PDA
View Full Version : Classic Tech
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. Lojack for classic cars? Costs/is it possible/etc?
  2. Bolt-on vs. weld-on subframe connectors
  3. fair price for the paint job
  4. S&W or Jegster roll bar?
  5. Bump steer or... ?
  6. steering column problem
  7. MY interior is finished lots of pics
  8. Will timing effect engine temp?
  9. Intolerable squeek coming fron driver's side door.. help!
  10. new shoes for my 67 fastback
  11. c4 shifting early
  12. Master Cylinder faulty?
  13. Speedometer gear
  14. c4 fluid capacity
  15. 8" to 9" break-in question
  16. Running Poorly
  17. Finally has some color!
  18. turn signal tips
  19. Sloppy steering
  20. Cable to Hydraulic clutch conversion
  21. Lowering 65
  22. firebird or camaro seats in a mustang
  23. Startup = Moment of truth = FAIL - 5.0 EFI conversion help
  24. Interior Kits
  25. Gears and Driveshaft
  26. Where to get stripes?
  27. Car has no park????
  28. How much HP will a C4 hold?
  29. my speedometer cable keeps breaking...
  30. How to get rid of smoke odor in interior
  31. Painting the interior of my '65
  32. Need carb help Engine dying
  33. CPRstreetmachines 1969 Turbo'd Pro-Touring GT2 build
  34. 68 SHelby GT 500 wiring
  35. New Convertible Top Arived, Time to Do Something Crazy
  36. Seat belt warning light?
  37. power steering fluid capacity
  38. electric fuel pump recommendations?
  39. Head light switch
  40. replacing 65/66 coupe wheel wells
  41. NE1 Convert a Pre-72 V8 to EFI ??
  42. How do I hook up 600hp?
  43. Need help with Air Conditioning set up for '66 Stang.
  44. Sway Bar Size
  45. Brand new gas tank.....
  46. ride height problem
  47. glass goddess
  48. Alcohol or Pump Gas?
  49. Need Carb tuning 101 class
  50. 70 hood scoop emblem
  51. Evaporator Change in a '68?
  52. Since Custom Audio Sound = Crap, what about Retrosound?
  53. 302 h.o. question
  54. door won't open
  55. Air Conditiong diagram for '66 Stang.
  56. Fiberglass Apron
  57. The Mustang is FINALLY painted
  58. Holley Carb troubles (aka, why I am glad my DD is EFI)
  59. shelby style hood for regular front end
  60. tell me how to weld up side down????
  61. Wilwood Superlite rear internal drum disc worth it?
  62. engine power up recommendations...
  63. Granada Swap Wheel Fit (I know I know...)
  64. 8" Posi......what one to get?
  65. Proportioning Valve
  66. How to bypass neutral safety switch?
  67. 56K warning Lots of pictures! Swapping a '67 Radiator Support into a '66
  68. Manual Choke Hole in Firewall?
  69. leaf springs
  70. Mechanical fuel pump lever question
  71. Wheel Issues
  72. Engine woes
  73. To resto-mod or Not, that is the ?
  74. Duraspark II to Hei conversion
  75. Wife wants a 64-66 'Stang...
  76. Getting there Engine bay pics Opinions?
  77. Driveshaft length... how do you know if it needs to be shortened?
  78. New stang owner in need of help 65 fastback
  79. rear suspension for Autox
  80. floor pan replacement question
  81. AOD ?
  82. Painting the Trunk and Engine Compartment in my '65
  83. Brake Switch Change?
  84. Finally got some new wheels! Lots of pics (56k no way)
  85. What next?
  86. Too much Brake Booster pressure?
  87. Anybody have a Sean Hyland front end?
  88. Just a freindly warning to Bnickel and jikelly.................Hide your women
  89. Engine runs hot and misses at idle.
  90. 64.5 Convertible "K" Code
  91. Engine Temperature To High?
  92. GT40P heads on a flat tappet engine
  93. How do I decode My Vin Please Help!!!!!
  94. Need better gas mileage...
  95. Motor vibration.....
  96. Getting a Boss 351
  97. little Sticker Shock on Cost of Paint Job
  98. New Radiator and 9 inch
  99. Brake kits - manual versus auto trans, why?
  100. Bearings ? or water pump?
  101. Emg brake cables to short
  102. Fuel delivery problems, I think.
  103. Changing My fuel LIne Please Help!!!!!!
  104. Painless? Wiring Turn/brake/Horn
  105. Difficult starting after sitting for a few days
  106. 65GT/66 dash cluster question (what numbers do they mean?)
  107. Painting in the trunk
  108. 255/40/17 fit in rear of 66
  109. It's alive!!!
  110. Tcp g-bar install and pics
  111. Runnin warm
  112. What manual transmission? +600 ft.lb.
  113. piston choice problem
  114. front coil spring question
  115. Headers & hard, hot starting- Solutions?
  116. C4 Shifting Delay
  117. street/track suspension help
  118. what gauge sheet metal
  119. Timing chain & gasket set(s) recommendations for 1972 351w
  120. Which V6
  121. NOOB with a GT40P Question
  122. Carburetor choice (daily driver, 351cid, ~400hp, manual transmission)
  123. Adjustable or Positive Stop???
  124. Clutch cable kit
  125. a-ha! Found the noise in my suspension!
  126. Timing cover leak
  127. Just thought I'd show this
  128. staggered shock pics?
  129. cam bearings install
  130. Damper, and pulleys
  131. Tri Y's and PS drop
  132. C4 to T5 swap guys... how far did you shorten your driveshaft?
  133. KYB GR2 shocks on the rear (Gas A Justs up front)?
  134. Used heads... how to tell if stem seals/retainers/valve locks/etc are okay?
  135. U joint part number needed
  136. installing aluminum dash inserts
  137. Preliminary dyno results
  138. bad vibrations
  139. 66 Mustang 289 4BBl Carb
  140. how do you fit the fiero fan? way to tight
  141. HELP!!rocker arm adjustment!!
  142. Recommendations for jumpy suspension?
  143. c-4 auto ?
  144. 289 or 351W + Brake Question
  145. More low fuel psi issues when hot
  146. Is this a good radiator?
  147. NASCAR style belt drive, where?
  148. Brakes w/o booster?
  149. My $2000 Ignition - I need help!
  150. 'Click' sound from front suspension during braking?
  151. power steering issue
  152. 69 Coupe Headliner
  153. California Special with an SLC DSO?
  154. Axle power rating
  155. Mods needed for mini-starter install
  156. Rear End help
  157. several questions
  158. suicide doors
  159. Updated times
  160. Ford Newbie - Intake gasket - '68 289 4bbl
  161. When was the first GT made?
  162. need help with a car cover
  163. T5 Help
  164. transmission issue
  165. Opinions: R302, Dart, World or Boss
  166. being told 2 different thing about a rear end
  167. new heads? or new engine?
  168. convertible subframe connectors
  169. 1" spring insulators
  170. 79 ford truck rear end, will this work?
  171. JBA Tri-Y/Long Tube/Mid-Length Headers
  172. hyd throwout toploader/jericho
  173. bigger dual quad
  174. Intake manifold rear crossover / Head gasket question
  175. Driveline ??
  176. 351 windsor knocking noise
  177. Identifiying 4V heads
  178. Radiator overflow question
  179. Knocking noise in my 351 winsor
  180. Lowering Blocks
  181. Car suddenly won't start??? Coil???
  182. I6 C4 rebuild for new 347?
  183. TOP hose cool BOTTOM hose hot?
  184. C4 tranny (fair price)
  185. 67 shelby hood for mock up
  186. th 400
  187. Can I use a helicoil in a flywheel????
  188. Deep Dish bullitts on a 65...how??
  189. Have some questions about my 68
  190. Thinking about getting Tinman subframe connectors
  191. Lowering Blocks...
  192. Front Suspension Noise
  193. Car Hates Gas
  194. Wheel bearings
  195. 73 Axel bearing removal
  196. Windshield chrome on 67, need help, I dented one
  197. sbf valve guides
  198. Vented gas cap question
  199. Finally, some Strip Times
  200. Spring Perches...
  201. need help with front wheels
  202. VIN locations
  203. Pinging/Knocking
  204. 71-73 lower fender attachment template wanted
  205. Opentracker roller idler arm and P/S
  206. 66 comet caliente
  207. AOD transmission Thread size????
  208. Control arm shims
  209. How do I determine if
  210. Overheating pony
  211. Which Convertible Top?
  212. 2005 mustang nose on classic mustang - has it been done?
  213. The Mustang is finally got paint on it.
  214. Odd problem with 347
  215. Priming in my garage???
  216. Calling all those on Megasquirt
  217. Need more tire...
  218. rear leafs
  219. Ram hydraulic throwout bearing
  220. Tie rod suggestions
  221. Bump steer kits..any good?
  222. Valve cover question...
  223. Long wheel studs/ Draglite/ Torq Thrust?
  224. what to do?
  225. how wicked is your cam?
  226. went to the junk yard to look for 9"rears
  227. Stang-Aholics 4-link rear suspension
  228. Best Cleaner & Preservative for a Vinyl Top?
  229. Softer than 620's w/ 1" drop?
  230. global west leaf springs
  231. Recommend me a camshaft
  232. Need advice for properly setting up valvetrain
  233. Magnaflow exhaust install question?
  234. what kind of oil?
  235. ez2wire harness installation
  236. 1970 Mach 1 4-spd into 68 coupe, easy fit?
  237. Baer Tracker with Granada Spindles
  238. Can someone give me the best information sources??
  239. Pertronix coil cracked
  240. Value of an original 64 1/2 coupe
  241. Fluctuating Oil Pressure (on high side)
  242. 67 Quarter Skin Help
  243. What do you guys think of my engine bay?
  244. 67 wheel clearance
  245. Help with coil springs!!! PLEASE!!
  246. Lower control arm ball joint - what size are the threads?
  247. Due to popular demand...Wheel Chart 2.0 has been hatched
  248. Turn Signal switch
  249. Will they Work?
  250. Polishing out windshield scratches?
