View Full Version : Classic Tech
- 7 or 9 hole water pump
- Battery Problems
- removing door lock cylinder linkage
- Recommend me a camshaft?
- Videos and Sound Clips of Mustang Fastbacks?
- Overcharging Battery ?
- heater hose replacement
- Clutch issues
- Website not scrollling
- What are the chances's?
- Off pace tonight....and damage
- Question on Heel toe, and the 2-3 upshift
- Dropping Oil pan
- Oil Pump and Alternator Question?
- Wheel/Tire for 1972 fastback - First Post
- Need help IDing a small block
- Rebuilt engine making clicking sound
- Shelby Drop Concern
- Braking problem - 65 Mustang
- Transmission kickdown holding me from full throttle
- Distribution block or proportioning valve?
- what is the function of the dashpot on my 2v carb?
- Flash Rust
- Inner/outer tie rod & idler arm torq #s
- Electrical problem: flashers and turn signals
- Help with trw pistons
- Flowmaster Exhaust sound clips
- Anyone with Hooker SuperComps/Borla XR-1's?
- Hey guys, help me out if you can...
- dash light question
- Windows go down *too* easily...
- 66 Mustang w/ 71 Mustang Disc Brakes, tie rod end issue?
- old timer intake trick?
- wire melted....what gives ?
- Warm weather & vapor locks?
- pedal support
- D. Hearne and others, junkyard help please!
- Have fun with this one!!!
- Help troubleshooting gauges
- 69 Mach 1 429 Cobra
- O/T but I don't care... SUPERDAVE IS BACK!!!...
- Eaton Power Steerign Pump
- Holly Help!!!!!!!
- no choke on 66 289 2bbl
- roll bar
- A/C not cycling
- Spark plugs
- Selling my car,What is it worth?
- Newbie..I need engine swap advice..
- New Spindles???
- Headlights blink on and off
- 1967 convertible frame replacement
- Which Headers????
- Kick panel question from a newbie
- Has anyone here used Hooker Aero Chamber Mufflers?
- 5.0 install booklet... Send you info/lessons
- problem with the belts and pullies on my swapped in 351c
- engine casting numbers
- 65 GT exhaust
- Not getting full throttle, problem with linkage
- Has anyone used the Dr. Gas Spintech mufflers?
- '66: Speedometer not accurate...
- '66: Fuel gauge not working...
- EFI benefits with Carb appearance?
- 351c water pump outlet on the wrong side?
- STRUT ROD BUSHING ?'s ASAP
- Paint or Powder coating?
- flaming river
- jeep/dodge intake
- Where to get factory manuals?
- door/window hardware install help!
- oil pan on a 67 coupe with manual steering
- 1966 Mustang Fastback, 514 cubic inch engine? How too!?
- Anybody running a 19:1 FR box with quick steer kit?
- Engine sluggish to crank
- 4 Lug Wheels for 1965 inline 6
- Transmission Position
- Valve Train Question...
- how much hp with this exhaust set up 5 hp at least?
- Stock Cumbustion Chamber size
- Holley Avenger OR Road Demon
- dangers of not using a pilot bearing
- i6 to v8 front brake conversion
- intake manifold gasket recommendations solicitied
- Opinions on wheel choice please...
- Help identifying '68-specific pedal assemblies.
- fuel cell vs. stock tank
- Need help with c6 trans...
- Front Timing Cover Oil Leak
- New brakes,pedal on the floor..
- Radiator problems
- Stubborn Turn Signal problem...almost caused fire
- car died, the started up later.
- 5.0 EFI guys, please post pics
- Alternator Bracket
- Desiel mustang?
- Wheels
- Holley 4V classic finish
- Eastwood Spot Weld Gun?
- Anybody in cleveland with a 67 fastback?
- More progress, engine complete..
- question about replacing center section
- Manual choke conversion – Ford 2V carb.
- Blue instrument panel lights PICS
- Drag racing question..*
- '66 Pwr Steering Slave Cylinder Replacement
- Adjusting Valves, please help
- Anyone have pictures of a classic with 01-03 rims?
- Belt Tension
- Yellow 67 fastback in Houston, TX
- Big Block in early seventies Mach 1
- Lower side scoops
- Grogain Seat Belt Dye
- Voltage at shift indicator light?
- gilmer drive
- What are the idiot lights in '69 standard dash?
- Shaker on a 65/66?? Anyone ever do it?
- Last wiring questions, I promise...
- Fuel line clips?
- My new baby! Hi-Po or no Hi-Po?
- Solid Gas Cap
- WTB: 69 Steering Column Trim Piece
- Discount code for Mustang Parts
- Rear axle and brakes help!!!
- Power Brake Problem!!!
- How do you take that stuff off the car?
- Anybody have HEI distributor AND MC bar ?
- 88 mustang 5.0 left rear park brake cable
- Engine is In
- newbie: 67 mustang, 289, timing/fuel issues
- Hp/Torque qoute
- i get a knocking sound coming from my front drums
- Brakes pedal sticking
- Wierd timing issue
- AOD in a 1968 mustang
- U-Joint Question
- Tell me I didn't just waste a bunch of time/money!
- Finding motor year
- The Dynamic Duo Strikes Again
- how do I?
- Engine
- fuel pump PSI
- Fall car show and swap meets in Moultrie Ga. dates?
- Fuel Line
- cheapest place to get braided hose?
- new 69 windshield
- heads
- Weight guessing..
- Where to mount electric fuel pump?
- Appraisal for my cobbled 65/66 coupe
- 1967 Rear Window Trim??
- Guess the mystery parts in my oil pan!
- why do I have a terrible vibration when braking
- gears
- Are composite leaf springs worth it on a street ride?
- Show me your 69 cars
- clutch pedal?
- TKO 600 in a 65?
- need a welding machine!
- Setting ignition timing before first start – advice please
- Which fan and fan clutch do I use on a 66 289?
- Which Flywheel?
- Transmission Vacuum Modulator Line
- Good camshafts?
- 5.0 EFI w/AOD swap into a '69 Coupe
- Ignition setup? I'm kinda lost here.
- 289 HiPo specs (inquiry)
- Carb Question Needed Quickly
- breaking rocker arms?
- Piston to Valve clearance on cam?
- Small ignition question.
- tranny problems need help!!!
- Progress on my 69 Coupe (56k Warning)
- Carb Spacer and RPMMMMMS
- Flywheel teeth
- underide vs overide trac bars
- battery keeps dying wont stay charged over night.
- distributor new stock one or aftermarket electronic?
- Dash replacement 65/66
- Removing rear brake hose
- should i buy or not
- How to use a power steering pulley puller?!
- Underdash Light 66 Mustang
- Carb question
- suspension 68 coupe??????????????????
- Price check on a 65 fastback
- Power Steering opinions
- Distributor question
- One Piece Front Clip
- How do I install a 69 steering wheel emblem?
- Removing weather stripping goo
- Original Tooling parts and the coating on them
- can I use this 1977 351w electronic distributor on my 67 289?
- fiberglass or carbon fiber
- How many 65 66's are left ?
- Cleaning the intake ?
- Clutch Problems.. what does this sound like
- where to start, what to get for a 67?
- Have you guys with expensive wheels seen these locks?
- How thick can I go with bondo?
- buy a doner car or buy peices at a time for my 5.0 conversion
- What a feeling
- rebuild holley or not??
- anyone use a vario-centric camber adjuster on 66... any tips??
- V-8 Fuel Line Routing
- Good source for new T5 transmission
- Why won't alternator gauge work?
- I cant get my charging system to work!!
- Carpet install
- bellhosing color
- What are my warning lights telling me
- Upper A -arms
- I think there is a tap dancer in my hood
- How do you remove the headlight switch in a 70?
- Clarifaction
- New Pics of my car after a good wash and wax
- Pictures of master cylinder and brake lines
- Steering Linkage Swap Advice/Tips?
- Coil mounting location?
- When will replacing a thermostat improve cooling?
- i need help
- Billet steering columns
- Should i add fiberglass restomod parts? eleanor/cali-spec?
- Engine balance question
- temp to high
- low oil pressure
- Need header advice
- installation of ATI p600b sc complete
- What primer should I use after aircraft paint remover?
- SERPENTINE belt conversion
- Best aluminum rad for my money?
- Brake Guru's...Need a Bit Of Advice.
- Cleaning engine compartment.
- mounting options??? help
- Can I remove my thermostat?
- Preparing for Dynojet Tuning
- Manual Drum Brakes to Power Disc Brakes
- Best RTV for engine rebuild?
- 5.0 conversion on a 66 mustang
- tie rod ends
- Need a vacuum diagram for a 67 289 2bbl stang
- What would make left front wheel chirp or squeal ?
- Rough Idle caused by electrical?
- Who in here has put a radio in their glove box?
- Help pulling engine.
- Pics of tail light "blackout" panel installed
- How to make a 67 handle
- Brake lights?
- Sounding like a mean monster
- Whats the differences between 66,67 fairlane and galaxie?
