PDA
View Full Version : Classic Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 [53] 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Any other 67 aqua interiors?
  2. Where to buy 393w kit?
  3. Can someone give me a HP/Torque estimate?
  4. Minnesota Mustangs –sunday- Sunday- Sunday
  5. Anyone here with a underhood light on a 69/70?
  6. Temp Spike on freeway
  7. Thinking of changing to auto tranny.....
  8. Stock temp gauge reading = ?
  9. cowl cover
  10. Running a little rough
  11. sound insulator
  12. wheel size
  13. Aluminum or 4 core
  14. 66 fastback trunk carpet
  15. t5 swap crossmembers
  16. When to paint block ect?
  17. Temp At 220+
  18. Steering colome bad
  19. Vibration
  20. Timing Light
  21. 65 A code Update
  22. Need help by tonight, engine problems continue
  23. MOOG or not MOOG that is the question
  24. Do I need guide plates?
  25. How do I mellow it?
  26. Mono leaf springs
  27. Stroker??
  28. Calling all body guys
  29. 60 over bore
  30. full frame replacement for our unibody cars
  31. Polyurethane Bushing Kit
  32. rally pac
  33. mustangsteve's 13" cobra brake lit is out and cheap
  34. New engine isnt sounding too good yet
  35. Trying 275/40/17s all around on a '70
  36. need to roll fender lip for 17x8's and 17x9.5's?
  37. booster question
  38. clank clank clank?
  39. drop in rpm
  40. Starting t5 swap, part list help, please.
  41. Ticking, smoking
  42. Dad wanting to drop from 4.11's to 3.55... whats needed
  43. AOD on 67 mustang with long tube headers
  44. lookin for a 9 in rear end and need some help
  45. I just purchased washmo66's coupe
  46. budget build on a 331/346 stroker
  47. Carburetor adjustment
  48. Mor Pics Of Christine
  49. water gauge Q.
  50. what carb would you put on this set up?
  51. e7 heads on an early 302
  52. paint pic=done
  53. Electrical Nightmare
  54. Custom 66 gauges... Finished!
  55. Anyone from Finland out there?
  56. any painters interested near buffalo, NY
  57. I'm almost scared to ask this..
  58. Dumb question regarding 8.8 rears
  59. Help with my duraspark conversion.
  60. something strange in my glove box...
  61. Engine Purchase Question
  62. Is 345 FWHP Enough ?
  63. Traction
  64. Stalled!
  65. Lakewood Scatter sheild and starter issues
  66. Kind of a dumb question, but...
  67. somewhat off-topic
  68. Weld on Traction Bars
  69. tach. mounting question
  70. Bell Housing & Clutch for 351W and Top Loader
  71. a few engine and hp questions
  72. AOD wars
  73. 67 6-cyl, worth $5k?
  74. Shelby Gauge pod?
  75. 2005 GT Grille
  76. AFR vs Dart Heads
  77. Powersteering drop bracket install?
  78. .22 rifle shot?
  79. I need some info from you calssic guys.
  80. exaust body plate
  81. best desktop software
  82. Finally Done !!!! See what you think
  83. seat?
  84. paint ?
  85. Couple noob questions I KNOW you guys can answer.
  86. Quick 351W question
  87. The Ford T-5 (Germany's Mustang)
  88. Tough to get into reverse recently
  89. Timing Question
  90. steering wheel restoration?
  91. quick finishing question
  92. granada disc brake swap to 67 mustang
  93. Early timing Chain Covers
  94. Brake fliud leaking through warning light switch?
  95. door latch part broke help!
  96. '69 Steering Gear Help!
  97. Brake Help! Please!
  98. Need some major help here guys :-/
  99. explorer axle swap
  100. Electric Vacuum Pumps
  101. Stuffing weiand stealth or performer RPM under the hood of a 65-66 351w car...
  102. 2bav8 a question for you
  103. New Engine- Engine Stand Question
  104. 60's Mustang Disk Brake Compatibility?
  105. Intake VS
  106. Want to upgrade/update my '66 GT brakes - ideas?
  107. HEY Bluemonster65!!!
  108. Subs in the Trunk.
  109. 10" rim fit on a 1967 mustang??
  110. Did the 9" Versaill rear end swap: never hooked up parking brake.....need help!
  111. Water/Crank/Alternator Pulley
  112. 393W or Nice 302 for a 66
  113. difference between harmonic balancers?
  114. Whoopee - another tire question...!
  115. Can someone help me identify this eec?
  116. good old exploding tank question..
  117. paint ?????????????? help!!!
  118. pearl paint ?
  119. Cut Pile: Carpet
  120. disc brakes kit from rcmotorsports?
  121. rearend under '71 cougar same width as
  122. c4 to t5
  123. New (rear) Gt Seats In A Classic
  124. how to connect a diode
  125. Headers and powersteering drop bracket
  126. 390 or 428 build for a '69 mach I?
  127. 351 cleveland fit in a '65 mustang?
  128. I Need a New Clutch, someone help?
  129. Restomod of a 1969 - Brake question.
  130. Tire Question on 17's
  131. Edelbrock Victor Water Pump
  132. AOD swap where do you start.
  133. Wider rear brakes????
  134. tire questions and radiator questionson high hp 67
  135. EFI swap question
  136. I got her running...
  137. New Radiator Died
  138. ?? centering wheel over K.P. axis
  139. Tremec Swap 351c
  140. Help!!!!!! Front End Trouble
  141. Problems (overheating) after re-installing heads
  142. Timing Chain Cover
  143. Timing Chain Oil Slinger
  144. Thermostat Selection
  145. Manual linkage block mounted pivot ball
  146. TT331FB Update
  147. Which mirrors to choose.....
  148. Brake line fittings
  149. Another Cowl repair question
  150. Fiberglass Hood -- to pin or not to pin...
  151. Paging sixtynine Mach
  152. Occasional puff of white smoke...what does it mean?
  153. 1/4 mile et goal
  154. Whats wrong with my motor??
  155. attaching front spoiler
  156. Couple questions
  157. Fat person in the trunk somewhere?
  158. tail light panel
  159. Decklid measurement
  160. Reen Machine now on eBay
  161. Big block and cheap
  162. new 3 row copper rad going in :)
  163. Got this car for free. Going to need a ton of work.
  164. Which coil to buy?
  165. 17x9.5 front edelbrock 454 on a '69-70?
  166. IFS Mustang 2 for '55 Chevy
  167. Power Steering Conv?
  168. question for those thta have used POR-15
  169. Custom a/c hose
  170. A Real Mustang II Suspension on a 65
  171. How do you adjust the accelerator pump on a holley truck avenger or 4160??
  172. EFI or no?
  173. Fuel Economy Help
  174. water
  175. leaf springs
  176. Oil pushing, any road racers on here?
  177. boost or stroked?
  178. 1973 Mustang help, no start
  179. HELp ME out with this one?
  180. speaker box dimensions
  181. Water Pump Selection
  182. Rear Sway Bar Options?
  183. What starter?
  184. kameleon color question
  185. Quick EFI firing order question?
  186. sad day in aldie...
  187. Cylinder Head issue
  188. How to identify tranny?
  189. Choke stove pipes are shot...
  190. distributer stuck
  191. Need info on shelby a-arm drop
  192. Ouch! Coilovers w/o new wheels=pain
  193. what is the right way to Adjust TV cable on AOD
  194. Building up 289?
  195. Door springs.
  196. looking for info on the net on holley truck avenger tuning etc.
  197. 77 f250 bogging under load HELP
  198. Noob....
  199. Lakewood bell: what size flywheel?
  200. Power steering thread ???
  201. Cut-out exhaust kit?
  202. Feel kinda dumb; C-4 modulator help?
  203. Electrical problem
  204. How big of a cam can i go with stock pistons???
  205. Rally Pac installation w/ Duraspark
  206. 72 mach for a parts car worth it?
  207. Several questions about cleaning...
  208. FR Tilt column install Q -
  209. Which gauge panels to go with.
  210. Torque Strap ideas?
  211. Im always out of gas
  212. Oil Pan???/302?
  213. Rear Seat Delete Ideas?
  214. Something Popped!!
  215. Engine/Trans Combo?
  216. Hydro-boost
  217. Are 67 gas caps vented?
  218. Original Fan Shrouds for 1966 V8 Plastic or Metal ?
  219. Cobra Valve Covers
  220. post rebuild carb problems!!!!!!!!!!!!!
  221. Ignition problems
  222. What size drum and shoes for 66 coupe V8???
  223. 66 steering wheel removal
  224. roller 302 and cam selection
  225. Need info about the quarter window frame and mechanism
  226. Vibration above 45mph after T-5 Swap
  227. currie rear housing
  228. Brake Drum Help
  229. Pcv Valve Removal
  230. New best! Analyze times.
  231. Should I use this block?
  232. Tcp Motor Mounts?
  233. rack and pinion idea
  234. Changing heads, couple questions
  235. T-5 Trans crossmember
  236. 429-460 head question
  237. Motor Mount Help
  238. 351W question
  239. JME Autometer Temp Gauge Problems
  240. How much would you pay for this 69 mustang? need advise
  241. export brace, monte carlo bar for I6 cars
  242. replaced intake, wont keep water PLZ HELP!
  243. where to start?
  244. how to plug the small hole in thermo housing
  245. OT: Heater core bypass '96 F150
  246. Leaf spring ??'s Replace or not ??
  247. Need throttle and kickdown help
  248. Shocks, Springs and Carb. question..need advice
  249. I need help building my 351C
  250. So it has begun ( turbo build up )
