PDA
View Full Version : Classic Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91
  1. Any T5 Clutch experts here?
  2. stock sounding mufflers
  3. 5.0 Waterpump rotation?
  4. EFI Throttle Cable Bracket
  5. interior uphostery!!!!!!!!
  6. Dual Quad Intake Need help with Adjustments
  7. Wetsanded Through The Clear. Now What?
  8. Bolt sizes
  9. Carb Plumbing help
  10. Randalls Rack and pinion steering
  11. where to buy 70 sport light/lamps
  12. 70 sport light switch
  13. Trip to Atlanta Dragway Sept. 22nd, Friday night races
  14. The I6 Lives!
  15. t5 swap driveshaft length/vibration question
  16. upgrading from 28 to 31 spline axles & I have a question
  17. rear sway bar mod
  18. 260 to 302 swap
  19. Autolite carb frustrations
  20. Milling off the Intake of an I6
  21. Found why no 1st gear
  22. PS pump is freaking out on me
  23. 66 mustang c4 vaccum unit
  24. How much clearance is needed?
  25. T5 Swap question
  26. 65 stang 3 speed clutch/flywheel issues
  27. Autometer oil pressure gauge question
  28. Hubs for G2C Conversion
  29. turn signal light question
  30. Racing Wheel Identification Help
  31. I6 Head bolt torque sequence
  32. Heidts MII - Progress + Sway Bar Question
  33. Please help on compressor decision
  34. c4 experts advice needed valve body question
  35. diagnosis: steering issues
  36. Headlights: H4 and projector lights question
  37. Vacuum Advance
  38. Exterior lighting help
  39. modular motor preoiler
  40. Help with new disk brake setup
  41. eliminating voltage regulator
  42. 302 not running?? video "56k warning"
  43. Help with Granada Spindles
  44. What's your temp. readings???
  45. How do I measure my RPMs with no tach ?
  46. Stock 69 302
  47. will 69 front drums bolt to 66 stang?
  48. DC Control electric fans
  49. Car pics w/ my vintage 50's and new seats
  50. Rear Door Glass Weatherstrip Replacement 71-73
  51. Tire Pressure Decal location 73 stang
  52. NPD Shelby Hoods
  53. Starter Grinding Intermittantly
  54. 66 mustang ammeter question
  55. Brake difference between 69 and 70...
  56. Rearend fitment?
  57. Seat Covers, How difficult?
  58. Good low cost paint gun
  59. Heidt's Rear 4-Link Coil-Over Suspension
  60. Head Work (stock heads)
  61. Oil Pressure threads (do you use a sealer?)
  62. Input from those w/ Edelbrock IAS (I did search)
  63. 65/66 Suspension picture
  64. Boss 302 stripes on a 66 fastback? am I crazy? any one with some photoshop skills?
  65. Need help finding Fuel Pump for early 260 V8
  66. 3 point seat belts mounted on roll bar
  67. emergency brake help
  68. Vinyl Paint & Plastic Paint On Doors?
  69. GT390 Block. Solid Lifter OK?
  70. leaf spring suspension question
  71. Power steering hoses
  72. Widest tires on lowest 'stang
  73. Next Sticky Post Poll
  74. Trick Flow vs Canfield Heads
  75. Home made toe in Gauge
  76. 4 Link Suspension Question
  77. Heater/AC vacuum hose diagram?
  78. conversion
  79. Ceramic coated headers
  80. Design Drawing / Blueprint / Schematic?
  81. Clutch fork in bellhousing question
  82. Cracked bellhousing 65 stang, 3 speed 200ci
  83. My newest pile of parts (pic).
  84. edelbrock 1406 carb
  85. Poly Leaf Spring Bushing ?
  86. Heater to AC conversion?
  87. cigarette lighter fuse keeps blowing
  88. Front brake swap (1970 into 1968)
  89. economic pony
  90. srew in studs
  91. Flaming River Column - 1967 Cougar Turn Signal Issue
  92. 65 Coupe Rear Seat Belts, Any options??
  93. AOD, NOS and Toploader
  94. classic auto air
  95. bleeding brakes on a 89 topaz, need help. wtf??
  96. Big block vs. small block PS hoses?
  97. Shock Tower Problem?
  98. New Exhaust then Header Later
  99. Has anyone purchased and installed these 3 point seat belts?
  100. towing question
  101. Head gasket sealant?
  102. 1966 Mustang Custom BackSeat/Trunk
  103. Where to buy Amsoil?
  104. Remove trunk lock w/o keyes?
  105. Gunning for Paul302
  106. steam holes for windsor jr's
  107. Paint help needed, DFW area Texas
  108. Horn contacts busted, can't locate!!!!
  109. need tranny advice
  110. 70 Mach Driveline vibration
  111. Ron Morris Motor mounts?
  112. Odd problem
  113. Brake caliper leaks - your opinion please
  114. Engine idle surging
  115. 1968 Shelby Turn Signal Wiring
  116. Retrofitting ac into a 73?
  117. Best carb/intake manifold for 289
  118. 72 PS pressure hose question
  119. Hood Hinges
  120. Starting Engine For First Time
  121. T-5 repair?
  122. 69-70 hood swap
  123. MSD and haneline gauges
  124. Do I have to shorten my 9"?
  125. Aftermarket Wheel Pics & Specs.......
  126. Smaller drums???
  127. T-5 swap headache
  128. Urethane bumper removal on 73 Mach
  129. qwick t5 question
  130. Going Racing Friday....Need some pointers
  131. instrument lights - what voltage do they run at?
  132. '66 Drive Shaft
  133. what are loops for on 65-66 lower control arms?
  134. 67-68 Door locking rod placement
  135. engine question
  136. Help me with this bolt situation (picts)
  137. Fan Question
  138. 65 200 3 speed clutch size
  139. Ignition Box
  140. side scoop question
  141. 1966 mustang Front Seat Removal
  142. Petronix ignition installed, running good
  143. Car Trouble
  144. Headlight Wiring Harness
  145. Steering Column and harness
  146. Grudge race w/ co-worker
  147. two steps fwd...
  148. Long Tube Headers
  149. Is this bad? (intake manifold)
  150. 67 Mustang 289 Power
  151. MCA Stampede
  152. Steering wheel removal, 65 stang
  153. Blasting Media Recommendation
  154. Voltage Regulator
  155. convert 66 coupe to Shelby?
  156. 69-70 Mustang Baer Brakes Installation
  157. Whats up with SpinTech?
  158. AOD Neutral Safety switch
  159. Windsor Engine Database - Please add your engine!
  160. Manual to Power Steering
  161. Monte Carlo Bar and Factory A/C?
  162. Non-Mustang (HONDA Civic) Brake question For Mustanggurl's Car
  163. Vent/Heater Blower quit
  164. Toploader Rebuild - Missing a Part - Help!
  165. 390 build?
  166. I need breather grommet and elbow
  167. Experience: Comp cams 268H in a stock 289
  168. Bleeding 4 piston calipers
  169. Regular 289 cast iron exhaust headers vs HiPo model
  170. 351C idling funny
  171. G.T.350 R Front Apron Dimensions
  172. increase HP in a I6 200ci
  173. roller 5.0 in a classic
  174. 1966 Reverberator
  175. Can you align a car with the old tires?
  176. 69' Hood - Repro or Ford tooling?
  177. HP Question
  178. Power Steering a problem???
  179. Radio delete plate. Any Ideas?
  180. 67' Car wont start after changing battery pls help my life
  181. 66 Mustang Susp. Swap Questions
  182. Lowering Seat Pans for Procar seats
  183. Looking for a Dual Master Cylinder for a 65.
  184. Lower Radiator Hose Spring
  185. Power Brakes ina 68 with JMC hydraulic clutch
  186. Two-Tone Interior Ideas?
  187. 69 mach glass
  188. allright, I give up
  189. 68 Mustang rear brake line routing
  190. Where to Buy: 1" Lowering Blocks for 67 FB
  191. Whats in my rear end
  192. starting to research for parts...your ideas/info?
  193. 70 Spindles for conversion?
  194. water pump removal?
  195. Decode my axle tag.. and a ????
  196. Brake fluid type
  197. Buying a Mustang. Questions and a poll...
  198. 66 emergency brake help
  199. 70 Mustang 351 C power steering question?
  200. 65 stang 3 speed vibration while shifting
  201. Why oil seems to be almost "milky" after EFI swap?
  202. Brake booster rebuilders ...
  203. Worth the money?
  204. Help! Does anybody know what this is?
  205. Any Mercury Comet Vendors out there
  206. Vacuum accessories with forced induction?
  207. Front End Suspension
  208. Fuel Line question
  209. dyno results - My first time
  210. Body Shop Estimate
  211. Right size combo?
  212. Steering Column Wiring
  213. C4 trans won't go into park unless I let the car roll a few inches
  214. UCA and LCA replacement
  215. Please help with painless install
  216. clearcoat wheel stripper ?
  217. Modern cars as classics?
  218. From AGHRAAAA...to...EUREKA-A weldor's folly
  219. 1965 Fastback project.
  220. 2005 Gt Wheels & Tires for $299 ????
  221. Mach 1 Wheels on '68 Notchback
  222. Really Dumb rear end question
  223. chassis stiffness
  224. Cool Flex heater hose
  225. What heads??
  226. Did All 1968 Fastbacks Have Rear Sidemarkers?
  227. Make your own plug wires ?
  228. Switching out bellhousings (aluminum to steel)
  229. Best tire choice for Stock Styled Steel 65 wheels?
  230. Cannot get cleveland to spline
  231. New Original style steering column
  232. Question about epoxy primer
  233. t5 install (more questions) regarding install (pt 2)
  234. How much is this 66 worth?
  235. fan size?
  236. 1968 Fuel Sending Unit Replacement
  237. Motor combo. Questions
  238. mini tub kit
  239. Rearend Swap info - FAQ
  240. FAQ's - Please read and contribute
  241. Bedliner under carpet or in trunk?
  242. How do I install '67 FB trunk spring rods?
  243. '67 Mustang Rear end interchange
  244. Anyone with a Year One instrument panel for a 1969-70 Mustang up for a group purchase
  245. Convertible top instructions needed
  246. Any timing experts out there?
  247. r.i.p. stang 2003-2006
  248. Quick Rewiring ?
  249. Restore switch bezel ?
  250. Power steering pump hoses
