PDA
View Full Version : Classic Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 [64] 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Voltage regulator?
  2. Holley 4160 too rich
  3. New guy here... Few ???? about my '65 GT FB
  4. advice on front end woes
  5. '67 Fastback on Ebay (not mine)
  6. Absolutely Frustrated...
  7. side exhaust/eleanor
  8. 351 CLEVELAND MODS QUESTION?
  9. new going old (backspacing ?)
  10. What cable size do I need?
  11. 351 strokeability questions
  12. For whoever asked - Scattershield Hyd. Line Bulkhead
  13. Carb spacer install
  14. Heidt's or Rod and Custom for Mustang II suspension?
  15. calypso coral paint
  16. Part Number
  17. is 600cfm really enough?
  18. looking for some good vids of classic stangs.
  19. suspension and engine bay paint
  20. Fixed brakes, and now gas guage is messed up....
  21. I am trying to see the value here.........
  22. Where to buy engines?
  23. which shifter?
  24. engine bay color?
  25. '65 Pony Int: Roll Cage and Seats
  26. Just went through all of Opentrackers posts I could find.
  27. Shelby Drop Alignment Specs
  28. Autometer Electric Speedometer ?
  29. Is this car really worth this much?
  30. Is This A Good Deal Part II (Project Mach)
  31. I need to verify title
  32. Where can I get a lower lip for the front?
  33. Best Place to get FLOOR PANS???
  34. Ignition Questions
  35. Whats the diffrence between drum and disc v8 spindles?
  36. Q's about the Wilwooods
  37. Mufflers?
  38. HELP!!! what tailshaft do i have?
  39. 66 ignition switch question
  40. Opentracker, do you have a website with all your mods?
  41. Cougar Seats Question
  42. Speedometer gear
  43. AOD and TV cable
  44. WOW, you have to see this 66 on Ebay!!!
  45. Need help from suspension gurus
  46. Tach Type and Location
  47. I.R.S. in '67 Complete!
  48. NOS?
  49. 66 Single to Dual MC Plumbing Question
  50. How should I go about fitting my front valance
  51. Alignment specs please
  52. 393 Stroker Engine?
  53. Need help with shop name
  54. Hey check my Stang 66
  55. Installing new Window Regulator and scissor assembly
  56. Wiring question re: Instrument panel
  57. Finally killed my 1st T5!
  58. Header Question
  59. Tach Wiring questions?
  60. 69 302 to aod
  61. Street style apron w/spoiler
  62. Front apron w/spoiler
  63. Did some quick mods to my car
  64. Holley electric choke
  65. Thoughts on Tremec's
  66. How do u adjust the timing on a 67 mustang
  67. Sanity check
  68. Tie rod or BeatTracker
  69. E-brake
  70. Need Help Finding a Freinds' Car
  71. Adding more HP?
  72. 73 Mustang frame diagram
  73. Muscle Car Drag Race...trophies for all
  74. eBay '69 I'm bidding on
  75. hydrolic cluch in a 69 mustang
  76. a couple of questions about efi 5.0 swap.
  77. Opinions on this parts car.
  78. Does this sound like a good deal?
  79. T5 fluid
  80. steering wheel
  81. Finally - Engine is at the machine shop.
  82. timing chain wear ?
  83. Strut Rod reinforcement
  84. Value question
  85. Best differential for the street?
  86. Alternator Bracket with AFR185's ?
  87. exhaust suggestions please
  88. Need a 22 gallon EFI fuel tank w/surge
  89. Gas tank barrier?
  90. fairlane parts for mustangs?
  91. Clutch pedal for t5z
  92. 5.0 into a 68 mustang
  93. Interior color?
  94. Maverick Power Steering in 66??
  95. Wheel questions: Will 15x8's fit in the front?
  96. Finished my front and rear suspension. Looks and handles great!!
  97. Help me narrowdown the non working front brake problem. please :)
  98. Stock Compression Ratio?
  99. My Baers suck when wet!!>>>
  100. Aftermarket repro shaker
  101. kid in need of advice
  102. Urgent Help!!!
  103. body work
  104. test driving an 05gt....
  105. Anyone have pics of 70 Mustang Starter Relay?
  106. Headers on aluminum heads
  107. Brake pedal swap Q
  108. which Long Tubes...
  109. 69/70 Aftermarket Bumper??
  110. shelby wheel flares?
  111. Underhood heat problems
  112. Would a 351c be a direct swap?
  113. How do I get this front end?
  114. Classic Owners who also have Fox 'Stangs - Ideas on brake updates
  115. 289 Will I notice the difference? Performer RPM
  116. 9" Rear Axle going in a '65 Coupe
  117. Pain all the way
  118. Pain all the way
  119. Motor Delima
  120. Better Header?
  121. 64 1/2-66, V8, 8", rear axles
  122. How would you repaint my car??????
  123. 351 W in 67
  124. Mustang Locating Services
  125. "street" harness in '69 Mach 1?
  126. Buy unbent or complete bent line?
  127. alum cyl heads, spark plugs, and anti-seizing gel
  128. How can i figure out what my 9inch has in it?
  129. Identify this axle please
  130. T-5 short shifter?
  131. Different Rear Suspentions...
  132. rear end assemblies
  133. Boss 302 in a 66
  134. 302 Idling Problem
  135. 2004 mitsubishi eclipse spyder gts vs. 68 mustang coupe
  136. putting 289 heads on a 69 302 block.
  137. 70 Mustang,351c,auto,header question
  138. horn question
  139. gearing for the t5
  140. U-Bolt size?
  141. ? for Granada brake folks...
  142. Engine Stand Question
  143. Seal Material- Glass Channels
  144. aftermarket 69 GT500 Convertible body panel compatibility questions
  145. Rear Disc Brakes for a 69 Mustang
  146. Danger: Single master cylinder on board!!!
  147. outta here....victim of marketing
  148. Gosh darn. It's always something
  149. Cold weather and aluminum rad??
  150. 72 Mustang/Cougar Disc Brake spindles
  151. Granada Spindles...?
  152. Nuts and Bolts question.
  153. Needle bearing spring pivots
  154. BOSS 302 VIN ?
  155. what size torque conv. on stock 66 c4
  156. DOH! I think I might have #@!*...
  157. Classic/Collector Insurance
  158. Keeping the Vents in???
  159. interior re-upholstery kits.....
  160. Block the goofy guy trying to sell stuff!
  161. Weatherstrip glue
  162. What IS that thing?
  163. gotta replace tie rods. Who makes the best ones?
  164. Pulling parts from my 88...what else needed
  165. And another suspension question....
  166. 66 Mustang Convertible Help
  167. Amp location
  168. Ring wash from running too rich????
  169. Which headers to buy?
  170. Floor or Rear Frame First?
  171. what rear end
  172. valve adjustment question...
  173. fuses
  174. replacement seats
  175. Gear Ratio ??
  176. Anybody use 68-70 discs or at least calipers on their 65s
  177. Considering purchase - advice needed
  178. 8.8 inch rearend in a 65
  179. Bonding Plastic?
  180. Rear end tips
  181. March pulley question
  182. firing but won't start
  183. Issues with transmission when cold.
  184. question...
  185. Lets talk mufflers....
  186. biggest tire ?
  187. HiPo Balancer?
  188. tourqe converter woes
  189. Turn a 65 Coupe into a Fastback?
  190. distributor gear Q
  191. Unique Coil over conversion
  192. looking for a "low profile" 6 pt. cage
  193. M-II front suspension
  194. Anyone used this electric fan?
  195. 65 wiring harness
  196. FORD RACING LONGBLOCKS
  197. T-5 yolk questions.
  198. Precision Oil Pumps
  199. Cleveland gurus in here!------->
  200. Rear end problem (uneven)
  201. Repro Window Moldings
  202. NEED HELP ASAP convertible header
  203. roller perches almost done....pretty easy!
  204. Rebuilding my 289
  205. 28oz. vs. 50oz. Crankshaft and Balancing Questions?
  206. Understeer and oversteer
  207. scary steering
  208. Tough door locks
  209. Opinions please...
  210. Mig welding on efi vehicle
  211. Got my new wheels for my 'stang...
  212. Need opinion on 347 setup
  213. Manual Steering a Power Box
  214. 9 inch axle questions
  215. Mustang Plus and the cowl hood
  216. Nomenclature Question
  217. Hydraulic clutch?????
  218. Paint stripping
  219. Best Mustang Magazine?
  220. Need advice bad!
  221. new tranny, how to go about it???
  222. large distributor question
  223. Another auto to 5 speed conversion question
  224. Buying a crate 302 and AOD transmission, need new exhaust, where can I find online...
  225. A new smog standard in California for classics?
  226. silver metallic paint???
  227. Can you see www.windsor-fox.com
  228. Ackerman Theory (this one's a doosie)
  229. San Diego Help? Pleeeease!
  230. How do you get the window regulator out?
  231. bigger than stock rotors? 13" cobra?
  232. Digital gauge instrument panel?
  233. FREE ROTISSERIE PLANS
  234. Help with a hp estimate
  235. Vaccuum leak....need help!
  236. Just Dashes
  237. Where to get "correct" comfort weave for 69 Mach I?
  238. rocker arms
  239. longer from suspension arms to fit '79+ wheels
  240. red paint
  241. Emblem pins
  242. MSD6A and Pertronix
  243. Looking for a chromer....
  244. 70 stang vacuum (pics)
  245. 5.0 Swap q's about dipstick
  246. Drag Pack Boss 302 Mustangs
  247. Missing Data Plate
  248. Need a beater car..
  249. Want your glovebox autographed by Caroll Shelby?
  250. More fuel line help...questions
