View Full Version : Classic Tech
- How much for a clutch/brake pedal assembly?
- 65-66 6 gauge bezel alternative
- Anyone put a hydraulic clutch in? Looking for T-5 Slave ideas
- C4 to T5 swap general questions- 65/66 Mustang
- Anyone have experience with Oxysolv?
- Spoilers for a '70
- Driver's Floor Support In, pics
- Fiberglass Hood
- Welp, the shaker is out.......
- Wiper removal
- Vent Windows
- Need help on what is this called and where can I buy one
- I NEED MORE TECHNICAL ARTICLES
- drip rail molding help needed
- anyone installed set of Mac true fit headers on the stang?
- Vibration is driving me nuts!!!!!!!!!!Any help please
- Griffin radiator symbol...
- New side windows...
- My trunk was broken into...
- need help finding-small heim joint for throttle....
- Need input shaft for 1975 SR4 transmission
- Lowering Blocks
- Back a 428cj with a t56???
- Tranny Sought
- tires for my 68 mustang
- Disc Brake Spindles
- Installed supercharger,Now need front suspension
- Got my new front valance
- open headers
- Bellhousing bolts
- how can you have reverse flow with just 3 pulleys.
- found a place WILLING to align my car, but shims on a 69&TCP????
- 1 wire alternator wiring
- Power Steering Problem...
- 1975 Four speed transmission help
- any classic Stangs at Woodward Dream Cruise ?
- Info on a 67
- 65/66/TCP Motor Mounts Question
- turn signal/ gas guage
- Runnin' Hot!!!!
- Retarded Cam? - How to check with engine completed / installed???
- is this cam too big?
- Powder on cylinder wall?
- 5. efi swap question
- If your gonna buy a welder buy this one (pic)
- t-sigs
- Motor Mounts
- GM T-5 TO MUSTANG
- Nickel Plated Headers?
- You won't believe what I saw yesterday!!
- Finally got some pics of my new project
- Picture of the Haneline Instrument panel set
- Shop Rate For 1/4 Panel Replacement?
- New Trunk weatherstrip...How does it go?
- Husky HVLP gun
- Stupid ? of the day from Mr. noob
- Brakes, speakers and dead batteries
- Ronstang saves day....Roller 5.OOOOOHHHH conversion
- Distributor - Hard to remove/HARDER to install?!
- Suspension question
- 65 Fastback Progress
- OFF TOPIC:Need help for Buick
- OH OH look at what I built, everything a redneck requires-welding,cutting,grinding...
- Drop in revs?
- Anyone tried putting late-model 8.8" rear end in a 65-66?
- AFR 205's and Dual Plane Intake on a 393 Stroker?
- Rear Gear Recommendations
- Head gasket placement q
- Rebuilding 289... please advise on manifold/carb/cam
- What Carb Spacer to go with ?
- RIP engine? need some good tech.
- rebuilding a holley 4160 to 4150
- oil pressure problems
- explorer rear?
- checking Painless Wire Projects
- OT/ sway bars
- header info. for 69 mach
- Stereo in the glove box pics?
- Rear end ID tag?
- Cheap tranny..........
- Headlight relay mod without splicing
- My 67 coupe
- Q for anyone using Randall's Rack
- Wheels for a 69
- I'll build the header chart.......catagories?????
- timing a 289
- Heater hose fittings for 351C
- Ideas on unknown engine startup
- chasis question
- Header Testimonials....Header Chart??
- Sorta OT: Headed to the Muscle Car Ranch Swap Meet in Chickasha, OK Sat.
- braking issue
- 69 Falcon wagon
- H pipe v X pipe?
- car cranks but wont start, and thats not the problem
- need help suspension steering problem!!
- Will a mechanical fuel pump work?
- Thanks Dodge - Wheels are Great!!!
- Vac advance, ported or manifold?
- Anyone heard of a "Muldoon" oil pan?
- Exhaust Coating (pics inside)
- Who has a tip for me on interior parts needed?
- what is the dist. with the Hei setup on it for the FORD
- Disc Brake Kit...Any preferences out there?
- Assemble order...dashpad then windshield?
- Best PCV hose connection? Intake manifold or Carb?
- weiand intake
- steering wheel/column
- how hard to replace heater core?
- 351w help
- 351W head ?s
- Need some part hunting advice...
- Tilt column for a 65-66.
- Anybody useing the K&N Top cover?
- Estimate for some restoration
- Cleveland Intake?
- 1966 Coupe with T5 from 2001
- I'm thinking of deleting my power steering when I do my efi 5.0 swap...
- Yup, another one of those threads......
- Best Super sustension kit
- Car stalls when cold under hard braking
- Popping noise out of newly installed rearend
- Tires that will fit on both dropped and stock height suspension
- exhaust rant
- Float Adjustment for Edelbrock Carb
- Fuel Pumps for EFI conversion?
- 69 console, yes or no? let me know what you think
- Windsor vs. Cleveland
- Strut Suspension upgrades in early Mustangs
- Finished paint pics of the fastback!
- Cam, rear gear and torque converter relationship?
- Post pics of nice 71-73 Mustangs
- 275/50R15 Fit 65-66 coupe?
- Shackles
- rusty bottom
- Best compression ratio for my 66
- NEED INFO PLEASE
- Reinstalling body, things don't line up... suggestions?
- export brace fitment ... probably a dumb question !!
- How long can I have the shock tower braces out?
- question for Mustang fans
- Eleanor body kit on a 68 Coupe
- 3in exhaust vs 2 1/2 in?
- 351c 2v or 4v
- 71 dash panel inserts
- what a deal
- Tire Opinions
- Steering Wheel Help!
- how hard would it be
- underside pics aod exhaust and engine pic
- Camshaft change opinions on a stroker
- Baers are on!!!.... Mostly... [pics]
- idiling problems??
- T5 Swap
- Long time no post
- t5 28oz flywheel?
- What kind of bolt is this?
- 71 mach 1 redo
- Carb Spacer ... is it needed ??
- 289 A-Code Perf. Build Up?
- WHAT STALL CONVERTER YOU RUNNING
- Make-a-Wiah Foundation car show - atlanta/peachtree city
- Ignition upgrade suggestions
- Plug gap and type with Flamethrower coil?
- 66 coupe front valance questions
- 65 or 66
- disc brake conversion question...
- Help, need to find more stuff for EFI swap.
- What should I expect to pay?
- Anyone make 69 mustang headlight buckets/fender extensions?
- tranny trouble (What no reverse?)
- AOD solenoid switch?
- Shock mount mod for '65-'66 cars with Koni's
- monte carlo brace
- engine building ?
- Need to find shock tower braces to clear EFI intake.
- Quick Question
- Dous any one know Front End alignment for a 67 stang? coupe
- Late model 5.0 shorty headers on a 351W ?
- New Mirror Poll
- position of rear shocks
- Ebay Scam Letter
- HEADERS ARE ON!!!!!
- Brake Spindle Source?
- Silver Bullet
- GM Alternator in '65
- E7's on a late 60's 302???
- AOD Shift Pattern?
- 351C questions
- Biggest Wheel and tire Combo
- 66 mustang engine replacement 289 or 302
- BAER master cylinder plumbing help...
- How do i trace the history of my car?
- Interesting cam break-in
- Best Looking Mustang (non stock) Pics
- trans leak
- Biggest cam for 70 302
- 25 pounds
- Big Surprise this weekend
- Side of cowl does not look like the repair panel
- Some software to help restore the classics
- Another way for a hidden radio install w/o cutting the dash
- Rims, Rims, Rims
- 390 In a 65?
- How to,,?
- Speedo bounce, need cable lube. Use?
- How accurate is Desktop Dyno2000?
- Which engine code is better?
- 79 302 question...yet again.
- AOD crossmember
- Just got a Linclon Mark VIII elec. rad. fan, now what?
- Courag Taillights in a 65
- Wiring harness problem
- Replacing leaf springs with coil
- Most Reliable Parts Source
- Radiator mods for reverse flow water pump?
- pro-m negative wedge kit
- Where to find 67 fastbacks?
- 79 302 water pump is it standard or reverse?
- 1966/1982 Drop top shelby for sale
- VIN PLATE TROUBLE
- Best paint for Radiator top?
- a freind needs help
- 67 options
- ATI Procharger
- Who is the better driver and why ? Auto-cross or Drag racing
- rejetting holley
- Anyone know where to get these clips?
- Front suspension rebuild?
- The one thing you would have done different.
- junkyard in knoxville Tn with 8 or 9 rears?
- I have a center cosole, now where do I put gauges?
- wanted: aluminum pedals
- PS Drop Bracket install questions.
- Rhoads lifters
- Home built chassis dyno plans
- 351w, stealth or Performer RPM? etc.
- help me pick a carb...
- Anyway to change gears with a 3 speed manual tranny?
- Reallly really really needing paint....for people in austin
- coil overs for 65 need cacs.
- 67 Coupe trunk seal?
- front suspension done, NICE
- What is the best way
- steering wheel / horn ring install. how difficult?
- Hood Clearance?
- Motor mount q's
- Borg Warner T-10 Tranny
- Transmission Ratios
