PDA
View Full Version : Classic Tech
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91
  1. what gauge sheet metal
  2. Timing chain & gasket set(s) recommendations for 1972 351w
  3. Which V6
  4. NOOB with a GT40P Question
  5. Carburetor choice (daily driver, 351cid, ~400hp, manual transmission)
  6. Adjustable or Positive Stop???
  7. Clutch cable kit
  8. a-ha! Found the noise in my suspension!
  9. Timing cover leak
  10. Just thought I'd show this
  11. staggered shock pics?
  12. cam bearings install
  13. Damper, and pulleys
  14. Tri Y's and PS drop
  15. C4 to T5 swap guys... how far did you shorten your driveshaft?
  16. KYB GR2 shocks on the rear (Gas A Justs up front)?
  17. Used heads... how to tell if stem seals/retainers/valve locks/etc are okay?
  18. U joint part number needed
  19. installing aluminum dash inserts
  20. Preliminary dyno results
  21. bad vibrations
  22. 66 Mustang 289 4BBl Carb
  23. how do you fit the fiero fan? way to tight
  24. HELP!!rocker arm adjustment!!
  25. Recommendations for jumpy suspension?
  26. c-4 auto ?
  27. 289 or 351W + Brake Question
  28. More low fuel psi issues when hot
  29. Is this a good radiator?
  30. NASCAR style belt drive, where?
  31. Brakes w/o booster?
  32. My $2000 Ignition - I need help!
  33. 'Click' sound from front suspension during braking?
  34. power steering issue
  35. 69 Coupe Headliner
  36. California Special with an SLC DSO?
  37. Axle power rating
  38. Mods needed for mini-starter install
  39. Rear End help
  40. several questions
  41. suicide doors
  42. Updated times
  43. Ford Newbie - Intake gasket - '68 289 4bbl
  44. When was the first GT made?
  45. need help with a car cover
  46. T5 Help
  47. transmission issue
  48. Opinions: R302, Dart, World or Boss
  49. being told 2 different thing about a rear end
  50. new heads? or new engine?
  51. convertible subframe connectors
  52. 1" spring insulators
  53. 79 ford truck rear end, will this work?
  54. JBA Tri-Y/Long Tube/Mid-Length Headers
  55. hyd throwout toploader/jericho
  56. bigger dual quad
  57. Intake manifold rear crossover / Head gasket question
  58. Driveline ??
  59. 351 windsor knocking noise
  60. Identifiying 4V heads
  61. Radiator overflow question
  62. Knocking noise in my 351 winsor
  63. Lowering Blocks
  64. Car suddenly won't start??? Coil???
  65. I6 C4 rebuild for new 347?
  66. TOP hose cool BOTTOM hose hot?
  67. C4 tranny (fair price)
  68. 67 shelby hood for mock up
  69. th 400
  70. Can I use a helicoil in a flywheel????
  71. Deep Dish bullitts on a 65...how??
  72. Have some questions about my 68
  73. Thinking about getting Tinman subframe connectors
  74. Lowering Blocks...
  75. Front Suspension Noise
  76. Car Hates Gas
  77. Wheel bearings
  78. 73 Axel bearing removal
  79. Windshield chrome on 67, need help, I dented one
  80. sbf valve guides
  81. Vented gas cap question
  82. Finally, some Strip Times
  83. Spring Perches...
  84. need help with front wheels
  85. VIN locations
  86. Pinging/Knocking
  87. 71-73 lower fender attachment template wanted
  88. Opentracker roller idler arm and P/S
  89. 66 comet caliente
  90. AOD transmission Thread size????
  91. Control arm shims
  92. How do I determine if
  93. Overheating pony
  94. Which Convertible Top?
  95. 2005 mustang nose on classic mustang - has it been done?
  96. The Mustang is finally got paint on it.
  97. Odd problem with 347
  98. Priming in my garage???
  99. Calling all those on Megasquirt
  100. Need more tire...
  101. rear leafs
  102. Ram hydraulic throwout bearing
  103. Tie rod suggestions
  104. Bump steer kits..any good?
  105. Valve cover question...
  106. Long wheel studs/ Draglite/ Torq Thrust?
  107. what to do?
  108. how wicked is your cam?
  109. went to the junk yard to look for 9"rears
  110. Stang-Aholics 4-link rear suspension
  111. Best Cleaner & Preservative for a Vinyl Top?
  112. Softer than 620's w/ 1" drop?
  113. global west leaf springs
  114. Recommend me a camshaft
  115. Need advice for properly setting up valvetrain
  116. Magnaflow exhaust install question?
  117. what kind of oil?
  118. ez2wire harness installation
  119. 1970 Mach 1 4-spd into 68 coupe, easy fit?
  120. Baer Tracker with Granada Spindles
  121. Can someone give me the best information sources??
  122. Pertronix coil cracked
  123. Value of an original 64 1/2 coupe
  124. Fluctuating Oil Pressure (on high side)
  125. 67 Quarter Skin Help
  126. What do you guys think of my engine bay?
  127. 67 wheel clearance
  128. Help with coil springs!!! PLEASE!!
  129. Lower control arm ball joint - what size are the threads?
  130. Due to popular demand...Wheel Chart 2.0 has been hatched
  131. Turn Signal switch
  132. Will they Work?
  133. Polishing out windshield scratches?
  134. Sorta OT: Polishing alloy/aluminum wheels?
  135. Can you replace the MC push rod w/o removing the MC?
  136. strength of the early 302 blocks compared to the 5.0 roller blocks
  137. c4 overhaul??
  138. Painted my 66
  139. getting ready to get this thing together
  140. finished control arms
  141. what shifter for your C4
  142. New Headers?
  143. torque converter opinion?
  144. LED dash light report
  145. 3 and 4 bolt ball joint
  146. Lost about which rearend to use.
  147. AC refrigerant question.
  148. Seriously Considering the Griggs Gr350
  149. Branda '66 Shelby Tach Fitment
  150. Master cylinder and prop valve install questions
  151. Post-stripping rust prevention
  152. Found for sale disc brake conversion
  153. Harmonic balancer
  154. shaving head ports
  155. Removing trans out my '67
  156. change manual steering to power steering
  157. Overheating Question = Answer?
  158. Quick Trick Flow Head compatibility question
  159. Cleaning the inside of the rear housing
  160. 69 Rariator?
  161. underbody coating?
  162. Removing cluster out of my '67
  163. Can some one plz post a pic for me
  164. Make a guess on quarter mile times this season
  165. how much power can these bodies handle before you have major problems?
  166. g-bar installed
  167. carb rebuild (holley, list1850)
  168. MMmmmmm....Octane!
  169. Kick panel speakers - intereferes with clutch operation?
  170. looking for info on mustang II swap
  171. Rear view mirrors anyone got a better option ?
  172. 94/95 parts for 66 coupe
  173. Took It To The Track
  174. efi 302 to carb
  175. cleaning up
  176. sputtering problem
  177. Got my 347 running for the Ranchero
  178. pinging problem
  179. Torque thrust 2 question
  180. Bad vibrations
  181. 76 maverick spindles tie rods etc, on a 65 mustang
  182. brake line removal
  183. Export brace, looking for alternatives.
  184. Tweeters in the dash...
  185. Sammy Hagar's "new" mustang... you want to see this
  186. 1st test drive with the new turbo
  187. where to get hydraulic slave cylinder?
  188. Question about shocks
  189. torque spec for granada spindle nut
  190. Billet Flywheels
  191. 289 help.. white smoke
  192. Shelby Bullet Mirrors on a '65 Coupe???
  193. 65 stang timing
  194. Fatman Fabrications dropped spindles
  195. export rear lights
  196. Let me see some modified early mustangs
  197. speedocable
  198. spindle problem
  199. Holley carb problem
  200. 94 Bronco 351 block
  201. 64.5 master cylinder and pushrod size
  202. Brake lights
  203. Removing Column Lock Cylinder 72 Mustang
  204. What to do? Seatbelts?
  205. Longevity of 408 Stroker
  206. Trac Loc?
  207. Pitman Arm question
  208. Weird bad vibration Help??
  209. HELP need to find the least expensive way to put AC in a 68 Mustang
  210. 66 center console door
  211. daily driver suspension upgrade
  212. Exhaust port bumps
  213. another ride height question
  214. underdrive pulleys
  215. Flywheel
  216. aluminum 2 core radiator VS others
  217. Instrument housing paint color?
  218. Should I swap my t5 out while the engine's out? Or just see if it lasts?
  219. Trans Slip Yoke the same for T5 and T5Z?
  220. need help from those in the know...
  221. How to identify rearends & Differentials
  222. Milodyne bushings, worse than poly.
  223. Disc Brakes conversion
  224. 5 speed swap in 70 stang
  225. 5 speed swap
  226. 8 gauge pod for '65
  227. 65 Fastback 4.6 DOHC Turbo Progress Pics
  228. Tips for keeping overspray out of cowl?
  229. Mount Pertronix igntion coil vertically or horizontall?
  230. speedometer funcion
  231. 9in rearend disassembly question
  232. What to look for tommorow
  233. no oil pressure on first start up?
  234. Newbie help with alternator
  235. HELP!
  236. 1991 Lincoln Mark VII
  237. Oil Pan Clearance :(
  238. What type of plug wires to use?
  239. 73 conversion
  240. Turn Signals dead
  241. Electrical problem....
  242. headers?
  243. custom door panel
  244. late model wheels on classic mustang
  245. Poly Front Leaf Spring Bushings
  246. Alt. 1st & 2nd gears in a C4?
  247. what stall speed for me?
  248. Gutting my coupe... how far?
  249. storing an engine what to do
  250. lowering a 67 coupe
