PDA
View Full Version : Classic Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91
  1. differential help
  2. Installing A '69 Trunk Spoiler
  3. Front and rear springs
  4. my 71 ???
  5. shock towers
  6. Have an oil cooler?? Lemme see! (Historic?)
  7. What do I need to pass inspection
  8. will 18 x 9's fit up front on a 67 stang
  9. Finished carpeting my trunk
  10. New gears and spool= better times
  11. 1965-66 R-Model Style Front Apron??
  12. Fuel System help
  13. convertible top CYLINDERS
  14. Drag strip disappointment
  15. HP gains from Cam swap.
  16. fuel sell mounting options
  17. What kind of welder do I need?
  18. Chassis experts and subframe questions.
  19. 73 rewire question
  20. anyone ever see this Kenwood?
  21. spark plug gap question
  22. 65/66 w/351w--Can I add PB?????????
  23. 1968 Big Block
  24. timing cover
  25. Ignition Issues - long post
  26. 65 Side Vent Question
  27. AOD with stock shifter & factory console on 67?
  28. running problems
  29. MSD blaster2 coil
  30. Help me pick some rear leafs
  31. Blown head gasket???
  32. Clutch pedal- manual or power brakes?
  33. 17x9 rims fit all the way around 69 Mustang
  34. Painting Questions
  35. OK now we have fire-engine sounding ads!!! WTF?!!
  36. Bent up frame rails
  37. Prepping, Rust Conversion, Sanding, ????
  38. ANOTHER coil-over kit -- Ron Morris Performance
  39. How do you install a batt cutoff switch??
  40. Any idea if this will work?
  41. Looking for input on subframe connectors.
  42. MONTE CARLO BAR PROBLEMS!
  43. Cougar scoop on a mustang?? Anybody?
  44. Is GW Suspension products worth the $$$?
  45. Pertronix Ignitor II Install Question
  46. Subframe Connectors
  47. Engine setback thought experiment??
  48. Radiator support bumper brackets
  49. 70NE's custom EFI conversion writeup - Part 4
  50. black diamond
  51. Foggy glass question
  52. Finally started working on my center console
  53. Need Some Electical Help For 66
  54. Would you go track or would you go street and why?
  55. Damn it, starting problems when hot
  56. gas in oil
  57. How do I add a picture to my signature
  58. May have a problem
  59. Which rod bearings?
  60. how much did your carpet cost ?
  61. What is an epoxy primered '68 coupe shell with all rust repaired worth?
  62. ATTN Shelby Gurus, need advice!
  63. '66 manual to power steering kit?
  64. Disc brake question
  65. What ball joints to use on '68 Mustang with Granada spindles?
  66. 66 Original Shelby Axel Housing Question
  67. Buying 67 conv, need help w/ missing VIN
  68. Can This Manual Pitman Arm be Greased?
  69. 65 fires for first time but weak spark
  70. Pics of '69 Convertible
  71. 68 Fastback VIN location question
  72. Body work for 2,000 dollars????
  73. Finally got pics of Stang
  74. Do rear ends perfectly swap from 65-70?
  75. Accessory mounting Help
  76. What involved in narrowing a rear end?
  77. shaker hood
  78. classic rims
  79. Cooling system help :(
  80. C4 ID/Weak link Info Needed
  81. not a mustang- but interesting stuff...
  82. Head work
  83. Need Tranny Help
  84. Exhaust Question
  85. Where to find trick old school pulleys for 70 Mustang
  86. 289 configuration advice
  87. SVO Master Cylinder
  88. Headlights with integrated turn signals???
  89. Traction Bars
  90. Need quick double check on alternator (pics)
  91. need some help..fuse panel info for 67?
  92. Can't get fluid from master cylinder
  93. Problems with suspension?
  94. RRS strut/brake conversion
  95. Gas pedal
  96. Seller suggests a 2800-3000 stall torque converter. Do you experts agree?
  97. edelbrock performer vs RPM
  98. headers for stroker
  99. Shelby fiberglass hood
  100. A/C brace?
  101. FMX shift kit pictures
  102. Brake Caliper & Drum painting ?
  103. "Factory" ASC power sunroof in '70 Mustang?
  104. a different electric wter pump question
  105. pictures of my new toy 66 gt350clone with built 351c
  106. Need help honing my engine
  107. Torque box repair
  108. Negative Wedge Camber Kit
  109. For the guy who posted Mach 1 wheels on a 66
  110. More wheels Options....
  111. Is this a detroit locker??
  112. Rear Main Seal?
  113. Beware of this guy on Ebay
  114. Which gear oil
  115. Balancer shifted. now what?
  116. Headliner
  117. New wheels oppinions???????
  118. Check out this 65 Fastback for over $75K!
  119. Mechanical Advance Going on Stock Distributor?
  120. Whos interested in carbon fiber products?
  121. Installation of Maier fender flares
  122. a little awareness of an ebay scam (another one....)
  123. Anyone from/around Georgetown, Ky???
  124. 4 Way Flashers
  125. Space Saver Spare Tire
  126. Starter is Sticking
  127. Anybody seen the new Shelby wheels ?
  128. seat belt retractor problem
  129. 351 windsord and cleveland
  130. can a C6 transmission oil pan fit on an FMX transmission?
  131. 5 speed conversion...best money ever spent!
  132. starter solenoid question
  133. Who makes electric cut outs
  134. New Engine
  135. 625 road demon tuning??
  136. Choke Wiring
  137. Big Block Conversion Mods
  138. Viberation
  139. charging system problem
  140. Has anyone put a late model exhaust in....
  141. EFI conversion progress
  142. Anyone in NJ do an EFI Swap??
  143. Help: Anyone with Cobra brakes
  144. rear end help!!!!
  145. Full Paint job
  146. Good Disc brake conversion kit for 66?
  147. Kick panel speakers
  148. A newbie Drum Brakes Question
  149. Read End help
  150. Year One Is A Rip Off
  151. Header Help....
  152. 70NE's custom EFI conversion writeup - Part 3
  153. Finally, a clean pass....or three !!
  154. A Well Written Restoration Manual
  155. pondering about nitrous................
  156. spindle sizes
  157. Post pics of your convertable sub frame connectors
  158. Rack & Pinion Comparison Matrix
  159. horn short ?
  160. Harmonic Balancer
  161. Whats wrong ?? 351w problems HELP !
  162. Mufflers: Offset vs. center outlet
  163. cowl panel
  164. adding a power seats track???
  165. Granada questions, not just brakes.
  166. frame rails
  167. tach mounted??
  168. jegster roll bar / roll cage
  169. Some Pics O the Stang
  170. scarebird
  171. drum brake backing plate
  172. Smeding Performance
  173. Who is interested in a turbo kit??
  174. Alternator?
  175. Holley powervalve
  176. how do i choose a clutch and flywheel?
  177. Who makes these wheels?
  178. TKO 500 in a classic
  179. just double checking
  180. TCP Rack & Pinion and Bumpsteer?
  181. Paint scheme request
  182. 65' brake question #2--dual master cylinder
  183. 65' brake question #1-PB
  184. upgrade to disc on my 69
  185. Finaly my 332 motor is done
  186. Update on my motor vibration on my newly purchased fastback (pulled trans)
  187. looking for 69/70 shelby type parts
  188. Eleanor tail panel question
  189. K&N X flow top filter?
  190. What gauges to get?
  191. Driver's side hood hinge has one stripped bolt!
  192. New Mach 1 wheels on An old Mach 1
  193. short little vid of 10secgoal's blow off valve
  194. mach 1 louvers
  195. 16" wheel pics
  196. Any real benefit to an H pipe compared to regular dual exhaust?
  197. 1969 Special Edition Mustang - Philadelphia region?
  198. Alignment drift?
  199. Electronic Ignition
  200. schematic help asap please. easy question
  201. Holley Jets
  202. 70NE's custom EFI conversion writeup - Part 2
  203. Steering Gearbox Leaking
  204. What would you pay for a turbo kit?
  205. What caused this carnage?
  206. Painted standard 67 dash ?
  207. eleanor taillight question
  208. anyone own a ford taurus or a car with a 3.0L v6? I need a measurment
  209. 66 rocker panel replacement
  210. Why did you do a hydro?
  211. AAAAAHHHHHHH! F%#&ING WIRING!!!
  212. Do they make Racing Stripes in Decal Form?
  213. Turbo 68 fastback... carb or efi?
  214. TCP or Randall's rack?
  215. 1968 302 motor question
  216. shipping engine cross country
  217. Moving the Car for Painting
  218. Filling Badge and Aerial Holes
  219. '65 Coupe Windscreen Removal
  220. 351 cleveland power estimate
  221. Need suggestion for rear end replacement
  222. How do you put -an fittings together??
  223. Putting a modern E-brake handle in a classic Mustan
  224. EFI Experience
  225. Lots of vibration from my newly purchased fastback (3000-4000rpm)
  226. my new fastback is smoking like mad but I have good oil pressure? (351cleveland)
  227. Nice size wheels
  228. What's a good site to buy or look at wheels?
  229. Plating and metal strength
  230. electrical advice needed, 67fb
  231. New wheels
  232. Opinion Please -- Contemplating a rear end swap
  233. 66 front springs
  234. My brakes suck !!
  235. need patch panel that NPD doesnt list
  236. Shelby engine compartment pic request
  237. 67 Shelby tail light question
  238. front/rear seat belts the same in a 68 mustang?
  239. Help Me! Turn Signal Wiring issue
  240. could someone make a list?
  241. how to remove wiper/ign swtiches? 65
  242. where can I find stuff to convert my 68 interior to white?
  243. Rack & Pinion Question
  244. I just bought a 68 with a 289 - lead additive needed?
  245. Are Caltracs traction bars a good choice for the street?
  246. long tube headers on a car this low?
  247. fog light splicing
  248. will my stock a/c, p/s and other brackets work on a 351?
  249. Rear end hopping.
  250. hey guys i just got a new car!!!
