View Full Version : Power Adders
Pages :
6]
10
11
12
15
- Blew Engine on Nitrous....WHY?
- What's your thoughts on a T-trim?
- which spark plugs
- N2O Drag Notch
- MSD BTM install with MSD 6AL
- ProCharger People!!
- Vortech T-Rex Pump
- Longevity of Kenne Bell?
- Thinking of converting to foxbody throttle setup with v2sq
- from 6 to 9 psi.
- MAF size
- Where to learn
- Price of a 1.7 KB vs 2.2 KB plus price of forged internals
- does a walbro 255lph intank pump car make the car hesitate ?????
- Sealant tape on the feed line
- belt tension for superchargers
- Mileage
- Procharger bracket question
- Zex's black box
- Should I use intake spacer?
- FRPP supercharger...........?
- Ignition Retard - MSD6AL
- whats the loudest supercharger
- supercharger question
- what is this exactly?
- V1 S-trim or V2 SQ-trim ?
- Vortech Kit, problems???
- Pulley swap on sc-trim?
- Pro-m Mass Air Gone Bad???
- Powerdyne ideas.
- 4.6l SOHC manifold/Lightning SC...
- Little 5.4 2V help
- [B]MSD 6BTM stopped working, do I need it?[/B]
- 351W Compression
- Low Profile Blower
- Calling all 306 and KB users
- 100 shot alright on 95 short block?
- What have you broken so far....
- How Do I Test Nitrous Solenoids?
- Micro Switch Bracket
- compression ratio help
- Tach Signal for wideband?
- What about wet nos & no tune
- Immediate help please
- Just Bought Blower...Need Info Please
- Stock 351w rods & boost
- Will thease plugs hold up to a 100 shot?
- Accessory belt tensioner w/ Vortech S-Trim 94-95
- Blow Through Or Draw Though Help
- Question about running different race fuel.
- Vortech People - Help
- Which turbo company is better???
- 9:1 compression.....?
- ProCharger Help!! Car wont idle and bucks under boost and dies :(
- What size fuel injectors?
- Who is the best tuner in Northern Virginia
- New to supercharging
- I'm assuming there's a catch...
- Fuel pressure gauge on my a pillar
- ?'s on turbo chagers
- Supercharger installed...blew out PCV valve
- weiland super chager
- Lenght of accessory belt for 94-95 S-Trim
- Safe shot for 5.0
- Are you able to see the timing pointer with your Novi 2k?
- Nitrous on a (very) Tight Budget
- How to figure what pulley=certain boost?
- S-Trim tensioner pulley bolt/nut/spacer
- HP turbo kit idle problems
- Kenne Bell questions
- when will novi 2000 reach full boost?
- S-trim pics please!!!
- whipple?
- Backfiring after letting off the gas... sometimes while coasting
- Max boost from my V-1 SC trim
- Just got back from dyno.
- Sprak plugs and boost
- turbo with speed density
- Gas mileage #s on Supercharged 2000GT...
- Acetone in fuel
- how do I make this Bosch bypass work?
- Who can beat summits Vortech prices?
- Safe compression ratio
- Vortech or Procharger?
- Blower on high mileage car?
- Car runs like crap after S/C, injectors, pump, tune
- Anyone thinking about getting a Super Charger.....
- Pros and cons using a LMAF on a fox
- Will this hurt my blower?
- Powerdyne
- Kruger Performance?
- Dry Nitrous with 24#ers
- 42's with FMU..... what disc?
- UPR or Anderson power pipe?
- Turbo for Daily Driver
- nitrous?
- 3.75 pulley
- question about vortech supercharger
- Parts list for 03 supercharger on 01 cobra
- supercharger or nitrous on a oil burning motor?
- 1500 or blowzilla?
- Dyno #'s on 2000 GT.............
- Will this combo work well for daily driving and occasional track use?
- gears or NOS
- ZEX nos and 03 Cobra?
- newbie needs advice
- 02 mustang GT supercharged fuel pump
- Blower cam specs for 5.0s
- Location of ACT sensor?
- Meziere elec water pump with Vortech problems!! 87-93
- Super Chargers on stock tranny's....whos got em?
- Vortech V1 S-Trim
- Forced Induction sound clips!!!!
- Crane HI-6S & boost
- timing issue
- Fittings for fuel pressure sender
- LaRocca Tune Vortechs/Methanol?
- NOS bottle heater w/ NX Kit
- clutch for a supercharged 02 GT
- O2 placement with single turbo...
- My Install is complete, I am now boosted...
- Purge line length
- Procharger problems?
- what is the best coolant that i can put in my maxflow aftercooler
- 2 Supercharged 05 Mustangs (video)
- how much can my car handle
- upr and bypass
- Testing my new turbo set up
- nitrous wet kit shot
- Horsepower Estimate
- Question - Is it okay to cold start a centri in cold weather?
- Real big problem someone help!!
- What size belt do i need?
- Discharge tube
- Part Number For SVT Focus Fuel Pump?
- Vortech Aftercooler
- Which intercooler kit is better
- Little hesitation when im vacuum with my vortech ???
- Nitrous questions
- Block issues?
- KB 1.7 for GT
- Novi bracket
- 8rib for 01 Cobra with ATI
- Supercharging my 03 GT
- Blowoff valve...
- Boost and Compression
- Idea with procharger
- OBD-2 Emissions Problem
- ceramic coatings and powder coatings cheap!
- Methanol / Water Injection
- Decided with Zex 125 shot,What timing?
- 03 GT adding supercharger
- I got my new engine with vortech, some question ?????
- anyone need 98 vortech bracket
- Fuel pressure source with Novi 2k?
- How much weight does a Vortech add?
- Who's motor has broken on 6-8psi?
- 03 Supercharger on 01
- Anyone w/vortech intercooler
- Vortech V1, Cooling Fan help
- Is an a-trim enough?
- Vortech S Trim Belt Coming off...
- Electric Boost/Vac Gauge help
- 331 or 347 with PS-1C
- Need Your Help
- Looking for a Root Style Supercharger for a SB Ford.
- World Man O War
- Which cam
- Braided Return line questions?
- Fuel pressure bypassing FMU
- 93 cobra w/v-2 sq
- Discharge tube
- Supercharger for 96-98 on a 01
- How much can a stock 89 bottom end take
- Kenne Bell users w/Fox body come in, need info
- Nitrous Coming got some ?s
- 01 Cobra....twin-turbo set-up???
- selling my nitrous kit
- What are my risks????
- Mongoose Owners....come in
- Fuel Pressure
- What kind chip comes in the Kenne Bell kits
- A few simple S/C supporting questions. please look!
- Sound like a good deal for this NX wet kit???
- ZEX Purge Install
- 75mm ProM and 36# @ 12psi
- Vortech V-1 S-trim
- MAF for supercharger
- Boost gauge
- vortech aftercooler, which coolant
- Need vortech head unit
- vortech SQ on the street
- Best plugs for nitrous?
- Vortech bracket
- engine questions
- Turbo not making boost! :( HELP
- sq trim
- Advice From Nitrous Experts
- vortech pulleys
- Nitrous Purge line/hose help
- what else is needed to switch to 9#?
- Vortech Racing Bypass Valve and AFM PowerPipe
- Nitrous Installation...?
- 347 Turbo help!
- EFI Systems programable ECU....?...
- N2O newb questions
- KB or Procharger on '96 Cobra?
- What to do?
- need some quick help with blower install!
- do i have the right calibrated FMU
- FRPP SC vs KENNE bell 1.7
- Procharger P600B Q's
- What would work better?
- Vortech Mini-Race Bypass Valve help!
- vortech pulleys
- vortech intercooler
- where to find cheap s/c???
- Back fire I guess
- Cobra tank/pumps
- Twin Turbo 05 GT!
- Is anyone Running the Kenne Bell 1.7 kit w/KB intercooler?
- My options for more v6 sound...please advise.
- Thread size NX nozzle
- Will a 2003 Cobra Supercharger work on a GT???
- To SC or not to SC.
- help with new plugs
- novi 1000 with 8 inch crank and 3.00 blower
- NOS on a 2004 GT?
- Anybody on here Rebuilt a Procharger P600B?
- Removing boost retard
- just ran zex for 1st time
- Blowing oil out of the valve cover breather
- what size injectors
- Ryan SG
- Discharge tube
- Home made turbo on a stock 5.0?
- Eaton Supercharger/Carburetor Question
- Most miles you have seen on a stock S/C 2V?
- Turbo Systems????
- 80mm MAF
- 42#s and 80mm - no FMU?
- Looking at a HP Performance stage 1 kit
- Will a PD11A fit on a PD10 Bracket??
- white smoke during start up occasilnally
- fmu ratio
- Help! Trying to add sound/power to my stock V6??
- How often to change on on S/C GT?
- Anyone using one of these for cooling?
- the best way to spend 1200 to strengthen a s/c stock 5.0
