PDA
View Full Version : Power Adders
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15
  1. bottom line supercharger needs
  2. Supercharged with Nitto Drag Radials
  3. Wide Band O2 users..........
  4. Supercharger Whistle
  5. Bottle valve question
  6. Modular Powerhouse 4.6 Vortech Tuner kit
  7. Nitrous Size Shot and Kit Recommendation 68 Mustang.
  8. Bypass valve. What about this!!
  9. Poor man's twin turbo setup.
  10. Car stutters on take off/low rpm after NOVI 1000 install?
  11. New to Nitrous - NOS 5115 questions
  12. NITROUS HELP ASAP!!!
  13. 100 shot of nitrous on a 97 Cobra which kit what do you use ?
  14. Need help from a s/c guru
  15. Vortech Rebuild
  16. Stock STrim,. loading up and boost levels in diff gears ??
  17. Vortech Installed/Need Help!
  18. Pulley change question
  19. Vortech question
  20. Questions about stroking a 351 ?
  21. What pulley size gets what boost on a vortech?????
  22. will the AC removal effect my install. please help
  23. cobra bolt ons
  24. Nitrous wiring question...HELP!
  25. looking to buy a novi 1000, what else do i need??
  26. Stock Cam or FTI?
  27. Changing alternator with Vortech installed on Fox
  28. KENNE BELL OR VORTECH FOR E-303
  29. 351C nitrous spark plugs? NGK?
  30. New vortech
  31. Wow this is cool
  32. Need belt size for my NOVI
  33. Only getting 3lbs of boost with new supercharger....WTF!
  34. Kenne Bell & strut tower brace
  35. kenne bell/non intercooled ??
  36. Got a 01GT with S-Trim lots of questions
  37. New to the S/C Game
  38. how much is too much
  39. nos jet sizes???
  40. Supercharger belt
  41. ATI Blower Question for 2001 Cobra 4V
  42. new to superchargers setup... 2 questions ?!?!
  43. antifreeze or water in the aftercooler?
  44. Doubling the output of SC Trim?
  45. YS to S/SQ trim??
  46. dyno numbers with new combo
  47. FMS ASF-22C
  48. Any body selling Superchargers?
  49. Nitrous Express Solenoid???
  50. Bottle quick release
  51. what is the max CR you can run & add a supercharger?
  52. running lean
  53. stock low end?
  54. Nitrous Help, setting up 2 stage system
  55. b.o.v vs. bypass valve
  56. Nitrous Kit
  57. Am i chancing it by only retarding the ignition 2*
  58. What valve spring is in your forced induction 2v modular?
  59. Smog pump needed for blower?
  60. Are there classifieds for this subject?
  61. I need help with zex install
  62. vortech question
  63. Saleen Series II out, Kenne Bell in
  64. People with KB kits please read
  65. How much boost without Bypass/blowoff?
  66. Head unit bracket troubles!!!
  67. Supercharger and nitrous
  68. PAXTON SN93 directions needed badly
  69. NOS NOSzle VS. NX Wet Kit
  70. Vortech S-trim guys...quick question
  71. Adding Vortech?
  72. Jet size for 125 horse
  73. Breaking up on the big end- S-trim
  74. Help me not get screwed at the Dealership :)
  75. s trim install?s
  76. supercharger/turbo guys might want to hear this
  77. Kenne Bell Belt
  78. 3rd belt within 2 months? WTF?
  79. Nitrous question
  80. vortech SC, wanting to upgrade to a.....
  81. Powerdyne Pulley Diameters?
  82. Good Powerdyne rebuild
  83. IAT sensor question...
  84. V-1sc any good?
  85. turbo kit?
  86. First supercharger build...Questions :|
  87. small superchager for 94-95 5.0 vert?
  88. Cheapest place to get a Vortech for my Cobra?
  89. procharger guys help me
  90. 13.0's ?
  91. ADVICE please
  92. pre det
  93. Easiest supercharger install??
  94. Vortech V2 S Trim on a 351 ?
  95. Schrader Valve for NOS 5116 ?? HELP!!
  96. Installed ZEX Dry - Injector/MAF/Regulator Questions
  97. Do i need an FMU & need info on how to do a cog system on my s-trim...
  98. installed new NX efi system
  99. Which blower
  100. Zex install.. Fuel pump & Spark plug questions
  101. Difference between roots and twin screw?
  102. S/C Videos Thread
  103. Dyno #'s fpr my 88 bird TC w/ATI
  104. no boost???
  105. Help! Vortech V-1 S-trim S/C
  106. Tomorrow is gonna be the first time with Nitrous at the track. Lots of Questions.
  107. SVO/FRPP roots blower ????
  108. Fuel Pressure
  109. How bad is your gas?
  110. Where to Find 42lb Injectors on the cheap
  111. Powerdyne BD-11A Instructions/Parts list
  112. PD Pulley help
  113. Underdrive Pulley on a Supercharged car?
  114. P1SC2 procharger
  115. S/C Options??
  116. NOS on edelbrock carb
  117. Blower cam question.
  118. WHAT RPM'S ARE YOU SHIFTING AT WITH 3:73's
  119. 99 cobra kb 1700
  120. powershot noids and 4an limit?
  121. Is it OK to bypass blower with a shorter belt?
  122. WET OR DRY NITROUS BETTER?
  123. Does nitrous like any particular plug over another?
  124. steel braid question
  125. nx install ?
  126. Nitrous fuel system???
  127. Damnit!!! AED Rev I, or Saleen Series II?
  128. S/C on a stock 302.
  129. HELP! Fuel Pressure Dropping.
  130. How does it feel?
  131. Stupid Question...
  132. Is there anyway to tell if the nitrous kit is working properly w/o spraying it?
  133. where to find directions on nx wet kit?
  134. hp performance turbo kit
  135. timing problem
  136. Centrifigul supercharger question
  137. cobra p1sc for sale
  138. Tee installation where is the hose
  139. Anyone use the Snow Performance Boost Cool??
  140. when to ditch the FMU
  141. Homemade power pipe/ after cooler/ intercooler
  142. powerdyne supercharger
  143. F cam or B cam good nitrous cams?
  144. Useful Formula
  145. Paxton Sn93
  146. Blown Mark VIII!!!
  147. Dry Shot Nitrous Question
  148. Twin Turbo with Edelbrock Carb - IMPOSSIBLE!
  149. ...for KB1500 Owners on a 5.0L...
  150. 99+ saleen blower series II
  151. P1SC people
  152. Turbo questions
  153. who makes the add on belt tensioners?
  154. this is silly
  155. 94 Stock GT +Vortech or Procharger=12sec @ over 110mph or 300rwhp Realistic?
  156. where to get
  157. Dynotune A/F Ratio Gauge
  158. Help!
  159. n2o product anyone know how to do this
  160. Supercharger or Turbo?
  161. Car down -need help w/ S-Trim idler pulley
  162. Short on Boost!
  163. What H/C/I to go with zex 125 dry kit in 94GT
  164. Its in a bird....
  165. Power pipe for ATI???
  166. Zex Dry Kit
  167. How Big of a shot with the stock fuel pump?
  168. Nitrous fog light arming switch?
  169. Need Help: Pro-M Blowthrough MAF
  170. turbo manifolds
  171. supercharger tunning
  172. Single Turbo user I got question for you
  173. what should i do for more power
  174. Vortech inlet pipe!!
  175. Run with Dry Shot Sat night. A problem...
  176. Patroit Performance Heads W/ Blower
  177. ET?
  178. What parts needed for Supercharger Tnner Kit
  179. fuel pump with boost question
  180. What nitrus kit should i go with??
  181. vortech Brackets
  182. Supercharged Fuel Filter Questions
  183. vortech oil return tap size??
  184. boost gauge
  185. electronic governors
  186. Novi 1000 performance?
  187. Nitrous TB plate spacer?
  188. Any ideas/suggestions
  189. Spark plugs and N20
  190. Boost retard wiring
  191. check out my setup sd guys !
  192. vortech t-trim w/ paxton air-to-air intercooler
  193. zex nitrous kit
  194. What 2 Do Next on 98 GT??
  195. why are my torque and horsepower numbers so different?
  196. anything to speed up a 2.3l?
  197. 93 Mustang supercharger kit in a 94 mustang?
  198. Novi 1200
  199. Kenne Bell Question
  200. where to get lighting MAF's
  201. boost question, pulleys?
  202. ripping belts after s-trim install
  203. Deleted AC, no belts will fit!!
  204. Air To Air Intercooler
  205. TNW Nitrous Jetting sizes
  206. q's all about the kb blower
  207. Saleen S281SC beat by LS-1?
  208. Vortech Need Help Quick! Possible Purchase!
  209. Wanted: 99 Cobra Throttle Body 4V
  210. Procharger intake tube broke (bad)
  211. 99 Saleen CAI
  212. SN93 supercharger discussion and advice. Come in please.
  213. Compression testing before ?'s!
  214. BTM hose
  215. Anyone running an AED Supercharger on their ride?
  216. question about cryo2
  217. Nitrous questions after Dyno
  218. Looking for this part....
  219. gt-40 motor question
  220. Stroker
  221. How much is a resonable price for my mustang?
  222. blower belt
  223. Procharger Oil leak
  224. cant find an answer anywhere, maybe you can
  225. I entered the dual poweradder world today
  226. Power #'s estimates??
  227. Sodier or Crimp???
  228. will i break 12's.
  229. what should i do??
  230. 1996-1998 mustang GT supercharger
  231. The time has come!
  232. n20 for 99 cobra (new to nos)
  233. Nitrous Questions
  234. Ebay scam ?
  235. Should I get a NOVI 1000 or NOT?
  236. Cold air intake with supercharger???
  237. Puttin my nitrous back on...
  238. What NOS jets should I run with Vortech?
  239. Running with SPOUT out. Any advantage to me?
  240. Anybody ever use a window switch with Zex? I'm having problems.
  241. Another turbo question
  242. AFR+S/C Plugs?
  243. Best Exhaust combination for power
  244. Steeda Duals Question
  245. Digital Window Switch Question
  246. Wanted: Used Supercharger for 1999 SVT
  247. What is a good turbo to go with?
  248. Blower/Turbo/Nitrous
  249. FMU?
  250. Powerdyne? Opinions?
