PDA
View Full Version : Classic Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. Starter or Flywheel/Flexplate - '66
  2. fuel pump wiring
  3. Oil pressure sender won't come off (need tips)
  4. Which first, subframes or engine reinforcement?
  5. Car pic and Slide-a-link question
  6. SHelby trademark applys to fiberglass
  7. Top loader prices?
  8. Clutch Question?
  9. getting ready to paint.
  10. Dyno #'s 347
  11. Ford Racing Crate Motors?
  12. Look at this ebay find....
  13. what flex plate do i need? 157 or 164
  14. help please!!!!!!!
  15. Floor shifter rebuild question
  16. brakes
  17. 289 Rebuild Parts
  18. Discs done, cut springs?
  19. Procar/Scat Elite seats.
  20. Mustang Show in Rockville, MD - Sunday
  21. Supercharging Questions.
  22. Who makes the best lowering blocks?
  23. 1965..289 motor. Is it worth anything to anyone?
  24. anybody have experience with the parker funnel web intake?
  25. can you help me figure out where my oil went????
  26. Wheels for 67 FB
  27. convertible boot sagging ?
  28. aod ?s
  29. Paint codes ?
  30. Help!? Need help seeing what FE Heads friend has
  31. Which aluminum raditor/fan combo for 68 FB?
  32. Carb Issues
  33. Securing package tray?
  34. Rear Shocks
  35. COBRA Brakes on 9 Inch?
  36. MSD tach drive
  37. Back from the Year One Experiance
  38. Nearly completed MassFlo EFI install
  39. Electric of Engine Driven Fan?
  40. Carb Problems Again - Boy Can I use Some Help
  41. DOOE Heads
  42. Why do the car gods hate me?
  43. What year is my c4 and how many teeth does my flexplate have?
  44. wheel/tire combo for spare
  45. question for sn65 about fender flares
  46. Sway bar end-links installation
  47. Some t5 questions
  48. NY Auto Show Pics
  49. More HP from my distributor?
  50. What stock '66 style motor mount (2 to chose from)
  51. Air fuel ratio (can you explain)
  52. Carb and Manifold Change
  53. What tool do I use to cut my coils?
  54. Tweeters in 66 A pillars?
  55. Installed 17x8 mach 1s, but can i change front fitment?
  56. What cam to choose (250-300rwhp build)
  57. Engine Noise
  58. Monte Carlo bar or no Monte Carlo bar?
  59. Rear End for my 347
  60. Engine Code help
  61. Carb isnt getting fuel (Holley 4160)
  62. Patriot tri-y fitment problem (rubs on shock tower)
  63. Just got back from the Dyno!
  64. Performance Automatic C4 Super Streeter transmission
  65. She's not starting! HELP! (could be timing issue?)
  66. Need a little help setting timing
  67. starter question??
  68. Insulating Material to Prevent AC Condensation
  69. can a 71 mustang be converted to a 69 shelby?
  70. the SN65 at the Autobahn race track
  71. difference in idler arm 68 manual vs power????
  72. Best drag radial?
  73. I got a V8... I don't need a stinkin' radio!!
  74. Holley 600 CFM D/P Carb users - What are your internals?
  75. rear end questions
  76. Does anyone have these brakes? SSBC Front Force 10
  77. Shock tower, replace or weld it up?
  78. welding prices???
  79. roller spring perches
  80. compression ratio??
  81. Hydroboost
  82. 71-73 brake pedal ?
  83. Gaskets with a carb heat insulator?
  84. autometer converstion question for those who've done it
  85. Body part prices? ...
  86. What's wrong with this picture??
  87. mandrel bent for gt valance?
  88. WTB: 2005 Mustang GT wheel center caps
  89. what header on my AFR's 1966 347
  90. Headlights turn off while driving
  91. Leaky FMX pan gasket!!! Ideas?
  92. Gas mileage with OD????
  93. 17's on my 67
  94. 2.5" exhaust with the GT valance panel?
  95. Which Edelbrock shock?
  96. Top-loader
  97. Transmission suggestions...which one???
  98. engine dyno in southern mn
  99. world golf village
  100. Functional hood scoop, is this an ok setup?
  101. how much are my seats worth
  102. 68 Coupe Wiper Clunk
  103. Anyone using a hydro clutch on a 65/66?
  104. Change Transmission Cooling Lines
  105. Splicing the fuel line
  106. Insane Rear brake conversion... ???
  107. Help with Electrical Gremlin
  108. What tunnel mods are required converting to AOD or T-5 type transmissions?
  109. Rear Main Seal - changing it w/ engine in car - Advice Please?!?
  110. Detroit Locker vs. TrueTrack?
  111. which AFR's?
  112. Need help on the aod swap.
  113. will 17x9.5 fit on rear what back space
  114. Underdash 66 wiring kit from NPD sucks
  115. TCI and B&M torque converters compared
  116. Finished up a T5 swap, comments and a review
  117. Smoke and Carbon
  118. Granada MC question
  119. Brake pedal all the way down?
  120. Help with tilt column installation
  121. exhaust manifold or headers? 428 into a 67
  122. Speaker wiring ?
  123. Need POWER for cd player!??
  124. 68 power steering conversion,adjustments
  125. Can't get drum spindles off of lower A-arms
  126. How much is my 351cleveland worth?
  127. Check out this low-voltage warning light setup...
  128. Seam Welding
  129. AFR heads on my 302?
  130. What do you think of my combo?
  131. help with my 65 lowering wonders...
  132. Rear Shocks
  133. Customizing old exhaust to fit new tri-ys
  134. Quick 600 holley double pumper tuning tips please???
  135. thoughts on fat man mcphereson strut suspension compared to MII?
  136. decision of AMP for sound system
  137. 65 c-4 shifter wont go into first or second
  138. Anyone heard of Diablo Engine (Crate Motor)?
  139. power steering delima
  140. Photos of 65/66 coupes with spoilered trunk lid?
  141. distributor modulator system
  142. Fuel tank gauge wire location?
  143. Driver side rear is lower than passenger side.
  144. Cracks in my flywheel
  145. Flat tappets?
  146. 67 ribbed tail light panel. What color?
  147. shaker hood on a 1968?
  148. 1968 coupe outside mirrors? What fits?
  149. Should I narrow my rear end on my 66?
  150. How to get a 69 pedal to work in 68 with EFI
  151. classic stang supercharger
  152. runs choppy when in reverse.
  153. subwoofers
  154. Block dealer?
  155. bronco rearend
  156. Crane XR-1/timing help
  157. Brake line question
  158. torque converter stud broken
  159. 9:DETROIT LOCKER TO NOISEY (HELP)
  160. hey, what's this windshield wiper part called?
  161. aftermarket C4 Tranny
  162. Question lubrication waterpump
  163. Starter Issue / Low Volts
  164. 1 wire alt
  165. Free Granada Swap Guide
  166. Bumperettes on GT valance
  167. What about these
  168. Problem with LED taillights
  169. Help me choose my wheels- I have 3 options-
  170. Toploader bellhousing question/problem
  171. Is the stock vacuum advance adjustable?
  172. Wanting to buy a cam...any suggestions?
  173. New dragstrip times
  174. Brake Experts, I need assistance (65 coupe)
  175. Starter / Flexplate problem SOLVED!!!!!!
  176. intake and carb
  177. detriot trutrac problem...
  178. Throttle rod / Kickdown question w/pic
  179. For those who didn't like my LSx in a classic thread...
  180. Keeping cool in Miami heat
  181. master cylinder push rod question
  182. rolling fenders, how is it done
  183. custom headliner
  184. Squeezing a new engine in a 67 Coupe
  185. B&M c4 Transpak
  186. assorted hose questions
  187. Master Cylinder Question.
  188. The 550 GTC Project
  189. Harmonic Damper (balancer - whatever) question
  190. 9" leaking?
  191. 76 maverick spindles on a 69?
  192. Opentracker is the man!
  193. who can guess on what numbers i might run
  194. Brake Help
  195. Brake lights stuck on, no headlights???
  196. Really Nice Pics!!!
  197. Issues with MAC exhaust
  198. Good Technical Manual
  199. just ordered some Ford Powertrain headers..
  200. Independent suspension. C4 Vette IRS vs. SN-95
  201. 9" Advice.
  202. So I'm preping for Por-15... got a question
  203. starting problems 66 stang
  204. Got new wheels ** Video **
  205. Battery Cables for '66
  206. Phoenix welders?
  207. Get your butt off that lawn chair this year!!!
  208. REAR SPRINGS SAG?
  209. what would you do?
  210. Electric Fan
  211. Carb help please!!! ASAP!
  212. 351W intake in a 302?
  213. AOD swap
  214. Please help with Brake Light problem
  215. Steering wheel moves around, side to side, up and down..?
  216. Dimming lights & guages after new alt,volt reg,relays
  217. Shocks
  218. Does anyone know the true diameter of a 157 & 164 tooth flexplate?
  219. Alternator questions
  220. what is this part called?
  221. widest tires in back in stock wheel-wells?
  222. Wiring Harness for 1969
  223. Air suspension system?
  224. Fuel line Questions???
  225. 3 bolt crank pulley and a 4 bolt damper?? help
  226. Heavy vibration after TCI Trans and TC install
  227. Sub Frame Connecter Help
  228. Aftermarket Gauges in 70/69 Mustang Dash
  229. Installed my new wheels today
  230. Billet Grille Help!
  231. Will a leaky rear main seal foul the flywheel/clutch interface?
  232. Dyno run pre-check list
  233. BRAKE problems, help!
  234. Stalling when coming to a stop.
  235. Speedometer gear?
  236. Suggestions about paint and prep
  237. New Motor Mounts - Poly or Rubber
  238. Help ID'ing 620# springs
  239. Going to Restore my '67 - Please chime in with helpful advice
  240. damn headers, alright I need a new set now
  241. Need Help with powersteering!
  242. 70 Mach I power steering pump question
  243. New Carb Time . . . input needed . . .
  244. Non WC T5 any good?
  245. 2006 YO Club
  246. Recommendations on suspension parts (which place to buy)
  247. Lookit what I found in my trunk..
  248. UGH!, What Now
  249. pic of a 2005 GT stang grill on a 67 stang
  250. Building up a new 5.0 roller block - Questions
