PDA
View Full Version : Classic Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 [73] 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91
  1. 65-66 Fastback rear window louvers
  2. disc brakes for 65 F-100
  3. hurst 3 speed mastershift
  4. Pitman arm removal
  5. C4 or FMX? (pics)
  6. new to board
  7. Need help finding...
  8. got the stang dyno'd! VID!
  9. 390 Coupe
  10. Brass Rad Sizing for my 68?
  11. couple q's on a 1967, 289/c4 .......
  12. 65-66 Fastback Aerodynamics?
  13. Aluminum or Iron Heads???
  14. Removed leaf from springs
  15. new wheel out similar to Eledbrock 454's
  16. Does this look like rust or damage?
  17. Ha sanyone ever put a toploader behind a 429?
  18. Looking at buying a 429. Is this right??
  19. rim blow horn
  20. New 66 Advice
  21. Transmission Cooler
  22. 351C carb and intake manifold question
  23. performance down sides to rear sway bar?
  24. Lentech AOD on sale...
  25. need help going from a C6 to a C4 what do I need to change?
  26. Rearend swap...driveshaft swap??
  27. Mustang part shop in Canada ??
  28. Do you have to have the pink resistance wire?
  29. price of a 8" locker pumpkin
  30. 351C 2V heads - Aussie or not?
  31. Spare tire cover
  32. Way OT: need help from someone in the North County San Diego, CA area
  33. Can I put a T-5 behind a 351C?? Please help I am about to spend big $$$
  34. Is anyone using The streetfighter or the sizzler C4?
  35. 71-73 Mach owners
  36. Whoops I broke a tranny cooler line, can I change to rubber hose?
  37. Anyone out there with NOS'd FEs? / Converting FI kit to Carb.
  38. Rear Gears
  39. 65/66 Tail Light Housings WITHOUT sockets?
  40. headers
  41. 351c block
  42. Radio Feed back Question
  43. Ported heads, joke or not ???
  44. 68 Fastback Purchase Price?
  45. Overheating
  46. What causes tire hop and how do you get rid of it???
  47. Cleveland question
  48. More turn signal woes...
  49. POR-15 use and holes question
  50. T-5 where can I find one that is affordable
  51. Original Parts
  52. where can i buy an edelbrock 1405/1406 carb rebuild kit?
  53. 1970 mustang rear suspension question
  54. Oil Pressure Question
  55. Heater Host Shut-off Valve
  56. Uh oh... VIN code issue
  57. Help - No more vacuum... that sucks??
  58. Any of you in North Carolina?
  59. Rim width
  60. Power steering interchange parts
  61. Radiator Fan Question
  62. Looking for a Holley 600
  63. Pertronix not coming to the rescue, need Advice please!!!!!
  64. 67 Pwr Steering Cylinder Rebuild
  65. Trans let go what else can happen? why why me!
  66. I need some wheels for 65, you guys got pics?
  67. Carb woes
  68. Spindles
  69. kick down lever
  70. 1969 power steering pump id
  71. 4 valve Cleveland heads not 4 barrel
  72. Fatman fabrication question
  73. Should I change my harmonic balancer when I change my cam?
  74. Hey Guys! Chevy 350 Tech Question - Don't shoot!
  75. Short vid of one slow 65 mustang
  76. i think my car is a 64.5
  77. Timing Q's
  78. Suspension Update
  79. Window a little off track.
  80. Timing Question
  81. Rearend
  82. Balljoint problem
  83. What's a 8 in. pig worth?
  84. centerlink Question
  85. Coils...
  86. Get out and enjoy those early models!
  87. replacing parts of the cooling system
  88. Whats the voltage suppost to be at the ballast risistor?
  89. 65/66 vs 67/68 Radiator Support
  90. Gas Question
  91. my 65's suspention
  92. RWHP Estimates please?
  93. Automatic Choke System - Carb Experts HELP!
  94. Locked up 302 with 10k miles on it.
  95. motor help needed
  96. Convertibles -- show me your exhaust
  97. Any gains in running an ignition box?
  98. Did I get a good deal on this 70 coupe?
  99. Finally decided to break down and buy a new cam, recommendations?
  100. Changing leaf springs tough?
  101. 13's too much to ask?
  102. Well the mustang ran for 2 days straight.Now it wont start?
  103. rebuilt a 3spd/od....need to vent frustration
  104. rebuilding AOD
  105. Please help! Door (pushbutton) latch assembly
  106. Clicking from wheel... bearing problem?
  107. Ford alum 2 x 4 Barrel Manifold (rare?)
  108. What if subframe connectors don't line up?
  109. Help can't get my car down!!! - Craftsman Floorjack repair
  110. Transmission swap from hell... speedo issue
  111. How do you plug a hole?
  112. Need info on Tremec TKO swap in 1970 Mustang
  113. FINALLY!! Got dyno #'s on 408!
  114. FMX to C6....Final Decision
  115. Found some great stuf for rust...
  116. Subframe Connectors
  117. Machine shops
  118. 68 Torino Rearend?
  119. Anyone know of a kit from chrome-ing parts
  120. Question for the people in Austin, TX
  121. what degree thermostat is everyone using
  122. Dyno questions
  123. A unique 3-point seatbelt question (maybe)
  124. Brake rod to long
  125. Oil Breathers
  126. Is this a good deal?
  127. Question about my speedometer
  128. Can someone please explain these specs on my camshaft?
  129. Help!! - Car won't start; electrical prob.
  130. Question of Morality
  131. Crate Engine Install Questions
  132. The price of a 70Stang...
  133. what should I run
  134. rear fold down seat?
  135. So Cal Salvage yard watch..........San Diego
  136. Carb Questions
  137. G-FORCE TRANNY SUPPLIER IN CA???
  138. billet tail light assembly
  139. High RPM stummbling
  140. c4 problems need help!
  141. Spindels??
  142. Windsor Crate Engine
  143. people with rear disc brakes...
  144. Auto to Manual
  145. Please ID this hood
  146. '70 conv. Mustang Boss 351 Restoration
  147. Lets talk posi, lockers, spools...
  148. Performance automatic valve bodies...
  149. Protecting hidden areas
  150. Interior color... 69 Mustang Coupe
  151. Do you think I COULD break into the 9's with this combo?
  152. not again overheating tell me not a head gasket?
  153. Water pump recommendations?
  154. rear leaf springs
  155. Some diff questions
  156. What to do with rusty headers??
  157. site for rare $22 t-handles
  158. 1976 mustang cobra 2?
  159. Yeeeeeeeeesssssss got it back on the road!
  160. Drop Springs 1 inch Help!!!
  161. went to the bone yard in search of electric fans......
  162. 351c Valley Pan
  163. vintage 45's in canada
  164. Going to remove vinyl top, got any tips?
  165. Looking for some used Edelbrock FE heads.
  166. alternator instruments?
  167. where can you buy rear shock plates???
  168. Help with roller rocker setting up.
  169. Took out plugs and ran compression test... have some questions
  170. what exhaust to put on
  171. ac sadan compressor conversion.......????????
  172. How do i lessen the Flowmaster drone?
  173. need help with sway bar link kit
  174. 5.0 EFI swappers- Electrical Question
  175. Tooks pics of my 64.5 with my parents 67 convert
  176. Wheel Questions???
  177. Igniton question
  178. Dyno Results Question??
  179. Pics from Pony Car Meet, Stockholm, Sweden
  180. flywheel balance
  181. POR 15
  182. door lock problem.. 66 fastback
  183. plug wires
  184. Who has actually tried randalls rack?
  185. Popping noise??? from header leak?
  186. Horsepower to quarter mile times
  187. axle seal vs axle retainer ring
  188. rear bushing problem
  189. Supercharger or Nitrous?
  190. Just put an AEM Air / Fuel guage in my 65
  191. Shock tower braces 71-73
  192. Where does the front carpet end?
  193. how much work to install a steering box (such as flaming river)?
  194. Six's, no NOS, Blowers, or EFI..
  195. How many of us build there own car parts?
  196. 69/70 & 71/73 CD player with radio bezel!
  197. #2- How do I get the bolt out for the rear leaf?
  198. How do I pull a rear axle bearing?
  199. Power Steering Pump
  200. 67-68 Turn Signal Hood.
  201. Rotisserie restoration frustration
  202. Guys with Flowmaster setups... how to stop exhaust rattle
  203. Mystery oil loss problem
  204. Getting rid of a mild ping
  205. C4 tranny question
  206. 65 Mustang w/ 70 front disc: Questions
  207. ucstang
  208. Header gaskets for Tri-Y's
  209. Weld Racing Wheels
  210. uggh! and the bad day just continues!
  211. Electronic ignition for I6???
  212. Which Rack & Pinion????
  213. need help cant find aftermarket pulleys for my stang.
  214. How good are hipo heads Iam buying a set today for $100 bucks
  215. What items would you like to see the aftermarket manufactures improve upon?
  216. underhood roots style blower??????
  217. Powermaster 140 install-PLEASE HELP ME :(
  218. 351 V Emblems?
  219. Tires wearing funny...
  220. ?'s on installing a new intake
  221. custom subframe idea.... feasible?
  222. big weekend for the windsor
  223. My 69 won't start when it's hot
  224. Disadvantages of putting 9" 3rd member in an 8" housing?
  225. 289 oil pump question
  226. Yay! I can fabricate!
  227. motor swap time, 67 302 to 98 efi 302
  228. O.K. forget fixing the FMX. Will a C4 bolt up the same?
  229. alternator suggestions?
  230. Rebuilding Calipers on 67 Musatng 4-piston
  231. WTF ? rust emitting gas bubbles under my bran new paint
  232. Tire Wobble
  233. Aftermarket Gear Sets...Who & Where
  234. Which C4 for 351W?
  235. NON-Tech Talk
  236. where to get 3-point shoulder harness for my 69?
  237. 9" locker in 8" rear?
  238. Im confused
  239. Picking up a 67 Coupe w/351W
  240. Need advise on fixing my Mustangs
  241. fan shroud...how much will it cool?
  242. Roof Rail molding question
  243. any type of auto electrical lub??
  244. Getting tired of this, please help: Granada Swap
  245. Engine bore Size... ??
  246. Anyone have a step by step for removing fenders for 66
  247. problems with valvetrain, do i have to pull the head?
  248. Cleaning/Polishing Glass
  249. question on spacer for axle spring plate hole vs. spring bolt size diff
  250. Radiator support, lh and rh apron replacement
