View Full Version : Classic Tech
- 67 Stang SSM bars or CalTracs??
- 66 Mustang crossmember
- Lincoln efi
- Bouncy bouncy bouncy......
- questions about petronix install
- 67 Mustang R. panel molding/ Glove compartment bolts.
- tach with pertronix?
- gear noise?
- 66 mustang rearend
- Electro luminescent gauges 67-68???
- Mustang Warehouse Thread on Corral...
- How do I know what rear end gears I am running?
- Fiberglass parts
- Engine bay spray paint?
- 351 W Headers
- Remote trunk release
- Data plate rivets
- 289 rebuild query
- time to be realistic
- Sway bar trouble
- Looking for info on Mexican built Mach 1's....
- Electric Windows
- steering column
- Loud Exhaust for classic stangs (289)
- Summering Modding Time
- oil slinger
- I need help with a flywheel
- My convertible top rattles ('70)
- Help guys im putting in a new engine!!
- Those of you with Pertronix
- Car driving me crazy...
- whats my distributor??
- I'm retarded -- how do I time my engine?
- What size anti-sway bar to use
- Potentially stupid questions about engines.
- need your expertice on gaskets and rust inhibitors
- 66 mustang
- Any pics of Quarter Panel Before/After
- Classic Mustang Exhaust
- Brakeline question?
- HELP: Trunk Lock
- 6 cyl to 8 cyl cars
- My 67 Fastbacks Pics
- Transmission Vacuum Hookup?
- Wheelhop?
- Mustang II front With Cobra IRS ?
- which one?
- brake push rod
- Randallsrack R&P questions
- pulley tips or tricks
- 1966 mustang
- Ok guys, gimmie your best stories
- Quite Performance Exaust ? which one is the best.
- What kind of reactions do you guys get on the street?
- Distributor question
- HELP WITH MY HOLLEY !!
- Please help Identify parts and possible gains!!!
- Are are some interior kits and weather stripping kits better than others?
- Can't find these simple screws...
- How much woud you pay ?
- Any other good classic mustang forums?
- Under car -- black tar stuff????
- Trunk rust -- how to fix? (Pics inside)
- How much does it cost to narrow a rear 2"?
- 274 w/ converter worth extra money over a 270H?
- Getting heads worked on... advice and costs
- what torque converter options are there for a '69 C6?
- ?'s on future purchases
- Modify disc hubs for Cobra Wheels
- trac lok differential question
- Replacing lower control arm?
- Installing lower control arm?
- Lower control arm replacement?
- Need electrical help...shop manual???
- lead work
- 68 Power Steering Pulley?
- Anyone running Rod & Custom MII coilover system? or offer advice?
- Need to order weld wheels for a 68 coupe...what sizes to order
- 65 Rear Seat Belts
- Detroit Locker VS True Trac.
- My '65 Fastback (Pics)
- torque boxes/frame
- 71 overheating at idle only
- Front rail repair/restore
- Pictures Needed Please
- Shock tower bolts?
- Silver Frost Mustangs?
- Don't buy at www.mustangdepot.com!
- Can someone photocrop this for me
- total restoration
- Work in progress...pics
- Have you heard about the new DM Terlingua Trans Am cars being produced?
- Problems with my C4, but first my ignition...
- Which igntion set-up?
- Taking bets on what's wrong with my motor...
- Global West Strut Rods. Who is using them?
- Installing headers! tips and tricks?
- 67 side scoops
- Clutch Pedal Assembly Question
- paint done, finally time for pics
- Another Photochop
- Carb linkages
- need some brake fitting sizes....quick!
- What type of fuel pump
- Testing out the new slicks
- Help with exhaust choices
- To chop or not to chop? (future of extra '70 fastback to be decided)
- 4 speed borg warner Owners My Horror story inside
- Does anyone run white letters out anymore?
- AFR 185's or 205's?
- ? about 94 block and cam advice
- Chrome shifter balls?
- Help me pick out an engine for my '65
- back glass drain
- My first stang... 64' Stang..
- my first mustang
- Cam Doubts
- Something to look at, pics on my cardomain site
- Knotts Berry Farm Pictures (tons of them)
- Brakelight Problems
- upper console wiring
- Mustang Plus Upgrade ?
- Just got the 66'!!! wow!! gotta ? though
- Seat Belts
- Need close up pics of 70 351W brackets
- Header question/help
- How does this intake sound with my engine combo?
- power steering question...
- maybe a dumb question but
- How Do These Power Window Kits Work?
- I Really Need Some Help PLEASE
- spindle length '68/'69 vs. '70
- Has anyone tried new PG based coolant?
- Will a 69 gas tank will fit into my 68?
- stupid question... what does a torque converter do?
- Hipo Clutch set for an A code 289
- Okay, I have a Setup Idea.. Pros cons?
- 40 years of pony car history
- Anyone using gear drive?
- New to the Board
- Went to track wed. and thurs. Wife is definetly going to leave me.
- Dang computers
- Rear Brake Line, One piece??
- OK Jump in Give ME Your 2 cents
- Re-jetting a Carter 750
- Anyone recognize these classic brackets?
- carb. mounting gasket?
- Monte Carlo Bar w/smog junk and A/C?
- aluminum driveshaft
- Ahhh! More pulleys I need help IDing!
- Need help IDing these classic Ford pulleys!
- Anti freeze on my floorboards????
- Rebuilt C4 trouble
- Big power loss when warm
- power steering problem
- Squeaky Belt
- Exploding Rim!!!!!
- Engine Running Hot?
- has anyone ever thought about running 2 alternatures, if so any ideas on how to wire?
- What Color to Paint
- 68 Thermactor Air Pump
- vacuum advance help needed
- Street Killer 393w Stroker Engine Build?
- 4-speed transmission problem
- 3-Speed Toploader swap to 4-Speed Toploader
- My '68...Help with Paint
- Longblock questions.
- 351C 2V should I?
- Digital Instrument Cluster for '67 Mustang
- TKO and hooker competition
- Increased gas consumption
- Late Model Rims and Wheel Adapters
- Lifter ticking...
- 15x8 Wheels
- Shims
- Guideplates and Carbs.
- In Search of... Rack and Pinion Info
- carb jetting
- Idler arm to frame question//
- 69 17" wheel/tire combos needed, i goofed and wasted big $$$ need help
- Choices...
- 1967 Conv. Eleanor
- finally installed rear sway bar.
- oil pan gasket help needed
- Engine tuning help please
- wheel and tire suggetions
- Doh! free CARFAX right now, but...
- ranchero parts
- Went racing again....wifes going to leave me, I know it
- Whats the best weekend warrior suspension?
- 351 4v quinch or cobra jet????
- Upper A-Arm Removal
- Im new here
- How Much Is It Worth
- Trac-Loc vs. Locker
- 1969 Mach1 Rim Blow Steering Wheel
- big body 460 swap
- Baer vs. SSBC???
- Resistor Wire
- Negative Wedge Kits for 67?
- Fuel injection?
- Make my horsey run cooler...
- 67 door locks
- Knotts Berry Farm 4/18/04
- 351C mod questions!
- T-10 help
- finally got soem pics of the stang
- VIN information
- Question about the front end?
- Hood got crunched...
- Roller Rockers Do they Make alot of taping sounds ?
- instrument panel lights
- 3 speed to 4 aod...
- Getting Engine Rebuilt
- Cool shift knob
- First time at the track!!
- Anyone see the new Jon Kaase heads yet?
- Tranny wasn't what was killing 1/4 mi time
- Anyone buy anything from Rustrepair?
- speed-o-meter
- My 68 progress
- gas mileage
- slight popping and backfiring
- Where do I start for 66 fastback
- Want to port my heads
- Psydwaze where are you??
- I need the specs on 1964.5 mustangs for a school project.
- mtv pimp my ride mustang
- Here is my set up for 65 stang
- 13" Cobra Disk Brake Brackets
- head gaskets leak
- Leaky Transmission with Good Seals?
- C4 tranny lines
- Starter Problem
- I need help restoring an old one
- and my fox gets some bling.
- Horsepower gains
- Does anyone know if these are 4 lug?
- New Radiator for my 67 200cu?
- wheel fitment question
- What do you guys mean by rolling up to fit 17x8s?
- altenator Bolt hole to small ? head problem
- 65-68 200cu Mustang... reliable.. daily driver?
- pitman arm removal
- Aftermarket oil pan question?
- 1970 351C Dyno Numbers (you should all be interested in this)
- OK - Friday I'm ordering a Randall's Rack
- Mallory Billet HEI, Finally!
- No clue how fast I'm going....
