PDA
View Full Version : Classic Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. I see where washMO66 is selling his coupe on Ebay and in the classifieds...
  2. Which flywheel for T-5 Swap: I have my engine casting number
  3. Need final suggestions before I tear it down
  4. Shifter Cable INstallation
  5. COMPRESSION RATIO info..
  6. Transmission fluid lines
  7. buffing help
  8. fiberglass hoods
  9. what new radiator is the best?
  10. Ahhhh my brakes!
  11. Pics Of Aftermarket Front Bumpers 67-68
  12. Part# for AOD shift shaft gasket?
  13. parking brake poblem
  14. help with water temp gauge
  15. Fire Breather!!!!!!
  16. JMC Hydraulic clutch kit
  17. the voltemeter guauge is the most useless guage ever
  18. Headers for a 66 with a 4 speed?
  19. Trade Parts Here!!!
  20. 8" rear questions
  21. BUYING an old engine HELP!!!!!
  22. Opinions needed on '57 Ford 9"....
  23. One more thing....then my 67 will drive.
  24. Firewall question
  25. 4 lug disc brakes?
  26. Phoenix AZ Guys - Parts Yards???
  27. reproduction fenders
  28. What is a safe redline? 289
  29. where can I find a guage pod for a 67?
  30. Factory 289 head/cam specs
  31. AC parts
  32. SoCal Track Events at Willow Springs
  33. Need help with purchaseing a new 3rd member
  34. 65 coupe driveshaft length?
  35. Car Slightly Jerky when Cruising
  36. An experence with Sanyo MAR-B1021
  37. 66 Fastback Restoration
  38. 68 power disk brake question??
  39. 68 rear leaf springs
  40. Which SBF cylinder heads?
  41. Nuerosis?
  42. hard brake lines...
  43. 302 Suddenly Dies!
  44. 66 mustang 2+2 w/FRPP crate
  45. melted Alt-to-engine ground. Why?
  46. Rack & Pinion and Coil Over Setup
  47. steering and suspension questions - 68 fastback
  48. Cobra IRS?
  49. 65-6 vs 67 front suspension
  50. Found a 70 Mustang convertable
  51. Lugnut thread size for 67
  52. that fix a flat stuff is amazing.
  53. Radiator donor car fo a 1970?
  54. bolt on x or h pipes for '67 smallblock?
  55. Crazy Clutch
  56. Engine start-up after long 6 month sleep?
  57. Engine Paint
  58. Small Block 302 ???
  59. Still Not Runnig Right
  60. My Mustang art !!
  61. How do I replace third member???
  62. 1969-1970 Mustangs lets see your T5's!!
  63. "New" gages with "old" style?
  64. Need New horns
  65. Carb. / Dist. vaccuum line question. 69, 302
  66. bullitts on 68, what backspacing ?
  67. General SBF engine stages?
  68. how do u replace turn signal cam?
  69. Ordered my G-force tranny
  70. Wimbledon white/black Titus look-alike?
  71. Power adder(s) on a relatively stock engine
  72. Ford Engineer Tells How the 428CJ Came About
  73. 69 Mach I engine compartment progress (DUW)
  74. 351w history
  75. Hi guys
  76. Build date
  77. who makes long tubes to go around an AOD in a classic?
  78. How do I take this off?
  79. Too Wide Rear End - what does it mean?
  80. cowl vent & frame rail replacement - 66 Mustang coupe
  81. '66 Constant Voltage Regulator
  82. 66 water pump questions
  83. 351C Distriubutor question
  84. Went for cruise, took pics of car. Pick which one you like best
  85. HEI cap question
  86. TCP and Granada spindles. Dare I ???
  87. c4 kickdown help
  88. Lifters / Valvetrain - not just Hyd VS Solid
  89. How MUch PoWer?????
  90. 302 Question??????
  91. It's ALIIIIIVE! (Again)
  92. Body dimension help
  93. GOT Brakes !!!!!!!!!!
  94. Starter blew...I need new lol
  95. Rack and Pinion Question
  96. Electric Fuel Pump problem: help please
  97. Flywheel Removal
  98. Intake Removal
  99. Where can I get one of these?
  100. Radio/Antenna wires?
  101. Auto Resto
  102. GT 40 intake under stock 69 hood
  103. For those having trouble keeping it cool....
  104. Trunk project conclusion (POR15 / Peel Away7)
  105. POST PICS of your steering wheel
  106. Tips on breaking in engine
  107. battery drain
  108. Rear Seal on a 4 Speed Top Loader
  109. Help Control Gas Prices.. Should Read
  110. 65 Bumper restoration?!?!?
  111. One Way Power Steering
  112. 429 Help to 1967 mustang!!!!!!!!!
  113. rebuilding a master cylinder
  114. 347 Coupe is going...........
  115. Burnout Video
  116. Edelbrock Carb. elect. choke
  117. what is the correct distance between shock towers
  118. Are all ARP rod bolts created equally?
  119. When to change oil if you dont drive much?
  120. Maier Racing
  121. How to remove bumper in door when doing weatherstrip?
  122. POST PICS of mustangs with 18" wheels
  123. Mustang Depot Shelby E2 scoops for 65-66?
  124. Best Header Port Gasket?
  125. Cleaning out my shop...........
  126. shorter shifter handle ?
  127. Dakota Digital tach error?
  128. Electric or Manual Choke?
  129. Windshield molding removal
  130. got my new 05!
  131. New Console Piece...Opinions wanted!!!
  132. Crate Engine???
  133. Bolt Kits
  134. Mounting bolts for 65 grille/corral
  135. How much should I offer this guy for Vert?
  136. radio help!!!!
  137. Passenger Side back(side) window
  138. Taking off underside coating
  139. 8.8 in a '66 - is it possible w/out being expensive?
  140. Original tachometer troubles
  141. New Transmission
  142. q about new heads...
  143. Pressure in Brakes
  144. 68 Fastback rear seat fold down question??
  145. How much for my fastback?
  146. Do you guys think i'll have piston to valve clearance with this setup (351w)
  147. Would this shifter handle bolt onto a T-5
  148. gasket kit
  149. Best $$ on Edelbrock wheels (Eleanor style)
  150. Rear end lube?
  151. Changing out guages
  152. I need a link to the gear calculator
  153. 351W Plug Wire Diagram Needed
  154. Video Hosting?
  155. So, whos got the pictures of the Knotts show?
  156. Original radio ????
  157. A Watts Link like mine on the market for $600 - Nice stuff
  158. pushrod length please help
  159. high horsepower engine value?
  160. original 289 specs needed for desktop dyno
  161. Rear springs
  162. Need Help with Cam and Cylinder Heads Choice
  163. Anybody have a Vacume line diagram?
  164. 65 interior changes
  165. Anybody have a Vacume line diagram?
  166. Master Cylinder for 4-Wheels Discs
  167. Compression Ratio?
  168. Distributor Wiring Diagram 351W Needed
  169. Finalized my "tide me over until 351w" 289
  170. Randalls Rack contact phone number?????
  171. Another T5 Swap
  172. Need help adjusting Caltracs
  173. Mustang Depot owner......
  174. how to check piston to valve clearance?
  175. Snapped a picture this weekend (large photo alert!)
  176. What would cause my power steering fluid to boil?
  177. do i need a new cam and lifters?
  178. Bad main bearing symptoms
  179. Why Do My Plug Wires Keep Popping Off?
  180. Parking Brake Handle
  181. New to the Board
  182. Flexplate ?
  183. how much is a rebuilt c4 tranny worth??
  184. Trouble with new starter relay
  185. Narrowed wheels
  186. The Reenmachine DOHC '67 Shelby Clone Convertible Progress
  187. Assembling heads soon - question
  188. Front end is tweaked 1/4"
  189. Which EFI kit?
  190. Let the projects begin on my 67 Fastback
  191. 69 Big block exhaust leak
  192. testing fuel pressure?
  193. EFI in Classic Mustang
  194. Wiring Harness
  195. Anyone ever changed to late style dizzy cap?
  196. blower motor..how many wires?
  197. Fan shroud question
  198. Best Carb to buy?
  199. Anybody in Kentucky or close that rebuilds 3rd members?
  200. Removing Rear Seat out of a 66 Fastback?
  201. '67 Pro-Touring Terlingua Tribute (DUW)
  202. Npd Door Shells
  203. hood or air scoop?
  204. Timing Assistance Needed
  205. AOD Swap help
  206. Need some answers from the EFI guys
  207. Major Problem!!!!
  208. convertible top fluid
  209. Rocker Arms
  210. ?s On 67 Radiator Support
  211. Grant steering wheel
  212. Ruh Roh! Cracking shock towers...
  213. I'll try again!!! 5.4 (mod, no 331 pushrod strokers)
  214. Nice engine bay - restomod
  215. 1967 Mustang Exhaust
  216. Holy Crap!
  217. Head Gasket Replacement
  218. Engine Coolant Drain Valve
  219. Removing Freeze Plugs
  220. Engine Block Casting Mark
  221. I did something stupid -- snapped off the dipstick tube
  222. suspension and brake problems.
  223. where to buy limited slip?
  224. braided steel flex hose and AN fittings
  225. Knotts Trip This Weekend
  226. Any SoCal welders wanna help me out
  227. Great website for 65-68 Wiring/vacuum diagrams.
  228. Anyone Running a Weiand 174 on there 289??
  229. For those of you with 6 cylinders
  230. edelbrock carb idle problems
  231. Removing Steering box
  232. Quick opinion on clutch pedals, Please.
  233. Door Reassembly. On-car or off-car??
  234. Subframe Connectors for Convertible w/center??
  235. Will a 750DP drown my engine?
  236. Stripped bolt on fuel tank!
  237. Drag Setups/TIPS/Rims and tires
  238. help identify these valve covers
  239. Rear Steer MII!?
  240. Mustang aftermarket seat install
  241. Anyone have a Bearing Grease preference?
  242. POR15 trunk project delayed! Need some help!
  243. brake fluid turns to mud why..?
  244. Where to buy 8in ring and pinon gears
  245. Who is going to Englishtown this weekend??
  246. Disc Brakes from a 71 to a 66
  247. Strut Conversion
  248. 20th Annual Fabulous Fords Forever!!!
  249. '73 might be down for the count
  250. door tag
