PDA
View Full Version : Classic Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 [70] 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91
  1. Im never gonna get anything done to my car!!!!
  2. Setting Points and Dwell
  3. Thunderbird t-5?
  4. Can I get the 2 for 1 special please??
  5. Really beginning to get upset
  6. Battery Relocation help
  7. Grease zerk size for UCA pivot?
  8. Back from Boston
  9. Tonight I say goodbye to my fastback
  10. YAY! Old cam out...
  11. Suspension Frustrations
  12. Safely jacking front end '66 coupe
  13. 65 - Front end feels light.
  14. Torque spec for wheels
  15. Mercedes SL500 seats... go for it or not
  16. Which AODS are acceptable?
  17. pics of 71-73 stangs with different wheels
  18. aod shift linkage
  19. Humphugger Console?
  20. Got the 157 tooth 50 ozflywheel/flexplate in today
  21. Finally in the shop. now for some decisions
  22. Lower arm mod...spherical bearing inside pivot and braced bottom.
  23. I have 69 mustang 302, 3speed, with 9in rearend, whats the best performance gear?
  24. questions about the bullit rims
  25. Over heating ?
  26. Over heating question
  27. Possibly buying a 67 coupe rolling chassis - questions
  28. Aftermarket seats
  29. More rearend widths - but different this time (maybe)
  30. For those who did a T5 swap
  31. Front spring change and alignment?
  32. how much fuel pressure
  33. K&N is my Friend
  34. What's a 9 in. worth as a bolt in part ?
  35. Ah got my speedo workin
  36. Sandblasting question
  37. Cam selection.
  38. What is the advantages of R&P?
  39. ford 8in ford 9 in and ford 8.8 in
  40. Fuel pump question
  41. PhotoChop a Color?
  42. $130 repo or $400 ford tooling fender on my 67? Whats your advice?
  43. AOD with 4bbl
  44. Car dogwalkin at 80mph
  45. Ignition problem when hot
  46. Need help with decision (Webers!!)
  47. Yet another wheel question
  48. Give me a hand
  49. How to fix the "Christine" syndrome...
  50. I'm Heading off to Oregon
  51. Which roller rockers from where?
  52. Alright somethings really getting on my nerves
  53. Did 64 galaxies come with 9" rears?
  54. 3 pt seat belt question
  55. Welder Question
  56. DarkBuddah...Found the guy that...
  57. Inside my doors
  58. 1969 mach 1 steering problems
  59. Colors... So many options...
  60. Granada Brake hardware question (not about the swap itself)
  61. Jet Hot Coating
  62. Aftermarket wheels
  63. Looking for a 9
  64. which aluminum rad do you use?
  65. quick question on header with non heat treated paint
  66. Getting rid of the heater core and blower
  67. Breaking in New Set-Up
  68. Ordered my new 50oz flexplate will be here friday.. lets hope vibration is gone
  69. New heater core in... Autozone SUCKS
  70. Best way for me to store my engine block?
  71. Cam suggestions carbed 5.0/AOD
  72. I used a smaller flywheel on the swap what else needs to be changed.
  73. What size fuel line?
  74. Pre-oiler???
  75. Udate on tranny swap after a broken u-joint and the list goes on LOL
  76. matching parts...
  77. Our club made it to MM&FF this month
  78. i know ima souind liek a real idiot but
  79. any one know of some good places to find...
  80. Tail shaft removal
  81. Need help.looking for '67-'68 pics with lowered suspention and 16"++ rims
  82. toploader info.
  83. 66 seatbelt mount location question
  84. Torque Convertor
  85. Ta Da!
  86. 1967 Exhaust tips - Whats available?
  87. Coil spring ID?
  88. Dash light went out.. how to fix..
  89. cheap stainless flowmasters!
  90. Do I have my alternator wired correcty?
  91. does the export brace need to be reinforced?
  92. 67 coupe project pics
  93. GT 500 SHELBY PIC..428C/J
  94. Help with ground effects
  95. 67 stang bad vibration fix advice?
  96. '65 GT Manual Steering Overheating? Take II
  97. What do i need to swap my 91 5.0 into my 66?
  98. Chin Spoiler
  99. cost comparison and benefits of auto to manual tranny conversion
  100. Monte Carlo Bar in a 6 cyl??
  101. 1968 Rims sizes
  102. 32 valve heads
  103. Eastwood Fender Roller Pics
  104. What's wrong with my AOD?
  105. transmission cooler?
  106. sparky 8131-duracool infromation.
  107. Granad brakes and aftermarket suspension?
  108. How much to stroke a windsor?
  109. Suspension rebuilding tips?
  110. OT: Just wanna let you guys know
  111. 69/70 Owners, you too Pak
  112. Bad Vibration in my 67 stang flywheel
  113. bad battery tray, bad
  114. Californa Special deck lid
  115. Kickpanel with Speaker holes
  116. Woohaaa! EFI here I come.
  117. Diamond tuck interior?
  118. Idle speeds and RPM's
  119. which radiator
  120. Washed, waxed and wheels polished.
  121. Another whats it worth thread (am I crazy??)
  122. Resetting/Tuning Mechanical and Vacuum timing advances
  123. Cragar SS wheel ?
  124. 1/4 mile times with stock C4 stock converter
  125. Last rearend disassembly question...
  126. Cobra Automotive fiberglass Cobra R apron quality
  127. Was this an optional 1969 spoiler?
  128. Second thoughts after all.....
  129. First drive tommorow
  130. Any Tips for Spark Plugs that Won't Budge
  131. 71/72 Mach 1 bumper question
  132. Testing the heater blower
  133. A/C Compressor stabilizer bar; Important?
  134. 65 289 waterpump pulley
  135. Radio interference compresser?
  136. stupid Question day for me I guess...
  137. was at a show today and saw a.....
  138. quick shift kit?
  139. 69 fastback trim questions
  140. fmx auto and 3.89 gear question
  141. Hooker Headers on a 69 Coupe
  142. boost gauge for paxton
  143. Accel Plug Wires = JUNK
  144. Reverse manual valve body question
  145. Right axle removal problems...
  146. need advice:Hooker LT's/ Tri-Y's/ 289HiPo Manifold
  147. Not totally dead
  148. Shelby Drop!!! Thanks Everyone
  149. PAK, decipher this one!
  150. Good headers suggestions?
  151. combustion problems - HELP
  152. Door Latch
  153. On a 67 GT500 , how close...
  154. 50 series flowmasters on my 69, advice please
  155. Rear suspension
  156. Alloy Cleveland block. I sheet you not.
  157. Follow-up pics of the black daytona wheels on my '66
  158. Cruise to Mars
  159. New upper control arms? Which ones?
  160. Pony door panel upgrade kit - parts ?
  161. Cookin' My Buns Off
  162. OT: Need help
  163. 69 mustang parking lights
  164. '66 289 carburetor dilemma
  165. AFR 195's for a 393 Stroker?? Sort of Different.
  166. Power Brakes or Manual Brakes?
  167. weight of stock heads
  168. Stupid Question... AOD 3 or 4 speed?
  169. 351C, long tubes and manual trans?
  170. Some help w/ paint
  171. remote door/trunk locks
  172. Spark Plugs??
  173. Rubber vs poly in front suspension?
  174. Lunati Bracket Master II cam any good?
  175. 3.55 Gears. Will it work?
  176. Converting to manual steering ?'s HELP!!!
  177. OOT - Please Behave :)
  178. Electrical Problem
  179. Opinions & thoughts on mustang trim & the shaving of it.
  180. Which Standard is the best?
  181. What is the best for performance out of 3,4,5 or 6 speed?
  182. Restomod Nearing completion
  183. 289 Coolant flow direction?
  184. which converter and flexplate to go with?!
  185. PCV Valve on aftermarket valve covers
  186. Power Brakes vs. Manual which do you perfer
  187. How many spot welds are there on a cowl?
  188. mustang rear end (how much can it handle??)
  189. Car's a pos...
  190. Don't know what to do.
  191. 68 ranchero??
  192. Thinking about AFR185's or 165's
  193. ok, need MORE ticking help, this time got pictures and video
  194. Sits diff. on all four corners.
  195. clutch linkage....
  196. Got an Edelbrock 600; What Else Will I Need?
  197. Damnit i always break things
  198. Finally! Fastback is out of the paint shop & flamed!
  199. MPH question
  200. New technique to rolling a fender....will it work?
  201. Header wraping
  202. Brake problems, and a question
  203. suspension noise
  204. hood clearance w/ air-gap intake
  205. Hello
  206. Intermittent wiper switch?
  207. Rebuilt 390, Need your help/opinions please……
  208. Windshield Washer Pump
  209. Anyone in here from NYC? PLEASE help
  210. gotta get a new radiator....which one though!
  211. Need to rebush the car, any suggestions?
  212. Why are my headlights/interior lights flickering?
  213. Fuel Line question
  214. Rear End Question
  215. Shelby 1" drop vs 1 3/4" negative wedge drop
  216. I think I've found my problem...
  217. Help with pushrods
  218. superchargers for a 302?
  219. Rearend help...
  220. Best Spark Plug wires???
  221. After Market Instrument Panel
  222. Dress up kits
  223. voltage regulator
  224. Fitting a Monte Carlo Bar & Exp. brace
  225. Where can I get door panel clips??
  226. Best head gaskets to ensure no leakage
  227. Anyone know what these tags means?
  228. calcium buildup in block?
  229. What carb do you guys use?
  230. Style steel wheel question
  231. Aftermarket Head Installation
  232. Swapping rears this weekend, any suggestions/things to look out for?
  233. 65/66 Tail Light Bodies W/O Socket?
  234. What cars can I get a 9 inch rear from
  235. Aligning quarter windows
  236. finished engine work
  237. heading for "plastic" surgery
  238. Sparking Alt.
  239. rear end leaking??
  240. Center(Drag) Link Issue
  241. Oil Brand & Weight Revistited
  242. Need help diagnosing a problem...
  243. 12 to 1 compression in a 351c?
  244. well making plans for a 408, neded advice on machine services..
  245. Help For The New Guy
  246. Educating Myself Slowly But Surely
  247. please help, not getting enough voltage from amp
  248. 5.0 EFI Swap Need Help
  249. Engine Rebuild
  250. ucstang
