99-04 mustang seats? WriteUp
- backfire question
- How much Should an exhaust install cost?
- 1970 Mustang Electrical Problems
- More EFI problems
- Starting problems!
- DRUMS TO DISC...
- wiring nightmare
- Which Wiring Harness???
- Help! 289 engine install
- Home Alignment
- Aluminum driveshaft from Ford Aerostar?
- Repaired! Starter won't disengage
- 1966 c4 transmission . . where do the check bearings go?
- steering wheel adapter for Grant wheel
- 1" drop spindle, '70 drum style?
- Have I installed the wrong Headers?
- Anyone using Edelbrock 1791 Quiet Flo pump?
- Pics of Taurus Fan on 20" radiator.
- who's got mustang monthly back issues
- How big are stock 302 valves?
- Starter won't disengage
- who makes good fiberglass fenders?
- Coils, wire's and ignitions oh my.
- horn question
- horn question
- running water instead of antifreeze
- '66 FastBack - Eliminating Shims
- Spring problems...
- pics of 05 GT rims on the 66
- Cd player in a 68.
- 65 coupe heater setup
- STEERING WHEEL...
- Heads milled - mill intake?
- Grant wooden wheel finish ?
- oil pan for 351w in 68 mustang
- Valve Cover Holes - yes or no?
- How much is this 72 mustang worth?
- Hydraulic Clutch Adjustment
- Infinite speed Wiper Switch
- Engine remains running after key turned off
- Crushed Mustang
- Will Foxbody gas tank fit in a 67?
- power steering hose
- Flywheel torque
- Maier Sub Frame Connectors
- toploader linkage
- Help with brake drums
- Need EFI Help
- Rear end number help
- 67 and 92 bolt pattern
- Bleeding Brakes
- Clearance Issues
- New Master Cylinder Defective?
- Aftermarket Seats??
- By far hardest decision ever!!!!!!!!
- Transmission Leak Question
- Holley 4Di Pro-Jection software?
- Well, Scarebird front discs DON'T WORK!!
- Help a newbie: which 351w do I have?
- Are Roller Cams Worth It?
- EFI Fuel Filter
- Frame Shop
- Drivers side '99 seats installation question
- Newbie mods for a 351w
- riring order off, no timing pointer, car runs great?
- What brands make good main/rod bearings?
- Will Granada spindles lead to problems w/ aftermarket UCA?
- replacement floor panel fit
- deluxe install
- EFI Conversion - Vacuum Troubles
- what wheel/tire size for a 67 fastback
- Tips for changing steering gear on '72
- granada swap question (prob. stupid)
- Billet Specialties; Anyone got pulley experience?
- Building Revs
- Are my bearings ok (post mortem of oil pump shaft failure)
- Is it the starter???
- engine casting # help
- 1969 Wiring Diagram
- New disc brakes not working
- shelby drop template
- Tranny Question
- any thoughts on reinforcing frontend for mustangII conversion?
- Corvette C4 rear end?
- post rust removal
- martin senour paints
- Anyone know where to get a stainless tank for 71-73 Mustangs?
- Head ticking
- Brake Pedal Rubber
- 66 with mustang II and 351 Cleveland, anyone done it?
- T5 Question
- School me on rear ends
- Door panel ?'s.
- 67 mustang GT??
- 67 mustang GT 390?
- Hydraulic brake light switch
- I dont want rear seats..options?
- exhaust for new rebuild
- 65 fastback project w/pics
- Engine Search Story
- 1965 1966 NOS Bumper Guards
- 200 I6 water pump bolt
- Paint scheme input
- Vibration coming up thru top loader shifter
- Noisy fuel pump
- Which First?
- fuel gage on 65 coupe..? fuse for this?
- Close to Paint
- rearend swap
- bolt pattern help
- Electric Fan/Alternator Experts needed
- oil pump
- keep the emblems?
- 58 Ford 9 inch in 65 Mustang - "Red 65"
- Best place to get tt2's for 73 fastback...
- Is my horn sucking my battery or could it have been the old battery cables.
- I6 to 408W swap?
- mods required for...
- Who has a Comp Cams Xtreme Energy XE250H Cam
- need good body shop/sheetmetal shop in DFW area
- Side marker, stay or go?
- t5 transmission input shaft question
- 8 inch rearend???
- T5 Swap - Driveshaft and output yoke
- Pony floor mat and windlace color
- have any suspension kits been skidpad tested?
- How do you know what size pushrods to use?
- Plug Gap on 351C motor
- blown 302 overheating
- Size of tool needed to remove drain plug
- Opentracker Autocross Upper Control Arms
- Question about open headers/exhaust
- Question Toploaders....
- Went to the Track, Have some problems and questions.
- Coolant/Oil Mixing - found freeze plug in oil pan
- Looking at getting a new driveshaft for my 67
- Ignition Trouble, Please Help!
- Battery Relo to Trunk Help Please
- Info on some fiberglass parts
- EFI for a 289
- I want to 'downgrade' to a v6, tell me what you think
- Opentracker UCA vs. Global West UCA
- 351W Throttle cable setup
- Ultimate Master / Booster?
- t-5 question
- Decode This! Universal VIN Decoder
- Need help Identifing a Cam..
- Need to know what size wrench fits a 30mm (measured) nut?
- rear end questions
- please help with excessive oil blowing out of motor.
- can I get some pictures of a 65-66 R front w/o bumper?
- difference in 65 and 66 intake
- Welding Through-Floor Subframe Connectors
- engine speed w/toploader and 3.5ish gears @80mph?
- Need some measurements
- Restomod question:67 tailight panel on a 66?
- soft top pics
- WHAT SHOULD I GET?...
- Trunk Carpet Question?
- Pulling a 289
- 15" x 10 wheel on 69 0k?
- W00 my Concept One Pulley System came in the mail TODAY!
- finally got my 68
- Pics of what my flywheel looks like after the machine shop got ahold of it
- 351 stroker
- need some gurus to answer!
- Wheel Fitment Q
- Discharging
- 8" Trac-loc clutch pack replacement
- AN0THER PR0BLEM...please help!!!
- New progress pics, finally
- does this sounds high for 1/4 skin replacment cost?
