PDA
View Full Version : Power Adders
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15
  1. s-trim problems
  2. Blower Mods
  3. People w/ ProCharger P-1SC on 99/00 GT
  4. Nitrous problem
  5. Which lighning mass air do I have?
  6. Ad hundreds of Horse Power to your engine
  7. is 108,000 miles too many to supercharge?
  8. Supercharger Whine alot louder wit removal of intake snorkel...is this normal?
  9. Dyno Numbers! P600B with H/C/I
  10. Will I need a retune?
  11. Supercharger Question??
  12. Excellent Supercharging Article enclosed
  13. thinking of a novi 1000 help needed
  14. I'm getting some free turbos...
  15. Supercharger-VORTEC OR PROCHARGER
  16. Which spark plug with SC ???
  17. Where to find nitrous lines/fittings?
  18. which Supercharger should i get???
  19. What the???Supercharger mileage question
  20. Anyone with a TT'd SN95?
  21. Timming question
  22. Problem with my NX fogger system.
  23. A-Trim Setup - Will this work with stock injectors
  24. Help supercharger made my car slower
  25. Supercharger Wastegates??
  26. I need a powerpipe for my vortech'd stang
  27. is nitrous illegal
  28. COMP Cams
  29. No Boost til 3500???
  30. HP twins
  31. Tim Barth(or anyone else), will this work for me?
  32. vortech guys running an alternator and water pump only come on in...
  33. INSTALLED VORTECH IDLE PROBLEM
  34. need info on a novi 1000
  35. How Hot Does It Get Under The Hood
  36. Autometer electric fuel pressure guage???
  37. Fuel pressure gauge install??
  38. 408 stroker, all forged, what heads and turbo to get?
  39. Vortech smooth idler pully on the bracket question
  40. Dry or Wet?!?!?!
  41. S-trim or A-Trim?
  42. lethrneck32 read this!
  43. There's not enough room to mount T-Rex..Help!
  44. AFM powerpipes
  45. Oil???
  46. Vid of KB GT
  47. 01 cobra nitrous ?
  48. Couple questions on Vortech install, PICS
  49. Nitrous Express Ford EFI Systems Summary
  50. Vortech rebuild kit
  51. Supercharger belt coming apart
  52. Intake spacer and nitrous?
  53. allen/eaton M90S
  54. fed up with procharger
  55. Boost sensitive fuel pressure regulator?
  56. Nitrous Jetting
  57. vortech pulley...
  58. Where to find NX Shark nozzle?
  59. NX Shark nozzle users?
  60. First Dyno Run On KB!!
  61. QUESTION Help me please
  62. powerdyne pullies?
  63. Wet kit and fuel injector size?
  64. anyone here running a moroso vac pump on there s/c car...HELP.
  65. Zex Nitrous Install Help!!
  66. 7 Quart Oil Pans
  67. gauges
  68. Any one need NOS kit for 99 and up
  69. Should I need another dynotune?
  70. Kenne Bell S/C for 87-93 5.0
  71. how do i get 500hp on a 4.6 mustang Gt
  72. Kenne Bell Instalation
  73. walbro GSS342, is it good for a 99+ fuel system?
  74. Dual fuel systems check it out
  75. old diesel turbo
  76. Window Switch RPM and Shift RPM when running Nitrous?
  77. Opinions Wanted! :-)
  78. Kenne Bell
  79. New Heads for 93 5.0
  80. how to replace the fmu with a afpr
  81. Platinum Spark Plugs
  82. 2003 gt? which kit and where to buy. wet or dry?
  83. DRY KIT WONT WORK ON MY MACH...
  84. Question about supercharger and ignition
  85. how much ET does N2O drop
  86. K.B. vs Gt 02 Someone have numbers?
  87. Boosted pi swapped 96-98 2v Q's
  88. Procharger P600B
  89. New to the 5.0 with juice. Have some ?
  90. Supercharger
  91. Track times w/N20
  92. 99-01 Kenne Bell supercharger
  93. which injectors
  94. What is a Blower?
  95. Ran new Turbo kit at the track
  96. Fuel Pressure spike on the nitrous side
  97. 75 dry shot 03 gt help
  98. popping noise on decel
  99. Inline fuel pump or 24lb injectors needed for N2O kit?
  100. Time to install Kirban AFPR, 36lb's, Fuel pump and MSD 6btm. How To?
  101. What do you think my numbers will be?
  102. Carburated options?
  103. please help me
  104. Pro Charger P-1SC air filter upgrade
  105. twin turbo instructions????
  106. New to superchargers, so help me out
  107. 03 cobra supercharger on 97 cobra?
  108. Which blower for a 04 GT
  109. Should I change pulley?
  110. Is the Paxton SN2000 good/bad???
  111. Procharger P-1SC or D-1SC
  112. DIS 4 ????????
  113. i just got a sn-89 supercharger
  114. Nitrous mountin question
  115. belt size ?
  116. 19/lb Injectors enough for Nitrous
  117. E 303 or F303
  118. BLOWER WITH UNDERDRIVE PULLEYS?!?
  119. Will stock 99 Cobra aluminum block hold up to 750rwhp?
  120. Turbo Kit on Budget ?????
  121. Vortech charger on 88 stang...questions
  122. Vortech A-Trim question
  123. Turbo engine management
  124. Poor Running 86 Mustang with a Kenne Bell Blower
  125. Anybody Running a Vortech w/ Paxton Intercooler
  126. WANTED: Paxton sn-92 bracket
  127. what size pulley ?
  128. Forced Fabrications Turbos
  129. Ever mess up a n2o plate w/ a backfire?
  130. Tuning suggestions?
  131. 94-95 turbo pics
  132. Best recommended Power Adder for $$$
  133. A-Trim Q & A
  134. best spot for wot switch on 5.0
  135. NOS GUYS HELP!!!!!
  136. Safe shot of giggle gas
  137. Kenne Bell supercharger for 99 SVT out 2nd week of May
  138. Question about supercharger
  139. Power Added by X or H pipe
  140. ATI P600B Questions
  141. Nitrous Kit wiring
  142. Pictures needed
  143. What kind of #'s do you estimate my combo to have
  144. Terminology help: Intercooler vs. Aftercooler?
  145. loading up and heating up
  146. 2003 GT turbo
  147. What Heat Range Plug after A-trim to SQ-trim Swap?
  148. air coolers for s/c
  149. Bypass Valve versus Blowoff Valve
  150. 11.4 seconds at 120 MPH
  151. C 02 vs Alcohol injection
  152. need a guru's help on 4000 detonation please
  153. paxton supercharger good deal or not?
  154. Has Anyone Tried this yet?
  155. turbo question
  156. Experienced nitrous guys in here please !
  157. Houston Area
  158. Vacuum/Boost connections for gauge/BOV/Fuel Pump
  159. Budget supercharger
  160. Nitrous kit Question
  161. Gauge Qs for S/C
  162. Fuel Pump Qs For S/C
  163. Supercharger budget
  164. Supercharger for the Wife's Daily Driver
  165. Any Advice????
  166. what does your oil pressure look like with blower???
  167. anyone selling a 8.8 rear end
  168. Procharger D1SC pics on 88-93 cars please!
  169. Hey Turbo Guys
  170. 03/04 cobra tank/pump
  171. supercharged efi problem HELP!
  172. im trying to buy a blower from someone but how do i know if it works or needs rebuild
  173. nitrous solenoid
  174. saleen supercharger for the 99 SVT Cobra
  175. need help-carbed paxton novi 1200
  176. Want to buy SC
  177. ZEX Kit ?
  178. Fuel pump reccomendations
  179. anyone have a part # for a spark plug thats one step colder
  180. Mustang-X.com
  181. status of the Kenne Bell for the 99 Cobra?
  182. supercharger?
  183. Need S/C help
  184. New Business
  185. Hello guys got a silly question bout superchargers
  186. Good deal?
  187. Sick and Tired
  188. What spark plugs for 100-150 shot on a 00 GT?
  189. Saleen series IV blowers or Kenne Bell?
  190. Need more info on - Nitrous Express Incognito
  191. Is anyone using or installed Diamond pistons
  192. Nos 5171 kit Q's
  193. blower install ?'s
  194. griddle in a 351w
  195. Expecting to much? Vortech v1 S 2002 GT
  196. Two fuel pumps
  197. FS: Zex Nitrous Kit Brand New!
  198. reved to 7k last night...
  199. Nitrous and Carb Combination
  200. Nitrous?? Zex kit
  201. question about pulley
  202. Kenne Bell Acting Funny
  203. question on supercharger
  204. 1999 SVT Convertible with a 6lb boost Kenne Bell supercharger
  205. FS: REBUILT SN 92 PAXTON BLOWER
  206. Can a custom burned chip fall out of tune?
  207. Can a custom burned chip just fall out of tune?
  208. upgrading rear end on my S/C automatic
  209. 2003 cobra SVT supercharger on a 1999 Cobra?
  210. NX wet kit users HELP
  211. How long does a turbo last?
  212. question about a supercharger
  213. AFM Powerpipe, UPR Boostmaster or other
  214. looking for the right carb
  215. gap spark plugs to stock specs or different???
  216. Paxton Novi1000/2000 Pulley on Paxton SN93?
  217. BOV for Vortech question.
  218. Quick injector question
  219. 2001 Cobra
  220. head gasket
  221. Bottle Opener Question
  222. turbo or supercharger?
  223. 4.6L TT setup
  224. Blower & CAMS
  225. looking for drivers side bracket for fox a trim
  226. S/C+mods Vs. Cobra
  227. At what point do you go to 24lb injectors
  228. Double power adder gurus come in !
  229. Upcoming Events?
  230. Nx wet kit for 2.3
  231. Pro-M Racing Univer MAF calibrated for 42lb fuel injectors
  232. Maf for 38 fuel injector
  233. paxton novi 1000 on a gt40 crate???
  234. 4.10 Gears and a kenne bell??
  235. Nitrous Question Inside..........
  236. Wet shot, and a dry shot at the same time??
  237. Torn Between Superchargers...
  238. Best SC Plugs??
  239. Need more fuel down low with 100 dry shot
  240. question about running an inline pump?
  241. 75 shot on 2003 GT
  242. Run 10#'s with 24's?
  243. anyone have a A4.bin file for tuning?
  244. power pipe?
  245. Do the gears have to be changed before installing a supercharger?
  246. which power adder to get??? sc or nitrous???
  247. Zex kit install questions 1995 GT?
  248. That was kinda weird
  249. are flowmasters hurting my supercharged performance?
  250. Looking for a 671 blower for '85 roller motor!
