PDA
View Full Version : Classic Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 [45] 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. Anyone have the new Super 40 Mufflers?
  2. Are these the right wheel studs?
  3. traction bars
  4. Brake booster vacuum line question.
  5. The '68 T/A restomod made some progress today.
  6. Tire size up front?
  7. Roller idler arm questions for those that installed one.
  8. Frame rail seems to be missing.
  9. C4 / C5 trans question
  10. What water pump?
  11. Head Porting ?
  12. Stuck bolt. How do I get it loose?
  13. Wont Start Up
  14. looking for 68-73 351W heads
  15. Who's running Aussie Cleveland Heads?
  16. bay area/norcal paint shop ideas?
  17. Slowly grinding down header flanges..
  18. Drip Rail Removal - Conclusion??
  19. 289 was built by chevy ???????
  20. upgrades for my engine
  21. Anybody using AC Delco plugs?
  22. Brake lights and blinker not working
  23. this doesn't sound safe to me...
  24. Short Block vs Stroker Kit
  25. flat tappet vs. roller TIP rockers
  26. crate motors versus vintage
  27. Lemme tell you y'all a story about 275 40 17s & 65 mustangs...complete with many pics
  28. Steering column help
  29. What's needed for a disc brake conversion
  30. With the new blue moon desing.....
  31. Since not everyone checks talk, there are some new forum styles in the lower lefthand
  32. Check Out this pic......
  33. WHOOHOO scored at NPD ocala today!
  34. Another Front suspension question.
  35. C4 install problems
  36. roller bearing idler arm kit
  37. marking bolts
  38. QUICK ANSWER PLEASE!! Is the fan blades
  39. 3rd time is a charm
  40. Do all headers require a power steering drop bracket?
  41. Hissing Carb
  42. new driveshaft install
  43. Header gasket for AFR 185 heads?
  44. We Have Calipers!
  45. Edelbrock Carb Question
  46. 3m Automix question
  47. Need help with stroker build.
  48. HELP! I am replacing my Front Suspension today
  49. Just Bought used heads, need Recommendations
  50. Help with choosing heads
  51. Headers?
  52. Thermostat Help
  53. Help me estimate the value!
  54. Engine temp sensor
  55. Fog Light Switch - Where do it go?!?!
  56. Powerdyne supercharger on a 66' 347ci
  57. 8 inch rear questions
  58. photochop needed
  59. Engine Question
  60. Safety quetion
  61. Hoses????
  62. Choke block-off cover plate ??
  63. C6 stock tranny for what years?
  64. Has anyone ever SPRAYED POR-15???
  65. Got some 351W Engine Goodies
  66. Mustang II UCA
  67. Subframe connectors
  68. oil pump installation?
  69. Dash Pad Install
  70. rod bearings, need specs,advice
  71. Another good source for Roller Spring Perches.....
  72. Knock Knock
  73. parts plus opinions
  74. Auto to manual coversion ???s
  75. Stainless moulding
  76. Summit Exhaust system bolt up to stock manifolds?
  77. Pulleys!!!
  78. It is a tough job but someone has got to do it!
  79. Invalid Thread Specified - Help?
  80. *** Ultra Rare 1967 Mustang? , Please help
  81. Forum upgrade freaking me out....
  82. So is coolant always flowing through my heater hoses?
  83. Interesting stuff
  84. Windsors
  85. 2" rear springs how much did they lower
  86. Disk Brake Question
  87. In the middle of T5 swap...Help!!
  88. 69 tank in a 67
  89. Edelbrock performer RPM crossover
  90. Need help from 69/70 owners with Shelby rear fiberglass!!!!!
  91. 1966 Manual trans Pedal+spring question
  92. New Rod bolts = resizing rods?
  93. engine bay sizes
  94. impact switch
  95. Fiberglass!!
  96. EFI harness picts
  97. fuel pressure gauge recommendation sought
  98. Just got a 429......how to extract 500 HP?
  99. Tranny mounts
  100. Updated Photos of my '65 fastback Projects
  101. Brake problems, possible booster!
  102. Anybody useing comps magnum roller tips with crane's cool nuts?
  103. Distributor Shaft
  104. Spend my money!
  105. 289 mini boss?
  106. Torque Box: Repair or Replace?
  107. Before restoration - After restoration pics
  108. Floor pans and my gas tank
  109. My new MSD 6AL has no spark! Please help.
  110. Heater core replacement Questions
  111. What a dipstick!
  112. Just got back from Dallas Mustang Dyno pull
  113. Pic's W or W/O
  114. Which is better?
  115. Headlight switch!!!
  116. WTF is this nipple thing?
  117. 65-66 Manual Trans Brake Boosters
  118. '66 wiring loom needed
  119. what should a port/polish job on cylinder heads and intake run?
  120. Water Pump question for 65'
  121. Restoration
  122. Winter Projects
  123. Swapping Heads
  124. GT Fog Light brackets
  125. If you think JME is overpriced, think again
  126. Ford Expolore rear end??
  127. Roller Engine swap Questions
  128. 28 inch tires on a 70 Coupe... Springs?
  129. has anyone had experince with master power brakes?
  130. Strange '69 running light problem
  131. Anyone running a 351w and Vic Jr intake???
  132. RUST:the number 1 thing I hate...please help
  133. What body piece am I missing?
  134. Timing Question 69mustang 1971 351w
  135. A little progress I've made
  136. Tranny Dead?
  137. Another brake question
  138. can anyone identify this shifter
  139. Questions on a '65 Mustang -- Any advice appreciated.
  140. Problems with 289 Engine. Looking for Help.
  141. new rims on the 67
  142. Rack and Pinion Spindle
  143. Where is the best place to buy carbs and distributor
  144. best plact to buy body parts ?
  145. [B]Does anyone know the specs on a 1975 351W?[/B]
  146. Help me with spindle design
  147. Sub Frame Connectors
  148. Hypothetical?
  149. Msd 6al Box is dead!
  150. Comp Cams XE268H
  151. 289 and 5.0 interchangable parts?
  152. Newer 5.0 Distributer?
  153. Zirgo Electric fans
  154. picture please
  155. Edelbrock Clev heads vs stock 4v
  156. Having problems with electric speedo
  157. Tuning This weekend
  158. rearend vibration???
  159. C4 tailshaft bushing
  160. Garage find: What's it worth?
  161. 6 speed??? tranny
  162. 67 brakes to 68 power brakes?
  163. Thinking about a 4 barrel
  164. Light problem
  165. Cheap "9 inch"
  166. Lets talk about brake systems
  167. # G alternator question
  168. parking brake
  169. Problem with head.......
  170. quick AOD swap question
  171. Cowl Vent Cover
  172. Back up light switch, where can I find one?
  173. Rear Sway bar installation instructions
  174. New leak found
  175. 351C - Low Profile Blower
  176. 289 Heads on 302?
  177. Rollbar Questions?????/
  178. How dumb would I be? 200 to 302
  179. 351c Questions
  180. new powersteering
  181. Granada Proportioning Valve
  182. Flat cam lobe
  183. Exhaust Leak?????
  184. ucstang
  185. Need help with Hood clearance......
  186. recommendation for prep and painting video
  187. need help on front end torque specs
  188. 302 carb recommendation
  189. Where to buy sheet metal?
  190. Changing MC from single to duel
  191. Car is eating starter solenoids.......
  192. Specific Emblem: Where can I get it.
  193. How to use Jeg's overflow tank?
  194. Power Steering
  195. drag suspension ?
  196. Engine Startup After Rebuild - advice please
  197. Any luck with fuel line in a roll
  198. Can't get my car out of 2nd gear
  199. Will cobra valve covers clear my roller rockers (edelbrock heads)?
  200. Opinions on oil...
  201. help with a bad miss
  202. Want a carb'd late model mod motor for your classic?
  203. Looking for '05 rims??? Found 'em cheap.
  204. 69 Falcon spindles
  205. Problems starting
  206. Removing heater control cables
  207. Boss 302 Gurus I need help
  208. 351W question
  209. heat/air control...
  210. 5.0 swap... front of motor to rad. measurements?
  211. Small Block engine Pics
  212. STUCK USING ROCKER PANEL CLIPS - Please advise!
  213. Fan doesn't turn on, escort
  214. Header Headaches!
  215. Mustang II Stock Suspenssion on a 65??
  216. removal of emblems and front bumper
  217. Final spindle assembly prototype
  218. Randall rack install...
  219. the 275/50/15 bulge
  220. Drum Hubs & Spindles for Cobra Brake Conversion
  221. 4 bolt main windsor block
  222. Will a '70 waterpump fit a '66 289
  223. 67-68 door shells
  224. 67 BB 428 & Rack and Pinion ?
  225. Dyno time any advice?
  226. Ford factory cams
  227. Another 5 Speed Swap Series
  228. How the heck does the heater switch work?
  229. Off idle stumble
  230. Anybody running a Blue Thunder intake?
  231. Help Diesling.
  232. Brake drum question
  233. Same ole more power thread
  234. AUTOZONE Engines
  235. Carb Tech, need help tuning.
  236. Is this power steering?
  237. Spark Problem
  238. Why is it so hard to make a sending unit seal up?
  239. What header to use in the $150 range
  240. brake rebuild kits
  241. What should I set plug gap? pertronix, edelbrock heads, stock c.r.
  242. Another timing Question
  243. painless wiring
  244. Can someone ID this relay?
  245. 289 Oil Pressure???
  246. wheel question
  247. clutch questions
  248. Msd blaster coil getting no spark!
  249. 65-66 Side Window Removal Steps
  250. Caltrac transfer link lock nuts & preload?
