View Full Version : Classic Tech
- 1968 289s
- Posi Kits
- Speedo stopped working
- Red Line
- 65 Fastback Project
- blower? EFI? 5.0 build up bananzaa
- Advice from Global West Owners...
- does this sound like a scam?
- Chrome TTIIs? Do they exist?
- A needed increase in hp, any suggestions...
- 1 of 50 consoles made????
- pro-m negative wedge
- 67 shelby clone fiberglass
- 65 mustang crager ss
- stupid BG tech support
- Updates on Rack & Pinion kits???
- What is my timeslip trying to tell me?!
- painting Shelby Stripes
- part?
- where can I find....
- Whats the servo on my C4 for?
- differential removal need help
- Slow Mustang
- Comp cam 280H timing ?
- Fuel tank sending unit?
- Little Screw Up Need Help
- 1970 mustang axle
- Another Stroker Question
- Scoop or Cowl Hood?
- Another HP/ 1320 times thread
- whats this head casting?
- 67 couger 9 inch will it work in my 65 stang?
- Anyone fitted a Crane XR-i Ignition module
- Timing Covers & Water Pumps
- Killed a 70 something model camaro tonight.
- Pulled engine/trans today
- No Fuel
- So now what?!
- Intake identification help
- Need help w/ identifying radiator hoses
- What type of car cover for my unfinished 67?
- Fuel return question for fuel injected 66
- 1/4 mile
- REAR AXLE
- differrent granada swap question
- Help with mini starter please
- Water Pump Question ???
- Need Administration help-I think
- will this work
- American Hot Rod building a 65 Mustang
- Do I need a bigger cam?
- Walked out to the stang and noticed...
- What's the deal with 16 x 8" wheels?
- Easy way to remove a clutch pedal
- Vinyl66 vs. the Porsche 911 Carrera
- why doesnt anyone
- Welding question-please help
- should there be any wiggle between the idler arm and the bracket?
- C4 Transmission linkage too short
- what does extrude hone mean?
- engine dies after washing my 67
- Compression Test Results?
- 03 GT seats in a 65 coupe
- san diego engine rebuilder
- T5 conversion advice, please
- Header ?'s
- 67 Dash install
- 1968 Ford Fairlane 500 fastback (pics)
- Fuel Pump Fitting
- If you had $10,000 to spend on your 66 what would you do?
- poll..what kind of water pump for a '69 408w?
- Upper RPM Miss?
- Oil Dipstick ????
- HAPPY DAYS at the track !!
- rearend woes
- Seam sealer
- Help, broken bolt stuck in engine block
- So its been a while.
- My 70 Dash...pics
- Ford heads...
- Pics of my car if you're interested...
- carb question
- Proportioning valve
- 289 HiPo or 302?
- Exhaust to auto-choke connection...
- Any way to eliminate the tranny from automaticly shifting when you put it in 1-2?
- Need help with finding a price for my mustang
- Power Steering Bracket
- GOOD NEWS! Well, how about not as bad news?
- feeler:65 coupe
- Head gaskets installed wrong?
- How hard/expensive is it to cut down a 9 inch?
- Supercharger questions.
- Bullitt vendors with custom backspacing?
- HELP! Oil pan vs. some big brace bar
- What about 17x9s?
- Timing Cover - HELP!!!
- Is it a immediate problem?
- Back to daily driving the classic, any tips?
- Ghost Flames?
- EFI Swap Problemon my 68 Stang.
- Cluth forks, and scattershields...
- Need help on choosing new clutch!
- 1966 wiring harness
- Question on Splash Shields
- Maryland Rear End Installation
- 1971,1973 clutch linkage differences
- Flexplate issues, i need help!
- Cam Change, what is needed?
- How much does it weigh?
- 65 loom diagram
- GT Fog Light grill bars....or something like that
- Traction Bars...help me find the perfect ones...
- T5 Clutch Linkage
- T-5 Clutch Fork
- Flywheel and clutch question
- Parts for a 67 with s6?
- Got a welder! What type of steel?
- Help!
- Pulley Setup!!!
- MACH 1 Rear
- MCA Judging Sheet for Conc. Trailered?
- help a newbie choose between 4.6, 5.0, & 351W?
- console mounted E-brake
- Anybody like their poly bushing?
- Fox Mustang 3 Spoke Wheels on a '65??
- speedogear questions with T-5
- Help opinions needed....what to do first?
- TMD "Pro Aluminum SBF heads"
- Source for slip yoke for T5
- edelbrock heads
- Stock Head Specs...
- Anyone interested in a 1972 Mach 1 for sale or trade?
- Rear end traction control
- Online parts suppliers?
- Mach 1 1969-73 Parts
- Engine upgrades
- Common need....
- Meet in N.East Jersey
- Need some advice relative to new wheels, discs, and possibly rearend
- explorer rear question
- Are the shackle sizes the same for 6 and 8 cyl 65s
- Mustangs Plus Shipping
- Can we do an "All Mustangs Registry"?
- Exterior Changes..time for a change
- Opinions on Stud Girdles
- Want everything to be tight....
- Polyurethane bushings
- Info on 427, 428, and 429
- Ignition wire
- Question about checking MC pushrod length
- Any classic mustang shops or anything around fort collins Colorado?
- help replacing heater core in 85 f150
- Leaking Coolant from Overflow, but not Overheating
- 1967 to 1970 Shelby Mustang CLONES
- Need advice on new delima
- Anyone looking for a damaged GT???
- anybody still have their old 65 or older v8 heads
- Any tips / tricks installing clutch spring with pedals in car
- Edelbrock Carb issues..."Dieseling"
- NEW news on the paintjob
- New Electric fan :) low voltage :(
- Fatmanfab ????
- timing question
- Battery Experts! Inside please.
- welding guidelines
- Roller Motor guys, please read.
- EVERYBODY please post your pics...
- 1966 Parking Brake Help
- Eagle STs?
- Race suspension set up..
- Autocrossed again...
- Weird Problems with Power Brake Conversion. Need Help.
- Hood scoop.
- which heads....
- Headers,
- Thought I had a new car tonight...
- best way to lower car
- Went for a ride in a 2005 and won a neat award
- 1966 Clutch
- 1969/70 mustang owners. Host your pics for free.
- 351 heads on a 289?
- Difference between 1969/70 Front end?
- Who has the best prices on SSBS brake kits?
- Firewall smoothing
- Can someone please explain
- 1973 mach 1.
- Motor Mounts on 65 289
- chrome bolt kit for 289 water pump install?
- Car has a mind of it's own...HELP!!!
- Hawks Racing Rods for 289
- Fuel Pump 1969 351..
- Chris Alston's Chassisworks 8pt roll cage
- Greets from a newbie.
- car still running even when keys are out please help!
- Rear disc
- 289 mods
- question about my C4 trans
- MSD Pro Billet Street Distributor;)
- Thermostat Rating
- '71 302 Firing Order, Oil Type, Etc.
- Drop spindles
- dyno-tune ?'s
- Scoop!
- just starting out question on shelby drop
- Carb to EFI swap; how much gain in numbers could I expect?
- Firing order...
- Need a new bellhousing.Which one do I need?
- 1969 fastback question.
- 66 Glove Box Locks
- Dropping Fuel Pressure Ghost Expelled!!!!
- this WAS a 67
- need some help polishing
- Disaster and rebirth
- installing new ignition
- vacuum secondary carb ?
- 67 coupe stalling
- Stroker question
- Alright I need some HP limit questions answered
- Fan question
- WHat's the best donor late model for a 65
- switching to an electric fuel pump
- Might be trading my '65 A-code coupe for a '67 coupe.
- My Roller Bearing Pedal Assembly
- upgrade granada calipers?
- vin plate location on door
- Changing your differential fluid?
- NPD Power Window Kit
- Timing problem
- AOD tranny into 68 Mustang
- Does anyone have any pics of a 2 tone mustang?
- New Stroker Motor for 1967 Fastback
- Need some car leagal advice.Got a destroyed!
- Door skin ?'s Oboebrian, your the man I'm lookin for.
- my rear end feels loose :)~ (help)
- 68 Mustang Alternator not Charging
- Guys---the mustang is wrecked........
- Still need pics of parking break cables
- Radio Installation Pics wanted
- Weight of 69 coupe?
- 1996 351 EFI Roller motor, is it worth it?
- Lenght of each brake line???
- Leaky Rear Main Seal - 'Sneaky Pete'... Advice please!
- March Alternator Bracket
- engine ID (by casting #)
- Maintenance
- 66 MT fit on mid-70's 302 was AT
- 1966 Mustang Power Steering
- 1972 Bumper
- Are these heads worth it?
