PDA
View Full Version : Classic Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 [50] 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91
  1. Production, Sportsman, Ford Racing....
  2. small air cleaner???
  3. Tach wireing
  4. Passenger Side squat = sagging.....
  5. Update on 289-->351c motor swap
  6. Block back & painted engine parts
  7. Need help with a 289
  8. door 1/4 window gasket
  9. Brake lights out!!
  10. Opinion on heads...........
  11. pushrod help
  12. where can I get a 67 fastback vin checked?
  13. Brake Valves...
  14. Which EFI option?
  15. Need help with the 302 heads with EGR.
  16. Power Brake Problem - Help!!!
  17. Flywheel Machining?
  18. newbie question about shelby drop
  19. New Mustang Rims on Classics
  20. 69 Engine paint code?
  21. rear track width on 65 convertible 8 inch rear end?
  22. Glass Storage
  23. 65 & 66 GT
  24. Cooling Help, overflows
  25. Hood Fell down :(
  26. Installed Aluminum Radiator
  27. MSD Distributor in 289 V8
  28. How to 67 headlight switch removal
  29. Exhaust cutout
  30. 302 runs like POOP. Help! (long, rambling newbie)
  31. 351W experts in here please lol
  32. Want to build a motor
  33. El Stango Idling Too Low
  34. Outragous Shipping
  35. trunk seal install
  36. 1966 coupe window questions
  37. Engine Questions/new Block
  38. violent shake when taking off
  39. lakewood traction bars?
  40. SRod Tranny compatability and condition check
  41. sudden over heating
  42. Questions about ride height
  43. Anyone have sound clips of Borla, magnaflow...
  44. roller pitman/idler
  45. PerTronix Billet Plug and Play Distributor
  46. See my stang here
  47. Putting front discs in...few questions.
  48. Need help on putting 93 5.0 heads on 289 rocker trouble?
  49. 1972 302 engine question
  50. C-4 problem, PLEASE Help!!!
  51. Edelbrock Carb Choice
  52. Got some pics of my car finally
  53. qucik question!
  54. Radiator Cap
  55. Immobiliser security system?
  56. Versailles rearend width
  57. How much is this worth?
  58. How To webpage on bleeding brakes ?
  59. Clutch Selection
  60. 66GT hesitates when accelerating & shakes above 55-60?????
  61. how can u tell its a shelby and is it worht it??
  62. Transmission Fluid Type
  63. oil dipstick inaccurate?
  64. $200 Pulley?
  65. I thought someone wanted to know about big rims on a '65/'66, here's 18s & 20s...
  66. Fastner ID
  67. 1990 in a 60's
  68. Manual or Power Steering
  69. glass packs good idea or not?????????
  70. is this a shelby and would it be worth the time and money??
  71. How do I identify my brake hoses?...
  72. Transmission leak problem
  73. Head experts and compression ratio guys in here please?
  74. All guys going to the track post times when you get back.
  75. 95GT Master Cylinder in my 68
  76. Brake drums stuck to the carrier-hub
  77. Oil pumps and oiling
  78. How to drag race your classic
  79. Engine Will Not Idle
  80. Dilemma...
  81. TMC rear lowering kit
  82. Pertronix ignition set install
  83. Difference between 69&70 rim blow wheels? (and column question)
  84. 70-79 Truck 2 Speed/intermitent Wiper Motor In To A 1966 Mustang
  85. Won't Turn Over
  86. Looking for Mustang Club in Monrovia
  87. Elevation change:jet size change ratio?
  88. what do do with you classic..poll!
  89. Msd Or Hyfire.
  90. Studs on Front Rotors
  91. Daily Driver AC Kit & Water Pump
  92. Any body want to swap pills....msd ones
  93. All that have done EFI conversions, a question?
  94. car wont stay running
  95. Cutch problems
  96. brake question.
  97. alignment shims.....
  98. New guy needs header clearance info
  99. Water pump issues.....
  100. Flowtech headers
  101. gas gauge issues
  102. What gap?
  103. Battery for '69 mustang
  104. fuse panel
  105. I think we need a drag racing link?
  106. 1970 alternator charge guage shows low?
  107. Late model hoods for 65 mustang
  108. Fan shroud diameter
  109. doesnt sound right does it?
  110. This is crazy what the $*#@ did I do?
  111. Maier racing sub-frames
  112. Paxton Crank Pulley?? A/C?? HELP!!
  113. blocking manifold exhaust crossover?
  114. another fuel line question
  115. How much to ask for a 289
  116. 428 Cam Specs
  117. Holley Problem
  118. Perception --
  119. 66 upper and lower control arms in a 70
  120. advice on buying
  121. Standard drum brakes to power brakes
  122. anyone with AOD & Lokar Kickdown..need help
  123. 66 mustang tri-4 link
  124. Custom upholstery Q
  125. Need help with 65 wiper motor
  126. drag racing suspension setups
  127. Seam sealer around shock towers
  128. Stang Dies
  129. Power steering pressure hose, o-ring, what size?
  130. Steel dash...not the pad
  131. Need pics of a 65 stang with 15x10 out back.
  132. Q: Remove rust from chrome wheels?
  133. Ok All You Efi Gurus, Here's Your Chance To Help
  134. Shocks or springs
  135. 66 V8 Fuel line installation
  136. Any Sugestions on a rear away Bar for 67
  137. 66 transmission shifter installation
  138. coil bind on a 351C
  139. weight hits starter????HELP!!
  140. Oil Pan ID
  141. Look what followed me home this weekend
  142. Dash Restoration on my 66
  143. Really need some help with ignition switch wiring in 64 1/2
  144. 16 or 17 inch wheels with no modifications?
  145. 1967 Shelby GT500 Fiberglass Body Kit
  146. Pulling motor on 68 Fastback
  147. When do you replace floorboards?
  148. 66 t-5 gears and rear end??
  149. '68 302 w/ 24" radiator fan shroud question
  150. Differential broken?
  151. Project Update (almost done) '65 Custom Fastback
  152. Paint aluminum radiator (How?)
  153. Can i save this paint?
  154. 289 blocks, help!
  155. Front and rear window questions
  156. Late model rims on a classic
  157. granada brakes for a 67 stang
  158. Measurement needed
  159. rear end/suspension ?'s
  160. What engine should I build?
  161. Big problem! Clutch or driveline, i dont even know
  162. 1970 air conditioner inside box condensation on outside of box dripping on floor
  163. What are the symptoms of blown power valve
  164. PCV Ticking?
  165. headers/exhaust for 65 w/ T5
  166. A few quick questions from a new guy...
  167. Cobra & Stang pic
  168. 67 mustang with AOD
  169. Two questions. . .
  170. filling chrome strip holes
  171. Track Lok Vs. LSD Vs. Detoroit Locker
  172. Best oil for a high mileage 289?
  173. Exhaust restriction or fuel problem?
  174. car stumbles from idle to 2500
  175. Turn Indicators not working
  176. Got my new seats...
  177. holley carb
  178. Traction Lok Unit Differences
  179. 1970 Brake warning light on dash question -
  180. 1969 Mustabg GT Convertible on e-bay
  181. Por 15 on undercarage
  182. 69 351W question: is the timing pointer at 10 or 11 o'clock?
  183. newbie question about thermostat bypass
  184. 64/5 Radiator upgrade
  185. Brake Warning Light Came on.
  186. 67 Dash Lights -Flickering?
  187. Fuel line question
  188. Pictures of the 70, Lowered and with 18's
  189. 351w swap, water pump/radiator ?'s...
  190. Any way to take apart seat belts?
  191. 18's or 20's on early Stang
  192. Marine 351?
  193. Procar seat adapters....
  194. GT-40 Heads on stock 289
  195. How to clean/prep metal w/ light rust for paint?
  196. torque specs on 66 Mustang strut rod?
  197. question about coil over kits.
  198. EFI Conversion
  199. Carb and/or ignition problems, which carb/ignition do u suggest?
  200. Firewall template for efi harness
  201. Shocks and Springs
  202. need help finding place to buy plugs and connectors from
  203. Fuel problem
  204. having timing pointer problems
  205. 73 coloum bad?!?!?
  206. Front spring removal
  207. Ride height question
  208. Timing problems
  209. Calling at Electrical Gurus
  210. which spark plug
  211. Is This Car a GT
  212. Rear ends....
  213. Help! Ignition problem
  214. car acts like it has a rev limiter but it does not?
  215. How much for a 67 Fastback...
  216. need info on a 351 CJ
  217. Help with Casting Numbers
  218. How do you remove the guage panel on a 69
  219. Newbie questions about 302 performance
  220. idle drops off at stop lights
  221. Car died
  222. Thread sizes on front brake hoses
  223. Tire Recommendation
  224. Tremec Clutch Cable Adjust
  225. aluminum wheels
  226. Finally getting stroked!
  227. Fiberglass hood hold-er-uppers
  228. 65 Mustang rubbing tires
  229. How much clearance?
  230. header heat wrap
  231. Removing leaf springs
  232. Outta ideas!! Overheating and pinging!
  233. Clutch Cable Conversion?
  234. engine oil in radiator
  235. Bypass hose size?
  236. Need Pertronix ignitor gap settings
  237. quality job at dying tan leather seats black possible?
  238. Explain different rears
  239. paint removal off chrome?
  240. '67 Factory A/C
  241. pics of our convertible project
  242. Noob
  243. Opinions on the Ford Racing 5.0 w/ GT40 Heads
  244. Granada power brakes on 66 Mustang?
  245. ignition switch
  246. Dual Exhaust 3" Tail Pipes?
  247. Interior assembly on 67 Coupe
  248. Shift kit?
  249. any new news on Dolfan's suspension?
  250. Ford Cobra Engines
