PDA
View Full Version : Classic Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 [67] 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90
  1. Sorry Fellas, But since the search function is gone, Question on 6 to V8 conversion
  2. Who made the kick panels with speaker inserts?
  3. Paint thread got me thinking
  4. Shaved Door Handles (Need tips!!)
  5. Do I need a different flexplate?
  6. What type of oil pan to use on late-model 5.0?
  7. How slow will a rear end ratio make your car?
  8. donor cars for 69 powersteering?
  9. 72 backspacing
  10. Heater Hoses
  11. Any shot at a C6 trans fitting in a 65?
  12. Lets talk welders...
  13. Please identify these rims...
  14. headers / muffler question...
  15. Paintjob time baby...
  16. looking for a classic mustang repair shop near by
  17. steering: I6 to v8 problem
  18. Quick Question about TDC
  19. Drip Rail Molding Install
  20. TTII or Magnum 500 Prices?
  21. Might start a war here... but T56 vs Richmond 6 speed
  22. oil pressure question
  23. Continuously variable transmissions... how do they work
  24. 351 Compression Ratio Piston Choices
  25. Stroker Info / Testimonials
  26. Engine Knocks At Idle
  27. Disc Brake Swap Question for '66
  28. Rear Leaf Springs on a 70 Mustang?
  29. 64 Fastback
  30. Soo confused with the numbers
  31. newbie needs help
  32. Outer wheelhouse replacement
  33. WTF? No oil pressure and the engine still runs?
  34. SB engine build
  35. Power Steering.
  36. 1970 coupe what do you guys think
  37. Quick Shelby drop question
  38. Questions on a 65...
  39. Fuel gauge help!
  40. sand blasting
  41. Ok, just in a mood to post pics, take a look :)
  42. Windshield wipers dont work...HELP
  43. 1967-1968 Coupe INTERIOR QUARTER PANELS
  44. The easiest things............
  45. Those with solvetnt tanks.....
  46. Panels and Doors for 66 Vert...
  47. I Am Looking To Buy a 1965-69 Fastback
  48. blower motor fan wiring
  49. 65 fastback window track
  50. FLASH: Randalls Rack used with longtube headers!
  51. My Engine pic
  52. Help on Choosing new intake
  53. NEED HELP! Might have broken something! LONG POST
  54. Cleaning advice
  55. Blue Thunder Medium and High Riser FE heads. ..Available next week.
  56. 289 with 351w ???
  57. 65-66 seats in my 67?
  58. Priceless!
  59. C4 Tranny Help Please
  60. Is this a problem?
  61. New rebuilt C4 hits neutral before hiting 3rd gear? Help please!!
  62. Headman Elite Headers 351W fitment problems
  63. 302 engine into 66 mustang fastback problems
  64. power steering pump??
  65. Is everyone behaving themselves?
  66. Need some EFI help ASAP please.
  67. The start of a great build.
  68. Piston notching tool
  69. speaker mounting
  70. Help required from England!
  71. R&P kit is here !!!
  72. Dumb Question: Heat and Oil Pressure
  73. need help to rich or to lean.
  74. 67 3 spd manual question
  75. Emachineshop
  76. Stinky AC
  77. Where can I find a radiator like this
  78. My engine pic
  79. Brakes problems
  80. 69 Mustang question
  81. What is wrong with this engine? Accelerates like I am pulling a big trailer
  82. 68 rear ends?
  83. baking soda media for sand blasting - where to get it?
  84. new engine, what can I reuse from old engine
  85. Where can I get an OEM type radiator top right bottom left?
  86. This is great...I found it yesterday
  87. Grinding noise
  88. Mac Equal Length in 68 Mustang
  89. Tire question
  90. 5.0 Engine from 95 Stang in a 65 Stang
  91. Another Wheel fitment question
  92. 1st Time Restoring Need Help!!
  93. c4 tranny advice.
  94. Strut suspension
  95. sand blasting
  96. Well my plates are registered
  97. Early narrow bolt pattern tranny to 302?
  98. 69 351 Stalling, need help
  99. opinions on un-shrouded electric fans please
  100. She's built. Help with soggy bottom end...
  101. 351w problems
  102. wont fire up
  103. I need some real help here...got mold in my interior....
  104. dolfan, any news....
  105. cable accelerator for a 65??
  106. How to figure stall?
  107. Anybody put bigger line into the gas tank??
  108. Something went wrong.... BOOM
  109. Stall converter?
  110. Need advice...carb related...
  111. Adding Lead to Gas
  112. Anyone with 15 inch rims
  113. Anyone used these rims?
  114. four bent rims & a warranty
  115. discouraged
  116. the racecoupe to be in Mustang and Fords Magazine
  117. Help Make Sense of my Dyno numbers (fuel problems)
  118. How much for a clutch/brake pedal assembly?
  119. 65-66 6 gauge bezel alternative
  120. Anyone put a hydraulic clutch in? Looking for T-5 Slave ideas
  121. C4 to T5 swap general questions- 65/66 Mustang
  122. Anyone have experience with Oxysolv?
  123. Spoilers for a '70
  124. Driver's Floor Support In, pics
  125. Fiberglass Hood
  126. Welp, the shaker is out.......
  127. Wiper removal
  128. Vent Windows
  129. Need help on what is this called and where can I buy one
  130. I NEED MORE TECHNICAL ARTICLES
  131. drip rail molding help needed
  132. anyone installed set of Mac true fit headers on the stang?
  133. Vibration is driving me nuts!!!!!!!!!!Any help please
  134. Griffin radiator symbol...
  135. New side windows...
  136. My trunk was broken into...
  137. need help finding-small heim joint for throttle....
  138. Need input shaft for 1975 SR4 transmission
  139. Lowering Blocks
  140. Back a 428cj with a t56???
  141. Tranny Sought
  142. tires for my 68 mustang
  143. Disc Brake Spindles
  144. Installed supercharger,Now need front suspension
  145. Installed supercharger,Now need front suspension
  146. Got my new front valance
  147. open headers
  148. Bellhousing bolts
  149. how can you have reverse flow with just 3 pulleys.
  150. found a place WILLING to align my car, but shims on a 69&TCP????
  151. 1 wire alternator wiring
  152. Power Steering Problem...
  153. 1975 Four speed transmission help
  154. any classic Stangs at Woodward Dream Cruise ?
  155. Info on a 67
  156. 65/66/TCP Motor Mounts Question
  157. turn signal/ gas guage
  158. Runnin' Hot!!!!
  159. Retarded Cam? - How to check with engine completed / installed???
  160. is this cam too big?
  161. Powder on cylinder wall?
  162. 5. efi swap question
  163. If your gonna buy a welder buy this one (pic)
  164. t-sigs
  165. Motor Mounts
  166. GM T-5 TO MUSTANG
  167. Nickel Plated Headers?
  168. You won't believe what I saw yesterday!!
  169. Finally got some pics of my new project
  170. Picture of the Haneline Instrument panel set
  171. Shop Rate For 1/4 Panel Replacement?
  172. New Trunk weatherstrip...How does it go?
  173. Husky HVLP gun
  174. Stupid ? of the day from Mr. noob
  175. Brakes, speakers and dead batteries
  176. Ronstang saves day....Roller 5.OOOOOHHHH conversion
  177. Distributor - Hard to remove/HARDER to install?!
  178. Suspension question
  179. 65 Fastback Progress
  180. OFF TOPIC:Need help for Buick
  181. OH OH look at what I built, everything a redneck requires-welding,cutting,grinding...
  182. Drop in revs?
  183. Anyone tried putting late-model 8.8" rear end in a 65-66?
  184. AFR 205's and Dual Plane Intake on a 393 Stroker?
  185. Rear Gear Recommendations
  186. Head gasket placement q
  187. Rebuilding 289... please advise on manifold/carb/cam
  188. What Carb Spacer to go with ?
  189. RIP engine? need some good tech.
  190. rebuilding a holley 4160 to 4150
  191. oil pressure problems
  192. explorer rear?
  193. checking Painless Wire Projects
  194. OT/ sway bars
  195. header info. for 69 mach
  196. Stereo in the glove box pics?
  197. Rear end ID tag?
  198. Cheap tranny..........
  199. Headlight relay mod without splicing
  200. My 67 coupe
  201. Q for anyone using Randall's Rack
  202. Wheels for a 69
  203. I'll build the header chart.......catagories?????
  204. timing a 289
  205. Heater hose fittings for 351C
  206. Ideas on unknown engine startup
  207. chasis question
  208. Header Testimonials....Header Chart??
  209. Sorta OT: Headed to the Muscle Car Ranch Swap Meet in Chickasha, OK Sat.
  210. braking issue
  211. 69 Falcon wagon
  212. H pipe v X pipe?
  213. car cranks but wont start, and thats not the problem
  214. need help suspension steering problem!!
  215. Will a mechanical fuel pump work?
  216. Thanks Dodge - Wheels are Great!!!
  217. Vac advance, ported or manifold?
  218. Anyone heard of a "Muldoon" oil pan?
  219. Exhaust Coating (pics inside)
  220. Who has a tip for me on interior parts needed?
  221. what is the dist. with the Hei setup on it for the FORD
  222. Disc Brake Kit...Any preferences out there?
  223. Assemble order...dashpad then windshield?
  224. Best PCV hose connection? Intake manifold or Carb?
  225. weiand intake
  226. steering wheel/column
  227. how hard to replace heater core?
  228. 351w help
  229. 351W head ?s
  230. Need some part hunting advice...
  231. Tilt column for a 65-66.
  232. Anybody useing the K&N Top cover?
  233. Estimate for some restoration
  234. Cleveland Intake?
  235. 1966 Coupe with T5 from 2001
  236. I'm thinking of deleting my power steering when I do my efi 5.0 swap...
  237. Yup, another one of those threads......
  238. Best Super sustension kit
  239. Car stalls when cold under hard braking
  240. Popping noise out of newly installed rearend
  241. Tires that will fit on both dropped and stock height suspension
  242. exhaust rant
  243. Float Adjustment for Edelbrock Carb
  244. Fuel Pumps for EFI conversion?
  245. 69 console, yes or no? let me know what you think
  246. Windsor vs. Cleveland
  247. Strut Suspension upgrades in early Mustangs
  248. Finished paint pics of the fastback!
  249. Cam, rear gear and torque converter relationship?
  250. Post pics of nice 71-73 Mustangs
