View Full Version : Power Adders
Pages :
1]
10
11
12
15
- What are the best Plugs to use w/ nitrous
- nitrous purge questions
- JMS chip vs Livernois Motorsports
- Problems with noszle kit PLEASE HELP!
- My P1SC RAN outta boost?? WTF?!?!
- Any good tuners near Greenville, SC to work on my car w/ a Paxton Novi 1000?
- KB blower delay for 2v 4.6 motor.
- Steeda Boost Pipe vs. AFM Power Pipe
- Boost increase???
- dyno tuners around Cleveland Ohio...
- Which is better? more boost - less compression, less boost - more compression
- Kenne Bell 5.0's come in
- Supercharged Aod's Come On In!
- HP Numbers??
- Novi 1200 where to buy?
- Nitrous Question? (Different fuel cell with 106 octane)
- Nitrous, WET or DRY
- Flow Rate for AED Mechanical intercooler pump
- Nitrous Works EFI plate setup? remove EGR spacer or NO??
- NOS jet ?s
- Most boost I can get out of a PS1C?
- just upgraded to 150 shot... car falls on it's face
- Ok Powerdyne guys, why am I eating belts and detonating?
- whos running thier supercharger without a boost/timing retard?
- Kenne Bell or Saleen Series IV
- What size injectors
- What else is needed besides supercharger
- speed density and nitrous ?
- 1996 vortech cobra's
- Got the KB NOW?????
- Powerdyne SC went bad again
- Question on nitrous and track:
- vortec supercharger shaker kit
- Drill or punch oil pan?
- Allmost got 11's
- Are 3.55's good for this street/strip car?
- Need opinions on Nitrous combo
- Anyone ever use Superchargersonline.com?
- f303 cam
- Supercharger on Fox Media Wanted
- ati vs. kenne bell
- P1SC / D1SC pics
- Kenne Bell Tuning Question
- Whos done their own junkyard turbo setup?
- any known problems with roots style blowers on a 4.6 SOHC
- Wet n' Dry?
- roots style blowers on a 4.6 SOHC vs. heads/cam/intak mani.
- Nitrous on 99+GT's?
- How much total timing?
- which vortech
- ProCharger-Cost of install????
- I want more boost from a-trim
- SC-trim info
- HELP!!! Nitrous fuel pressure problem.
- NOS won't activate at WOT
- Water cooler
- Supercharger Vs Turbo Vs Nos
- powerpipes
- Saleen Supercharger
- Newbie questions
- Kenne Bell 2200/flowzilla
- 94-95 1/4 times w/Vortech
- anyone done a 98GT pi heads swap? Horsepower?
- ??? for BrightBlue00GT ????
- wet or dry kit
- plastic intake
- Procharger fox body users. 17 PSI kit?
- How many ProCharger D-1 users on here?
- Nitrous +430's+28 inch tires=?
- Nitrous Question
- Spark Plug Question for Supercharger????
- Plug thread lengths
- Vortech V2SQ for a GT on a Cobra
- vortch Sc-trim max impeler speed..
- Which MAF for 12psi of boost?
- Nitrous and Timing
- Injector change on 99+ Cobra
- kenne bell vs turbo
- What's the best Intake for Nitrous?
- Powerdyne Installation Instructions for 95GT
- Anybody ever reclock their blower?
- Boost Question For '02 Gt?????
- Vecco Twin Turbo Kit
- Lakewood 90/10
- Need help removing P1SC pulley
- Size of fox vortech discharge tube
- Turbo & Nitrous Together?
- Best way to boost a 2001 GT?
- vortech sc engine bay measurements
- S-Trim install Wednesday. CobraKiller tune Thursday
- nos bottle pressure
- whats the best one
- 87-93 Procharger D-1sc kit FOR SALE!!!
- couple questions
- quick nitrous question
- Saddam is Captured!!!!!
- Anyone Know Anything About Gaping Spark Plugs
- How to calibrate a MAF
- Saleen Whipple vs ATI and Vortech
- NOSzle Direct Port
- Torker II GUYS NEED YOUR HELP
- old school time does anyone have pic of a SC in a 65 66 stang.
- hiding NOS
- How to launch with dragradials??????
- just bought allen 9 psi
- 99/01 Cobra Owners Where Are You!?!?! Kenne Bell INFO
- Vortech and FMS A/C delete
- Best off the shelf cam for boost....?
- my car is running really bad help...
- vortech setup and running issues
- How much boost is safe???
- SN95 w/blower out of hood....
- cheap charger unit
- supercharger debate!!!
- Gapping plugs with nitrous
- Is this normal?
- Supercharger Decision Crisis
- few questions about Superchargers and Injectors.
- Detonation, now not running ::help::
- Centrifugal or twin screwwed
- Help with how you activate/use Nitrous? And Turn off.
- where to hook up boost gauge
- novi feed back
- Timing for Nitrous Question
- would this be okay
- Detonation "101".....
- whats the low down on TDC
- New support forum for Innovate LM-1 users
- Need to see pics of PCV and Breather systems.
- Just Ordered a v-2 sq s trim
- I cracked a piston
- Correct Compression Ratio
- Turbochargers and MPG
- Finally Dyno'd/Tuned......#s Inside.
- 4440 RWHP on 9 PSI
- what would make more power
- Any super chargers yet for the Mach?
- valve stem seal question
- Nitrous kits?
- What gap size for plugs?
- Does IAT sensor connect to the powerpipe?
- Info From Vortech about the SQ's...
- Would someone host my dyno sheet...
- 30lb'ers large enough?
- does any one know anybody
- Does a T-trim bolt up to A-trim brackets?
- What to look for with initial start up?
- Car cutting out after N20 use. Help.
- Anyone making over 500rwp w/ p1sc
- First oil change with a Vortech....HELP!
- Anderson B-31 Cam
- Blower or nitrous???
- Cam Help !!!
- Lightning Blower on 4.6L 2V
- how much power does it make
- New dyno numbers
- Vortech Supercharger LEAK!?
- Fuel System for SC Engine
- What kind of tranny is this?!
- 97 cobra vortech S/c 1/4 ET's?
- Powerdyne and Fuel pressure???????
- Am I gonna KILL MYSELF? NITROUS
- A9P or AEM to go with T Turbo's?
- NX nitrous & fuel solenoids not working???
- Vortech SC-trim pulley setup
- Who sells procharger decals
- 6 rib blower pulley w/ 8 rib crank?
- Alternative to buying a vortech belt?
- got $2000 !!!!! Where to go to buy a supercharger with this much?
- CAn a HKS blow off valve WORK ON S-TRIM????
- Can u guys tell me what do u think about this setup
- A little help please.....
- almost blew motor on nitrous...please help with problem
- Question after S-Trim install???
- Turbo Gurus in here plz
- Turbo Q's
- Kenne Bell on '03 GT, gear noise question....
- SC-Trim Videos?
- looking to get kenne bell tuned?
- Anyone use a Holley 174 Blower on a carbed 351W engine?
- Nitrous fuel PUMPs??
- My Car is Driving me CRAZY, please help....
- 469 rwhp stock 2v w/ D1SC
- Wrong reading with pinched boost/vac tubing?
- Engine Misses after hard acceleration....??????
- best place to buy pulleys
- which blower do you mustang guys prefer?
- Vortech leaking oil
- First Dyno numbers for S-Trim
- Ford roots type
- Highest boost for street car
- Need to get a MAF
- Powerpipe guys
- decent blower/turbo for stock 98 2v?
- How long would it take a blower to seize from lack of oil?
- 01 Novi Cobra....which MAF?
- 3/8 npt tap
- Best nitrous kit for Mach 1?
- nitrous installed wrong
- Need advice on S or T-Trim...
- I have an SN89, how much ATF do I refill it with?????
- High Performance Inlet for power adders
- What is the best price for NX Genx-2 I can get ?
- got boost/now want the juice
- Car not making RWHP I expected...
- Do you think it well hold up ?
- HELP ME OUT do you know??
- v2-sq trim
- Nitrous jetting and tuning
- thinking of spraying my 93, anyone do it?
- anyone 99 cobra w/ NOS??
- Just ordered my KB 2.2 today!! Ques on thier mass air.....
- Help with dumb Q about pullies
- What are all the possible places a Vortech could leak?
- 4.6 nitrous question
- What to buy for a power adder?
- Paxton Blower for Sale
- T or YS-Trim videos???
- 331 w/ power adder ??
- Ideas for stroked/blown 351w EFI
- What supercharger sounds more like a Jet Engine?
- Anyone gasket match their shorties?
- SN2000/brackets, need help
- supercharger&n2o am i the only 1
- what kind is a v1 s/c
- what size shot?
- what system
- newb... need advice for picking a blower.
- fuel pressure regulator
- supercharger mounting hardware
- Is a D-1SC too much for a stock 99 Cobra ?
- maximum Boost, How much can I use??
- Finally went to the track......
- Fuel feed for NX kit?
- Nitrous on old motor?
- ProCharger P1SC ?
- 2 more #'s of boost = ??? pwr
- NX Nitrous on 04 GT?
- NX kit
- Vortech?
- Good tuners in the Cincinnati Area??
- Procharger P-1SC or D-1SC
- newbie vortech ????
- how much more boost with a power pipe
- Vortech install with A/C and smog pump delete?
- 02 GT nitrous system
- Help on Drivability?
- Vortech V-1 S-trim For Sale
- nitrous help
